When I install downloaded LT2010 when installing I get the following error message.
Error 1322. A portion of the folder path exceeds the length allowed by the system. Can some kind person help. Using XP with SP3. Running LT2008 & LT2009.
How big is your hard drive?
Thanks for reply 500 gb. 400gb spare
Try this link: I think it will help you. This guy has the same error as you. Start reading it from the 2nd post:
Error 1322 Help
From AutoDesk:
"The target installation folder contains special characters or exceeds the limit set by the operating system (character limit is generally 255 characters in 32-bit Windows). To resolve this problem, restart setup and choose a shorter target path that contains no special characters."
From AutoDesk:
Making a note if that for future reference!
