  1. Today
  2. Do you have an example drawing that does this? That sounds more like a Graphics Card or driver issue, though as you say, could be AutoCAD 2010 (I presume that's what you mean since v10 is very old now and was released in 1988). If you still use v10 I would definitely say that's the issue.
  3. I moved your thread to the AutoCAD 3D Modelling & Rendering Forum. Please start threads in the most appropriate forum.
  4. This can happen when working on a 3D model. Two solids may look like one object, but they can still be separate. A simple way to check is to click each part and see if you can select them separately. If they need to become one solid, UNION can combine them. You can also use INTERFERE to check if two solids are overlapping. How many of you have faced this while making a 3D model?
  5. Have you ever used PEDIT → JOIN, but CAD does not join the lines? Sometimes the lines look connected, but there is a small gap between them. They can also have different Z values. First, check the endpoints using OSNAP. If the lines have different Z values, FLATTEN can help bring them to the same level. How many of you have faced this problem? What fixed it for you?
  6. Yesterday
  7. One other thing I've noticed.. Inserting a 3d block into model space. Occasionally everything in model space disappears and the 3d part appears, nothing else. Purging does not solve it, the 3d part is invisible otherwise. It's very strange and may be a bug in v10.
  8. [Side DIM] VCID: 5EDNWJ @ VedaCAD
  9. [Omni Wheel] VCID: US87Y8 @ VedaCAD
  10. Last week
  11. Hi, Does anyone have experience with stack social? (LT @ 199/yr) Thanks!
  12. ReMark
    Judging by what I have seen other students use I would say 8" would be sufficient. BTW... your drawing needs further work. Footings need to be trimmed where beams appear above them. Likewise, channels are not continuous. They too need to be trimmed where they intersect with the beams.
  13. https://drive.google.com/drive/folders/1RW3VS_e2hrR0-L4AcJnErnl0MR6DnZFp?usp=sharing When using this version, check the "Merge PDF" box to print in "Publish" mode.
  14. Hi, Suppose we have three groups positioned within another but all separate. Is there a way to nest the interior groups to the exterior one whilst keeping them intact . If the whole needs to be edited, they can be pulled away as one, then edited as separate entities. Thanks!
  15. I wonder what he thinks about the above...
  16. Can this be modified to include the hyperlinks, like that of publish command in autocad?
  17. @ReMark yes, this drawing is mine I'm on to doing the dimensions I wanted to know the size of the text.
  18. SLW210
    I wouldn't rely on AutoCAD's Autosave feature, see this recently revived old thread... I have some links where you can "Autosave" without Autodesk's version. I know for AutoCAD LT the VBA solution will not work, but maybe the others are worth a shot. As I mention, get into the habit of Ctrl+S often. From the other link I posting in that thread explaining Autosave, etc....
  19. It is widely known that DCL has its native limitations, and to create beautiful and elegant UIs, it's not only about simplifying the underlying logic but also about DCL's presentation. Please share those DCL interface designs that are worth sharing! Here are the DCL interface designs for my two plugins. In the end, it was the image control that took on everything!!!
  20. X11start
    Actually I set the autosave every 5 minutes. At this point the only annoying element of this "bug" is that... it can happen that you don't remember what things have been changed in the last few minutes, so you run the risk of skipping some of them. It happens when I have to retouch a drawing in various areas... but as I say it's a rare case: by now I know about this "bug" and I'm careful!
  21. Danielm103
    Python for AutoLISP Users part 1:
    This thread discusses PyRx. PyRx embeds the Python runtime inside AutoCAD/BricsCAD’s process space. It’s CAD that does the .DWG/DXF file IO. There’s other packages like ezdxf that can read write files. PyRx, is analog to CAD’s .net wrappers in that its bound to ObjectARX
  22. BIGAL
    Pathon a new programming language ? Just open a dxf or a dwg can then run Python scripts. But must install the Python run time.
  23. A google should have pointed you to the great Website by Lee-mac, Bounding Box.
  24. ReMark
    Who's drawing is pictured above? Yours or that of someone else? If it is yours then I assume you are at the point where dimensions are added. One would dimension from centerline-to-centerline both horizontally and vertically. Then one would add an overall dimension for both length and width.
  25. Update for the BatchPlot.exe installation version. Free Download: https://drive.google.com/drive/folders/16RZS69S2tzZZzFnYW0H6QNQ3klwxB2C6?usp=drive_link
  26. @ReMark
  27. Good afternoon can someone help me I start this project, but I'm confused on what to do next right now I'm on dimlin.
