  1. Today
  2. BIGAL
    Python with CMS IntelliCAD 14.1
    I post the 3d house image often and a version of that software was available for Intellicad back in the 90's, there was no VL lisp in those days. It was very good then and seen as a competitor to LT,
  3. Danielm103
    I was able to connect with ITC Directly and report the items I felt are important from an API perspective. AcRxClass::dxfName() is null with AcDbObject AcDbObject::close() has an access violation if called twice. I think the next release or so of IntelliCAD will be a real competitor in the space. Assuming pricing is stable, there’s no reason to buy any ‘lite’ version of CAD
  4. Danielm103
    But there’s stuff missing, from the automated tests in PyRx "collecting ... collected 529 items / 210 deselected / 3 skipped / 319 selected" There are 210 tests that I had to disable to get a clean run. I’m still working through them, I disabled the whole class on some tests all the test_Ax**** tests are not accurate, I've not worked through them yet Filename NextLine -------- -------- test_Ax3DFace.py class TestAx3dFace: test_Ax3DPolyline.py class TestAx3DPolyline: test_Ax3DSolid.py class TestAx3DSolid: test_AxAcadSortentsTable.py class TestAcadSortentsTable: test_AxAcadSortentsTable.py test_AxApplication.py class TestAxApplication: test_AxArc.py class TestAxArc: test_AxAttribute.py class TestAxAttribute: test_AxBlock.py class TestAxBlock: test_AxBlockReference.py class TestAxBlockReference: test_AxBlockReference.py class TestAxDynBlockReference: test_AxCircle.py class TestAxCircle: test_AxDatabase.py class TestAxDatabase: test_AxDocument.py class TestAxDocument: test_AxEllipse.py class TestAxEllipse: test_AxEntity.py class TestAxEntity: test_AxGroup.py fail test_AxLayout.py class TestAxLayout: test_AxLWPolyline.py def test_getcoordinate(self): test_AxLWPolyline.py test_AxMenu.py class TestAxMenu: test_AxModelSpace.py class TestAxModelSpace: test_AxObject.py class TestAxObject: test_AxPoint.py class TestAxPoint: test_AxPolygonMesh.py class TestAxPolygonMesh : test_AxPolyline.py class TestAxPolyline: test_AxPreferences.py class TestAxPreferences: test_AxPreferences.py class TestSelection: test_AxPreferences.py class TestDrafting: test_AxPreferences.py class TestDisplay: test_AxPreferences.py class TestPrefFiles: test_AxSummaryInfo.py class TestAxSummaryInfo: test_AxTable.py class TestAxTable: test_AxUtility.py class TestAxUtility: test_Brep.py class TestBrep: test_AssocPersSubentIdPE.py test_AttributeDefinition.py (mtext attributes) test_AttributeDefinition.py test_Database.py def test_dbopbject_dxfname(self, db_06457: Db.Database): test_Database.py def test_getSummaryInfo(self): test_Database.py def test_blocktable(self, db_06457: Db.Database): test_Database.py def test_GeoPositionMarker(self, db_geo: Db.Database): test_Database.py def test_GeoData(self, db_geo: Db.Database) -> None: test_Database.py def test_GeoData_transformFromLonLatAlt(self, db_geo: Db.Database) -> None: test_Database.py def test_tdusrtimer(self) -> None: test_DbObject.py def test_property_ids2(self): test_DbObject.py def test_undo_recording(self): test_DbObject.py def test_BinaryData(self): test_DbObject.py def test_BinaryXdData(self): test_entity.py def test_dbtext(self): test_entity.py def test_dbleader(self): test_entity.py def test_table_cells1(self, db_06457: Db.Database): //missing iterator test_entity.py def test_table_cells2(self, db_06457: Db.Database): //missing iterator test_entity.py def test_table_cellValues1(self, db_06457: Db.Database): //missing iterator test_entity.py def test_table_cellValues2(self, db_06457: Db.Database): //missing iterator test_entity.py def test_table_cellValues4(self, db_06457: Db.Database): //missing iterator test_entity.py def test_table_calcTextExtents(self): test_entity.py def test_create_wipout(self): test_entity.py def test_create_extruded_surface(self): test_SortentsTable.py def test_getinstance(self): test_XrefGraph.py def test_XrefGraph(self, db_xrefGraph: Db.Database): test_Editor.py def test_evaluateDiesel(self): test_Curve2d.py def test_ge2dcurve_length(self): test_Curve3d.py def test_Ge_lineseg3d_1(self): test_Curve3d.py def test_ge3dcurve_length(self): test_GsCore.py def test_gs_getBlockImage(self, db_dynblock: Db.Database): test_RxObject.py def test_name(self): test_SheetSet.py class TestSheetSet: test_wx.py def test_wx_CallAfter(self): test_block_reference.py def test_get_attribute(self, db_06457: Db.Database): test_prompt.py def test_select_entity_without_type(self): test_prompt.py def test_select_entity_with_single_type(self): test_prompt.py def test_select_entity_with_multiple_types(self): test_reload.py class Test_Reload: test_reload.py class Test_reload_func:
  5. Danielm103
    Thanks! I’m always rooting for the underdog, I guess to promote competition in the space. I’ve been goofing around with the clones since the early days. I think before version 9. Every year, I download the trial and try out the IARX SDK. The trial is 14 days, this is the first time I was able to get past day 1 and run some real tests. Here’s my little mini review of the API. - I was able to compile my custom object https://github.com/CEXT-Dan/ArxTin While I didn’t test all the protocols, the important ones work great! dwgOutFields, dwgInFields, subWorldDraw, subTransformBy etc. The most impressive thing besides it working, is the subWorldDraw performance. In this sample, I’m pushing 10s of thousands of edges to the graphics interface and transformby is as fast a moving a line. A $250 cad is out performing a $1200 cad by 10x
  6. Yesterday
  7. mhupp
    ZWCad Debug
    My 0.02¢ sprinkle some code in updates a variable through out the code. and recall it with error trapping This will show Error# 4 : bad argument type <(40)> ; expected <NUMBER> at [DXF/XED data] this error message would tell you to look after (setq x "4") for the error. (defun c:CIR (/ cen rad) (defun *error* (msg) (if (not (member msg '( "Function cancelled" "quit / exit abort"))) (princ (strcat "\nError# " x " : " msg)) ) (princ) ) (setq x "1") (setq cen (getpoint "\nSpecify center point: ")) (setq x "2") (if cen (progn (setq x "3") (setq rad (getdist cen "\nSpecify radius: ")) (setq x "4") (if rad (entmake (list '(0 . "CIRCLE") '(100 . "AcDbEntity") '(100 . "AcDbCircle") (cons 10 cen) (cons 40 ra))) ) (setq x "5") ) ) (setq x "6") (princ) ) -edit guess this is more steps then what Steven P posted. Also remember someone saying that zwcad can't use some vl commands.
  8. BIGAL
    ZWCad Debug
    Like Steven P often use an Alert so it stops and can see where it got to. I tend to test code as I make it so I don't write all the code then test, If using defuns in main code test them by using Setq to set the value of the variables used in the defun and I use copy code and paste to command line to run a few lines at a time. The obvious problem I use Notepad++, is check for open and close bracket matching as I create code. I think it was ZWCAD that wrote VBA code when using macro record am I correct ?
  9. BIGAL
    Happy New Year 2026
    Very clever, that would have taken a while to do. Happy new year, will put a shrimp prawn on the BBQ for you new years day.
  10. Troller
    ZWCad Debug
    Thanks Steven P
  11. Steven P
    ZWCad Debug
    Not sure for ZWCad, but if you put checks into the code this can narrow down to where there error is. For example (princ "\nOK to here 1")... and 2, 3, 4 etc will show where the code runs to before an error (often errors are grammatically correct and just not doing what you want). Might help you out till you get another answer
  12. Troller
    ZWCad Debug
    Thanks SLW210! I use ZWCad 2026
  13. SLW210
    Happy New Year 2026
    Happy New Year!!
  14. SLW210
    ZWCad Debug
    I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. You may need the ZWCAD plug-in for VS Code. https://marketplace.visualstudio.com/items?itemName=Zwsoft.ZwLisp What version of ZWCAD do you use?
  15. Saxlle
    Happy New Year 2026
    Hvala lepo @marko_ribar, takodje, sve najbolje u novoj godini!
  16. marko_ribar
    Happy New Year 2026
    Odlicno... Srecna Nova 2026... Pozdrav svima i neka nam svima bude dobra i bericetna... Puno veselja, srece i dobrog zdravlja u novoj godini...
  17. CyberAngel
    Some really cool stuff here
  18. Troller
    ZWCad Debug
    I'm having trouble debugging AutoLISP code in ZWCad. In AutoCAD, I can use the VLIDE editor or set the LISPDEBUG variable to trace errors and see where they occur, but ZWCad doesn't seem to support LISPDEBUG (it says the variable doesn't exist). When I type "VLIDE" in the ZWCad command line, it just opens VS Code for editing the .lsp file, which doesn't help with runtime debugging. Are there any built-in tools or methods in ZWCad for debugging Lisp scripts? For example, how can I get line numbers for errors, trace function calls, or step through code? I've tried loading the file and running it, but the error messages in the command line don't specify the exact location. Any recommendations for external tools or workarounds would be appreciated. Thanks!
  19. Does not sound familiar. The only other civil project I am aware of is the Capistrano property. What have you accomplished so far? Can you attach a copy of the project instructions to your next post? Do NOT attach a drawing.
  20. Greetings to all members of Cad Tutor, Based on the upcoming holidays and New Year, I'v made something interesting which I want it to share with you. Everything was made using a Lisp. I hope it will interesting to all of you and maybe give some inspiration to the next year to made something different and share it with rest of us . Notice (it is on cyrillic, in Serbian language): - ЗИМСКА СЛУЖБА = Winter service on roads; - СРЕЋНА НОВА ГОДИНА = HAPPY NEW YEAR; - XO-XO-XOO = HO-HO-HOO (). Happy New Year 2026 to all members, and wish you all the best and new codes . NovaGodina2026_CadTutor.mp4 Best regards, Saxlle.
  21. Wondering if you did the Stines residential drawing yet if can you help me please this book isn’t any help
  22. Danielm103
    test with wxPython
  23. Danielm103
    Here’s a test extracting data from multiple drawings import traceback import pandas as pd import os from pyrx import Ap, Db, Ed, Ge def proccessDrawing(db: Db.Database, data: dict): blk_dict = db.getBlocks() fname = os.path.basename(db.getFilename()) data[fname] = [] for name, id in blk_dict.items(): if name != "RMNUM": continue btr = Db.BlockTableRecord(id) for refid in btr.getBlockReferenceIds(): blkref = Db.BlockReference(refid) for attid in blkref.attributeIds(): attref = Db.AttributeReference(attid) data[fname].append(attref.textString()) def openSideDatabase(dwg_path: str, data: dict): sdb = Db.Database(False, True) sdb.readDwgFile(dwg_path) sdb.closeInput(True) proccessDrawing(sdb, data) @Ap.Command() def doit(): try: data = {} dwgs = Ap.Application.listFilesInPath("E:\\FloorPlans", ".dwg") for dwg in dwgs: openSideDatabase(dwg, data) df = pd.DataFrame(data) print(df) except Exception as err: traceback.print_exception(err) output : Success module _DOIT is loaded: Command: doit 1st floor.dwg 2nd floor.dwg 3rd floor.dwg 0 1049 2049 3049 1 1045 2045 3045 2 1032 2032 3032 3 1048 2048 3048 4 1046 2046 3046 .. ... ... ... 94 1122 2122 3122 95 1106 2106 3106 96 1104 2104 3104 97 1093 2093 3093 98 1042 2042 3042 [99 rows x 3 columns]
  24. Super cool to see the progress IntelliCAD has made with their C++ API. I’ve been working to port pyrx, still not released, there’s a couple small issues I need to work out import traceback from pyrx import Ap, Db, Ge # ----------------------------- # Simple spline-based vector font # ----------------------------- FONT = { "H": [[(0, 0), (0, 10)], [(5, 0), (5, 10)], [(0, 5), (5, 5)]], "A": [[(0, 0), (2.5, 10), (5, 0)], [(1.2, 5), (3.8, 5)]], "P": [[(0, 0), (0, 10)], [(0, 10), (5, 9), (5, 6), (0, 5)]], "Y": [[(0, 10), (2.5, 5)], [(5, 10), (2.5, 5)], [(2.5, 5), (2.5, 0)]], "N": [[(0, 0), (0, 10)], [(0, 10), (5, 0)], [(5, 0), (5, 10)]], "E": [[(5, 0), (0, 0), (0, 10), (5, 10)], [(0, 5), (4, 5)]], "W": [[(0, 10), (1.2, 0), (2.5, 6), (3.8, 0), (5, 10)]], "R": [[(0, 0), (0, 10)], [(0, 10), (5, 9), (5, 6), (0, 5)], [(0, 5), (5, 0)]], " ": [], } # ----------------------------- # Create a spline from points # ----------------------------- def add_spline(ms, pts, base, scale): arr = [] for p in pts: arr.append(Ge.Point3d(base.x + p[0] * scale, base.y + p[1] * scale, 0.0)) spline = Db.Spline(arr, 3, 0.0) ms.appendAcDbEntity(spline) # ----------------------------- # Write text as splines # ----------------------------- def write_happy_new_year(start=Ge.Point3d(0, 0, 0), scale=5.0, spacing=8.0): db = Db.curDb() ms = Db.BlockTableRecord(db.modelSpaceId(), Db.OpenMode.kForWrite) cursor = Ge.Point3d(start.x, start.y, 0) text = "HAPPY NEW YEAR" for ch in text: strokes = FONT.get(ch.upper(), []) for stroke in strokes: add_spline(ms, stroke, cursor, scale) cursor.x += spacing * scale # ----------------------------- # Entry point # ----------------------------- def PyRxCmd_HAPPYNEWYEAR(): try: write_happy_new_year(start=Ge.Point3d(0, 0, 0), scale=2.5, spacing=7.0) except Exception as err: traceback.print_exception(err)
  25. Last week
  26. A couple of LISPs, PurgeZeroLengths and PurgeZeroTexts: Note that purgezerolengths has a 'less than a length' for very short lines, here set at 0.01 - comment that out with ;; at the beginning of the line if not needed. These remove orphaned lines and texts. Copy and paste to a new drawing (top left -> bottom right seletion) or wblock does a lot. If not needed delete points - don't show up on the printed page, and if not needed get rid. Bit more effort but using blocks for repeated objects can remove some bloating. If you don't need them to be polylines, explode 2 vertex polylines into lines (2nd LISP box below). Explode heavy polylines into LW polylines of you can, both smaller file sizes One I have tucked away, join perpendicular lines back together - example convert from PDF, dashes are individual lines, this will go some way to recreating them as lines - run after 2 vertex poly to line (3rd LISP box, not perfect, only does H or V lines) (defun c:PurgeZeroLengths ( / MySS DelSS MyEnt EndA EndB) ;; for within blocks (setq MySS (ssget (list (cons 0 "LINE,SPLINE,LWPOLYLINE,POLYLINE,ARC,CIRCLE,ELLIPSE")))) (setq acount 0) (setq DelSS (ssadd)) (while (< acount (sslength MySS)) (setq MyEnt (ssname MySS acount)) (if (equal (vlax-curve-getDistAtParam MyEnt (vlax-curve-getEndParam MyEnt)) 0) (progn (setq DelSS (ssadd MyEnt DelSS)) ) ) ; end if ;;If less then a length (if (< (vlax-curve-getDistAtParam MyEnt (vlax-curve-getEndParam MyEnt)) 0.01) (progn (setq DelSS (ssadd MyEnt DelSS)) ) ) ; end if (setq acount (+ acount 1)) ) ; end while (princ "\nDeleting ")(princ (sslength DelSS))(princ " lines") (command "erase" DelSS "") (princ) ) (defun c:PurgeZeroTexts ( / MySS DelSS MyEnt MyText) ;; for within blocks (setq MySS (ssget (list (cons 0 "*TEXT")(cons 1 "")))) (setq acount 0) (setq DelSS (ssadd)) (if MySS (progn (while (< acount (sslength MySS)) (setq MyEnt (ssname MySS acount)) (setq MyText (cdr (assoc 1 (entget MyEnt)))) (if (equal MyText "") (progn (setq DelSS (ssadd MyEnt DelSS)) ) ) ; end if (setq acount (+ acount 1)) ) ; end while (princ "\nDeleting ")(princ (sslength DelSS))(princ " lines") (command "erase" DelSS "") ) ; end progn (progn (princ "No zero content texts found") ) ) ; end if (princ) ) (defun c:pdfDashed2PL ( / MyEnt MySS EndA EndB LEndA LEndB Orientation acount EndPoints LineLengths) ;; Selects by layer and colour (defun LoadLineType (doc LineTypeName FileName) ;;https://www.cadtutor.net/forum/topic/76557-load-linetypes-from-lisphelp/ (if (and (not (existLinetype doc LineTypeName)) (vl-catch-all-error-p (vl-catch-all-apply 'vla-load (list (vla-get-Linetypes doc) LineTypeName FileName) )) ; end vl-catch ) ; end and nil T ) ; end if ) ; end defun (defun existLinetype (doc LineTypeName / item loaded) (vlax-for item (vla-get-linetypes doc) (if (= (strcase (vla-get-name item)) (strcase LineTypeName)) (setq loaded T) ) ) ) (setq thisdrawing (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark thisdrawing) ;;Load Line Types (LoadLineType ThisDrawing "Dashed" "acad.lin") (LoadLineType ThisDrawing "Center" "acad.lin") ;;Select Reference Line (while (= MyEnt nil) (setq MyLine (car (entsel "\nSelect reference Line"))) (if (= MyLine nil) (princ "\nPity the fool, nothing selected. ") (setq MyEnt (entget MyLine)) ) ) ; end while ;;Work out 2 end points (if (= (cdr (assoc 0 MyEnt)) "LINE") (progn (setq EndA (cdr (assoc 10 MyEnt))) (setq EndB (cdr (assoc 11 MyEnt))) ) ; end progn (progn (setq EndA (cdr (assoc 10 MyEnt))) (setq EndB (cdr (assoc 10 (reverse MyEnt)))) ) ; end progn ) ; end if ;;Work out orientation (if (equal (car EndA) (car EndB) 0.0001) (progn (setq Orientation "V") ; Orientation (setq SSFilter "=,*,*") ; SSGET filter (setq EnFilter1 "caddr"); CAR / CADR Filter for entity (setq EnFilter2 "cadr") ; CAR / CADR Filter for entity ) ) (if (equal (cadr EndA)(cadr EndB) 0.0001) (progn (setq Orientation "H") (setq SSFilter "*,=,*") (setq EnFilter1 "cadr") (setq EnFilter2 "caddr") ) ) ;; Get Selection Set (if (= Orientation nil) (progn (princ "Selected line is not orthogonal") ) ; end progn no orientation (progn (princ "\nSelect Broken line: ") (if (assoc 62 MyEnt) (setq MySS (ssget (list (cons 0 "*LINE")(assoc 8 MyEnt)(assoc 62 MyEnt)(cons -4 SSFilter) (cons 10 EndA) ))) (setq MySS (ssget (list (cons 0 "*LINE")(assoc 8 MyEnt)(cons -4 SSFilter) (cons 10 EndA) ))) ) ;; Delete non ortho from SS (setq acount (sslength MySS)) (setq EndPoints (list)) (setq LineLengths (list)) (while ( > acount 0) (setq AnEnt (entget (ssname MySS (- acount 1)))) (setq LEndA (assoc 10 AnEnt)) (if (= (cdr (assoc 0 AnEnt)) "LWPOLYLINE") (progn (setq LEndB (assoc 10 (reverse AnEnt))) ) (progn (setq LEndB (assoc 11 AnEnt)) ) ) ; end if (if (and (equal ((eval (read EnFilter2)) LEndA) ((eval (read EnFilter2)) (assoc 10 MyEnt)) 0.0001) (equal ((eval (read EnFilter2)) LEndB) ((eval (read EnFilter2)) (assoc 10 MyEnt)) 0.0001) ) ; end and (progn ;;Lines to join in SS (setq EndPoints (cons ((eval (read EnFilter1)) LendA) EndPoints)) (setq EndPoints (cons ((eval (read EnFilter1)) LendB) EndPoints)) (setq LineLengths (cons (distance (cdr LendA) (cdr LendB)) LineLengths)) ) (progn ;; Remove lines from SS (setq MySS (ssdel (ssname MySS (- acount 1)) MySS)) ;; Remove line from selection set ) ; end progn ) ; end if (setq acount (- acount 1)) ) ; end while (setq EndPoints (vl-sort EndPoints '<)) ; order small to large ;;Modify Reference Line (if (< ((eval (read EnFilter1)) EndA)((eval (read EnFilter1)) EndB)) (progn (if (= (cdr (assoc 0 MyEnt)) "LINE") (if (= Orientation "H") (progn (setq MyEnt (subst (cons 11 (list (car EndPoints) (cadr EndA) (caddr EndA))) (assoc 11 MyEnt) MyEnt )) (setq MyEnt (subst (cons 10 (list (last EndPoints) (cadr EndB) (caddr EndB))) (assoc 10 MyEnt) MyEnt )) (entmod MyEnt) ) ; end progn (progn (setq MyEnt (subst (cons 11 (list (car EndA) (car EndPoints) (caddr EndA))) (assoc 11 MyEnt) MyEnt )) (setq MyEnt (subst (cons 10 (list (car EndA) (last EndPoints) (caddr EndB))) (assoc 10 MyEnt) MyEnt )) (entmod MyEnt) ) ; end progn ) ; end if (if (= Orientation "H") (progn (setq MyEnt (subst (cons 10 (list (car EndPoints) (cadr EndA))) (assoc 10 (reverse MyEnt)) MyEnt )) (setq MyEnt (subst (cons 10 (list (last EndPoints) (cadr EndB))) (assoc 10 MyEnt) MyEnt )) (entmod MyEnt) ) ; end progn (progn (setq MyEnt (subst (cons 10 (list (car EndA) (car EndPoints))) (assoc 10 MyEnt) MyEnt )) (setq MyEnt (subst (cons 10 (list (car EndA) (last EndPoints))) (assoc 10 (reverse MyEnt)) MyEnt )) (entmod MyEnt) ) ; end progn ) ; end if ) ; end if line ;; (princ "\nEnd A smaller") ) ;end progn (progn (if (= (cdr (assoc 0 MyEnt)) "LINE") (if (= Orientation "H") (progn (setq MyEnt (subst (cons 11 (list (car EndPoints) (cadr EndA) (caddr EndA))) (assoc 11 MyEnt) MyEnt )) (setq MyEnt (subst (cons 10 (list (last EndPoints) (cadr EndB) (caddr EndB))) (assoc 10 MyEnt) MyEnt )) (entmod MyEnt) ) (progn (setq MyEnt (subst (cons 11 (list (car EndA) (car EndPoints) (caddr EndA))) (assoc 11 MyEnt) MyEnt )) (setq MyEnt (subst (cons 10 (list (car EndA) (last EndPoints) (caddr EndB))) (assoc 10 MyEnt) MyEnt )) (entmod MyEnt) ) ) (if (= Orientation "H") (progn (setq MyEnt (subst (cons 10 (list (car EndPoints) (cadr EndA))) (assoc 10 MyEnt) MyEnt )) (setq MyEnt (subst (cons 10 (list (last EndPoints) (cadr EndB))) (assoc 10 (reverse MyEnt)) MyEnt )) (entmod MyEnt) ) (progn (setq MyEnt (subst (cons 10 (list (car EndA) (car EndPoints))) (assoc 10 (reverse MyEnt)) MyEnt )) (setq MyEnt (subst (cons 10 (list (car EndA) (last EndPoints))) (assoc 10 MyEnt) MyEnt )) (entmod MyEnt) ) ) ) ; end if line ;; (princ "\nEnd B smaller") ) ; end progn ) ; end if smaller ;; set MyEnt to line type - dashed / centre (setq LineLengths (vl-sort LineLengths '<)) ; order small to large (if (< (* 2 (cadr LineLengths))(cadr (reverse LineLengths))) ; 2nd longest line 2x longer than 2nd shorted line (vla-put-Linetype (vlax-ename->vla-object MyLine) "Center") (vla-put-Linetype (vlax-ename->vla-object MyLine) "Dashed") ) (setq MySS (ssDel MyLine MySS)) (command "erase" MySS "") ) ; end progn H or V ) ; end if Orientation H or V (vla-Endundomark thisdrawing) (princ) )
  27. ReMark
    The easiest way to do it would be to add horizontal lines running between the W12x45's indicating the location of the C9x20's. Leave the profile of your channels just as they are.
  28. EmeraldSynth
    Hello! I've moved on from being confused on the Oleson subdivision to being confused on the Structural Drafting project lol. So far I've made the W12x52 columns, the footers, and the girders. But I'm having trouble with placing the channels. (the C9x20 beams) So I drew them according to the AISC database, but how do I draw them as a beam running across the structure, versus how I have it in the photo circled in blue. I hope that's not a stupid question, but it's just not making sense in my head.
