ExporttoAutocad with suffix and dated folder
rcb007
I am trying to figure out a way to add a suffix of the current date into the file name while it places the exported file into a sub Folder "Export Current Date".
This is what i have came up with for the file name.
(command "-exporttoautocad" "_S" " - " (substr (rtos (getvar "CDATE") 2 0) 3) "" "")
This is what I am trying to incorperate into the above to make the Export Current Date Sub Folder.
Lee had this code below, I was hopeing i could it switched from copy to an export. lol
(defun c:sav ( / cpy sub )
   (setq sub "Superseed") ;; Subdirectory
   (cond
       (   (zerop (getvar 'dwgtitled))
           (princ "\nCurrent drawing is unsaved.")
       (   (not (or (findfile (setq sub (strcat (getvar 'dwgprefix) sub))) (vl-mkdir sub)))
           (princ (strcat "\nUnable to create directory " sub))
       (   (progn
               (princ "\nSaving current drawing...")
               (command "_.qsave")
               (not
                   (vl-file-copy (strcat (getvar 'dwgprefix) (getvar 'dwgname))
                       (setq cpy
                           (strcat sub "\\"
                               (vl-filename-base (getvar 'dwgname)) "-"
                               ;;(menucmd "m=$(edtime,0,YYYYMODD-HHMMSS)")
				(menucmd "m=$(edtime,0,YYYYMODD)")
                               (vl-filename-extension (getvar 'dwgname))
           (princ (strcat "\nUnable to copy drawing to " cpy))
       (   (princ (strcat "\nDrawing copied to " cpy)))
whats the difference between copy and export?
(defun c:sav (/ cpy sub)
  (setq sub (substr (rtos (getvar "CDATE") 2 0) 3))  ;; Subdirectory
  (cond
    ((zerop (getvar 'dwgtitled))
    ((not (or (findfile (setq sub (strcat (getvar 'dwgprefix) sub))) (vl-mkdir sub)))
    ((progn
        (command "_.qsave")
        (not
                        (setq cpy (strcat sub "\\" (substr (rtos (getvar "CDATE") 2 0) 3) "_" (getvar 'dwgname)))
    ((princ (strcat "\nDrawing copied to " cpy)))
I can't remember why I did it this way, but on my PDF routine  I added a date and time stamp using:
(setq myfilename --filepatgh and filename-- )
(setq myfilename (strcat myfilename " [" (menucmd "M=$(edtime,$(getvar,date),DD-MO-YY)") " " (menucmd "M=$(edtime,$(getvar,date),HH-MM-SS)") "]" ))
Will it work using that and inserting the whole filepath and filename instead of suffixing the time and date?
I had to do some research, but when you go to saveas a file out (which has AEC Objects) and explode the file etc, there still is remains of AEC Objects. The EXPORTTOAUTOCAD somehow removes everything and treats it as a new file without any remains of the AEC Objects.
https://www.theswamp.org/index.php?topic=54258.15
Quote
Even if you figure out how to expolde the aec objects your drawing will still be "infected" and that's why the exporttoautocad command creates a new drawing. There are drawing variables, dictionaries, etc... that will still be drawing, cause object enablers to load, infect other drawings.
If your end goal is to get rid of all the AEC stuff, and not have it affect other drawings, I dont think you have another option than creating a new drawing.
I did what MP already mention, I coded up a routine that takes all .dwg files in folder and batches the exporttoacad command placing them into a folder called "exported".
Within the Following, how can I get it to read "ExportToCAD - 20210802"?
 (setq sub "ExportToCAD - (substr (rtos (getvar "CDATE") 2 0) 3))"  ;; Subdirectory
Then towards the end of the routine I can activate the export command.
(command "_.-exporttoautocad" "F" "2010" "" "")
This will overwrite a file if it exits but not in use or create it if their isn't a file there.
  (cond
    ((progn
        (command "_.qsave")
        (if (findfile cpy)
          (vl-cmdf "_.-exporttoautocad" "_F" "2010" "" cpy "_Y")
          (vl-cmdf "_.-exporttoautocad" "_F" "2010" "" cpy)
    (princ (strcat "\nUnable to expot drawing to: " cpy))
  ((princ (strcat "\nDrawing exported to: " cpy)))
Edited by mhupp
Awesome... got one more question for you. Within the Folder Name. How can i get it to add this into it?
As for the export works great!
(setq sub (strcat (getvar "dwgprefix") "ExportToCAD-"(substr (rtos (getvar "CDATE") 2 0) 1)))  ;; Subdirectory
Edited by rcb007
Sorry for not getting back to you sooner. That is what I was going for and I think I figured it out.
(setq sub (strcat "ExportToAutoCAD-" (substr (rtos (getvar "CDATE") 2 0) 1)))
  (cond
    ((progn
        (command "_.qsave")
        (setq cpy (strcat sub "\\" (substr (rtos (getvar "CDATE") 2 0) 1) "-ACAD-" (getvar 'dwgname)))
        (if (findfile cpy)
Thank you again for all your help!!!
  • Agree 1
