Dung Do Thanh joined the community
asab joined the community
https://drive.google.com/drive/folders/1RW3VS_e2hrR0-L4AcJnErnl0MR6DnZFp?usp=sharing When using this version, check the "Merge PDF" box to print in "Publish" mode. -
Zayar joined the community
Hi, Suppose we have three groups positioned within another but all separate. Is there a way to nest the interior groups to the exterior one whilst keeping them intact . If the whole needs to be edited, they can be pulled away as one, then edited as separate entities. Thanks!
Create bounding box
I wonder what he thinks about the above... -
Graphic-don joined the community
symoin replied to CamDuy's topic in AutoLISP, Visual LISP & DCL
Can this be modified to include the hyperlinks, like that of publish command in autocad? -
LISP: Find & Replace Without the Lag of AutoCAD's Default Command
good -
muharrembayram6155 joined the community
@ReMark yes, this drawing is mine I'm on to doing the dimensions I wanted to know the size of the text.
I wouldn't rely on AutoCAD's Autosave feature, see this recently revived old thread... I have some links where you can "Autosave" without Autodesk's version. I know for AutoCAD LT the VBA solution will not work, but maybe the others are worth a shot. As I mention, get into the habit of Ctrl+S often. From the other link I posting in that thread explaining Autosave, etc....
VicoWang started following Share the most elegant interface design under DCL limitations
dcl Share the most elegant interface design under DCL limitations
It is widely known that DCL has its native limitations, and to create beautiful and elegant UIs, it's not only about simplifying the underlying logic but also about DCL's presentation. Please share those DCL interface designs that are worth sharing! Here are the DCL interface designs for my two plugins. In the end, it was the image control that took on everything!!! -
Actually I set the autosave every 5 minutes. At this point the only annoying element of this "bug" is that... it can happen that you don't remember what things have been changed in the last few minutes, so you run the risk of skipping some of them. It happens when I have to retouch a drawing in various areas... but as I say it's a rare case: by now I know about this "bug" and I'm careful!
ross1446 joined the community
Er Nitya joined the community
t.wong started following AutoCAD 3D Modelling & Rendering and AutoLISP, Visual LISP & DCL
t.wong joined the community
This thread discusses PyRx. PyRx embeds the Python runtime inside AutoCAD/BricsCAD’s process space. It’s CAD that does the .DWG/DXF file IO. There’s other packages like ezdxf that can read write files. PyRx, is analog to CAD’s .net wrappers in that its bound to ObjectARX
Pathon a new programming language ? Just open a dxf or a dwg can then run Python scripts. But must install the Python run time.
Create bounding box
A google should have pointed you to the great Website by Lee-mac, Bounding Box. -
Who's drawing is pictured above? Yours or that of someone else? If it is yours then I assume you are at the point where dimensions are added. One would dimension from centerline-to-centerline both horizontally and vertically. Then one would add an overall dimension for both length and width.
Update for the BatchPlot.exe installation version. Free Download: https://drive.google.com/drive/folders/16RZS69S2tzZZzFnYW0H6QNQ3klwxB2C6?usp=drive_link -
@ReMark
Good afternoon can someone help me I start this project, but I'm confused on what to do next right now I'm on dimlin.
asos2000 started following Python for AutoLISP Users part 1:
Pathon work on dwg or dxf only?
Superstretch
What happens when you try to stretch them? You might try PICKSTYLE setting, I set mine to all values in 2026 and they all stretched a Group, but I am not sure which version improved the editing of Groups. -
Create bounding box
Google AI... (defun C:BBOX ( / ss index ent vlaObj minPt maxPt minExt maxExt pt1 pt2 ) (vl-load-com) (princ "\nSelect objects to enclose in a bounding box: ") ;; Prompt user to select objects (if (setq ss (ssget)) (progn (setq index 0) ;; Loop through all selected objects (repeat (sslength ss) (setq ent (ssname ss index)) (setq vlaObj (vlax-ename->vla-object ent)) ;; Safely catch objects that do not support a bounding box (if (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list vlaObj 'minPt 'maxPt)))) (progn (setq pt1 (vlax-safearray->list minPt) pt2 (vlax-safearray->list maxPt)) ;; Initialize or update the overall minimum and maximum coordinates (if (not minExt) (setq minExt pt1 maxExt pt2) (setq minExt (mapcar 'min pt1 minExt) maxExt (mapcar 'max pt2 maxExt)) ) ) ) (setq index (1+ index)) ) ;; Draw the bounding box if valid coordinates were collected (if (and minExt maxExt) (progn ;; Deactivate Object Snap temporarily to ensure precision (setq oldOsmode (getvar "OSMODE")) (setvar "OSMODE" 0) ;; Draw a standard rectangle using the global coordinates (command "_.rectangle" minExt maxExt) ;; Restore original Object Snap settings (setvar "OSMODE" oldOsmode) (princ "\nBounding box successfully created!") ) (princ "\nError: Could not calculate bounding box for selected objects.") ) ) (princ "\nNo objects selected.") ) (princ) ) (princ "\nType BBOX to run the command.") (princ) -
Hi, is there a script to create a rectangular bounding box around selected objects? Regards, Lu
Superstretch
Yes, 2011 -
Superstretch
I can in AutoCAD 2026. Are you still using AutoCAD 2010? -
Hi, Is there a way to stretch groups without ungrouping ? Normally I ungroup and then stretch and then group again. Does it have to be a script to do a chain of commands ? Actually maybe all I want is to suspend group (pickstyle) instead of ungrouping. i.e Group remains intact , I only need to stretch parts of it . -- Thanks
Why do some objects disappear when you plot a DWG?
CyberAngel replied to indiancad's topic in AutoCAD 2D Drafting, Object Properties & Interface
Nonplotting layers have always made me uncomfortable. I see the value of them, but they break the WYSIWYG rule. -
There was most likely a reason the layer was non plot, you should just move things you need plotted to a new layer that allows plot, presuming you were not the one making the layer non plot and if you made it non plot it was by mistake, there could be objects plotting that shouldn't.
