nzoro99 Posted January 23, 2022 Posted January 23, 2022 (edited) Hello, If I run each line of this section of code it works , but if I incorporate it in modified VPSEL lisp, it gets stacked somewhere. Lisp doesn't stop on error, neither on break toggle. I wonder if I need (else parameter in (if .and if I need else parameter indeed I don't know how tell the lisp continue to next item. (setq data ss1) (setq i 0) (repeat (sslength data) (setq e (ssname data i)) (if (and (< i (sslength data)) (equal "DIMENSION" (cdr (assoc 0 (entget e)))) ) (setq entdimnstyle (entget e)) (setq newdim (subst (cons 3 "NewDimension") (assoc 3 entdimnstyle) entdimnstyle ) (entmod newdim) ) (setq i (1+ i)) ) ) ) and here is the complete code ;;;---------------------------------------------------------------------------; ;;; ;;; vpsel.lsp ;;; ;;; By Jimmy Bergmark ;;; Copyright (C) 1997-2006 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com ;;; ;;; 2000-04-14 - First release ;;; Tested on AutoCAD 2000 ;;; ;;;---------------------------------------------------------------------------; ;;; DESCRIPTION ;;; ;;; Select all visible objects in selected or active paperspace viewport ;;; Works transparently when in modelspace and for polygonal viewports too ;;; Example1: ERASE ALL R 'VPC >>> Erase all in model except what is visible ;;; Example2: (command "erase" "all" "r" (c:vpc) "") ;;; Example3: VPC ERASE >>> VPC is run previous the command and the objects ;;; are also in previous selection set ;;; ;;; c:vpc - select all visible objects with crossing in viewport ;;; c:vpw - select all visible objects with window in viewport ;;;---------------------------------------------------------------------------; (defun c:vpttt () (vpselttt "C") (princ) ) (defun c:vpwttt () (vpselttt "W") (princ) ) (defun dxf (n ed) (cdr (assoc n ed))) (defun vpselttt (typ / ad ss ent vpno ok vpbl vpur msbl msur msul mslr ss1 pl nlist x n ) (vl-load-com) (setq ok t) (if (= (getvar "tilemode") 0) (progn (setq ad (vla-get-activedocument (vlax-get-acad-object))) (if (= (getvar "cvport") 1) (if (and (= (getvar "cmdactive") 0) (setq ss (ssget "_x" (list '(0 . "VIEWPORT")))) ) (progn (setq ent (ssname ss 2)) (setq vpno (dxf 69 (entget ent))) (vla-Display (vla-get-activepviewport ad) :vlax-true) (vla-put-mspace ad :vlax-true) (setvar "cvport" vpno) ) (progn (setq ok nil) ) ) (setq ent (vlax-vla-object->ename (vla-get-activepviewport ad))) ) (if (and ok (/= 1 (logand 1 (dxf 90 (setq ed (entget ent)))))) (progn (if (= (vla-get-clipped (vlax-ename->vla-object ent)) :vlax-false ) (progn (vla-getboundingbox (vla-get-activepviewport ad) 'vpbl 'vpur ) (setq msbl (trans (vlax-safearray->list vpbl) 3 2)) (setq msur (trans (vlax-safearray->list vpur) 3 2)) (setq msul (list (car msbl) (cadr msur))) (setq mslr (list (car msur) (cadr msbl))) (setq ss1 (ssget (strcat typ "P") (list msbl msul msur mslr)) ) ) ;;; (progn ;;; (setq pl (entget (dxf 340 (entget ent)))) ;;; (setq nlist nil) ;;; (foreach x pl ;;; (if (eq 10 (car x)) ;;; (setq nlist (cons (trans (cdr x) 3 2) nlist)) ;;; ) ;;; ) ;;; (setq ss1 (ssget (strcat typ "P") nlist)) ;;; ) ) (sssetfirst nil ss1) (if ss1 (setq n (sslength ss1)) (setq n 0) ) (princ n) (princ " found ") (if (and ss1 (= (getvar "cmdactive") 1)) ss1 ) ) ) ) ) ;;; (setq ss nil ss1 nil) (setq data ss1) (setq i 0) (repeat (sslength data) (setq e (ssname data i)) (if (and (< i (sslength data)) (equal "DIMENSION" (cdr (assoc 0 (entget e)))) ) (setq entdimnstyle (entget e)) (setq newdim (subst (cons 3 "NewDimension") (assoc 3 entdimnstyle) entdimnstyle ) (entmod newdim) ) (setq i (1+ i)) ) ) ) (princ) Thank you for the input! Edited January 23, 2022 by nzoro99 Quote
nzoro99 Posted January 23, 2022 Author Posted January 23, 2022 This worked for me ;;;---------------------------------------------------------------------------; ;;; ;;; vpsel.lsp ;;; ;;; By Jimmy Bergmark ;;; Copyright (C) 1997-2006 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com ;;; ;;; 2000-04-14 - First release ;;; Tested on AutoCAD 2000 ;;; ;;;---------------------------------------------------------------------------; ;;; DESCRIPTION ;;; ;;; Select all visible objects in selected or active paperspace viewport ;;; Works transparently when in modelspace and for polygonal viewports too ;;; Example1: ERASE ALL R 'VPC >>> Erase all in model except what is visible ;;; Example2: (command "erase" "all" "r" (c:vpc) "") ;;; Example3: VPC ERASE >>> VPC is run previous the command and the objects ;;; are also in previous selection set ;;; ;;; c:vpc - select all visible objects with crossing in viewport ;;; c:vpw - select all visible objects with window in viewport ;;;---------------------------------------------------------------------------; (defun c:vpttt () (vpselttt "C") (princ) ) (defun c:vpwttt () (vpselttt "W") (princ) ) (defun dxf (n ed) (cdr (assoc n ed))) (defun vpselttt (typ / ad ss ent vpno ok vpbl vpur msbl msur msul mslr ss1 pl nlist x n ) (vl-load-com) (setq ok t) (if (= (getvar "tilemode") 0) (progn (setq ad (vla-get-activedocument (vlax-get-acad-object))) (if (= (getvar "cvport") 1) (if (and (= (getvar "cmdactive") 0) (setq ss (ssget "_x" (list '(0 . "VIEWPORT")))) ) (progn (setq ent (ssname ss 2)) (setq vpno (dxf 69 (entget ent))) (vla-Display (vla-get-activepviewport ad) :vlax-true) (vla-put-mspace ad :vlax-true) (setvar "cvport" vpno) ) (progn (setq ok nil) ) ) (setq ent (vlax-vla-object->ename (vla-get-activepviewport ad))) ) (if (and ok (/= 1 (logand 1 (dxf 90 (setq ed (entget ent)))))) (progn (if (= (vla-get-clipped (vlax-ename->vla-object ent)) :vlax-false ) (progn (vla-getboundingbox (vla-get-activepviewport ad) 'vpbl 'vpur ) (setq msbl (trans (vlax-safearray->list vpbl) 3 2)) (setq msur (trans (vlax-safearray->list vpur) 3 2)) (setq msul (list (car msbl) (cadr msur))) (setq mslr (list (car msur) (cadr msbl))) (setq ss1 (ssget (strcat typ "P") (list msbl msul msur mslr)) ) ) ;;; (progn ;;; (setq pl (entget (dxf 340 (entget ent)))) ;;; (setq nlist nil) ;;; (foreach x pl ;;; (if (eq 10 (car x)) ;;; (setq nlist (cons (trans (cdr x) 3 2) nlist)) ;;; ) ;;; ) ;;; (setq ss1 (ssget (strcat typ "P") nlist)) ;;; ) ) (sssetfirst nil ss1) (if ss1 (setq n (sslength ss1)) (setq n 0) ) (princ n) (princ " found ") (if (and ss1 (= (getvar "cmdactive") 1)) ss1 ) ) ) ) ) ;;; (setq ss nil ss1 nil) (setq data ss1) (setq i 0) (repeat (sslength data) (setq e (ssname data i)) (if (and (< i (sslength data)) (equal "DIMENSION" (cdr (assoc 0 (entget e)))) ) (progn (setq entdimnstyle (entget e)) (setq newdim (subst (cons 3 "NewDimension") (assoc 3 entdimnstyle) entdimnstyle ) ) (entmod newdim) (setq i (1+ i)) ) (setq i (1+ i)) ) ) ) (princ) Quote
