  2. marko_ribar
    Segments of polylines
    I found some lacks, so I had to change my latest attachments... M.R.
  3. Today
  4. Hi again! I had this crazy idea to automate the drawing name process by making a lisp that will generate the drawing name (using titleblock attributes Name, Dwg.no, revision, status and so on). I have the below lisp that works great on AutoCAD, but I need it to work on LT. My question: Is there a way where AutoCad LT to copy something into the clipboard? (defun C:PrintMe (/ ss en ent data dwgno dwgstatus dwgrevision dwgtitle Dwg_No Dwg_Status Dwg_Rev Dwg_Name final fPath fPtr curTag curVal titleblockname _TitleCase) ;; Helper Function: Convert string to Title Case (e.g. "GROUND FLOOR" -> "Ground Floor") (defun _TitleCase (str / res cap next) (setq str (strcase str t) ; lowercase whole string res "" cap t) ; flag for first letter (repeat (strlen str) (setq next (substr str 1 1) str (substr str 2)) (if (= next " ") (setq res (strcat res next) cap t) (if cap (setq res (strcat res (strcase next)) cap nil) (setq res (strcat res next)) ) ) ) res ) ;; 1. Configuration (setq titleblockname "LE Titleblock Information `@A1") (setq dwgno "DRAWING_NO.") (setq dwgstatus "VIS_TEXT") (setq dwgrevision "REV") (setq dwgtitle "DRAWING_TITLE") ;; 2. Selection Logic (setq ss (ssget "_I" (list '(0 . "INSERT") (cons 2 titleblockname)))) (if ss (setq en (ssname ss 0)) (setq en (car (entsel "\nSelect the Title Block: "))) ) (if en (progn (princ "\nProcessing Plot Name...") (command "_.UPDATEFIELD" en "") (setq ent (entnext en)) ;; 3. Loop through attributes (while (and ent (/= (cdr (assoc 0 (entget ent))) "SEQEND")) (setq data (entget ent)) (setq curTag (strcase (cdr (assoc 2 data)))) (setq curVal (cdr (assoc 1 data))) (cond ((= curTag (strcase dwgno)) (setq Dwg_No curVal)) ((= curTag (strcase dwgstatus)) (setq Dwg_Status curVal)) ((= curTag (strcase dwgrevision)) (setq Dwg_Rev curVal)) ((= curTag (strcase dwgtitle)) (setq Dwg_Name curVal)) ) (setq ent (entnext ent)) ) ;; 4. Construct Final String (if (and Dwg_No (/= Dwg_No "")) (progn ;; Extract first 2 chars of Visibility (if (and Dwg_Status (/= Dwg_Status "")) (setq Dwg_Status (substr Dwg_Status 1 2)) (setq Dwg_Status "XX") ) ;; Handle Revision default (if (or (not Dwg_Rev) (= Dwg_Rev "")) (setq Dwg_Rev "00")) ;; Apply Title Case to Dwg_Name (if (or (not Dwg_Name) (= Dwg_Name "")) (setq Dwg_Name "Untitled") (setq Dwg_Name (_TitleCase Dwg_Name)) ) ;; Combine string (using your "_" separator for the title) (setq final (strcat Dwg_No "-" Dwg_Status "-" Dwg_Rev "_" Dwg_Name)) ;; 5. Send to Clipboard (setq fPath (strcat (getvar "TEMPPREFIX") "clip_tmp.txt")) (setq fPtr (open fPath "w")) (princ final fPtr) (close fPtr) (command "_.SHELL" (strcat "clip < \"" fPath "\"")) (princ (strcat "\nSuccess! '" final "' copied to clipboard.")) (princ "\n") ;; 6. Launch Plot Command (initdia) (command "_.PLOT") ) (princ "\nError: Drawing Number (DRAWING_NO.) is empty.") ) ) (princ "\nError: No valid Title Block selected.") ) (princ) ) ;; Activation command: PRINTME
  5. SLW210
    Running DCL directly
    The more recent poster is having an issue running the LISP. Which is here... (defun RlxPreviewDcl_MainDialogActions () (action_tile "bt_dcl_source_folder" "(RlxPreviewDcl_SelectDclSourceFolder)") (action_tile "eb_dcl_source_folder" "(RlxPreviewDcl_CheckManualInputSourceFolder $value)") ;<============== (action_tile "lb_dcl_filenames" "(RlxPreviewDcl_SelectDclSourceFile $value )") ;(action_tile "lb_dcl_dialognames" "(setq dialog-name (nth (atoi $value) dcl-dialognames))") (action_tile "lb_dcl_dialognames" "(RlxPreviewDcl_SelectDialogName (nth (atoi $value) dcl-dialognames))") (action_tile "accept" "(done_dialog 1)")) I ran one I had already (it seems slightly different) and also ran the one above by @rlx, it ran fine for me on several DCLs.
  6. Akash_SAK
    what if ? In our setup, we have access only to the .pgp (Program Parameters) file and do not have permission to load or execute AutoLISP (.lsp) files. As you may be aware, .pgp files are limited to defining command aliases only and cannot execute command logic, options or automation. For reference, below is the AutoLISP command we are currently using in standard AutoCAD: (Defun C:QD () (Command "LENGTHEN" "DELTA" pause) ) This LISP command: Launches the LENGTHEN command Automatically selects the DELTA option Pauses for user input However, when restricted to .pgp files, the closest possible format is only an alias, such as: D, *DIMLINEAR (example only) Unfortunately, .pgp files cannot replicate AutoLISP behavior, meaning they cannot pass command options (e.g., DELTA) and cannot include pauses or logic and can only map a shortcut to an existing command. As a result, the above LISP logic cannot be converted or replicated using .pgp alone. The only feasible workaround in a .pgp-only environment is to map a shortcut directly to the base command (e.g., LENGTHEN), after which options must be entered manually by the user. I wanted to highlight this limitation so expectations can be aligned accordingly. Please let me know if macro-based solutions (CUI macros) or additional permissions can be considered within the OEM environment. Thanks in advance for the understanding and support.
  7. Yesterday
  8. BIGAL
    Not sure what your after, you can preview/display the dcl but it has no interaction. A lisp looks at what happens with "Action" of the Keys. Can you explain more what it is your trying to achieve.
  9. marko_ribar
    I've finished with "lw_orth.lsp"... Take it, or leave it... It's up to you OP... I've found some lacks in latest updates - in 3d with ucs aligned in 3d with lwpolylines (grread-mult) versions produced unwanted behaviour... Hopefully now fixed... Also, added (vl-cmdf "_.undo" "_m") as first line at each command function, so upon finished execution, you can just use UNDO (Back) to return before running command... There was 5 downloads till I reattached fixed version... Sorry for inconvenience - it happens from time to time... Regards, M.R. lw_orth.lsp orthogonalize_lwpolyline-ucs3D.dwg
  10. SLW210
    Dynamic Panel with array rivet holes problem.
    Are you using AutoCAD LT? You posted in the AutoCAD LT Forum, but your profile shows AutoCAD 2026 (which is full AutoCAD).
  11. SLW210
    Are you sure you copied it correctly? Runs just fine on my AutoCAD 2026.
  12. Last week
  13. PS I forgot one detail: the resulting route won't emulate the curves, if there are any. It will simply draw straight segments.
  14. Steven P
    Converting menues
    A little tip - when you find setting like these that sets CAD to how you like it, put them into a LISP (setvar 'menubar 1) for example - mine is saved something like CADSettings.LSP... so that when it is upgrade time there is half a chance of a quick fix to make thing 'correct' - or spend a day trying to remember what you did 2, 5 or 10 years ago. Add comments so you know what each does,
  15. I took a look at your modifications to make the code more robust I have to say that I didn’t think it would be possible to consider the presence of “splines” in the drawing. But I agree with including this filter in the current code. As for the filters for “legacy” POLYLINEs and LWPOLYLINEs, the code wouldn’t need those filters if we accept the premise that only straight distances between points will be measured. BUT: to also cover this possibility, I’ve introduced a new function and made some modifications that allow any “*LINE” to be included in the analysis (including any “POLYLINE” or “SPLINE”). In this way, the filters for the selection set become, once again, much simpler. This also allows the drawing to compute routes using curved linear objects (arcs are excluded for now). Regarding the use of LM:rtos, I consider this optional for cases where small cells are desired, and this may introduce some drawbacks. Moreover, using such small cells significantly harms execution speed. I ran a comparison between the execution speed of your code and this new one I’m attaching, and yours is 3 x slower. Additionally, creating the matrix with your requirements is also quite slow. ;; Pathfinding with the A* algorithm by ymg 22/07/2024 ; ;; ; ;; Revised a prog by HELMUT SCHRÖDER - heschr@gmx.de - 2014-09-14 ; ;; found at Cadtutor.net ; ;; ; ;; Kept the same format for edges list but added lines as valid choice ; ;; Format: (((x1 y1) (x2 y2)) (((x2 y2) (x3 y3))....(xn yn))) ; ;; ; ;; The user is asked to pick a start and an endpoint. ; ;; The program will find the shortest path in a network of connected ; ;; polylines and/or lines and draw a new polyline representing the result. ; ;; ; ;; Two lists of nodes openlst and closelst are created from the above ; ;; mentionned edges list. The format of a node list is: ; ;; (((Point) (Prev Point) Cumulated_Distance Estimated_Total_Distance)...) ; ;; ; ;; Main change from origina are: ; ;; - cons the list instead of append ; ;; - vl-sort the openlist instead of the quicksort ; ;; - Replaced and renamed some vars and subroutine. ; ;; - Added fuzz 1e-4 to all points comparison ; ;; - Change the get_path function ; ;; - Added line as possible edges ; ;; - Added an error handler ; ;; - Added a timer to the search portion of the program ; ;; ; ;; The above changes amounted to an acceleration of about 4x from the ; ;; original program. ; ;; : ;; If you compile this program to a .fas you'll get more than 10x faster. ; ;; ; ;| Added or revised code by GLAVCVS (january 2026) -All set are grouped into one -An associative sparse matrix cell->handles is created for faster cell querying (using new 'addToDict' and 'getCell' functions) -The "edges" list is replaced with the local search retourned by 'getCell' T E S T S ===== fas: 4-5 x faster than previous fas lsp: 7-8 x faster than previous lsp (february 8, 2026): -Added new function '·dist·' for measuring distances of curved segments -Added a new lightweight function 'glvFix' to prevent possible rounding mismatches -Several modifications to include in filters and matrix the necessary compatibility with curved linear objects |; (defun c:A** (/ *error* addToDict getCell upd_openlst in_openlst get_path memberfuzz mk_lwp f3Dpol LM:rtos set_errhandler sspl i startp endp e openlst closelst found acdoc lstClvs Pathlay Pathcol Pathlwt varl node ti ·dist· glvFix ) (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com)) (defun *error* (msg) (if e (if command-s (command-s "_.draworder" e "" "_f") (vl-cmdf "_.draworder" e "" "_f") ) ) (mapcar (function eval) varl) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))) (princ (strcat "\nError: " msg)) ) (vla-endundomark acdoc) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;ADDED by GLAVCVS ;;;Create dictionary (defun addToDict (en / p val id clv i l c a) (setq i -1 id (cdr (assoc 5 (setq l (entget en)))) c (= (cdr (assoc 0 l)) "LINE") a 10) (while (setq p (if (and (setq i (1+ i)) c) (cdr (assoc (+ a i) l)) (vlax-curve-getPointAtParam en i))) (if (setq val (assoc (setq clv (strcat (itoa (glvFix (car p) 0.0001)) "," (itoa (glvFix (cadr p) 0.0001)) "," (itoa (glvFix (caddr p) 0.0001)))) lstClvs)) ;(setq val (assoc (setq clv (strcat (LM:rtos (car p) 2 4) "," (LM:rtos (cadr p) 2 4) "," (LM:rtos (caddr p) 2 4))) lstClvs)) (setq lstClvs (subst (append val (list (cons id i))) val lstClvs)) (setq lstClvs (cons (list clv (cons id i)) lstClvs)) ) ) ) (defun ·dist· (l? e p1 p2) (if l? (vlax-curve-getEndParam e) (abs (- (vlax-curve-getDistAtParam e p1) (vlax-curve-getDistAtParam e p2))))) ;;;return list cell ;;*** Modified to access the new dictionary format *** (defun getCell (pt / val clv lr pr par l c oc p0 p) (defun oc (c e i) (if c (cdr (assoc (+ i 10) l)) (vlax-curve-getPointAtParam e i))) (if (setq val (assoc (setq clv (strcat (itoa (glvFix (car pt) 0.0001)) "," (itoa (glvFix (cadr pt) 0.0001)) "," (itoa (glvFix (caddr pt) 0.0001)))) lstClvs)) (foreach par (cdr val) (setq e (handent (car par)) c (= (cdr (assoc 0 (setq l (entget e)))) "LINE")) (if (zerop (setq pr (cdr par))) (setq lr (cons (list c e pr (1+ pr)) lr)) (setq lr (cons (list c e (1- pr) pr) lr) lr (if (vlax-curve-getPointAtParam e (1+ pr)) (cons (list c e pr (1+ pr)) lr) lr) ) ) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ; ;; upd_openlst ; ;; ; ;; Each node of the openlst is passed to this sub and we scan the edges list ; ;; to find the corresponding edges. Then both points of the edges are tested ; ;; for equality to the nodes. The fixed cost (distance) is updated and so is ; ;; the estimated total distance. Updates are first put in a temporary node. ; ;; ; ;; We then proceed to test if the temp variable is already in the closelst ; ;; and proceed to the next edge. ; ;; ; ;; If temp is true and temp is not in closelst we go to the recursive sub ; ;; in_openlst which adjust the values and return the updated openlst ; ;; ; ;; Upon return we sort the openlst on smallest estimated distance ; ;; and return the openlst to the main routine ; ;; ; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun upd_openlst (node endp openlst closelst / lEdges pt fcost p1 p2 d l? temp) (setq pt (car node) fcost (caddr node) ) (setq lEdges (getCell pt)) (foreach edge lEdges (setq l? (car edge);new e (cadr edge);new pr1 (caddr edge);new pr2 (cadddr edge);new p1 (vlax-curve-getPointAtParam e pr1);new p2 (if l? (vlax-curve-getEndPoint e) (vlax-curve-getPointAtParam e pr2));new d (·dist· l? e pr1 pr2);new temp nil ) (cond ((equal pt p1 1e-4) (setq temp (list p2 p1 (+ fcost d) (+ fcost d (distance p2 endp)))) ) ((equal pt p2 1e-4) (setq temp (list p1 p2 (+ fcost d) (+ fcost d (distance p1 endp)))) ) ) (if (and temp (not (memberfuzz (car temp) closelst))) (setq openlst (in_openlst temp openlst)) ) ) (vl-sort openlst (function (lambda (a b) (< (cadddr a) (cadddr b))))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun in_openlst (node lst) (cond ((not lst) (list node)) ((equal (car node) (caar lst) 1e-4) (if (< (cadddr node) (cadddr (car lst))) (cons node (cdr lst)) lst ) ) (t (cons (car lst) (in_openlst node (cdr lst)))) ) ) ;; ; ;; get_path ; ;; ; ;; Returns The list of points of shortest path found from closelst. ; ;; ; (defun get_path (lst / path) (setq path (list (caar lst)) prev (cadar lst) lst (cdr lst) ) (while (setq lst (memberfuzz prev lst)) (setq prev (cadar lst) path (cons (caar lst) path) ) ) path ) ;; ; ;; memberfuzz by Gile Chanteau ; ;; ; ;; Modified to work with nodes list ; ;; ; (defun memberfuzz (p lst) (while (and lst (not (equal p (caar lst) 1e-4))) (setq lst (cdr lst)) ) lst ) ;; ; ;; f3Dpol ; ;; ; ;; Draw an 3dpolyline given a point list ; ;; ; ;; Will be drawn on layer, lineweight and color defined by Variables ; ;; at beginning of program. ; ;; ; ;;;ADDED by GLAVCVS (defun f3Dpol (pts c / ep ll la e) (setq ep (if (= 1 (getvar (quote cvport))) (vla-get-PaperSpace acdoc) (vla-get-ModelSpace acdoc)) ll (apply (function append) pts) la (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length ll)))) (mapcar (function float) ll)) e (vla-Add3DPoly ep la) ) (vla-put-Color e c) (vla-put-Layer e Pathlay) (vla-put-Lineweight e Pathlwt) (vlax-vla-object->ename e) ) ;; ; ;; mk_lwp ; ;; ; ;; Draw an lwpolyline given a point list ; ;; ; ;; Will be drawn on layer with color and lineweight defined by Variables ; ;; at beginnung of program. ; ;; ; (defun mk_lwp (pl) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 8 Pathlay) (cons 62 Pathcol) (cons 90 (length pl)) (cons 70 (* 128 (getvar (quote plinegen)))) (cons 370 Pathlwt) ) (mapcar (function (lambda (a) (cons 10 a))) pl) ) ) ) (defun glvFix (r i / f f1) (if (= (setq f (fix r)) (setq f1 (fix (+ r i)))) f f1)) ;; A wrapper for the rtos function to negate the effect of DIMZIN - Lee Mac (defun LM:rtos (real units prec / dimzin result) (setq dimzin (getvar (quote dimzin))) (setvar (quote dimzin) 0) (setq result (vl-catch-all-apply (function rtos) (list real units prec))) (setvar (quote dimzin) dimzin) (if (not (vl-catch-all-error-p result)) result ) ) ;; Error Handler by Elpanov Evgenyi ; (defun set_errhandler (l) (setq varl (mapcar (function (lambda (a) (list (quote setvar) a (getvar a)))) l)) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; MAIN ROUTINE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; Change values of following 3 variables to suit your need. ; (setq Pathlay "0" Pathcol 3 ; 1=Red 2=Yellow 3=Green etc. ; Pathlwt 30 ; lineweight for path 0.3 mm ; ) (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))) (set_errhandler (list "clayer" "osmode" "cmdecho")) (setvar (quote cmdecho) 0) (setvar (quote osmode) 1) (setvar (quote lwdisplay) 1) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (prompt "\nSelect LINE and polygonal POLYLINE network entities...") (if (setq sspl (ssget '((0 . "*LINE")))) (foreach en (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex sspl))) (addToDict en) ) ) (initget 1) (setq startp (getpoint "\nPick or specify Start Point : ")) (initget 1) (setq endp (getpoint "\nPick or specify End Point : ")) (setq openlst (list (list startp (list 0.0 0.0 0.0) 0.0 (distance startp endp)))) (vla-startundomark acdoc) (setq ti (getvar (quote millisecs))) (while (and openlst (not found)) (setq node (car openlst)) (if (equal (car node) endp 1e-4) (setq found t closelst (cons node closelst)) (setq closelst (cons node closelst) openlst (upd_openlst node endp (cdr openlst) closelst)) ) ) (if found (if (vl-some (function (lambda (x) (not (equal (last x) 0.0 1e-4)))) (setq path (get_path closelst))) (setq e (f3Dpol path Pathcol)) (setq e (mk_lwp path)) ) (alert "No path was found...") ) (princ (strcat "\nExecution time : " (itoa (- (getvar (quote millisecs)) ti)) " milliseconds...")) (*error* nil) ) In any case, I haven’t tested the code thoroughly enough on drawings containing “splines” or other complex linear objects. In addition, there may be some situations that may not be covered. But it should work. In any case, the code is open to any improvements anyone may want to make. Best regards.
  16. foer
    no function definition: RLXPREVIEWDCL_CHECKMANUALINPUTSOURCEFOLDER
  17. BIGAL
    Another way around the task is to use a lisp to do all the calculations and the object from 1st principles. ie not a Dynamic block. Something like this. You could have a first dcl with images so choose shape, then 2nd dcl pops up with the enter values. Let me know if you want something, post a sample dwg for layers etc.
  18. Good day all, I have a dynamic block that I use to stretch to the right size for fabrication of panels. I am trying to get the block to automatically add holes as the panel is stretched. The holes need to be spaced equally at maximum 16" o.c. I have set up all my formulas, etc. and in Block editor it looks good. The array is showing properly, etc. The problem is that when I stretch the panel, the holes and formulas do not automatically update. In fact when I stretch the panel, the Constraint dimension that I use for my calculations does not stretch with the panel. It moves the entire constraint dimension. Therefore my formulas are not updating and the array is not working as required. I have tried numerous attempts to get this dclinear dimensions to stretch with the panel to no avail. Maybe there is another way to do this? Ideally when i stretch the panel, the holes should update as per my formulas. Link to AutoCAD Forum with pictures. https://forums.autodesk.com/t5/announcements-and-meet-greet/dynamic-block-with-array-of-rivet-holes-problem/td-p/14007890 Any help is appreciated.
  19. marko_ribar
    I've added (c:lw_orth-2) and (c:lw_orth-grread-2), but IMHO, version 1 is better... Here is link... Regards, M.R.
  20. CyberAngel
    custom part builder
    If I'm looking at the same subsystem, when you edit a part drawing, the Toolspace includes Model Parameters (under Modeling) and Size Parameters (under the part). When you right click on a part in the Size Parameters, you get an "Edit..." option. That opens an "Edit Part Sizes" window, which is a table. Pull down the box on the toolbar (the default is Values) and pick Parameter Configuration instead. That gives you a different table with more rows. One of those rows is Units. Check the units for your part and see if they match your drawing. If that doesn't take care of your issue, please give us more information.
  21. I use the dimensions in the drawing in mm. I need a copy of the dimensional text in m for further calculations. Therefore, the @ronjonp code is quite suitable for me.
  22. You are most welcome.
  23. Converting mm dimension to m? My preference would be to leave the dimension to measure properly and adjust the scale in the properties to 0.001, then you can just copy the text and everything is consistent.
  24. thank you tharwat
  25. BIGAL
    Converting menues
    Yep same for if you do or dont like the Ribbon. Ribbonclose and Ribbon.
  26. john madsen
    Converting menues
    MENUBAR = 1
  27. The path found has to travel on edges not on points. If your graph does not have edges on the diagonal of the nodes it cannot find that path. ymg
  28. I must apologize for forgetting to reply to your comment. Please forgive me for this. Welcome to the forum. Yes, that's right. In the case of that drawing, the code doesn't return the shortest path. Perhaps it's a limitation of A* for drawings like this. I think @ymg3 is the most qualified to answer this.
  29. Douaa
    custom part builder
    when i design a custom manhole in part builder , i have a problem that when i do swap part to place the new manhole that i created instead of an old one in my network (my model), the new manhole seems quite big its even bigger than my model so what do you think i should do ? my manhole is in mm and all the part in my system is in mm but when i measure it in the system its in m .
