dber started following Lisp Code for transforming list number to numbered block?
dber posted a topic in AutoLISP, Visual LISP & DCL
I was wondering if it was possible to turn a multiline-text list of construction notes into a standard way we label construction notes using this hexagon and numbering them. I included a CAD file with sample text (paperspace) and the final product of hexagon placement (0.25" from text, centered with text for 1-line, centered between top 2 lines for multi-line text). NotesLispTest.dwg - Today
FYI: When running VS Code to select everything including the parenthesis, When near the beginning of the code: Click position right in front of the open parenthesis, then hit the following keyboard combinations Shift+Ctrl+Alt then Down Arrow When near the end of the code: Click position right after the close parenthesis, then hit the following keyboard combinations Shift+Ctrl+Alt then Up Arrow
AI recreating a floor-plan screenshot in AutoCAD - feedback welcome
SLW210 replied to Andrea Rocco Matta's topic in Application Beta Testing
In the past lots of napkins, drawn on hands, cardboard (both drawn on and cut to some weird shape), no rubber gloves, but work gloves. Not for CAD, but, I have hade to build things to hammer handles, coworkers hand size, etc. when somehow nobody had a tape measure. And NO, I wasn't laughing, I am serious, AI has it's uses, but some things it will never get a grasp of IMO. Though I only have tried the free stuff, maybe paid for is better, I did like some of the images to video I did on TikTok and the special effects on some of the grandkids sports videos. -
Steven P replied to Andrea Rocco Matta's topic in Application Beta Testing
You laugh.... had a colleague years ago handed me a rubber glove "Draw this up" - scribbles on his hand on site - so I did. 2nd pass I took off the glove shape... -
Why does FILLETEDGE fail on some 3D solid edges?
Why? Are you just guessing at a radius value? I normally just use (F)illet, I only occasionally have the need for FILLETEDGE, but it has a dynamic preview, so I am not sure why even if guessing a nice radii it would fail or give an unexpected result. -
Hard to compare without seeing the original. I have redone PDFs a good bit in the past, some go very quickly (vector and some raster) others are a mess from the start, different scales, fat lines, blurry lines and Text etc. What can AI do when you hand it a scribbled on wet napkin? -
Have you ever tried using FILLETEDGE on a 3D solid, only to find that the command fails or produces an unexpected result? One thing I check first is the fillet radius. If the radius is too large for the available space, AutoCAD may not be able to create the transition. I also inspect nearby edges and faces for small or complicated geometry that could interfere with the operation. When a fillet fails, I usually try a smaller radius first. If the model has several details, applying larger fillets before adding smaller features can also make the process easier. When FILLETEDGE fails, what do you normally check first: the radius, the edge selection, or the surrounding geometry? -
Steven P started following AI recreating a floor-plan screenshot in AutoCAD - feedback welcome
Intriguing to use AI to draw it all for you - certainly could speed up things - I'd need to thoroughly check a few times to gain confidence in the process. My approach is slightly different generally. Recent PDFs done with CAD allow you to convert to lines, arc, and so on but the accuracy might be off. I'll scale the PDF, convert and then snap entities to a grid again - often 1.25 or 2.5mm - and that usually gets the right result... on a PDF that can be converted. A mix of both, yours and mine could get good results. Our biggest problem is historic records - scanned paper copies originally drawn in pen and ink - now that would be a good work out for AI ! -
VicoWang started following AI recreating a floor-plan screenshot in AutoCAD - feedback welcome
VicoWang replied to Andrea Rocco Matta's topic in Application Beta Testing
In the AEC field, the key issue is not that AI drawing has improved drafting efficiency (though this is what many AI drawing tools advertise), but rather that it conflicts with the precision required in engineering drawings. For example, a few lines might represent an expensive wall or a full-length load-bearing column. Given that AI generates outputs probabilistically (AI hallucinations), the real question is whether engineers dare to delegate drafting responsibilities to AI. On the other hand, in a comprehensive AEC project, drafting may account for only 20% of the time and workload; even if it were reduced to zero, the overall efficiency gain for the entire project would still be limited. -
Align the extension lines to the short line of each selected size
After installing the above bundle, everything works as expected. (To install these bundle, a free vedacad account is sufficient.) --- After nearly 40 emails of intense communication with @Paul Li, I saw the professionalism and rigor of the senior developer, and this real feedback after actual use has taken VedaCAD a big step forward. Thank you @Paul Li -
ScottMC replied to Nikon's topic in AutoLISP, Visual LISP & DCL
here's 2 for h&v alignment:..DIM.Fix.Y.Leaders.lsp ..DIM.Fix.X.Leaders.lsp -
luisifer999 joined the community
BIGAL replied to Andrea Rocco Matta's topic in Application Beta Testing
This was created using a pdf as the base and Cadarc architectural program over the top, internal doors to be added. -
As @VicoWang mentioned I've been running some major tests implementing this new VedaCAD system of deploying 3rd party add-ons in my case specifically to AutoCAD users. @VicoWang has been really response with all my feedback. I'm fairly impressed with how this provides a software developer like myself another platform to push out my apps to end users to implement on their AutoCAD system. The following is a list of my VCIDs. Along with AutoCAD users, I'm hoping AutoCAD LT 2024 and higher version users will also try installing and running these apps. Since currently the Autodesk App Store (now known as the Design & Make Marketplace) do not support AutoCAD LT, this VCID deployment method provides an excellent solution to have AutoLISP coded apps load & run on LT. [DDCalc] VCID: B-NN9XC DDCalc is an on screen graphical calculator within Autodesk® AutoCAD® that supports feet, inch & fractional numeric entries. [DDList] VCID: B-NLR04 DDList is Autodesk® AutoCAD® basic list command but on steroids. [DwgSetup] VCID: B-4K6UL DwgSetup App offers two user friendly graphic user interface commands to make drawing setup changes: (1) DDSetup and (2) DDDwgunits [VpScale App] VCID: B-31VQK VpScale Apps offers two very useful Viewport Scaling Applications: DDZmVpSc & DDSetVpSc [VTN] VCID: B-0Z8Q6 Virtual Tablet Navigator (VTN) is an add-on AutoLISP application using DCL to bring Autodesk® AutoCAD® physical Tablet Menu commands virtually onto the graphics screen. [XOM] VCID: B-09NQD Xref Object Manager (XOM) is an AutoLISP application using a dynamic dialog box to present built-in & added operations to manage External Reference Objects displayed both in a Tree and a List view. -
Andrea Rocco Matta started following AI recreating a floor-plan screenshot in AutoCAD - feedback welcome
Andrea Rocco Matta posted a topic in Application Beta Testing
Hi everyone, I'm Andrea, an architect and co-founder of Ideatura. We've been working on letting AI create and edit geometry directly inside AutoCAD, and I'd like some honest feedback from people who use it every day. For this example, I gave it a floor-plan screenshot, told it to assume a 5 m spacing between two grids and scale the rest proportionally, and asked it to work in stages so I could review each step. It created walls and columns, then doors, windows, stairs and grids, followed by furniture, fittings and room labels. The result is editable AutoCAD geometry: polylines, arcs, blocks and text. This run was in AutoCAD 2027 on Windows. The video is sped up, especially during processing. This is an approximate reconstruction from an image and an assumed scale. It still needs checking, and one unclear perimeter edge was left open for clarification. Would checking and correcting a first pass like this save you time compared with drawing it yourself? What would you inspect first: accuracy, wall joins, blocks, layers, or something else? Feel free to pick apart the result. I'm interested in what would make this useful in an actual drafting workflow. -
Andrea Rocco Matta joined the community
Title: Why can a LOFT create a twisted 3D shape even when the profiles look correct?
I have seen cases where a LOFT between two profiles produces a twisted or unexpected surface, even though the cross-sections appear correct. One thing worth checking is the position and orientation of the profiles. Their starting points, alignment, and placement can affect how the loft connects corresponding sections. When the result looks wrong, I check the profiles individually, adjust their alignment, and try different loft settings before rebuilding the geometry. This is especially important when creating transition pieces, ducts, or curved components. When a LOFT twists unexpectedly, what do you check first: profile alignment, placement, or the loft settings? -
Title: Why does SHELL sometimes remove the wrong face from a 3D solid?
Have you ever used SHELL on a 3D solid, expecting to create a hollow part, but ended up with an unexpected opening? One thing I check first is whether I selected the correct face to remove. The face selection determines where the solid opens, while the shell thickness controls the remaining wall thickness. For a more predictable result, I inspect the model from different viewing angles before applying the operation. I also check whether the chosen thickness is suitable for the size and shape of the part. A small selection mistake can change the entire result. When creating hollow 3D parts, do you prefer SHELL or do you usually model the inner geometry and use SUBTRACT? -
ReMark replied to JimJames1978's topic in Student Project Questions
cauldmofbats: Have you figured it out yet? -
MojtabaZamani joined the community
ADRIAN YUNGHOI joined the community
Steven P started following Select Between Bracket in Notepad+
Never thought about that - I always still use ctrl+ V / C - means I have to let go of the mouse every now and then
Danielm103 started following Select Between Bracket in Notepad+
Danielm103 replied to ymg3's topic in AutoLISP, Visual LISP & DCL
I use this in visual studio to toggle between header and source. also since I'm a southpaw, I use home and end for copy paste autohotkey is the GOAT! #z::Run www.autohotkey.com ;ALT + XX ; home::send ^c ; end::send ^v ; #IfWinActive ahk_exe devenv.exe ;PgUp::SendRaw `,DS.ARGS() ;misc command ;PgDn::SendRaw `,DS.ARGS({"val:type"}) ;misc command Insert::send ^k^o ;toggle header/source Delete::send ^a^k^f{Esc} ;select all and format #IfWinActive - Last week
ymg3 started following Select Between Bracket in Notepad+
If you use notepad+ as an editor for Autolisp, the CTRL+ALT+b leaves a lot to be desired when it comes to selecting between brackets. The VLIDE double-click is much more satisfying. So here is an AutoHotKey script that gives you this functionnality while preserving the normal Dbl-Click of notepad+: #Requires AutoHotkey v2.0 #SingleInstance Off ; 1. Set up a unique communication highway (MsgNumber 0x401) OnMessage(0x401, ReceiveCloseSignal) ReceiveCloseSignal(wParam, lParam, msg, hwnd) { ExitApp } ; 2. Find any running old instance (ignoring itself) and send it the "Self-Destruct" signal DetectHiddenWindows True if (oldScriptHwnd := WinExist(A_ScriptFullPath " ahk_class AutoHotkey")) { if (oldScriptHwnd != A_ScriptHwnd) { ; Ensure the script doesn't close itself! PostMessage(0x401, 0, 0, , "ahk_id " oldScriptHwnd) WinWaitClose("ahk_id " oldScriptHwnd, , 2) } } ; 3. Automatically relaunch the script using UI Access to bypass UAC entirely if !A_IsCompiled && !InStr(A_AhkPath, "_UIA.exe") { uiaPath := RegExReplace(A_AhkPath, "\.exe$", "_UIA.exe") if FileExist(uiaPath) { try { Run('"' uiaPath '" "' A_ScriptFullPath '"') ExitApp } } } ; 4. Your Application-Specific Hotkeys #HotIf WinActive("ahk_class Notepad++") ~LButton:: { static lastClick := 0 currentClick := A_TickCount if (currentClick - lastClick < DllCall("GetDoubleClickTime")) { KeyWait("LButton") Sleep(60) SendEvent("^!b") lastClick := 0 } else { lastClick := currentClick } } #HotIf Link to download AutoHotKey https://www.autohotkey.com also available on Microsoft app store (Free) NppBrackets.ahk
Alexman joined the community
Danielm103 started following Block Manager in Python
This is a port of BrxBlockMan to Python. should be a good sample of how to use a lot of the API, Palettes, Jigs, Cloning Etc. - select a drawing from the directory control - double click or drag a block from the List control to the current drawing - double click the main preview to insert the whole drawing - click the open folder button to add your favorite folder(s) - use the dropdown to navigate to a favorite folder - right click on a dwg to open it in Bricscad - right click on a folder to add it to favorites - right click on the dropdown ctrl to clear favorites https://github.com/CEXT-Dan/PyRx/tree/main/PySamples/wxPython/BlockMan Requires PyRx, BlockMan.py and BlockMan.xrc should be in the same folder
- 1
I’m not sure whether CADTUTOR is currently using Cloudflare’s proxy-based DNS resolution. However, if it is already using Cloudflare and still behaves this way, it seems they don’t have any better options at the moment. Accordingly, when developing my VedaCAD.com system, I fully considered and leveraged Cloudflare’s edge caching technology—complete with built-in free DDoS protection—to enhance performance under high concurrent access.
If it doesn't kill us, it makes us stronger...and older! Growing old beats the hell out of the only other option.
Just looking at the stats this month (September 2026) I can see that after the US (which always tops the charts) the next five biggest IP locations for visitors were Ireland, Armenia, Seychelles, Angola, and Unknown. You can be pretty certain that they are all spoof IP addresses used by scraping bots and those 5 account for almost half the bandwidth this month.
