  2. EmeraldSynth
    TitleBlock.dwg
  3. Today
  4. (defun c:crs (/ *error* _StartUndo _EndUndo ss ss1) ;; AI.. https://www.google.com/search?q=copy+region+edge+segment%2C+autolisp&client=firefox-b-1-e&hs=LJSp&sca_esv=28d160b4388e87a1&biw=1143&bih=530&ei=t2enadf8OfXIp84PyJ69kA8&ved=0ahUKEwiXtPqy6oSTAxV15MkDHUhPD_I4ChDh1QMIEQ&uact=5&oq=copy+region+edge+segment%2C+autolisp&gs_lp=Egxnd3Mtd2l6LXNlcnAiImNvcHkgcmVnaW9uIGVkZ2Ugc2VnbWVudCwgYXV0b2xpc3AyCBAAGIAEGKIEMgUQABjvBTIFEAAY7wUyBRAAGO8FMgUQABjvBUjeM1C3D1iRLnABeACQAQCYAYgIoAHMC6oBBzAuNC43LTG4AQPIAQD4AQGYAgagApcNwgIIEAAYsAMY7wXCAgoQIRigARjDBBgKmAMAiAYBkAYFkgcHMS40LjYtMaAH0BCyBwcwLjQuNi0xuAffDMIHBzItMS4zLjLIB2uACAA&sclient=gws-wiz-serp (princ "\nSelect Region to Copy Edge From: <oops> ") ;; micro altered.. ;; https://www.cadtutor.net/forum/topic/99013-segment-copy-of-a-region-cleaning-request/#findComment-678508 (setvar 'cmdecho 0) (defun *error* ( msg ) (setvar 'cmdecho 0) ;; 5.28.24 (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (if msg (prompt (strcat "\n" msg))) (setvar 'nomutt 0) (setvar 'cmdecho 1) (princ) ) (defun _StartUndo ( doc ) (_EndUndo doc) (vla-StartUndoMark doc) ) (defun _EndUndo ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndoMark doc) ) (princ "\r") ;; added to merge final info/cmd-line ) (setvar 'nomutt 1) ;; bypass ssget 'select prompt (if (setq ss (ssget ":S" '((0 . "REGION")))) (progn (command "_.copybase" "0,0,0" ss "") ;; copy region to clipbrd (command "chprop" ss "" "c" 252 "") ;; change color (setq LastEnt (entlast)) ;; ;;; !!!!!!!!!!!!!!!! (_StartUndo doc) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (command "_.explode" ss) ;; make segs accessable, saved in 'ss to erase (setq SS1 (ssadd)) ;; create a blank selection set or add to an existing one., saved in 'SS1 to erase (while (setq LastEnt (entnext LastEnt)) (ssadd LastEnt SS1) ) (princ "\nSelect Region Segment to Copy ") (initget 1) (command "_.copy" (ssget ":S")) ;; select segment (setvar 'nomutt 1) (princ "\nSpecify Basepoint: ") (command "" "\\") (princ "\nSpecify Destination: ") (command "\\") ;; +move (setvar 'nomutt 0) (command "_.erase" ss "") ;; region copied/erasure (command "_.erase" ss1 "") ;; erases exploded region (_EndUndo doc) ; (princ "\nSelect Items to Remove..") ;; <- my only known method \ ; \ ; (command "_.erase" "w" "\\" "\\" "") ;; <- manual erase :( -- solved!!! ; / ;; ... SEEING AS MY AUTOLISP EXPERIENCE SUCKS .. / ;; how can the eXploded region / lines etc, be ERASED/selected ? / ;; how to: make a selection set? / (command "chprop" "_L" "" "c" "bylayer" "") ;; ch copied to bylayer ) ;; end of progn ;;(c:crs) ) ;; end of if (command "_.pasteclip" "0,0,0") ;; re.place original region (setvar 'nomutt 0) (setvar 'cmdecho 1) (*error* nil) (princ) ) Only oops is when I rt.clk after selecting region .. tried 'initget 1 but no fixy just so glad this works. Thanks again Mr. mhupp
  5. I tested it under AutoCAD 2022 and BricsCAD V26 and it worked well and with arced segments... Do you receive some error messages?
  6. Then again, if people are still having the same problem, or proposing new solutions, is the issue really closed? There are bugs in AutoCAD still there since I started using it, and that's a long time.
  7. Marco, when'd u write that? let me try it... seems to refuse arc segs but do like your select style
  8. PURRRFECT! Thanks so much 'mhupp This gets me all.the.more excited to learn more!
  9. If I understood you correctly, you are searching to something like this... (defun c:copy_reg_edg ( / *error* car-sort osm cmd pt ptt regpt reg x el ell edg edgs ss m ) (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com)) (defun *error* ( m ) (if osm (setvar (quote osmode) osm) ) (if cmd (setvar (quote cmdecho) cmd) ) (if m (prompt (strcat "\n" m)) ) (princ) ) (defun car-sort ( lst fun / r ) (setq r (car lst)) (foreach itm (cdr lst) (if (apply fun (list itm r)) (setq r itm) ) ) r ) (setq osm (getvar (quote osmode))) (setvar (quote osmode) 3) (setq cmd (getvar (quote cmdecho))) (setvar (quote cmdecho) 0) (if (and (not (initget 1)) (setq pt (getpoint "\nPick edge of region to copy - you may use any OSNAP option; hover cursor over segment mid, or end point to see active OSNAP - <end,mid>... : ")) (setq regpt (nentselp pt)) (setq reg (car regpt)) (= (cdr (assoc 0 (setq x (entget reg)))) "REGION") (/= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (cdr (assoc 8 x)))))))) (progn (setq ptt (trans pt 1 0)) (setq el (entlast)) (vla-explode (vlax-ename->vla-object reg)) (while (setq el (entnext el)) (setq ell (cons el ell)) ) (if (not (equal pt (osnap pt "_end"))) (progn (setq edg (car-sort ell (function (lambda ( a b ) (< (distance ptt (vlax-curve-getclosestpointto a ptt)) (distance ptt (vlax-curve-getclosestpointto b ptt))))))) (foreach el ell (if (not (eq el edg)) (entdel el) ) ) (vl-cmdf "_.move" edg "" "_non" (trans ptt 0 1) "\\") ) (progn (setq ell (vl-sort ell (function (lambda ( a b ) (< (distance ptt (vlax-curve-getclosestpointto a ptt)) (distance ptt (vlax-curve-getclosestpointto b ptt))))))) (setq edgs (list (car ell) (cadr ell))) (foreach el (cddr ell) (entdel el) ) (setq ss (ssadd)) (ssadd (car edgs) ss) (ssadd (cadr edgs) ss) (vl-cmdf "_.move" ss "" "_non" (trans ptt 0 1) "\\") ) ) ) (setq m "Missed, or picked wrong entity type - you must pick REGION entity on unlocked Layer... Better luck next time...") ) (*error* (if m m)) )
  10. not sure what your trying to do. you can set entlast before the explode then add all the entities into the selection set. (setq LastEnt (entlast)) (command "_.explode" ss) (setq SS1 (ssadd)) ;create a blank selection set or add to an existing one. (while (setq LastEnt (entnext LastEnt)) (ssadd LastEnt SS1) )
  11. Question in code.. (defun c:CopyRegionEdge (/ ss) ;; AI.. https://www.google.com/search?q=copy+region+edge+segment%2C+autolisp&client=firefox-b-1-e&hs=LJSp&sca_esv=28d160b4388e87a1&biw=1143&bih=530&ei=t2enadf8OfXIp84PyJ69kA8&ved=0ahUKEwiXtPqy6oSTAxV15MkDHUhPD_I4ChDh1QMIEQ&uact=5&oq=copy+region+edge+segment%2C+autolisp&gs_lp=Egxnd3Mtd2l6LXNlcnAiImNvcHkgcmVnaW9uIGVkZ2Ugc2VnbWVudCwgYXV0b2xpc3AyCBAAGIAEGKIEMgUQABjvBTIFEAAY7wUyBRAAGO8FMgUQABjvBUjeM1C3D1iRLnABeACQAQCYAYgIoAHMC6oBBzAuNC43LTG4AQPIAQD4AQGYAgagApcNwgIIEAAYsAMY7wXCAgoQIRigARjDBBgKmAMAiAYBkAYFkgcHMS40LjYtMaAH0BCyBwcwLjQuNi0xuAffDMIHBzItMS4zLjLIB2uACAA&sclient=gws-wiz-serp ;; micro altered.. (princ "\nSelect Region to Copy Edge From: ") (setvar 'cmdecho 0) (if (setq ss (ssget ":S" '((0 . "REGION")))) (progn (command "_.copybase" "0,0,0" ss "") ;; copy region to clipbrd (command "chprop" ss "" "c" 252 "") ;; change color ;;; ??????????? (command "_.explode" ss) ;; make segs accessable <not a selection set> (princ "\nSelect Region Seg to Copy ") (command "_.copy" (ssget ":S") "" "\\" "\\") ;; select seg +copy +move (command "_.erase" ss "") (princ "\nSelect Items to Remove..") ;; <- my only known method (command "_.erase" "w" "\\" "\\" "") ;; <- manual erase :( ;; ... SEEING AS MY AUTOLISP EXPERIENCE SUCKS .. ;; how can the eXploded region / lines etc, be ERASED/selected ? ;; how to: make a selection set? (command "chprop" "_L" "" "c" "bylayer" "") ;; ch copied to bylayer ) ) (command "_.pasteclip" "0,0,0") ;; re.place original region (setvar 'cmdecho 1) (princ) )
  12. Yesterday
  13. This is what I use, I think the root LISP is the same as the OPs, over time I have added to it: txtfindreplace ;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/find-and-replace-text/td-p/5649883 (defun FindReplace (Str$ Find$ Replace$ / Cnt# FindLen# Loop Mid$ NewStr$ ReplaceLen# acount) (setq Loop t Cnt# 1 NewStr$ Str$ FindLen# (strlen Find$) ReplaceLen# (strlen Replace$) ) (setq acount 0) (while Loop (setq Mid$ (substr NewStr$ Cnt# FindLen#)) (if (= Mid$ Find$) (progn (setq acount (+ acount 1)) (setq NewStr$ (strcat (substr NewStr$ 1 (1- Cnt#)) Replace$ (substr NewStr$ (+ Cnt# FindLen#))) Cnt# (+ Cnt# ReplaceLen#) );setq );end progn (setq Cnt# (1+ Cnt#)) );if (if (= Mid$ "") (setq Loop nil)) );while (list NewStr$ acount) );defun FindReplace (defun FindReplaceNew (Find$ Replace$ / SS acounter acount ent1 entlist1 entcodes1 EntType Text$ text01 ReplaceWith$ FoundReplaced NewTxt MyBlockEntList BlockCounter ) ;;;Sub Routines ;;;; ;;;;;;;;;;;;;;;;;;;; ;;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/get-entities-inside-a-block/td-p/2644829 (defun getblkitems ( EntName / sel items) ;;Blocks: (setq nfo (entget EntName)) (progn (vlax-for item (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object) ) ) (cdr (assoc 2 nfo)) ) (setq items (cons (vlax-vla-object->ename item) items)) ) ;end vlax ) ; end progn ) ;end defun (defun updateblock ( EntType ent1 entlist1 acount Find$ Replace$ / MyBlockEntList BlockCounter EntType2 ent2 entlist2 ) (if (= EntType "INSERT") (progn ;;Updates block texts & block blocks (setq MyBlockEntList (getblkitems ent1) ) (setq BlockCounter 0) (while (< BlockCounter (length MyBlockEntList)) (setq ent2 (nth BlockCounter MyBlockEntList)) (setq entlist2 (entget ent2)) (setq EntType2 (cdr (assoc 0 entlist2)) ) ;;Attrributes (setq acount (updateattribvalues EntType ent1 entlist1 acount Find$ Replace$)) ;;Texts (if (or (= EntType2 "TEXT")(= EntType2 "MTEXT")(= EntType2 "MULTILEADER")) ;;attributes? (setq acount (updatetext EntType2 ent2 entlist2 acount Find$ Replace$)) ); end if ;;Changes Dimensions (if (or (= EntType2 "DIMENSION") ) (if (= (cdr (assoc 1 entlist2)) "") ;;if has text over ride () (progn (setq acount (updatetext EntType2 ent2 entlist2 acount Find$ Replace$)) ;;same as text -if- ent code 4 used (command ".-refedit" (cdr (assoc 10 entlist1)) "ok" "all" "yes") ;;update block definition (command "refclose" "s") );end progn ) ;end if ); end if (if (= EntType2 "ACAD_TABLE") (setq acount (UpdateTable EntType2 ent2 entlist2 acount Find$ Replace$)) );end if (if (= EntType2 "INSERT") ;;Blocks (setq acount (updateblock EntType2 ent2 entlist2 acount Find$ Replace$)) );end if (setq BlockCounter (+ BlockCounter 1)) ) ; end while );end progn );end if acount ) ;;End Blocks ;;;;;;;;;;;;;;;;;;;; (defun updateattribvalues (EntType ent1 entlist1 acount Find$ Replace$ / ) (setq EntName^ ent1 EntList@ entlist1 EntType$ EntType Text$ (cdr (assoc 1 EntList@)) );setq (if (= EntType$ "INSERT") (if (assoc 66 EntList@) (progn (while (/= (cdr (assoc 0 EntList@)) "SEQEND") (setq EntList@ (entget EntName^)) (if (= (cdr (assoc 0 EntList@)) "ATTRIB") (progn (setq Text$ (cdr (assoc 1 EntList@))) (if (wcmatch Text$ (strcat "*" Find$ "*")) (progn (setq FoundReplaced (FindReplace Text$ Find$ Replace$)) (setq ReplaceWith$ (nth 0 FoundReplaced)) (setq acount (+ acount (nth 1 FoundReplaced))) (entmod (subst (cons 1 ReplaceWith$) (assoc 1 EntList@) EntList@)) (entupd EntName^) );progn );if );progn );end if attrib (setq EntName^ (entnext EntName^)) );while );progn );if );if acount ) ;end defun ;;;;;;;;;;;;;;;;;;;; (defun updatetext (EntType ent1 entlist1 acount Find$ Replace$ / entcodes1 FoundReplaced NewTxt) (progn (setq entcodes1 (gettextdxfcodes entlist1) ) ;list of ent codes containing text. (setq text01 (gettextasstring ent1 entcodes1) ) ;Text as string (if (= text01 nil) () (progn (setq FoundReplaced (FindReplace text01 Find$ Replace$)) (setq NewTxt (nth 0 FoundReplaced)) (setq acount (+ acount (nth 1 FoundReplaced))) (addinnewtext NewTxt entlist1 ent1) )) ;end progn, end if ) ; end progn acount ) ;;;;;;;;;;;;;;;;;;;; (defun UpdateTable ( EntType ent1 entlist1 acount Find$ Replace$ / text01 Newentlist1 counter) (setq counter 0) (setq Newentlist1 '()) (while (< counter (length entlist1)) (if (or (= (nth 0 (nth counter entlist1)) 1)(= (nth 0 (nth counter entlist1)) 302) ) (progn (setq text01 (cdr (nth counter entlist1))) (setq FoundReplaced (FindReplace text01 Find$ Replace$)) (setq NewTxt (nth 0 FoundReplaced)) (setq acount (+ acount (nth 1 FoundReplaced))) (setq text01 NewTxt) (setq Newentlist1 (append Newentlist1 (list (cons (nth 0 (nth counter entlist1)) text01)))) ) ;end progn (setq Newentlist1 (append Newentlist1 (list (nth counter entlist1)))) ;;ignore entity item ) ;end if (setq counter (+ counter 1)) ) ;end while (setq entlist1 Newentlist1) (entmod entlist1) (entupd ent1) acount ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;end subroutines 'findreplace' (setq acount 0) (setq acounter 0) (command "UNDO" "BEGIN") (setq SS (ssget "x" (list '(-4 . "<AND") '(-4 . "<OR") '(0 . "*TEXT") '(0 . "INSERT") '(0 . "ATTDEF") '(0 . "ATTRIB") '(0 . "DIMENSION") '(0 . "*LEADER") '(0 . "POSITIONMARKER") '(0 . "*TABLE") '(-4 . "OR>") (cons 410 (getvar "CTAB")) '(-4 . "AND>") ))) ; end setq, end ss, end list ;;;FILTER SS to text string (while (< acounter (sslength SS)) (setq ent1 (ssname SS acounter)) (setq entlist1 (entget ent1)) (setq EntType (cdr (assoc 0 entlist1)) ) (setq Text$ (cdr (assoc 1 entlist1)) ) ;;change this line to get all texts inc. long texts etc. ;;Changes Attribute Values - In Blocks (setq acount (updateattribvalues EntType ent1 entlist1 acount Find$ Replace$)) ;;Changes Block Texts (if (= EntType "INSERT") (setq acount (updateblock EntType ent1 entlist1 acount Find$ Replace$)) );end if ;;Changes Texts (if (or (= EntType "MTEXT")(= EntType "TEXT") (= EntType "MULTILEADER") (= EntType "POSITIONMARKER") ) (setq acount (updatetext EntType ent1 entlist1 acount Find$ Replace$)) ); end if (if (or (= EntType "DIMENSION") ) (if (= (cdr (assoc 1 entlist1)) "") ;;if has text over ride () (setq acount (updatetext EntType ent1 entlist1 acount Find$ Replace$)) ;;same as text -if- ent code 4 used ) ); end if (if (or (= EntType "ATTDEF")(= EntType "ATTRIB") ) (progn (setq ent2 (entget ent1)) (setq AttText (cdr (assoc 2 ent2))) (setq FoundReplaced (FindReplace AttText Find$ Replace$)) (setq NewTxt (nth 0 FoundReplaced)) (setq acount (+ acount (nth 1 FoundReplaced))) (setq newval Replace$) (entmod (subst (cons 2 NewTxt) (assoc 2 ent2) ent2)) (entupd ent1) );end progn ); end if (if (= EntType "ACAD_TABLE") (setq acount (UpdateTable EntType ent1 entlist1 acount Find$ Replace$)) );end if (setq acounter (+ 1 acounter)) ) ; end while (command "REGEN") (command "UNDO" "END") acount );defun FindReplaceNew (defun c:txtFindReplace( / old_text new_text) (setq old_text (getstring T "OLD Text to replace (replace in this model/paper space and text case as entered): ")) (setq new_text (getstring T "NEW Text: ")) (princ "Changes: ") (princ (FindReplaceNew old_text new_text) ) (princ) )
  14. I tried this as a test, so finds the #1234 text. It will find 123#456 also. But the lisp as suggested by @Steven P should cater for that. (setq ss (ssget "X" (list (cons 0 "*text")(cons 1 "*#*")))) (princ (sslength ss)) 12
  15. For example I use a LISP find/replace if I don't want a dialogue box for example in a batch process.
  16. Welcome to Cadtutor. You can draw a rectang that represents your viewport for a given scale matching a known title block. It is a lisp program. Just pick a point in model space, the rectang can be moved and/or rotated, part 2 is make a matching layout. So can see the dim problem and make some choices. Just ask if sounds helpful.
  17. Welcome aboard last post was 11 years ago. So it could be considered a closed post. Yes if using CIV3D it locks lots of stuff in a dwg wether its used or not. PURGESTYLEANDSETTINGS comes to mind.
  18. I have moved your thread to the AutoCAD Bugs, Error Messages & Quirks Forum. Can you post a screenshot of what's happening?
  19. That works well if there is only one value that needs to be replaced. Thanks.
  20. Why not just use the built-in FIND command in AutoCAD? You just have to turn off the "Use Wildcards" option.
  21. My screen is occupied for a half by a dark grey space, so I can view only a part of the model or of the sheet. How can modify this visualization to have back the fill screen to work?
  22. The text replacer lisp refuses to work when there is a # in the text string tobe replaced or the string to replace it. Does anyone know how to fix? revised per #555188 revised per #666299 TXTREPLACE.LSP
  23. if i publish to pdf multi sheet layout the transparency items appear like in photo, with a lot of lines. why? if i remove silhoutte edges the problem solve, but i want line thickness.
  24. The OP seems to have exited the conversation, but just for others with the same inquiry. As I have mentioned, this is mostly an issue with your PDF editor, the instructions for using the OCR should be in Foxit Help. If this is something you need to do going forward without any effort, you need to use TTF.
  25. I moved your thread to the AutoCAD 2D Drafting, Object Properties & Interface Forum. It is indeed a pain. Your only options AFAIK, use LIMITS instead of EXTENTS or EXPLODE the Dimension.
  26. The student should have already drawn the channels, in sectional view, prior to sheet 4. All you are being asked to do is provide an enlarged view since you are creating a detail sheet. Refer to American Standard Steel Channels: Weight, Dimensions, & Properties. Copy the sectional view of one of your channels (previously drawn prior to Sheet 4), paste it in your new sheet, then use the Scale command to enlarge the geometry by the necessary scale factor called for in your instructions.
  27. is there any opinion to "hide" the center node...? sometime I use DimArc at Pspace, the center node shown outside the title block... (or DimArc at Mspace, the center node shown at the outer space...) it affects Zoom~Extents and choosing Extents as plot area... (gotta use Window to point-pick plot area... it's pretty trouble as I use Page Setup to Publish outputs very often...)
  28. Look with Civil3D in Toolspace ; Settings ; Pipe Network ; Delete part lists like Full Part List if they exist.
