;;------------------------------------------------------------------------- ;; TXT2XL.lsp | Version 1.0 ;; NEW TOOL - Pick text entities one by one in AutoCAD. Each pick is sent ;; straight into Excel (uses your open Excel if there is one, otherwise ;; opens a fresh one), starting from wherever your cursor is in the sheet. ;; Keep picking - press ENTER or ESC to stop. ;; Changelog: ;;------------------------------------------------------------------------- (vl-load-com) ;; Returns the VLA Active Document Object (defun t2x_acdoc nil (eval (list 'defun 't2x_acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (t2x_acdoc) ) ;; Opens an Undo Group. (defun t2x_startundo ( doc ) (t2x_endundo doc) (vla-startundomark doc) ) ;; Closes an Undo Group. (defun t2x_endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Write a value into a cell (row, col) via the Cells collection's Item property ;; - this is the pattern confirmed working on Ajmal's setup (from QS-05.lsp) (defun t2x_write_cell ( xlCells row col val ) (vlax-put-property xlCells "Item" row col val) ) ;; Gets the clean text string from a TEXT or MTEXT entity, else nil (defun t2x_get_text_value ( ent / obj etype ) (setq etype (cdr (assoc 0 (entget ent)))) (if (member etype '("TEXT" "MTEXT")) (progn (setq obj (vlax-ename->vla-object ent)) (vla-get-textstring obj) ) ) ) ;; Main command (defun c:TXT2XL ( / *error* xlApp xlRun xlBooks xlBook xlSheets xlSheet xlCells xlCell es ent val row col wr ) (defun *error* ( msg ) (if xlBooks (vl-catch-all-apply 'vlax-release-object (list xlBooks))) (if xlApp (vl-catch-all-apply 'vla-put-visible (list xlApp :vlax-true)) ;; leave visible so Ajmal keeps the data ) (if xlApp (vl-catch-all-apply 'vlax-release-object (list xlApp))) (t2x_endundo (t2x_acdoc)) (if (not (wcmatch (strcase msg t) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (t2x_startundo (t2x_acdoc)) ;; use Ajmal's Excel if one is already open, otherwise open a fresh one (setq xlApp (vlax-get-or-create-object "Excel.Application") xlRun (vlax-get-property xlApp 'Visible) ) (if (= xlRun :vlax-false) (progn (setq xlBooks (vlax-get-property xlApp "Workbooks") xlBook (vlax-invoke-method xlBooks "Add") xlSheets (vlax-get-property xlBook "Sheets") xlSheet (vlax-get-property xlSheets "Item" 1) ) (vla-put-visible xlApp :vlax-true) ) (setq xlSheet (vlax-get-property xlApp 'ActiveSheet)) ) (setq xlCells (vlax-get-property xlSheet "Cells")) ;; start writing from wherever the cursor is in Excel right now, so an ;; existing sheet's data never gets overwritten (setq xlCell (vlax-get-property xlApp 'ActiveCell)) (setq row (vlax-get-property xlCell 'Row) col (vlax-get-property xlCell 'Column) ) (princ "\nTXT2XL running - pick text, ENTER/ESC to stop.") (while (setq es (entsel "\nSelect text: ")) (setq ent (car es)) (setq val (vl-catch-all-apply 't2x_get_text_value (list ent))) (cond ( (vl-catch-all-error-p val) (princ (strcat "\nRead error: " (vl-catch-all-error-message val))) ) ( val (setq wr (vl-catch-all-apply 't2x_write_cell (list xlCells row col val))) (if (vl-catch-all-error-p wr) (princ (strcat "\nExcel write error: " (vl-catch-all-error-message wr))) (progn (princ (strcat "\n-> Row " (itoa row) " : " val)) (setq row (1+ row)) ) ) ) ( t (princ "\nNot a TEXT/MTEXT entity - skipped.") ) ) ) (princ "\nDone. Excel left open with your data.") (*error* nil) (princ) ) (princ "\n:: TXT2XL.lsp | Version 1.0 :: Type TXT2XL to run.") (princ)
Spoken dialogue passes through the ears to the brain, the written word causes the eyes to glaze over... I used to know phone numbers, worked in a job where I had to phone many people up - and now with mobile phone contact list and calling over the internet using Teams or Skype contact lists... I cannot remember my home phone number! Yes there is some truth in that RLX AI everything... because it is new and trending, not because it is necessary. AI enabled fridges... because they can and not to make the milk in my morning coffee any better.
a little story : This is the famous Myth of Thamus and Theuth, found in the dialogue Phaedrus by the Greek philosopher Plato (written around 370 BCE). In this text, Plato has his teacher Socrates relate an ancient Egyptian anecdote. Here is how the story unfolds: The Invention The Egyptian god Theuth (Thoth), the deity of inventions, visits Thamus, the king (pharaoh) of Egypt. Theuth presents his various creations, including arithmetic, geometry, and astronomy. Finally, he introduces the written word. Theuth is enthusiastic and claims: "This invention will make the Egyptians wiser and improve their memories. It is a potion for both memory and wisdom!" The Pharaoh's Objection King Thamus is not impressed and responds with deep skepticism. He argues that writing will have the exact opposite effect: Memory loss: People will stop training their memories. By relying on external written characters, they will no longer internalize knowledge. The illusion of wisdom: People will read quantities of information without proper instruction. As a result, they will appear knowledgeable but will actually remain ignorant, becoming conceited and difficult to get along with. The Historical Irony Socrates used this story to argue that spoken dialogue is superior to the written word. He believed text is dead; it cannot answer back or clarify itself when misunderstood. The ultimate irony is that Socrates himself never wrote anything down. The only reason we know this story today is because his student, Plato, wrote it down. This ancient debate resurfaces with every technological leap. The same anxieties were voiced about the printing press, calculators, the internet, and now, Artificial Intelligence (AI).
julie_jdr joined the community
VicoWang joined the community
This particular issue has been in play for a long time. Have you ever gone to a food joint, the power is out, and the staff refuse to prepare food for you because they can't ring it up? Like they've never heard of pencil and paper or making change. If you can't do the basic, human version of your job, you'll be left in the dark (sometimes literally) when the AI can't do its job. Worse, you won't recognize when the AI is making a mistake. Without a real-world backup, and the sense to use it, you're at the mercy of the AI and its hallucinations. It's the height of irresponsibility to replace us with something that needs its hand held all the time in case it has a malfunction.
Hello all, Thanks for taking the time to respond, apologies for not coming back sooner (work got in the way). I'll try and pull together a bit more info when I am back into that project. Thanks
nareans joined the community
asmetal2 joined the community
Danielm103 started following LISP FOR BATCH OVERKILL FOR BLOCKS
Danielm103 replied to MARINA's topic in AutoLISP, Visual LISP & DCL
You’re going to want to use .NET or ObjectARX for something like this. - The routine would need a fast KD-tree so as not to do brute force curve evaluations - AcGeCurveCurveInt3d. This class contains query methods that return intervals of overlap between the two curves. - Other items like TEXT or MText, I would use custom hashing routine to bypass slow O(N^2) comparison loop, in theory speed would be O(1) - you would need a GUI for properties to be excluded. I.e. layer. - Attribute defs are owned by the block table record, while Attribute refs are owned by Block reference. you'll need to define the behavior - You cannot safely run this on a dynamic block, if one of the items that is deleted is part of an action, the block has undefined behavior. I did some work on comparing blocks by hash here [Python] https://www.theswamp.org/index.php?topic=60513 Actually, I would consider prototyping in Python before porting to C++. Python already has a hasher for points. .NET has some hashing stuff too, but I’ve never used it. good luck -
RITIK MALLIK joined the community
AI has been around a long time, LLM since the 1990's, LISP was created for AI programming IIRC. It's a tool just like VLIDE, VS Code, etc. for programming. Problem, just like before, people came on to forums often demanding a code, etc. be written to make their life easier instead of learning something on their own to do it themselves. Most forums used to provide help and occasionally a custom code, etc. just like... That's a long list of requests. So now they demand AI to do their demands, those with some abilities have success, those that have great abilities have great success, etc. I know recently a man in Lee County, FL was arrested for a crime committed in or near Jacksonville, FL due to AI facial recognition, done by a third county's AI program, no second looks, no reasonable investigation, the man had never been to Jacksonville and a valid alibi for the time showing such. That's the bigger problem with AI right now, accepting the results without question. From the comments I see everywhere a great many seem tired of the AI everything.
The full scope of what you are asking seems quite a lot to me. Thought, REFEDIT instead of BEDIT might be faster? I'm not sure about using BlockTableRecord, I'll have to look into that as well. How would those items be separated from what does need OVERKILL? As for the last part, nothing is really being modified except to be cleaned up, so what exactly doesn't need cleaned and improved? I think LISP might be slow using commands compared to .NET or other methods, I might look into it if that's an option. Do you have an example drawing? How far have you got on writing this code?
Steven P started following LISP FOR BATCH OVERKILL FOR BLOCKS
Steven P replied to MARINA's topic in AutoLISP, Visual LISP & DCL
This does blocks, but I can't remember why I stopped using it, think it was a speed thing. It BEdit each block to overkill, but since automated does it a lot quicker than manually open-close each block. Overkill settings are whatever you did last - no option to adjust settings in this script Might be a start for you to work from (defun c:OK-Ill ( / MySS) ;;Overkill by LISP (Batch processing...) (if (setq MySS (ssget "_x")) (command "-overkill" MySS "" "") ) ) (defun c:OK-BLOCKS ( / MySS acount MyEnt BlockName BlockList MyOption) (defun Blocklist (/ LL_Return) (vl-sort (vlax-for LL_Item (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object))) ;; can also do get-layers etc (if (equal (substr (vla-get-Name LL_item) 1 1) "\*") (progn ) (progn (setq LL_Return (cons (vla-get-Name LL_Item) LL_Return)) ) ; end progn ) ; end if ) ; end vlax-for '< ) LL_Return ) ; end defun (defun OKBlocks (BlockList / acount) (setq acount 0) (while (< acount (length BlockList)) (command "bedit" (nth acount Blocklist) ) (c:OK-ILL) (command "bsave") (command "bclose") (setq acount (+ acount 1)) ) ; end while ) ; end defun (initget "All Space") (setq MyOption (getkword "Select All Blocks or in this space (All or Space)")) (if (equal MyOption "Space") (progn (setq MySS (ssget "_X" '((0 . "INSERT")))) (setq acount 0) (setq BlockList (list)) (while (< acount (sslength MySS)) (setq MyEnt (entget (ssname MySS acount))) (setq Blockname (cdr (assoc 2 MyEnt))) (if (member Blockname BlockList) () (setq BlockList (cons Blockname BlockList)) ) (setq acount (+ acount 1)) ) ; end while ;;DO STUFF TO BLOCK LIST (OKBlocks BlockList) ) ; end progn (progn (OKBlocks (setq BlockList (BlockList))) ) ; end progn ) ; end if space (princ "\n")(princ (length BlockList))(princ " blocks assessed") (princ) ) -
I’m loving AI, it’s allowed me to do stuff that would take months to write in days. Example, this dark mode project to BricsCAD (https://github.com/CEXT-Dan/BrxDarkMenu) would have taken months to research.I had already done some win32 programming in the past, but very little. In short, you kind of have to know what you’re doing to use AI. I read about the Brown university thing where the professor made the students do their exams in class and most of the class failed. Scary! People need to at least learn foundational level stuff before using AI. What if the cloud is down, or you reach your token max, would you be able to go old school and continue? Or just sit there and twiddle your thumbs. With regards to anti-scraping, I see lots of open-source projects moving off GitHub to other places like Codeberg so their projects aren’t scraped, I guess so big companies that use AI don’t end up getting their code. I’m the opposite, I want AI to train on my code (if its open source)
Couple of comments to add: MHUPP mentioned anti-scraping, years ago I had a website and would layer the important images, put together they showed correctly but a left click, copy, paste, gave something like just the yellow and a transparent colour block - had to dig a little deeper to get the original image... so it is something that has happened kind of for years. If it is out there though I don't know if you can have a true anti-scraping system and have it visible to the humans CADTutor, for the future of AutoCAD, I am not concerned - though I am also including the others such as BricsCAD and so on - many of the issues on one system are common to the others and this forum will be relevant for a while yet (15 years please, till I retire...).
caatwan joined the community
Due to my workload and a busy weekend, it will be sometime next week before I fix the one I have posted. I have so far a working DXF-DWG, DWG-DXF, and DWG-DWG (change the version) on the Multi-file Batch Convertor using ODBX, I plan to add DGN, SAT, PDF, and maybe more, but those aren't exposed to ODBX AFAIK, but I am not going to use Express Tools. Thanks for the inspiration and help to get back on this. Besides the original DGN batch convertor I found and adapted, I was surprised nobody ever tried to make an improved version before.
Dynamic / Pointer input changes units
SLW210 replied to JDowls's topic in AutoCAD 2D Drafting, Object Properties & Interface
It's actually acting correctly, according to Autodesk. Move in a straighter line and/or adjust precision. Better explained at Displacement Dimensions changing. -
thinhperman joined the community
JDowls joined the community -
JDowls posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Looking for a little help with something that has been frustrating me over the last few months. Started a new job, AutoCAD already configured on the laptop. For the life of me, I cant figure out why the dynamic/pointer input switches between Architectural units and Scientific units while the mouse moves. For example drawing a line, sometimes it shows the arch units (8'-9 23/64") and sometimes it shows scientific (1.074880E+02). This is the same polyline command, just moving the mouse a bit further right. Does anyone know how to fix this? -
Clint changed their profile photo -
ODBX: The excellent and elegant solution provided here is heartening. As originator and, due to several demands being disconnected, of this important posted topic, your work is appreciated. Best regards, Clint
Fair bet if BricsCAD and AutoCAD are OK then the others are not too far off either, nice work so far!
dadetianzi joined the community
AutoCAD Command: TESTDBX Success! Total objects in Model Space: 41769 BricsCAD : TESTDBX Success! Total objects in Model Space: 41769 I didn't try ZwCAD or GstarCAD
I suppose if time allows I could work out to get it working for other CAD that use ODBX. After all, that is my reasoning on eliminating the use of Express Tools, make it more universal. Without having anything else to test I would need testing volunteers with appropriate CAD platform. Maybe at some point I could download the trial version if they have them.
YuriC started following Batch convert dxf to dwg
CADTutor started following AI taking over and Forum upgrade to Invision Community 5
Hello everyone, Advanced notice Every few years, the software used for this forum goes through a major point upgrade and that time has come round again. At some point in the next few days, I will close the forum for a short while, maybe 24 hours, so that the new software can be installed and the forum can be configured and themed. I'll be in touch with more details shortly.
- 2
What were the results?
There is a plug-in to connect AutoCAD, AutoCAD Civil 3D, etc. directly to ArcGIS. ArcGIS® for Autodesk® AutoCAD® There is also Reading a Civil 3D Corridor Project Using CSX Format : Softree Technical Systems Support. I believe it is $, but has a free trial. There are several YouTube videos around on exporting with the "Export to FGDB" in Civil 3D.
Hi All, apologies for arriving late to this discussion. @SLW210 is right about the decline in forums before AI. There was a big shift away from forums like this one towards social media platforms and it does seem that most of us left here are Boomers. However, despite the decline, I have noticed that in recent years, it has plateaued and although number of visitors are significantly lower than they were (say) 15 years ago, they are no longer declining but seem stable. Traffic here is probably around 10% of what it was back in the day. Currently, new sign-ups to the forum average around 100 per month and that has been pretty stable for the past few years. So that's the background picture. AI has made a difference only in that all the data on this forum and others has now been well and truly scraped and is still being scraped by more and more bots. The graph below shows traffic to this site since January. You can see three massive spikes - those are all bots, scraping content. The result is that most people don't need to visit the site because the scraped content is being provided to them via AI agents. You might think that would result in even lower traffic to the site but that's not what I'm seeing. My guess is that the sort of visitors who prefer to use AI results rather than going to source are the same ones that stopped visiting forums and shifted to social media. So what remains is a solid core of Boomers who genuinely care about community and respect the skill and experience of others. Fortunately, there's enough of us around to keep things going. The future? It's very difficult to predict but my view is that most people are becoming tired of the toxic nature of social media and will likely learn to value the genuine human interactions and sense of community that forums can provide once they realise that AI is just another tool and not a friend that can't always be relied upon. So I'm predicting a return of popularity in forums for special interest groups. As for AutoCAD, I don't really have a good understanding of its popularity any more. It's a long time since I used it professionally (almost 10 years) but I'm not aware that it's being replaced by anything else. Gemini tells me that AutoCAD retains a 38% global market share, so I guess it's still relevant and that this forum is therefore still relevant.
Help to Modify Existing Line Annotation LISP
Tsuky replied to KraZeyMike's topic in AutoLISP, Visual LISP & DCL
An another code, for lines or polylines. (vl-load-com) (defun make_label (pt alpha val_txt / nw_obj) (setq nw_obj (vla-addMtext Space (vlax-3d-point pt) alpha val_txt ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation 'Width) (list 5 (getvar "TEXTSIZE") 5 pt "BEARING" "LABEL-BEARING" alpha 0.0) ) ) (defun c:label-bearing ( / l_var js htx AcDoc Space nw_style n obj ename pr dist_start dist_end pt_start pt_end seg_len alpha val_txt pt) (setq l_var (mapcar 'getvar '("AUNITS" "AUPREC" "LUPREC" "LUNITS"))) (mapcar 'setvar '("AUNITS" "AUPREC" "LUPREC" "LUNITS") '(4 3 2 2)) (princ "\nSelect Polylines/Lines.") (while (null (setq js (ssget '((0 . "LWPOLYLINE,LINE"))))) (princ "\nSelection is empty or not are LWPOLYLINE, LINE!") ) (initget 6) (setq htx (getdist (getvar "VIEWCTR") (strcat "\nSpecify text height <" (rtos (getvar "TEXTSIZE")) ">: "))) (if htx (setvar "TEXTSIZE" htx)) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (vla-startundomark AcDoc) (cond ((null (tblsearch "LAYER" "LABEL-BEARING")) (vlax-put (vla-add (vla-get-layers AcDoc) "LABEL-BEARING") 'color 7) ) ) (cond ((null (tblsearch "STYLE" "BEARING")) (setq nw_style (vla-add (vla-get-textstyles AcDoc) "BEARING")) (mapcar '(lambda (pr val) (vlax-put nw_style pr val) ) (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag) (list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 0.0 1.0 0.0) ) ) ) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) ename (vlax-ename->vla-object obj) pr -1 ) (cond ((eq (vlax-get ename "ObjectName") "AcDbLine") (setq seg_len (vlax-get ename "Length") alpha (vlax-get ename "Angle") val_txt (vl-string-subst "%%d" "d" (strcat (angtos alpha) "\\P" (rtos seg_len) " m")) ) (setq pt (vlax-curve-GetPointAtParam ename (* 0.5 seg_len))) (if (and (> alpha (* pi 0.5)) (< alpha (* pi 1.5))) (setq alpha (+ alpha pi))) (make_label pt alpha val_txt) ) (T (repeat (fix (vlax-curve-getEndParam ename)) (setq dist_start (vlax-curve-GetDistAtParam ename (setq pr (1+ pr))) dist_end (vlax-curve-GetDistAtParam ename (1+ pr)) pt_start (vlax-curve-GetPointAtParam ename pr) pt_end (vlax-curve-GetPointAtParam ename (1+ pr)) seg_len (- dist_end dist_start) alpha (angle (trans pt_start 0 1) (trans pt_end 0 1)) val_txt (vl-string-subst "%%d" "d" (strcat (angtos alpha) "\\P" (rtos seg_len) " m")) ) (setq pt (vlax-curve-GetPointAtParam ename (+ 0.5 pr))) (if (and (> alpha (* pi 0.5)) (< alpha (* pi 1.5))) (setq alpha (+ alpha pi))) (make_label pt alpha val_txt) ) ) ) ) (vla-endundomark AcDoc) (mapcar 'setvar '("AUNITS" "AUPREC" "LUPREC" "LUNITS") l_var) (prin1) ) -
I'm not very familiar with ArcGIS, although I have prepared drawings to import into it. Which entities exactly do you need to transfer? Surfaces, polylines, points, or something more complicated? This page tells you how to export feature lines, COGO points, and surfaces. The feature line option includes polyline, grading feature, alignment, and profile options. There's a tool called Connector for ArcGIS, but it's probably not worth buying if you only use it occasionally. According to this page, you can import many civil objects directly into ArcGIS. Can you provide more information about what you need to bring into ArcGIS?
I just had AI write a test to see if ODBX worked. (defun c:TestDbx ( / dbxProgId dbxDoc extFile) (vl-load-com) (if (vl-string-search "BricsCAD" (getvar "PROGRAM")) (setq dbxProgId "ObjectDBX.AxDbDocument") (setq dbxProgId (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2))) ) (setq dbxDoc (vl-catch-all-apply 'vla-GetInterfaceObject (list (vlax-get-acad-object) dbxProgId))) (if (vl-catch-all-error-p dbxDoc) (progn (princ (strcat "\nError: Could not load interface using ProgID: " dbxProgId)) (princ (strcat "\nDetails: " (vl-catch-all-error-message dbxDoc))) ) (progn (setq extFile (getfiled "Select Drawing to Read" "" "dwg" 0)) (if extFile (progn (vla-open dbxDoc extFile) (princ (strcat "\nSuccess! Total objects in Model Space: " (itoa (vla-get-count (vla-get-modelspace dbxDoc))))) ) (princ "\nNo file selected.") ) (vlax-release-object dbxDoc) ) ) (princ) )
