  2. Callout blocks on floor plans are specialized, often circular or bubble-shaped, graphical symbols used to highlight a specific area, detail, section, or elevation, indicating that more detailed information about that area can be found elsewhere in the drawing set.
  3. BIGAL
    Vertex Icon Highlight
    You can get all vertices step 1, Step 2 is enter vertice number place a "X" say as text on vertice. If wrong do again erasing existing "X". An example of get co-ords. (setq plent (entsel "\nPick lwpolyline 2D ")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) (princ co-ord) If you have 3D poly's then use (setq obj (vlax-ename->vla-object (car (entsel "\nPick pline ")))) (setq co-ord (vlax-safearray->list (vlax-variant-value (vla-get-coordinates obj))))
  4. Today
  5. ScottMC
    no show/difference with a 'CONVERTPOLY Enter polyline conversion option [Heavy/Light] <Light>: h' 2d polyline..
  6. GLAVCVS
    'CurrentVertex' is not a property of "LWPOLYLINE" objects
  7. I also don't know what they mean about callout blocks for elevation. I cant even read what the callout blocks say in their example with my readers on...lol
  8. correct. Here's a few of the files. Right now I'm having an issue with missing dimensions and furniture blocks when I upload the drawings into sheets from model space. I made sure no layers were frozen, nothing is on def points, ran an audit....etc Flr-B.dwg Flr-1.dwg FLR-2.dwg Exterior Elevations corrected.dwg Site plan Alternate.dwg Wall Section.dwg Building section.dwg Stair Detail.dwg
  9. Alright, another Penn Foster student here. Big shocker there, I know. I put all my drawings from model space in to sheets but I lost all my dimensions and some of my furniture blocks. I double checked to be sure I didn't have any frozen layers, nothing is in def points, they're in correct layers, I ran an audit and it found and fixed 0 errors. I'm really new to all this auto cad stuff but apparently my work thinks I need it even though ill never use it. I'm not even ALOUD to have it on my computer at work...lol Any help would be greatly appreciated Flr-B.dwg Flr-1.dwg FLR-2.dwg
  10. here's the AI reply to my question: "Activate Current Vertex 'X' marker: as if Clicking on the Current Vertex field on gis Properties, autolisp" here's the code and tried but my a2k might not be able.. can someone try this <short>Vertex.X.lsp? (defun c:Sv ( / ent obj vla-obj vertexNum) (vl-load-com) ;; 1. Select the polyline (setq ent (car (entsel "\nSelect Polyline: "))) (if (and ent (member (cdr (assoc 0 (entget ent))) '("LWPOLYLINE" "POLYLINE"))) (progn (setq vla-obj (vlax-ename->vla-object ent)) ;; 2. Ask for the vertex index (0-indexed) (setq vertexNum (getint "\nEnter vertex index (0 is first): ")) ;; 0) ;; <- my choice (if (and vertexNum (>= vertexNum 0)) (progn ;; 3. Set the CurrentVertex property (Activates the X marker) (vl-catch-all-apply 'vlax-put-property (list vla-obj 'CurrentVertex vertexNum)) ;; 4. Refresh to show the marker (vla-update vla-obj) (redraw) (princ (strcat "\nVertex " (itoa vertexNum) " activated.")) ) ) ) (princ "\nNot a valid polyline.") ) (princ) )
  11. What are you being asked to create? Since it is an architectural drawing I would say a floor plan, at least two elevations, a section and related details. Is that correct?
  12. Yesterday
  13. What specifically is the project? Is it a 2D or 3D drawing that is required?
  14. correct. yea that's the book
  15. I tried the link but the furthest I got was to a screen where I was told I don't have access to the book. The title of the book referenced was "Residential Design Using AutoCAD 2023." Sound familiar?
  16. Last week
  17. BIGAL
    Breakline in lines...help
    I think a custom DCL front end would be good. Will have a think about it. The extend option is easy just set the default length to 0.0 so any other value means yes. Nikon the dynamic block is a nice idea.
  18. Like @Steven P "Generally I save to the same folder as the CAD file" In the attached file is a plot a range of pdf's a DCL pops up for the range then the plots are done. In the code you will see a command Mk-dir that is used to make a PDF directory. I think we have discussed previously about making menu's as the simplest way of click on a choice and it happens. See image above, keep adding options for users, they don't need to worry about appload or (load."????") I had 8 users, our menu was on a server so would auto update for end users. You will need to change the code to suit your title block and pdf settings have a go. It is set up for title block at 0,0. It is possible to have one lisp but it uses different variables for different output devices and title blocks. A version I have for a client looks at title block name and sets the correct plot size settings. Come back if have a problem, you have my Email ? plotA3Pdfrange.lsp Multi GETVALS.lsp
  19. BIGAL
    Drag Units?
    The dimension style holds the settings for dimensions not the units, the Units would be used for setting imperial or metric.
  20. BIGAL
    You need to understand what is a OEM version it is used by software providers as a means to get an Autocad but with their software as the essential item. Refering to OEM document "Deliver products with scaled feature sets at scaled price points and provide an AutoCAD-based platform that cannot be customized or extended by end users." So any outside program lisp or .NET etc can not be ran by you. But you can add programs using the OEM key that is held by the software developer. You would have to go back to them to add. What program did you buy ?
  21. This is what its called "AutoCAD Applications-Construction". Here's a link to the project instructions https://online.vitalsource.com/reader/books/9781630567422/pageid/2 Not sure if you have to sign in to see it or not. Heres a screenshot of the class title. Im going back and fixing stuff currently. I messed up a lot...lol
  22. A house project? Like for HVAC? What is Penn-Foster calling this project? Where do you normally go to download P-F projects?
  23. Well, apparently the house project that I'm working on hasn't been talked about..lol...The instructions are through "VitalSource Bookshelf". Is there a way to download that and my project so I can upload it here somewhere and hopefully someone much more experienced than I am can critique it for me before I submit it?
  24. Awesome. Ill look into it. Its too late for the Oleson Village one but Ill look at it anyway just to see exactly what went wrong but honestly the lack of response combined with the horrible instructions (or lack there of) makes it really difficult for someone trying to learn. Thank you fellas. I'm sure Ill have more questions before i submit the final prject
  25. Hello, I'm trying to create a macro to dimension angles using a vertex starting at 0,0 to 0,1, and then a point. I thought it would be rather simple compared to other things that I have tried. I thought that this would do what I want, but for some reason the first line in the angle is all over the place. Any ideas as to why? ^C^C^C_dimangular;;0,0;0,1;\
  26. Nikon
    A small modification of the DZ code for convenience. The Break lines can be lengthen by the specified distance (Fixed) or proportionally (by 1/3) or None. [Fixed/Proportional/None] ;;; Lisp to draw Single or Double "Z" Break Lines ;;; © A.Henderson 2002 ;;; Modified By Charles Alan Butler 10/06/2004 ;;; To allow any angle and to trim lines that ;;; do not run through both break symbols ;;; Modified 12/02/26 ;;; The Break lines can be lengthen by the specified distance (Fixed) ;;; or proportionally (by 1/3) or None (defun c:dz-mod (/ oldlay oldotho oldosmode ztype dist ang extOpt extLen dist0 segLen e1 e2 p1 p2 p3 p4 p5 p6 p7 p8 p9 p10) ;; return vertex list by MP (defun cdrs (key lst / pair rtn) (while (setq pair (assoc key lst)) (setq rtn (cons (cdr pair) rtn) lst (cdr (member pair lst)) ) ) (reverse rtn) ) ; defun ;; set osnaps ON/OFF (defun setosnaps (value) ; value = "ON" or default to "OFF" (if value (setq value (strcase value)) ) (cond ((or (and (= value "ON") (>= (getvar "osmode") 16383)) (and (/= value "ON") (<= (getvar "osmode") 16383)) ) (setvar "osmode" (boole 6 (getvar "osmode") 16384)) ) ) ); defun ;; Start of routine ================================== ;; Save settings (setq oldlay (getvar "clayer") oldortho (getvar "orthomode") oldosmode (getvar "osmode") ) ;_ end of setq ;; I use current layer - CAB ;;(command "_.layer" "_make" "Z-Line" "_Colour" "41" "" "") (initget "S D") ;(setq ztype (getkword "\n Single or Double -^v-^v- ? (S or D) <S>")) (setq ztype (getkword "\n Single or Double -^v-^v- ? [S/D] <S>")) (setosnaps "ON") ; force on ;;=========================================== (if (and (setq p1 (getpoint "Starting point of break line : ")) (setq p6 (getpoint p1 "End point of break line : ")) ) (progn;=========================================== ;;; --- EXT --- calculate the base length/angle based on the selected points (setq dist0 (distance p1 p6)) ;;; --- EXT --- elongation mode (Fixed = 50 by default) (initget "F P N") (setq extOpt (getkword "\nExtend beyond picked points? [Fixed/Proportional/None] <Fixed>: ")) (cond ((or (not extOpt) (= extOpt "F")) (setq extLen (getdist "\nExtension length <50>: ")) (if (null extLen) (setq extLen 50.0)) ) ((= extOpt "P") ;; 1/3 of the straight section (straight section = 0.4167*dist for S, and 0.4167*(dist/2) for D) (setq segLen (* 0.4167 (if (= ztype "D") (/ dist0 2.0) dist0))) (setq extLen (/ segLen 3.0)) ) (T (setq extLen 0.0)) ) (setvar "plinewid" 0) (command "._undo" "_begin") (cond ((/= ztype "D") ; default to single (setq dist (distance p1 p6) ang (angle p1 p6) p2 (polar p1 ang (* 0.4167 dist)) p5 (polar p1 ang (* 0.5833 dist)) p3 (polar p2 (+ 1.25664 ang) (* 0.1667 dist)) p4 (polar p5 (+ 4.39824 ang) (* 0.1667 dist)) ) ;_ end of setq ;;; --- EXT --- we only lengthen the ends (the symbol remains at the base points) (setq p1 (polar p1 (+ ang pi) extLen) p6 (polar p6 ang extLen) ) (setosnaps "OFF") ; force off (command "_.pline" p1 p2 p3 p4 p5 p6 "") ; Draw the Z-Line ) ;_ end cond "S" ;;=========================================== ((= ztype "D") (setq p10 p6 dist (/ (distance p1 p6) 2.0) ang (angle p1 p6) p2 (polar p1 ang (* 0.4167 dist)) p5 (polar p1 ang (* 0.5833 dist)) p3 (polar p2 (+ 1.25664 ang) (* 0.1667 dist)) p4 (polar p5 (+ 4.39824 ang) (* 0.1667 dist)) p6 (polar p5 ang (* 0.8334 dist)) p9 (polar p6 ang (* 0.1661 dist)) p7 (polar p6 (+ 1.25664 ang) (* 0.1667 dist)) p8 (polar p9 (+ 4.39824 ang) (* 0.1667 dist)) ) ;_ end of setq ;;; --- EXT --- we extend the start and the very end (p10), we do not touch the inside (setq p1 (polar p1 (+ ang pi) extLen) p10 (polar p10 ang extLen) ) (setosnaps "OFF") ; force off (command "_.pline" p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 "") ; Draw the Z-Line ) ;_ end cond ) ; end cond stmt ;; Position the second break line (setq e1 (entlast)) (command "_.pedit" e1 "_L" "_ON" "") (command "_.copy" e1 "" (getvar "lastpoint") pause) (setq e2 (entlast)) (setq plast (getvar "lastpoint")) ;; trim function (initget "Y N") (setq ans (getkword " Do you wish to trim the lines now ? [Y/N] <Y>")) (if (or (= ans "Y") (not ans)) (progn (setq lst '() dist (/ dist 140.0) ; trim distance ) ;; create trim lines (command "._offset" dist e1 plast "") (setq evl1 (cdrs 10 (entget (entlast)))) ; ent vertex list (entdel (entlast)) (command "._offset" dist e2 p1 "") (setq evl2 (cdrs 10 (entget (entlast)))) (entdel (entlast)) (setq lst (append evl1 (reverse evl2))) (setosnaps "OFF") ; force off (command "_.trim" e1 e2 "" "_F") (apply 'command lst) (command "" "") (command "_.trim" e1 e2 "" "_F") (apply 'command lst) (command "" "") ) ; progn ) ;_ endif (command "._undo" "_end") ) ; progn ) ; endif ;;================ ;; Exit sequence ;;================\ ;; Restore settings ;; I use current layer - CAB ;;(command "_.layer" "set" oldlay "") (setvar "orthomode" oldortho) (setvar "osmode" oldosmode) (princ) ) ;_ end of defun (prompt "\nDouble Break Symbol Creator loaded. Type DZ to run it." ) (princ) (setfunhelp "c:dz" "acadtools.chm" "dz")
  27. I merged your 2 threads, no need to post twice, if you post in the wrong forum it can be moved, 2 threads becomes confusing.
  28. Generally I save to the same folder as the CAD file - most of our projects however have a PDF folder... but the relative file paths to these are different depending which project manager sets up the folders... so save to the same as the CAD file is easiest and most logical really. Usually I have windows Explorer opened at that point anyway from opening the files to start with. (setq MyFilePath (getvar 'dwgprefix) ) ;; Example c:\\CADFolder\\TestFiles\\ (setq MyFileName (vl-filename-base (getvar 'dwgname)) ) ;; Example MyDrawing (setq MyFileNamePlusType (getvar 'dwgname) ) ;; Example MyDrawing.dwg (setq PDFFilePathandName (strcat MyFilePath MyFileName ".pdf") );; Example c:\\CADFolder\\TestFiles\\MyDrawing.pdf Noting the double \\ is generated automatically with these. Which might be applied to yours like this: (setq MyFilePath (getvar 'dwgprefix) ) (setq final (strcat Dwg_No "-" Dwg_Status "-" Dwg_Rev "_" Dwg_Name)) (setq PDFFilePathandName (strcat MyFilePath final ".pdf") ) As for comfortable with things, once you show them PDFs being made with 6 or 7 characters from the keyboard, command line, should win them over
