  2. SANDIP PAITAL
    Associative Textbox (Lee Mac)
    Dear Sir, one request AssociativeTextboxV1-3 programming two modification required , Select Text or Mtext (Option required Select all text (A) or Single text pick) and all text or single text are layer name TBOX.
  3. I have seen a dwg with a complete project inside the current dwg which had nothing to do with the dwg being worked on. Look for $AC.... blocks these can be very extensive in size. You need to insert explode erase then can purge. Do you get a blank screen with Zoom Extents ? This is indicating that something is way out there normally in a corner and can be a complete dwg. The only real way to fix is to look at the dwg, understand company copy right problem but you can PM or email via a PM to people here who will look at the dwg and let you know what they find.
  4. You are right its a bit fudgy but you can read a CSV made by Excel, you would have to count lines as row number, then using say lee-mac parse lisp break the line down into individual values representing cells then use a (nth x excelline) where x is the column number in Excel. Like wise make a csv then open in excel. If LT supports you can use (startapp to open Excel and provide the CSV file path & name so it opens it within your lisp saving a step. oh depending on where you are in the world Excel uses a comma or a semicolon for CSV files.
  5. There is an extensive post about this question its out to 6 pages with various people offering suggestions, I think that GP may have posted there as well. Now where is it
  6. Today
  7. I use ACAD 2012
  8. Discus84
    HARD ORTHO
    I have ortho on, however I can still pull, push and stretch diagonally.. Unless this is how it's supposed to be. What I'm after is being able to only draw and stretch objects at right angles. Thanks!
  9. thanks in advance for any help
  10. Hello everyone. I’ve been exploring profiles of educational leaders recently and am curious about how their diverse experiences shape their approach. One figure who stands out is Grady Gaston, whose career path and achievements seem to reflect a strong commitment to innovation and student success. How do leaders like this balance administrative responsibilities with community engagement and mentoring? What strategies have you seen work best in fostering growth and collaboration within educational institutions? I’d love to hear perspectives on how professional background influences leadership style, especially in contexts similar to those navigated by Grady Gaston.
  11. To test my memory, I opened the default drawing, created a new scale 1:1, and drew a couple of objects and a dimension. I made the dimension annotative and gave it the 1:1 scale. I copied those objects to the clipboard. Then I opened a second new drawing, which had our template settings, including a 1:1 scale. I pasted the objects from the clipboard into the second drawing. You'll never guess what happened. The pasted dimension had a scale of 1:1_1. In other words, that's the type of name AutoCAD gives a duplicate scale when it doesn't want you to rename an arbitrarily large group of settings. Does that shed any light on the issue?
  12. There are some free and paid apps in the Autodesk Appstore that really do a super job. Not sure if they work on AutoCAD 2010 though and OP refuses to respond to my question on what CAD they use.
  13. Doesn't AutoCAD LT have Tables that can Datalink to Excel? AutoCAD LT 2025 Help | About Linking a Table to External Data | Autodesk
  14. I truly hope so. I'm just glad to find out I wasn't crazy looking at these instructions and thinking they don't all make sense. But holding out hope for that day when they make the program better and more clear to understand. I wish you well also
  15. I have never seen a standard scale of 1:1_1. Scale Type Scale Description Imperial Architectural 1/4" = 1'-0" (1:48) Commonly used for floor plans 1/8" = 1'-0" (1:96) Used for detail drawings 1/2" = 1'-0" (1:24) For larger details or sections 1" = 1'-0" (1:12) Used for large scale details 3/4" = 1'-0" (1:16) Used for specific areas 1" = 10' -0" (1:120) For site plans or larger layouts Imperial Engineering 1" = 10' (1:120) Used in civil engineering 1" = 20' (1:240) Site plans and large infrastructure 1" = 30' (1:360) Larger site layouts 1" = 40' (1:480) Used for extensive projects Metric 1:1 Full scale 1:10 For large models 1:20 Common for architectural plans 1:50 Used for detail and construction plans 1:100 Site plans and larger structures 1:200 Used for overview layouts 1:500 For urban planning diagrams 1:1000 For regional planning Can you post an example .dwg with a non-editable scale?
  16. Do you have an example drawing that does this?
  17. That’s a massive block library! It sounds like the real bottleneck is the 'individual setup' for each export. If you're looking for an 'Excel on steroids,' maybe give Power BI a look? It connects directly to Excel files, and once you set up your 'program' for filtering and summing distances, it stays there. You just refresh the data when you get a new export from Nova or CAD. It's much more visual than a standard spreadsheet.
  18. It's causing a plotting issue. The way I work is, model space set to meters and scale is 1:1_1. Paper space is in millimeters. I then set the viewport scale to be whatever I want it to be. I've worked like this since starting using AutoCAD some 25 years ago. Occasionally I get sent a file where this doesn't work and when I look into it, the problem is that for scale 1:1_1 it's set to '1 paper unit = 0.001' drawing unit'. This makes the viewport scale1000 times larger. If I could edit it to be '1 paper unit = 1 drawing unit' it wouldn't be a problem but it won't allow me to edit it. If I'm plotting something at 1:5000 I have to pick the scale 1:5 as a work around.
  19. There probably is a post like this since it is quite a generic theme, but I didn't find it. OK, so I can't write to excel on LT, but I can write to a .csv; all I need to do is write values then retrieve them through Excel, a .csv should be enough for that, right? Anyway thanks a lot BIGAL.
  20. No worries @pavanetc, just need to know everytime that when you need something, you need to make a good explanation, provide an example drawing and be flexible in explanation to others understand the problems whom you meet. Best regards.
  21. Was this posted elsewhere ? Ok first answer you can not use LT2024+ as it does not support the "get application" method. Acad full or Bricscad plus others etc are fine. For LT2025 must use read / write a csv. Happy to provide lots of defuns re Excel to and from but not for LT.
  22. This might be too general for a question, but how can you pass a string to a certain cell in an Excel file? Is there any good tutorial out there that you know about Excel and AutoLISP?
  23. Agree with that @BIGAL . As @SLW210 mentioned and also agree with that, the @pavanetc need to provide more information if he want to get the best results from lisp.
  24. hi engineers! It was amazing!!! great work, I really appreciate everyone in the Lisp community. I was able to relax and forget everything for a while; your code was like a shot of coffee. Thanks to everyone for your time and effort. I’m new to posting topics here, so please forgive me if I made any mistakes. I need to learn lot from yours.....
  25. Buenos días Bigal, esa forma si lo sabia colocándole un guion al final del nombre del fichero de autocad "TOMO_", pero cuando quiero publicar al mismo tiempo en PDF, lo tengo que volver a renombrar sin "-" si no me sale con doble "-" osea TOMO--001.pdf. Siento molestarte, pero muchas gracias.
  26. There are still bugs in the closed polyline version, such as when drawing the centerline of a building's walls, it may fail or the drawn centerline may not achieve the desired effect.
  27. Yesterday
  28. I am like others as suggested dont use a command word, as your wanting to use a defun then why not just call the defun something shorter, like CENTL.You can use AUTOLOAD to load the actual lisp at the first time you type centl. You would put the "Autoload" in say a custom lisp that is loaded on startup, along with your other AUTOLOAD's (autoload "CENTL" '("CENTL")) (autoload "COPY0" '("COPY0")) (autoload "COPYCOMMAND" '("ZZZ")) (autoload "COVER" '("COVER"))
