  1. Today
  2. Sorry guys for the late reply. @devitgHere is an example of the drawing processed by the code I've been trying to work on for a while now. But it can only handle 2-Description at a time, either a combination of two different lines or a line and block combo. Let say, “L1E/L2S” or “L1S/BP” which is a point block and can no longer TRIGGER to read 3-Description csv line like “L1E/L2S/BP”, this kind of description can only plot the “BP”, it will not plot the "L1" lines calling “L1E” (the trigger) to plot L1 Group then start collection of L2 point groups. But upon checking the group list say for L1, the points are there inside that list but cannot trigger to plot the L1 group of points into lines since BP is already called in the first condition of the code. This is the reason I want to change the point collection list into groups and process the line list groups after reading all the lines in the csv. @BIGAL, thank you for your response. I also work in Civil 3D to process these kinds of data. The only problem is that you need to export it in plain AutoCAD format to arrange all the annotation etc., cause COGO are not easy to handle. Say aligning the annotation for block points to be aligned to lines or move it into desired location. Line1 and 2 Group List.dwg
  3. Not sure about ZWCAD, but AutoCAD 2025 and newer now needs... (acet-load-expresstools) Do you have a link to specific LISP instructions for ZWCAD? Is there a LOFTNORMALS in ZWCAD?
  4. Thanks for this. How can the large size array be used ? does it need to be passed to a function ?
  5. Ok that is what you get in field survey using Total stations, GPS etc so you want to string the description. Yes I have something, working on it for Bricscad. I have spent over 45+ years doing civil work, so can see what you want, the simple answer is CIV3D or Civil Site Design or Carlson, etc that is civil software, When reading a points file it will string the points via a description, add blocks matching descriptions and more. I am working on the add blocks and line work on correct layer. Your csv processed. Happy to discuss further. But I don't intend to reinvent the wheel to much.
  6. I still think its easier to copy/array the dynamic block just setting the correct visibility state so that would be 2 3 4 5 6 only. No working out the dynamic pattern. Angle is not a problem. This is all your sizes up to length of 50 the pattern is length, how many 6s 5s 4s 3s 2s could do way more you can also change the way a length is made example 10 is 2x5 or a 6+4 ((51 8 0 0 1 0) (50 8 0 0 0 1) (49 7 1 0 0 1) (48 8 0 0 0 0) (47 7 1 0 0 0) (46 7 0 1 0 0) (45 7 0 0 1 0) (44 7 0 0 0 1) (43 6 1 0 0 1) (42 7 0 0 0 0) (41 6 1 0 0 0) (40 6 0 1 0 0) (39 6 0 0 1 0) (38 6 0 0 0 1) (37 5 1 0 0 1) (36 6 0 0 0 0) (35 5 1 0 0 0) (34 5 0 1 0 0) (33 5 0 0 1 0) (32 5 0 0 0 1) (31 4 1 0 0 1) (30 5 0 0 0 0) (29 4 1 0 0 0) (28 4 0 1 0 0) (27 4 0 0 1 0) (26 4 0 0 0 1) (25 3 1 0 0 1) (24 4 0 0 0 0) (23 3 1 0 0 0) (22 3 0 1 0 0) (21 3 0 0 1 0) (20 3 0 0 0 1) (19 2 1 0 0 1) (18 3 0 0 0 0) (17 2 1 0 0 0) (16 2 0 1 0 0) (15 2 0 0 1 0) (14 2 0 0 0 1) (13 1 1 0 0 1) (12 2 0 0 0 0) (11 1 1 0 0 0) (10 1 0 1 0 0) (9 1 0 0 1 0) (8 1 0 0 0 1) (7 0 1 0 0 1) (6 1 0 0 0 0) (5 0 1 0 0 0) (4 0 0 1 0 0) (3 0 0 0 1 0) (2 0 0 0 0 1))
  7. Yesterday
  8. @GLORY Please upload a sample.dwg as you need it to be, at least 2 lines
  9. Hello Everyone, I need some help; here is my list in csv 1,21.188,19.762,0.000,L1S 2,31.804,7.629,0.000,L2S 3,44.106,18.077,0.000,L2 4,32.984,30.378,0.000,L1 5,45.117,40.995,0.000,L1 6,56.239,26.671,0.000,L2 7,68.878,36.782,0.000,L2E 8,57.587,50.937,0.000,L1E 9,49.168,65.549,0.000,L1S 10,43.612,72.164,0.000,L1 11,50.491,77.059,0.000,L1 12,55.253,70.179,0.000,L1C 13,41.363,59.993,0.000,L2S 14,34.616,68.460,0.000,L2 15,27.472,64.094,0.000,L2 16,33.954,55.495,0.000,L2C And I want to make that list into something like this, (setq pt (list (nth 1 ln) (nth 2 ln) (nth 3 ln))) (setq mylist '( (("L1S" (list pt)) ("L1" (list pt))...("L1E" (list pt))) (("L2S" (list pt)) ("L2" (list pt))...("L2E" (list pt))) (("L1S" (list pt)) ("L1" (list pt))...("L1C" (list pt))) (("L2S" (list pt)) ("L2" (list pt))...("L2C" (list pt))) ) ) In order to plot the lines into groups by creating another set of group of points if the description has "S" or start at the end, say L1S for Line 1 Start. Thank you in advance.Line1 and 2 Group List.csv
  10. The geometric center (a.k.a. centroid) of an open polyline is deteremined by summing the length of each line segment times the coordinates of the midpoint of the respective segment. The result is then divided by the total length of the polyline. It is NOT the average of the point locations. ; Calculates the centroid for an open lwpolyline ; lrm 8/9/2025 (defun c:pl_centroid (/ ss pt_lst sum_x sum_y sum_d n i d mid_pt centroid) (setq ss (entget (car (Entsel "\nSelect Open Polyline"))) pt_lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) ss) ) ) (setq sum_x 0 sum_y 0 sum_d 0.0 n (length pt_lst) i 0 ) (while (<= i (- n 2)) (setq d (distance (nth i pt_lst) (nth (+ i 1) pt_lst))) (setq mid_pt (mapcar '/ (mapcar '+ (nth i pt_lst) (nth (+ i 1) pt_lst)) '(2 2 2) ) ) (setq sum_x (+ sum_x (* (car mid_pt) d)) sum_y (+ sum_y (* (cadr mid_pt) d)) sum_d (+ d sum_d) i (+ i 1) ) ) (setq centroid (list (/ sum_x sum_d) (/ sum_y sum_d) ) ) (princ "\n Centroid at: ") (princ centroid) (command "_point" "_non" centroid) (princ) )
  11. Steven P
    SELECT TEXTS OTHER THAN 3.5..HELP
    To enter the value into your selection set see below. In LISP the '( ... ) lists mean it is a static list, it is read exactly as it is written, (list ... ) means that CAD will create the list if for example variables are a part of the list, and (cons ... ), also used to create a list - in this case relevant to create a dotted pair. (setq MyThing 5) '(1 2 3 4 MyThing) is read as 1 2 3 4 MyThing - and an error since it is looking for MyThing to be a string, "MyThing" (list 1 2 3 4 MyThing) is read as 1 2 3 4 5 - list has been created by the LISP (cons 1 MyThing) is read as (1 . 5) So this might help... As above though you select the text with the selection set ss, but haven't done anything with it - if you are a part way through the LISP that is all good, but just put a report in so you can see it is working as it should as you go along perhaps (sslength SS) maybe. (Oh, just me, I also amended the indents, and added where commands end if over a few lines, I find it easier to read LISPs as below, that's all) (defun c:test (/ old_err EscVP StrScale2 TxtHt StrScale ss) (setq old_err *error*) (defun *error* ( a / ) ;; Add here return cmdecho to as it was, cmdecho 1 (princ "") (setq *error* old_err) (princ) ) ; End Error Defun (setvar "cmdecho" 0) ; perhaps record the state of cmdecho before here, and reset to that value at the end (if (and (setq EntVP (car (entsel "\Seleccione VIEWPORT: "))) (= (cdr (assoc 0 (entget EntVP))) "VIEWPORT") ) ; end and (progn (setq EscVP (vla-get-CustomScale (vlax-ename->vla-object EntVP))) (setq StrScale2 (rtos (* 3.5 (/ 1 EscVP)) 2 1)) (setq TxtHt (* 3.5 (/ 1 EscVP)) ) ; a number not a string ;; added this (setq StrScale (rtos (/ 1 EscVP) 2 2)) (setq vpnum (cdr (assoc 69 (entget EntVP )))) (vl-cmdf "_.mspace") (setvar "CVPORT" vpnum) (setq ss (ssget (list(0 . "TEXT") (-4 . "<>") (cons 40 TxtHt))) ) ;;What are you doing with ss now? (Prompt (strcat "\nLa escala de La Ventana es 1/" StrScale)) (princ "\nLos textos de 3.5 en el interior de la ventana deben ser de: ") (princ StrScale2) ) ; end progn ) ; end if (setvar "cmdecho" 1) (princ) );fin defun
  12. GLAVCVS
    Hi I think it would be easier to find the problem if you attached an example drawing.
  13. Last week
  14. BIGAL
    Table of contents
    If your making layouts then do that then go into mspace pick the page details than pop back to pspace and fill in your title block not that hard. Yes a lisp. One of the things I have looked at is pick a point on dwg in Model space, select scale, select title block and make the layout. You could add pick the mtext for title block also. It will cost you a cup of coffee as have to hard code the title block details etc.
  15. Not quite the middle of say 2 points. The red is the average answer. The green is gcen. so 4 answers. If the shape is say 4 points then you could force a close get the Gcen then do a undo.
  16. leonucadomi
    thanks, now I explain In the modelspace I have texts of different height in paperspace in the paperspace I have viewports of different scales If I use the chspace command and take those texts to paper space they should be 3.5 height I'm looking for a routine that helps me detect which texts do not meet that height in each viewport (defun c:test (/ EscVP StrScale2 StrScale) (setq old_err *error*)(defun *error* ( a / )(princ "") (setq *error* old_err)(princ)) (setvar "cmdecho" 0) (if (and (setq EntVP (car (entsel "\Seleccione VIEWPORT: "))) (= (cdr (assoc 0 (entget EntVP))) "VIEWPORT")) (progn (setq EscVP (vla-get-CustomScale (vlax-ename->vla-object EntVP))) (setq StrScale2 (rtos (* 3.5 (/ 1 EscVP)) 2 1)) (setq StrScale (rtos (/ 1 EscVP) 2 2) ) (setq vpnum (cdr (assoc 69 (entget EntVP ) ) ) ) (vl-cmdf "_.mspace") (setvar "CVPORT" vpnum) (setq ss (ssget '((0 . "TEXT") (-4 . "<>") (40 . 3.5))) ) (Prompt (strcat "\nLa escala de La Ventana es 1/" StrScale)) (princ "\nLos textos de 3.5 en el interior de la ventana deben ser de: ") (princ StrScale2) ) ) (setvar "cmdecho" 1) (princ) );fin defun I am looking to enter this calculated value here but it doesn't work
  17. Steven P
    This (ssget '((0 . "TEXT") (-4 . "<>") (40 . 3.5))) should work. You can change "TEXT" to "*TEXT" to also capture MText Though looking at the code you have, I am assuming that is just a snippet of what you want to do. Here are a couple of hints: (defun c:pru ( / ss ) ;;Yup localised variables, C: prompt, all good (setq ss (ssget '((0 . "TEXT") (-4 . "<>") (40 . 3.5))) ) ;; ADDED (SETQ SS ... ) so that you can use the selection set later (princ (sslength ss)) ;; Added this in to show the result of the selection set (princ) ;;Exit quietly )
  18. leonucadomi
    (defun c:pru2 ( / ss alturaColor colorNuevo) (setq alturaColor 3.5) ; Define la altura a verificar (setq colorNuevo 1) ; Define el color a aplicar (ej. rojo) (setq ss (ssget "X" '((0 . "TEXT,MTEXT")))) ; Selecciona todos los textos (if ss (progn (setq i 0) (while (setq en (ssname ss i)) (setq obj (vlax-ename->vla-object en)) (if (/= (vla-get-height obj) alturaColor) (vlax-put-property obj 'color colorNuevo) ; Cambia el color ) (setq i (1+ i)) ) ) ) (princ) ) This routine does what I need, but it has a problem that I cannot understand, I have objects in the paperspace that have a height of 3.5 and it recognizes them as if they did not have it and changes them to red. can someone help? thanks
  19. LI & LU Layer isolate and Layer unisolate are extremely helpful, I concur. I also favor "all off" rather than "Fade". I am quite partial to the LAYERS 2 toolbar also.
  20. Strydaris
    Table of contents
    @SLW210 Thanks. I will take a look at that. @BIGAL Thanks for the code. We stopped using sheet titles on our titleblocks. Sometimes we would end up having too many drawings on a single page and there wouldnt be enough room for it all on titleblock. We removed it and opted for a Table of Contents with all the labels. And yes we do primarily work in modelspace but all our current titleblocks are located in Paperspace. The drawing titles are located below the drawings in model space. Our table of contents is in modelspace as well. Our model space typically looks like this. Where as our Titleblock version of that looks like this ( the red blob is our company info blanked out)... The fields in the titleblock are linked to dwgprops for easy updating. Page # on the bottom right is a diesel expression that pulls the layout name. Anyways, the only method I can think about doing this is to select each drawing title in model space and have the lisp auto number the pages and organize in a table or formatted MTEXT.
  21. leonucadomi
    I ALREADY TRIED IT AND IT SELECTED THEM ALL FOR ME, I DON'T KNOW WHAT HAPPENS My purpose is to detect all texts that do not have a desired height, in this case 3.5
  22. Hi, I use ZWCAD and the Express is loaded I try what GP_ and enthralled said to solve the problem but get this error Command: CPL Error: ZWCAD setvar reject: LOFTNORMALS 0 Any ideas? Thanks
  23. SLW210
    Need better multiline
    At home I have some file compare programs, Notepad++ with the Compare plug-in as well. IIRC, there are some online as well, WinMerge I think is one of my programs, I use AntiTwin to find duplicate files, it may have a compare function. So while everyone is doing there jobs, if YOU have the time, you might could compare the file and see what all is different. At least that will be a start, maybe I can talk IT into putting one of those programs on my work computer. I used to have a program from CabloFil, not sure if they still have anything for doing cable trays in AutoCAD. Here it is... Cable Management 3D Modeling Tools | Legrand I haven't done a cable tray in ages, so not sure what all it does.
  24. You can actually calculate it, here is the code (you can change it for your purposes): (setq ptlist (mapcar 'cdr (vl-remove-if-not (function (lambda (x) (= (car x) 10))) (setq ent (entget (car (entsel "\nSelect the line:")))))) ;; point list sum_x 0 sum_y 0 vertices (cdr (assoc 90 ent)) ;; number of vertices for LWPOLYLINE ) (foreach pt ptlist (setq sum_x (+ sum_x (car pt))) ;; sum only the X vertices values ) (foreach pt ptlist (setq sum_y (+ sum_y (cadr pt))) ;; sum only the Y vertices values ) (setq sum_x (/ sum_x vertices) ;; dividing the total sum X by the number of vertices sum_y (/ sum_y vertices) ;; dividing the total sum Y by the number of vertices pt (list sum_x sum_y) ;; geometric center ) Below are the pictures with geometric center for open and closed polyline (picture 1 open, picture 2 closed). Picture 1. Picture 2. This is true. Best regards.
  25. Only the geometric center is available for closed areas, since open polylines have no area and therefore no true center. If it’s just a line, the "geometric center” is the midpoint.
  26. Steven P
    Generally were busy people this week - if you open the LISP in a text editor, search for the line that asks for the new width - problem will be sometime after that - but will narrow down the issue a bit and give a less daunting task
  27. (setq gct (osnap (vlax-curve-getStartPoint bm) "gcen")) The above code line gives only closed polyline How to find the geometric center of an open polyline and a single line
  28. DATVO
    Try this: ;; Modified by DV. Visit my page at: https://lispautocad.gumroad.com/ (defun c:PRU (/ ss) (if (setq ss (ssget '((0 . "TEXT,MTEXT") (-4 . "<>") (40 . 3.5)))) (progn (sssetfirst nil ss) (princ (strcat "\nSelecting: " (itoa (sslength ss)) " objects.")) ) (princ "\nNo Object.") ) (princ) )
