Haha, fair point BIGAL! "OC" (Oceania) is just the boring geographical zone our cloud provider uses on the dashboard. But rest assured, the actual physical node is sitting right there in Sydney, making sure the Aussies get the absolute lowest latency possible! Cheers, mate! - Today
ArkiJM joined the community
BIGAL replied to CamDuy's topic in AutoLISP, Visual LISP & DCL
@HypnoS if your using title blocks then it is possible to detect the name of the title block and use the correct plot settings, for example a A4 in landscape or portrait mode. Just using say layout extents can return wrong answers as even where I worked there was occasional junk in a layout outside of the title block. -
OC. No we are Aussies ! AUS. -
HypnoS replied to CamDuy's topic in AutoLISP, Visual LISP & DCL
Hi, you've created a very cool tool. I admit I've been looking for something like this for some time. However, I'm wondering if it's possible to print drawings of different dimensions to PDF? For example, I have a .dwg file with drawings measuring 297x1110mm or 594x930mm. The overall dimensions vary. I print them from paper rolls with widths of 297mm, 420mm, 594mm, and 841mm, but the lengths vary. I'd like the program to automatically detect the frame dimensions and adjust the PDF dimensions. Is this possible? -
Testing DWG compatibility with different CAD applications
Danielm103 replied to indiancad's topic in Catch All
I didn’t test lisp, however, I was able to get this to compile on CMS Intellicad, totally impressed https://github.com/CEXT-Dan/ArxTin I only goofed with it for the trial. They don’t have a developers program. -
SLW210 replied to indiancad's topic in Catch All
CMS IntelliCAD is in the same price range, AFAIK, most of the IntelliCAD based CAD software now has an improved LISP, etc. I was looking to give CMS and a few others a try here soon. -
[Quick Annotator] VCID: 7JAU18 @ VedaCAD -
[Gomoku CadCade] VCID: 1G8VY1 @ VedaCAD -
v1.0 Jul 21, 2026 - Initial version released - Pioneer plan launched VedaCAD V1.0.VLX --- Known items to be optimized in V1.0: Auto-filling Asset Name from File Name (Thanks to zaphod's suggestion, we will add this feature in the next version) -
VicoWang started following VedaCAD - Technical Support, Updates & Community VCIDs
Hi everyone, Vico here. As the VedaCAD ecosystem continues to grow, I wanted to create a dedicated, centralized thread to act as our official support and updates hub on the forum. For those new to the project, VedaCAD (vedacad.com) is a modern cloud package manager and environment synchronizer for CAD: The Client: A unified, pure LISP (.vlx) engine that natively manages all your CAD plugins and environment configurations via an isolated local sandbox (Zero-Install, bypassing traditional APPLOAD fragility). The Cloud Ecosystem: Personal Tiers: A frictionless, unlisted distribution network where developers can share tools instantly using 6-character ShareCodes (VCIDs)—no review bottlenecks, what you code is exactly what is delivered. Enterprise Tiers (B2B): A Zero-Trust infrastructure with granular RBAC for internal employee synchronization, and 'Project Arks' for strict sub-contractor drafting standard enforcement. Open Ticket System Please treat this thread as our open ticket system. If you encounter any bugs, have optimization suggestions, or need usage help, drop a reply here. I promise to respond to every single question within 48 hours. Architecture & Data Sovereignty We take performance and data compliance seriously. VedaCAD spans 6 user tiers (BASE, FREE, PRO, TEAM, CORP, and CORP(DED)). To guarantee low latency and strict data residency compliance globally, our backend is deployed across 5 major geographical data centers (ENAM, WNAM, EU, APAC, and OC), powered entirely by Cloudflare's edge network. Version Updates Whenever the VedaCAD client receives a version update, I will post the official Release Notes and changelogs right here in this thread. Share Your Work! Lastly, this space belongs to the community! If you are a developer and have published your plugins on VedaCAD, you are highly encouraged to share them here. Please drop your VCID, a link to your original forum release thread, and a Demo GIF if you have one. Example: [Codebase Packer] VCID: 0FBGZB @ VedaCAD https://www.cadtutor.net/forum/topic/99202-sharing-a-lisp-codebase-packer-thoughts-on-modern-cad-environment-governance/ -
BIGAL replied to indiancad's topic in Catch All
Price is low and if has lisp ability plain and VL then yes is very cheap. Hints at VLX and Fas. Many years ago did a package for Intellicad worked about 99% had to write some bits of lisp in a slightly different way to Acad, but overall was good. -
What are your best practices for working with large DWG files?
As hinted once had a DWG which contained a complete other dwg, as a $ac.... block, it was not inserted so I went looking at what all these $ac.... blocks were and renamed some of them, purged others. So cleaning the dwg is the obvious 1st step. Have seen sample dwg's provide here with like 20 $ac... blocks. It really comes down to management, do you need every XREF loaded to work on a dwg. Are objects duplicated in Xrefs ? Does a Zoom E seem to go to a blank screen which means objects are way, way apart. To many scenarios to narrow down to one particular idea of speeding up a dwg. - Last week
fire protection LISP routine for the distribution of sprinklers and fire detectors in fire protection installations
Tharwat replied to Javier Longa's topic in AutoLISP, Visual LISP & DCL
Here's my Fire Fighting Sprinklers Distribution Program. https://autolispprograms.wordpress.com/fire-fighting-sprinklers-distribution-program/- 13 replies
- 1
Tharwat started following LISP routine for the distribution of sprinklers and fire detectors in fire protection installations
Once again please mention the ActCAD you used for the testing, it also wouldn't hurt to mention what CAD you compared. ActCAD is IntelliCAD based. Looks to be priced very nicely as well. -
Can CAD be an online battle platform? I decided to try it.
The framework of CadCade has been clarified. A connected game is handled by an independent distributed server, which transmits the match results to the main server for scoring and ranking. A separate CadCade game client is created to unify account settings, network matching, game startup, and provide data interfaces to the core. The Gomoku game is made into an independent game algorithm core (a function library, a plugin type without command preloading in VC), which can be expanded to multiple game cores (pure algorithm libraries, communicating with the hall through interfaces) in the future. -
So name the other CAD platforms tested since that would seem relevant and include your thoughts on each if you don't mind. Also, there are three versions of ActCAD, which did you test? If you tested Premium, I would be interested into the import and export of different file types. I did notice the Premium shows the Dassault Systems Spatial logo, so should be using Spatial products for most of that or maybe just ACIS? -
What Is a DWG File? How to Open and View DWG Drawings
What is a DWG file? A DWG file is one of the most common file types you’ll run into when working with CAD drawings. If someone sends you a floor plan, mechanical layout, site plan, or detailed construction drawing, there’s a good chance it may arrive as a .dwg. Quick answer: A DWG file is a CAD drawing file used to store design data for 2D drawings and 3D models. It can include geometry, layers, dimensions, annotations, and other project information used in drafting, design, engineering, architecture, construction, and manufacturing workflows. You may encounter a DWG file even if you’re not a regular CAD user. Maybe a contractor sent over a floor plan. Maybe a manufacturer shared a part drawing. Or maybe you downloaded project files and need to know what software can open them. This blog explains what the DWG file format is, what kinds of data DWG files can store, how they’re used across design and drafting workflows, and how to open DWG files with tools such as AutoCAD software or a DWG file viewer. What Is the DWG File Format? The DWG file format is the native drawing file format for AutoCAD and one of the most widely used formats for creating, editing, and sharing CAD files across design workflows. It helps preserve the drawing information professionals need to review and revise work, from precise geometry and layers to dimensions, annotations, and other project details. DWG is closely tied to computer-aided design (CAD) because it supports editable, accurate drawing data. That matters when a file needs to move from one project stage to another: a concept layout becomes a construction document, a shop drawing moves into review, or a manufacturing detail gets revised before production. What data can a DWG file store? A DWG file can store much more than the lines you see on screen. It can carry the design data that helps a drawing stay useful as it moves through drafting, review, revision, sharing, and documentation. Common types of information stored in a DWG file include: 2D geometry, such as lines, arcs, circles, polylines, and shapes 3D model data, when the drawing includes three-dimensional design information Layers that organize drawing objects by discipline, system, material, or purpose Dimensions that communicate measurements, spacing, tolerances, or other design requirements Annotations, notes, labels, and text used to explain the drawing Blocks and symbols, such as doors, fixtures, fasteners, title blocks, or standard details Layouts and sheets prepared for plotting, printing, or sharing Metadata and other project information that help describe or manage the drawing That range of information is one reason DWG files are common in design and drafting projects. A DWG can support the visible drawing, but it can also preserve the structure behind it, which matters when different people need to open, edit, review, or convert the file later. What software supports DWG files? Several Autodesk tools support DWG files, but the right choice depends on what you need to do next. Opening a file for a quick review is different from editing a production drawing, converting a file, or collaborating with others online. <?xml encoding="utf-8" ?>ToolBest forAutoCADCreating, editing, documenting, and working with DWG files in full CAD workflowsAutoCAD LT2D drafting, editing, and documentation with DWG filesAutoCAD WebOpening, reviewing, and editing DWG files in a web browser and on mobile devicesAutodesk ViewerViewing and sharing DWG files online without installing CAD softwareDWG TrueViewViewing DWG files and converting them to earlier DWG file versions Some non-Autodesk CAD programs may also support DWG files. Compatibility can vary, though, especially when a drawing includes specific objects, file versions, custom data, or features that another program may not fully read. When accuracy matters, use the tool that best matches the work: view, edit, convert, or collaborate. DWG vs. other CAD file formats DWG is one of several CAD file formats used in design workflows. The main difference is intent. Some formats are built for editing. Others are better for exchanging, viewing, publishing, or transferring design data between tools. <?xml encoding="utf-8" ?>File formatPrimary useWhen to use itDWGCreating and editing CAD drawingsUse DWG when you need to work with editable 2D or 3D design data, especially in AutoCAD-based workflows.DXFExchanging drawing data between CAD programsUse DXF when you need to share drawing information with another CAD application that may not use DWG as its main format.DWFSharing and publishing design informationUse DWF when you need to distribute a design for viewing, markup, or review without sending the full editable drawing file.STLTransferring 3D model geometry for fabrication workflowsUse STL when you need a 3D model format commonly associated with 3D printing or other geometry-based transfer needs. For most drafting and design work, DWG is the file you’ll use when the drawing still needs to be edited, coordinated, or developed. Other formats often come into play when the file needs to move outside that working environment. Common uses for DWG files DWG files show up in many drafting and design projects because they can support editable drawing data, structured project information, and file sharing across teams. That makes the format useful when a drawing needs to move from concept to documentation, review, revision, or production. Common uses for DWG files include: Floor plans for residential, commercial, or industrial spaces Construction drawings used by architects, engineers, contractors, and project teams Site plans that show property layouts, utilities, access points, grading, or surrounding conditions Engineering drawings for mechanical, electrical, civil, or structural work Product designs and manufacturing details used to describe parts, assemblies, or fabrication requirements 2D drafting files for plans, elevations, sections, details, schematics, and diagrams 3D drafting or model files when a project includes three-dimensional design information Review and collaboration files shared between designers, consultants, clients, or production teams In short, you’ll often encounter a DWG file anywhere precise design information needs to stay editable, measurable, and ready for the next person in the workflow. Open, view, or convert DWG files with Autodesk tools Once you know what a DWG file is, the next step is choosing the right tool for the task. You may only need to view the drawing. You may need to convert it. Or you may need to edit the file as part of a CAD workflow. <?xml encoding="utf-8" ?>If you need to…Autodesk tool to considerView a DWG file onlineUse Autodesk Viewer to open and review DWG files in a browser.View or convert a DWG fileUse DWG TrueView for DWG viewing and file conversion.Edit a DWG file in a browserUse AutoCAD Web to open, review, and edit DWG files online.Create and edit DWG files in a full CAD environmentUse AutoCAD for DWG drafting, design, and documentation. For a quick look, a viewer may be enough. For ongoing drafting, editing, or documentation, use an AutoCAD tool that supports the level of control your work requires. DWG file FAQs What does DWG stand for? DWG is commonly understood as shorthand for “drawing.” In CAD workflows, a DWG file is a drawing file that stores design information used for drafting, modeling, documentation, and review. The term is closely associated with AutoCAD because DWG is the native file format for AutoCAD drawings. Over time, it has become one of the most familiar file types in professional design and drafting work. Is a DWG file a CAD file? Yes. A DWG file is a type of CAD file used in design and drafting workflows. It can store precise drawing data, including geometry, dimensions, annotations, layers, layouts, and other project information. That makes DWG files useful across many drafting and design projects, from architectural plans and engineering drawings to manufacturing details and construction documentation. Can you open a DWG file without AutoCAD? Yes. You can open and view DWG files without installing AutoCAD software, depending on what you need to do with the file. If you only need to view a drawing, Autodesk Viewer lets you view DWG files online in a browser. If you need to view or convert DWG files, DWG TrueView supports DWG viewing and conversion. If you need to edit drawings, consider AutoCAD, AutoCAD LT for 2D drafting and documentation, or AutoCAD Web for browser-based DWG viewing and markups. Can DWG files store 3D data? Yes. DWG files can store 3D data when the drawing includes three-dimensional design information. They can also store 2D geometry, layers, dimensions, annotations, layouts, and other project details. This flexibility is one reason the format is used across different project types. A DWG file might contain a simple 2D plan, a detailed 3D model, or a drawing set with both model and documentation information. What is the difference between DWG and DXF? DWG is commonly used as a working file format for creating and editing CAD drawings, especially in AutoCAD-based workflows. DXF is often used to exchange drawing data between different CAD programs. A simple way to think about it: DWG is often the file you continue editing, while DXF can help transfer drawing information between software tools. The best choice depends on whether you need to keep working in the drawing or share it with another system. Can DWG files be converted to other file formats? Yes. DWG files can often be converted to other formats for viewing, sharing, publishing, or compatibility with another CAD application. The right conversion path depends on the destination format and what information you need to preserve. For example, you may need to keep editable CAD data, create a viewable file for review, or prepare a file for someone using different software. DWG TrueView can help view and convert DWG files, while AutoCAD tools can support broader editing and export workflows. The post What Is a DWG File? How to Open and View DWG Drawings appeared first on AutoCAD Blog. View the full article -
Danielm103 started following Testing DWG compatibility with different CAD applications
If I’m not mistaken, ACTCAD uses ITC/ODA libraries. DWG compatibility should be good. -
indiancad replied to indiancad's topic in Catch All
Thanks. I included ACTCAD because I was testing the same files across multiple CAD platforms under similar conditions. During the process, I also received a technical demo on large-file performance, troubleshooting, and useful cleanup commands, which helped me understand some of the performance issues better. Overall, the testing was mainly about comparing practical workflows rather than choosing one particular CAD platform. -
Do you have actual numbers to support your claims for ACTCAD, or just a general feeling of being better? What "other" CAD applications did you compare? Are you only here to advertise ACTCAD? You have another thread making ACTCAD comparisons and you appear to be associated with a seller of ACTCAD. Back on topic, Xrefs, Blocks and general drawing cleanups, Audits, -Purge, etc. help a lot, but to be honest, the actual file size can be irrelevant, even small file sizes containing certain objects can cause issues. My biggest slow down at work is the choked off network and ITs issues with security software, etc. and yes, some of that is Autodesk's License verification, etc. and my company isn't a CAD work company, I just support manufacturing, facilities, etc. so IT priority is not Autodesk connectivity and performance. I have worked on files that were a struggle at work on my old slow home computer and they ran just fine. But, no doubt, if you work regularly with large files a powerful workstation would definitely be a must have. -
dozza6570 joined the community
Standard texts are hiding somehow can anyone please help??
animal1103 replied to Vijay's topic in AutoCAD 2D Drafting, Object Properties & Interface
可能使用了背景遮罩 -
tomai joined the community
yes !that absolutely right; then what about who wants to open large dwg files. when they can't afford the features you mentioned. -
Best processor, graphics card and lots of ram. A very simple answer. -
indiancad posted a topic in Catch All
Large DWG files can become difficult to work with when they contain thousands of objects, blocks, hatches, XREFs, and detailed drawings. I’ve been testing the same larger DWG files in different CAD applications to compare practical performance during opening, zooming, editing, saving, and switching between layouts. ACTCAD was one of the applications I tested, and I was pleasantly surprised with how smoothly some of the larger files handled. I’m curious about the experience of other CAD users here. What techniques do you normally use to keep large DWG files fast and responsive? -
I completely understand why seeing a "Sign In" button triggers the password fatigue alarm! But if you actually click that button, it redirects you to our Web Portal (app.vedacad.com — I’ve attached a screenshot for you). You won't find a "Create Password" field anywhere in our system. It operates entirely via one-click OAuth, secure Magic Links sent to your email, or Enterprise SSO (OIDC) for corporate users. no new passwords. As for your summary: "a fancy DCL popup that links to an online file store"—from a draftsperson's perspective, I take that as a huge compliment! It should feel that incredibly simple. The ultimate goal is zero friction. But under the hood, that "fancy DCL" is just the visual shell for a robust LISP microkernel. Here is what it's actually doing in the background: Isolated Sandbox & Proxying: It doesn't just download files; it vaults them in a secure local sandbox (%APPDATA%) and dynamically generates demand-load proxy hooks in memory, keeping your CAD startup footprint at 0%. Environment Injection: It natively reads and injects configuration files (.CTB, .DWT, .SHX, .CUIX) directly into AutoCAD's Preferences and Support Paths, silently aligning the drafting standards without the user lifting a finger. Lock-Bypass Hot-Swapping: It handles Windows file locks natively. If a developer pushes an update, the kernel re-routes the running binary (via .bak renaming) to silently hot-swap the .vlx or .dll while the user is actively drafting. Zero-Trust MDM: For enterprise deployments, it constantly listens for kill-switch directives to physically shred revoked assets (like expired sub-contractor standards) from the local hard drive. So yes, it looks like a simple popup, but it hides an entire IT deployment and environment governance engine behind it.
