Perform hatch without superfluous requests
Couldn't open the link... I used the MHATCH.lsp code author VVA (2006). ; Thanks to the author VVA /2006/ (defun c:MHATCH ( / nab cmd osm *error*) (defun *error* (msg)(princ msg) (if cmd (setvar "cmdecho" cmd)) (if osm (setvar "osmode" osm)) (princ)) (vl-load-com) (setq cmd (getvar "cmdecho")) (setq osm (getvar "osmode")) (setvar "cmdecho" 0) (setvar "osmode" 0) (setvar "hpassoc" 1) (setq nab (ssget "_:L")) (if (and nab (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex nab))))) (foreach item lst (vl-catch-all-apply '(lambda () (command "_.-bhatch" "_s" item "" ""))))) ;_foreach (setvar "cmdecho" cmd) (setvar "osmode" osm) (princ)) I added two main lines (setvar "hpdouble" 1) - criss-cross (setvar "hpspace" 200) - spacing The code is working. Perhaps there is a simpler solution. I accept comments from the pros... ; MHATCH VVA /2006 + additions /2026 (defun c:UShatch_Doub_200 ( / nab cmd osm old_hpname old_hpang old_hpdouble old_hpspace old_hpassoc lst *error*) (defun *error* (msg) (princ msg) (if cmd (setvar "cmdecho" cmd)) (if osm (setvar "osmode" osm)) (if old_hpname (setvar "hpname" old_hpname)) (if old_hpang (setvar "hpang" old_hpang)) (if old_hpdouble (setvar "hpdouble" old_hpdouble)) (if old_hpspace (setvar "hpspace" old_hpspace)) (if old_hpassoc (setvar "hpassoc" old_hpassoc)) (princ) ) (vl-load-com) (setq cmd (getvar "cmdecho")) (setq osm (getvar "osmode")) (setvar "cmdecho" 0) (setvar "osmode" 0) (setq old_hpname (getvar "hpname")) (setq old_hpang (getvar "hpang")) (setq old_hpdouble (getvar "hpdouble")) (setq old_hpspace (getvar "hpspace")) (setq old_hpassoc (getvar "hpassoc")) (setvar "hpname" "_USER") (setvar "hpang" 0) (setvar "hpdouble" 1) (setvar "hpspace" 200) (setvar "hpassoc" 1) (setq nab (ssget "_:L")) (if (and nab (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex nab)))) ) (foreach item lst (vl-catch-all-apply '(lambda () (command "_.-bhatch" "_s" item "" "") ) ) ) ) (setvar "hpname" old_hpname) (setvar "hpang" old_hpang) (setvar "hpdouble" old_hpdouble) (setvar "hpspace" old_hpspace) (setvar "hpassoc" old_hpassoc) (setvar "cmdecho" cmd) (setvar "osmode" osm) (princ) ) (princ "Type in the command prompt UShatch_Doub_200") Thank @BIGAL, you gave me the right direction. "Maybe use (setvar 'hpname "User") in code, sets the pattern name". - Today
Steven P started following Perform hatch without superfluous requests
If it all goes wrong then entmake it.... This link might help, with the code from code ding https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/entmake-hatch-with-base-point-or-object-polyline-entity-name/td-p/8696712 -
Repair Lisp to create superimpose acad
devitg replied to karfung's topic in AutoLISP, Visual LISP & DCL
some like it copy to desktop.dwg copy to desktop.dwg -
karfung replied to karfung's topic in AutoLISP, Visual LISP & DCL
@devitg The file was created automatically by using the Lisp code. The format within the file did not follow to the template. We shall need the Lisp code to set the created file by automatically. Thanks. -
@karfung, why not to do a Writeblock command, it allow to set units as need, and show zoom extend new block.dwg -
Artem joined the community
Tsatso joined the community
karfung replied to Chicane_Apex's topic in AutoLISP, Visual LISP & DCL
You can use etransmit by type "etransmit". It can plot all the individual acad files. Thanks. -
Done joined the community
@rlx Wow, your code is awesome and works very well. Thank bro. Additionally, could you assist in setting the new file with the condition as follows, 1). Please set the unit to be "mm" in the created file. 2). Please zoom extend for the created file. Kindly advise. Thanks. -
SLW210 replied to karfung's topic in AutoLISP, Visual LISP & DCL
Select at start of what you need, then shift select the end is fastest I know (you can actually go from end to the beginning as well). -
Wilmath joined the community
unbesiegbar joined the community
Spacing=200, double=yes and (setvar 'hpname old_hpname) do not work in this code Is there a solution? (defun c:HatchUserHpn ( / ss old_hpname ) (setq old_hpname (getvar 'hpname)) (setvar 'hpname "_User") (setq ss (ssget)) (if ss (progn ;; User-defined, angle=0, spacing=200, double=yes, select objects (command "BHATCH" "U" "0" "200" "D" "Y" "S" ss "" "") ;(command "_.-BHATCH" "_U" "0" "200" "_D" "_Y" "_S" ss "" "") ) ) (setvar 'hpname old_hpname) (princ) ) -
SINGFENG started following The printing LISP does not work with some drawing files.
SINGFENG posted a topic in AutoLISP, Visual LISP & DCL
Hello everyone. I have been following this website for a long time and would like to kindly ask for support regarding an AutoLISP printing routine. I used AI assistance to develop a printing code, however some drawings produce no output when printed. Could anyone help me find the cause? I can provide the code and sample drawings that work and those that do not. Thank you. Desktop.rar -
Hi I want to model an aircrafts winglet. I am having trouble sweeping the airfoil, curve 1, around the 60 degree's of a derived curve, (sketch 17). Initial sweeping resulted in a problem with SW maintaining tangency to the curve in sketch 17 so I added the same curve into sketch sketch 18, but I don't seem to be able to pierce it properly. Below is what happens if I 'Keep Normal Constant.' I want the left most face inclined at 60 degrees to the right most face, (i.e. not so they are parallel). Can anyone help me in making the profile incline around the Z axis as it goes round the guide curve ? I dont seem to be able to upload my SLDPRT Brgds Mark
nzhills1 joined the community
ryanatkins49056 joined the community
Need a routine lisp for bearing & azimuth in realtime.
Tsuky replied to oliver's topic in AutoLISP, Visual LISP & DCL
@devitg Ok, try this. Now labels are fields. If you prefer simply Mtext, Ithink that you can change it (with previous code) mult-label_bearing.lsp -
rlx replied to karfung's topic in AutoLISP, Visual LISP & DCL
somehow a document type object lives along your copied_objects so try this : (defun c:new_desktop_file_copy ( / acad_dbx object_list zero_point db) (defun make_color_21 (/ layers) (setq layers (vla-get-layers acad_dbx)) (vlax-map-collection (vla-get-blocks acad_dbx) '(lambda (block) (vlax-map-collection block '(lambda (object) (vla-put-color object 256) (if (/= 21 (vla-get-color (setq layer (vla-item layers (vla-get-layer object))))) (vla-put-color layer 21)))) ) ) ) (setq acad_dbx (vla-getinterfaceobject (vlax-get-acad-object) (strcat "ObjectDBX.AxDbDocument." (substr (getvar 'acadver) 1 2)))) (prompt "\nPick objects to copy to a new file on the desktop...") (setq object_list (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget)))))) (setq zero_point (getpoint "\nPick zero point for the copied entities: ")) (setq db (vla-get-database (vla-get-activedocument (vlax-get-acad-object)))) (foreach copied_object (setq odbx_objects_list (vlax-invoke db 'copyobjects object_list (vla-get-modelspace acad_dbx))) (if (vlax-method-applicable-p copied_object 'move) (vla-move copied_object (vlax-3d-point zero_point) (vlax-3d-point 0 0 0)) (princ (strcat "\nUnable to move object name : " (vla-get-name copied_object))) ) ) (make_color_21) (vla-saveas acad_dbx (princ (strcat (getenv "userprofile") "\\Desktop\\" (getstring "\nEnter file name: ") ".dwg"))) (vlax-release-object acad_dbx) (princ) ) - Yesterday
@SLW210 how to select all the code at code tags , like a short key ctrl+a or whatever -
Maybe use (setvar 'hpname "User") in code, sets the pattern name. -
@karfung see the new dwg new block.dwg -
devitg started following Repair Lisp to create superimpose acad
@karfung it seem to be you need to make a new.dwg , if so, you can use WRITEBLOCK acad command . -
rlx started following Repair Lisp to create superimpose acad
maybe first do an audit on this drawing -
pkenewell started following Repair Lisp to create superimpose acad
pkenewell replied to karfung's topic in AutoLISP, Visual LISP & DCL
Does the LISP file load the Visual LISP ActiveX functions with (vl-load-com)? I don't see it in the code. -
Your video did not work for me. Your LISP ran just fine on my computer. -
In the future, please place your code in code tags. (<> in the editor toolbar) -
Hi, everybody. It is necessary to perform hatch, regardless of the previous type of hatching. The code performs the hatch using the previous type, not the one specified in the code. ; *********** (defun c:HatchUser ( / ss) (setq ss (ssget)) (if ss (progn (command "_.-BHATCH" "_User" "_Double" "_Yes" "0" "200" "_S" ss "" "") ) ) (princ) ) HatchUserdwg.dwg
@oliver Try to reload the code at this answer -
Lee Mac started following Lisp area and/or length of polyline, as a leader
(defun c:new_desktop_file_copy (/ acad_dbx object_list zero_point) (defun make_color_21 (/ layers) (setq layers (vla-get-layers acad_dbx)) (vlax-map-collection (vla-get-blocks acad_dbx) '(lambda (block) (vlax-map-collection block '(lambda (object) (vla-put-color object 256) (if (/= 21 (vla-get-color (setq layer (vla-item layers (vla-get-layer object))))) (vla-put-color layer 21) ) ) ) ) ) ) (setq acad_dbx (vla-getinterfaceobject (vlax-get-acad-object) (strcat "ObjectDBX.AxDbDocument." (substr (getvar 'acadver) 1 2)))) (prompt "\nPick objects to copy to a new file on the desktop...") (setq object_list (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget)))))) (setq zero_point (getpoint "\nPick zero point for the copied entities: ")) (foreach copied_object (setq odbx_objects_list (vlax-invoke (vla-get-database (vla-get-activedocument (vlax-get-acad-object))) 'copyobjects object_list (vla-get-modelspace acad_dbx) ) ) (vla-move copied_object (vlax-3d-point zero_point) (vlax-3d-point 0 0 0)) ) (make_color_21) (vla-saveas acad_dbx (princ (strcat (getenv "userprofile") "\\Desktop\\" (getstring "\nEnter file name: ") ".dwg"))) (vlax-release-object acad_dbx) (princ) ) Hi Bro, The LISP code above is awesome, and it is working. But, I encountered an error below and as per the attached drawing 1 with mp4 video (in link) and added it as follows, 1). Please set the unit to be "mm" in the created file. 2). Please zoom extend for the created file. fyi, I did changed the LISP code to "CP" Kindly advise and revert with the completed Lisp code. Thanks. https://drive.google.com/file/d/15VNesdJ3uHtPbUlrNbCsaP0yMzY3e2Po/view?usp=sharing Drawing1.dwg
devitg replied to oliver's topic in AutoLISP, Visual LISP & DCL
@Tsuky Thanks for label_bearing-vertex, I need to label from points , not from polilines . Just to loop around the label_bearing.lsp from point to point Best regards label_bearing.lsp
