Performance helps for Large-Scale Z-Flattening (Z0) AutoLISP Routine?
Tsuky replied to p7q's topic in AutoLISP, Visual LISP & DCL
Hi, Here is a code that projected simples entities : POLYLINE,LWPOLYLINE,LINE,SPLINE,ARC,CIRCLE,ELLIPSE,POINT. on the SCG at a Z-coordinate to zero if as the entities of start are in a UCS parallel or not. For example, a circle in a UCS non-parallel will become an ellipse. I do this because this is much faster than FLATTEN (which is more efficient: it can handle more entities, but slow) If it can help... (defun l-coor2l-pt (lst flag / ) (if lst (cons (list (car lst) (cadr lst) (if flag (+ (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) (caddr lst)) (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) ) ) (l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag) ) ) ) (vl-load-com) (defun c:my_project ( / jspl nbr n AcDoc Space UCS save_ucs WCS ent_name indx l_blg l_pt ename id_obj pl_typ index nw_pl) (setq jspl (ssget '((-4 . "<OR") (-4 . "<AND") (0 . "POLYLINE") (-4 . "<NOT") (-4 . "&") (70 . 112) (-4 . "NOT>") (-4 . "AND>") (0 . "LWPOLYLINE,LINE,SPLINE,ARC,CIRCLE,ELLIPSE,POINT") (-4 . "OR>")) ) nbr -1 n 0 ) (cond (jspl (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (eq (getvar "CVPORT") 1) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) UCS (vla-get-UserCoordinateSystems AcDoc) save_ucs (vla-add UCS (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point (getvar "UCSXDIR")) (vlax-3d-point (getvar "UCSYDIR")) "CURRENT_UCS" ) ) (vla-put-Origin save_ucs (vlax-3d-point (getvar "UCSORG"))) (vla-StartUndoMark AcDoc) (setq WCS (vla-add UCS (vlax-3d-Point '(0.0 0.0 0.0)) (vlax-3d-Point '(1.0 0.0 0.0)) (vlax-3d-Point '(0.0 1.0 0.0)) "TEMP_WCS")) (vla-put-activeUCS AcDoc WCS) (repeat (sslength jspl) (setq ent_name (ssname jspl (setq nbr (1+ nbr))) indx -1 l_blg nil l_pt nil ename (vlax-ename->vla-object ent_name) id_obj (vla-get-ObjectName ename) ) (cond ((member id_obj '("AcDbPolyline" "AcDb2dPolyline" "AcDb3dPolyline")) (setq pl_typ (if (vlax-property-available-p ename 'Type) (vlax-get ename 'Type))) (if (member id_obj '("AcDbPolyline" "AcDb2dPolyline")) (if (not (equal (vlax-get ename 'Normal) '(0.0 0.0 1.0) 1E-13)) (progn (repeat (fix (vlax-curve-getEndParam ename)) (setq l_pt (cons (vlax-curve-GetPointAtParam ename (setq indx (1+ indx))) l_pt) index (float indx)) (if (or (eq pl_typ 1) (if (< pl_typ 3) (not (zerop (vla-GetBulge ename indx))))) (while (eq indx (fix (+ 0.01 index))) (setq l_pt (cons (vlax-curve-GetPointAtParam ename (setq index (+ 0.01 index))) l_pt)) ) ) ) (setq l_pt (cons (vlax-curve-getEndPoint ename) l_pt)) ) (setq l_pt (mapcar '(lambda (x) (trans (list (car x) (cadr x) (- ;+ (if (eq id_obj "AcDbPolyline") (caddr x) 0.0) (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) ) ) ent_name 0 ) ) (l-coor2l-pt (vlax-get ename 'Coordinates) (eq id_obj "AcDb2dPolyline")) ) ) ) (setq l_pt (l-coor2l-pt (vlax-get ename 'Coordinates) T)) ) (if (eq (vla-get-ObjectName ename) "AcDbPolyline") (setq nw_pl (vlax-invoke Space 'AddLightWeightPolyline (apply 'append (mapcar 'list (mapcar 'car l_pt) (mapcar 'cadr l_pt))))) (setq nw_pl (vlax-invoke Space 'AddPolyline (apply 'append l_pt))) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) (if (vlax-property-available-p ename 'Type) (progn (setq pl_typ (if (eq (vla-get-ObjectName ename) "AcDb3dPolyline") (if (zerop (vlax-get ename 'Type)) (vlax-get ename 'Type) (1+ (vlax-get ename 'Type))) (vlax-get ename 'Type) ) ) (if (and (vlax-property-available-p ename 'Normal) (not (equal (vlax-get ename 'Normal) '(0.0 0.0 1.0) 1E-13)) (eq pl_typ 1)) (vla-put-Type nw_pl 0) (vla-put-Type nw_pl pl_typ) ) ) (if (and (vlax-property-available-p ename 'Normal) (equal (vlax-get ename 'Normal) '(0 0 1) 1E-13)) (progn (repeat (length l_pt) (setq l_blg (cons (vla-GetBulge ename (setq indx (1+ indx))) l_blg))) (foreach el l_blg (vla-SetBulge nw_pl indx el) (setq indx (1- indx))) ) ) ) (vla-put-Closed nw_pl (vlax-get ename 'Closed)) ) ((member id_obj '("AcDbEllipse" "AcDbCircle" "AcDbArc")) (if (not (equal (vlax-get ename 'Normal) '(0.0 0.0 1.0) 1E-13)) (progn (setq index (vlax-curve-getStartParam ename) l_pt (list (vlax-curve-GetPointAtParam ename index)) ) (while (< (setq index (+ 0.01 index)) (vlax-curve-getEndParam ename)) (setq l_pt (cons (vlax-curve-GetPointAtParam ename index) l_pt)) ) (setq nw_pl (vlax-invoke Space 'AddLightWeightPolyline (apply 'append (mapcar 'list (mapcar 'car l_pt) (mapcar 'cadr l_pt))))) ) (cond ((eq id_obj "AcDbEllipse") (setq l_pt (vlax-get ename 'Center) nw_pl (vlax-invoke Space 'AddEllipse (list (car l_pt) (cadr l_pt) 0.0) (list (car (vlax-get ename 'MajorAxis)) (cadr (vlax-get ename 'MajorAxis)) 0.0) (* (caddr (vlax-get ename 'Normal)) (vlax-get ename 'RadiusRatio)) ) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) (vla-put-StartAngle nw_pl (vlax-get ename 'StartAngle)) (vla-put-StartParameter nw_pl (vlax-get ename 'StartParameter)) (vla-put-EndParameter nw_pl (vlax-get ename 'EndParameter)) ) ((or (eq id_obj "AcDbArc") (eq id_obj "AcDbCircle")) (setq l_pt (vlax-get ename 'Center) nw_pl (if (eq id_obj "AcDbArc") (vlax-invoke Space 'AddArc (list (car l_pt) (cadr l_pt) 0.0) (vlax-get ename 'Radius) (vlax-get ename 'StartAngle) (vlax-get ename 'EndAngle)) (vlax-invoke Space 'AddCircle (list (car l_pt) (cadr l_pt) 0.0) (vlax-get ename 'Radius)) ) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) ) ) ) ) ((eq id_obj "AcDbSpline") (if (or (zerop (vlax-get ename 'IsPlanar)) (and (not (zerop (vlax-get ename 'IsPlanar))) (not (equal (cdr (assoc 210 (entget ent_name))) '(0.0 0.0 1.0) 1E-13)) ) ) (progn (setq index (vlax-curve-getStartParam ename) l_pt (list (vlax-curve-GetPointAtParam ename index)) ) (while (< (setq index (+ 10.0 index)) (vlax-curve-getEndParam ename)) (setq l_pt (cons (vlax-curve-GetPointAtParam ename index) l_pt)) ) (setq nw_pl (vlax-invoke Space 'AddLightWeightPolyline (apply 'append (mapcar 'list (mapcar 'car l_pt) (mapcar 'cadr l_pt))))) ) (progn (setq l_pt (l-coor2l-pt (if (zerop (vlax-get ename 'NumberOfFitPoints)) (cdddr (reverse (cdddr (reverse (vlax-get ename 'ControlPoints))))) (vlax-get ename 'FitPoints)) T) nw_pl (vlax-invoke Space 'AddSpline (apply 'append (mapcar '(lambda (x y) (list x y 0.0)) (mapcar 'car l_pt) (mapcar 'cadr l_pt))) (list (car (vlax-curve-getFirstDeriv ename 0)) (cadr (vlax-curve-getFirstDeriv ename 0)) 0.0) (list (car (vlax-curve-getFirstDeriv ename (vlax-curve-getEndParam ename))) (cadr (vlax-curve-getFirstDeriv ename (vlax-curve-getEndParam ename))) 0.0) ) l_pt (l-coor2l-pt (vlax-get ename 'ControlPoints) T) ) (vla-put-ControlPoints nw_pl (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (* (length l_pt) 3))) ) (apply 'append (mapcar '(lambda (x y) (list x y 0.0)) (mapcar 'car l_pt) (mapcar 'cadr l_pt))) ) ) ) ) ) ) ((eq id_obj "AcDbLine") (setq nw_pl (vlax-invoke Space 'AddLine (list (car (vlax-get ename 'StartPoint)) (cadr (vlax-get ename 'StartPoint)) 0.0) (list (car (vlax-get ename 'EndPoint)) (cadr (vlax-get ename 'EndPoint)) 0.0) ) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) ) ((eq id_obj "AcDbPoint") (setq nw_pl (vlax-invoke Space 'AddPoint (list (car (vlax-get ename 'Coordinates)) (cadr (vlax-get ename 'Coordinates)) 0.0) ) ) (vla-put-Normal nw_pl (vlax-3d-point '(0 0 1))) ) ) (vla-put-TrueColor nw_pl (vla-get-TrueColor ename)) (vla-put-LineType nw_pl (vla-get-LineType ename)) (vla-put-LinetypeScale nw_pl (vla-get-LinetypeScale ename)) (vla-put-Lineweight nw_pl (vla-get-Lineweight ename)) (vla-put-Material nw_pl (vla-get-Material ename)) (vla-put-Layer nw_pl (vla-get-Layer ename)) (vla-delete ename) ) (and save_ucs (vla-put-activeUCS AcDoc save_ucs)) (and WCS (vla-delete WCS) (setq WCS nil)) (vla-EndUndoMark AcDoc) (princ (strcat "\n" (itoa (sslength jspl)) " entity(s) submissive to the command. ENDED !" ) ) ) (T (princ "\nNo compliant entities selected..!")) ) (prin1) ) -
dexus started following Performance helps for Large-Scale Z-Flattening (Z0) AutoLISP Routine?
Steven P replied to p7q's topic in AutoLISP, Visual LISP & DCL
Thanks MHUPP - that was a thought I'd add for the OP tomorrow, can copy and paste from here rather than try to remember where I last used last ent. -
Change elevation only works if all points are on the same Z elevation. this might be why also flatten isn't working for you. Two things you can do to speed up. Combine all the commands into one call like you did below Command has some type of "lag" but for example lets just call it 100ms this would remove 500ms for each loop. Not to mention all the command line spam. (setvar cmdecho 0) when you sent LastEnt anything created or modified is "behind" LastEnt in the drawing and can be added to a selection set with a simple loop. rather then selecting everything in the drawing and checking against the before selection set to find the new items. (setq zList '()) ;(setq before (ssget "_X")) ;not needed anymore (command "regen" "_.copy" obj "" '(0 0 0) '(0 0 0)) (setq LastEnt (entlast)) ;set right before you create/modify objects. you want to either add to a selection (command "_.explode" newent) (while (setq LastEnt (entnext LastEnt)) ;after entities are created this will add them to a selection set. (ssadd EntLst newents) ) (foreach e newents -
Just to amuse myself, here is a snippet that will flatten simple entities, not sure if that helps you along the way - you can use what code works for 3d polylines, hatches, regions and blocks - might be a bit quicker Command: NewFlatten An edit for later... (defun FlattenLines ( Pt1 Pt2 / MySS MyEnt acount ed) ;;For arcs, attdef, circle, (dimension N/A), Insert, Line, LWPolyline, Mtext, Point, text, ;;Does lines, circles, arcs, ellipses, texts, LWPolylines (if (< (car pt1)(car pt2)) (setq MySS (ssget "_W" pt1 pt2 (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") ))) ; end list, ssget, setq (setq MySS (ssget "_C" pt1 pt2 (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") ))) ; end list, ssget, setq ) ; end f ; (setq MySS (ssget "_X" (list ; '(-4 . "<OR") ; '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) ; '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) ; '(-4 . "<>") (cons 38 0) ; '(-4 . "OR>") ; ))) ; end list, ssget, setq (setq acount 0) (while (< acount (sslength MySS)) (setq MyEnt (ssname MySS acount)) (setq ed (entget MyEnt)) (if (equal (assoc 0 ed) (cons 0 "LWPOLYLINE")) (progn (entmod (setq ed (subst (cons 38 0) (assoc 38 ed) ed) )) ;; Elevation to 0 ) ; end progn (progn (entmod (setq ed (subst (cons 10 (mapcar '* '(1 1 0) (cdr (assoc 10 ed)))) (assoc 10 ed) ed)) ) (entmod (setq ed (subst (cons 11 (mapcar '* '(1 1 0) (cdr (assoc 11 ed)))) (assoc 11 ed) ed)) ) ) ; end progn ) ; end if (setq acount (+ acount 1)) ) ; end while ) (defun SSMouseOrder ( / MyList MySS pt1 pt2 MyEnt SelSS MySS MyDuir acount) ;; Enttypelist: wildcards are OK but not for single selection. ;; Enttypelist in CAPITALS for single entity selection to work. (princ " (Crossing selection, not single picks please). ") ;;Set up LISP (setq MySS (ssadd)) ;; Blank Selelection Set (if (= EntTypeList nil)(setq EntTypeList (list "LINE" "ARC" "CIRCLE")) ) ;; default entity filter (setq MyList (list (cons -4 "<OR") )) ;; Create filter to use with ssget (foreach n EntTypeList (setq MyList (append MyList (list (cons 0 n)) ) ) ) ; end foreach (setq MyList (append MyList (list (cons -4 "OR>")) ) ) (while (setq pt1 (getpoint "Select Objects:"));; Loop to select entities (setq pta pt1) ; record pt1 selected (if (setq MyEnt (car (nentselp pt1))) ;; If 1st point selected was on an entity: Single entity selected (progn (if (ssdel MyEnt MySS) ;; If entity is in selected selection set, delete it (progn (redraw MyEnt 4) ;; Take away highlight ) (progn ;; Else add single entity to selection set (If (member (cdr (assoc 0 (entget MyEnt))) EntTypeList) ;;Check entity type is desired (progn (setq MySS (ssadd MyEnt MySS)) ;; Add to selection set (princ (strcat " 1 Found, ")) ;; Report selection found (redraw MyEnt 3) ;; highlight entity ) ; end progn ) ; end if member ) ; end progn ) ; end if ssdel ) ; end progn (progn ;; Else if clicked point not an entity (setq pt2 (getcorner pt1 " Specify Opposite Corner")) ;;get 2nd point (if (< (car pt1)(car pt2)) ;; Left to right, right to left to determine window or crossing filter (setq SelSS (ssget "_W" pt1 pt2 MyList) ) ;; Get selected entities (setq SelSS (ssget "_C" pt1 pt2 MyList) ) ) (setq acount 0) (if SelSS ;; If anything was selected (progn (princ (strcat " " (rtos (sslength SelSS) 2 0) " Found, ")) ;; report how many entities selected (while (< acount (sslength SelSS)) ;; add entities to selection set (setq MySS (ssadd (ssname SelSS acount) MySS)) (redraw (ssname SelSS acount) 3) ;; Highlight each entity (setq acount (+ acount 1)) ;; Loop counter ) ; end while ) ; end progn ) ; end if SelSS ) ; end progn ) ; end if MyEnt (setq MyDir 0) ;; Work out mouse click directions. Note single selection direction is LL->UR (if (< (cadr pt1)(cadr pt2)) ;; Horizontal (setq MyDir 0) (setq MyDir 1) ) (if (< (car pt1)(car pt2)) ;; Vertical (setq MyDir (+ MyDir 0)) (setq MyDir (+ MyDir 2)) ) ) ; end while (setq acount 0) ;; clear highlights (while (< acount (sslength MySS)) (redraw (ssname MySS acount) 4) (setq acount (+ acount 1)) ) (if (= (sslength MySS) 0) ;; report the selection set and direction or nil if no selection nil (list MySS MyDir) ;; MyDir: 0 BL->TR (or point selection), 1 TL->BR, 2 BR->TL, 3 TR->BL ) (list pta pt2 MyDir) ; MyDir 0, 1-> L to R, 2, 3 -> R to L ) (defun c:NewFlatten ( / Pts) (princ "Selection: ") (setq Pts (SSMouseOrder)) ;;Mouse order returns Selection set points. Used later. (FlattenLines (car Pts) (cadr Pts) ) ;; flatten simple entities ) ; end defun -
Depends what you are using for obj, if it is an entity name this is a bit quicker: (command "_.copy") (command obj) (command "") (command '(0 0 0) '(0 0 0)) (setq newent (entlast)) (command "_.explode" newent) becomes (command "_.Explode" (setq NewEnt (entmakex (entget obj)) ) ) where obj might be from (car (entsel)) or (ssname MySS number) Might want to look at the number of loops in the snippet you posted -
I trid Change > elevation > 0 but not working. I can't share the full code, but for REGION entities, I'm currently using a method that copies and explodes them to get the Z values, then moves the original REGION to Z=0. I know it's not efficient, but it works. ((equal entType "REGION") (vl-catch-all-apply (function (lambda () (setq zList '()) (setq before (ssget "_X")) (command "regen") (command "_.copy") (command obj) (command "") (command '(0 0 0) '(0 0 0)) (setq newent (entlast)) (command "_.explode" newent) (setq after (ssget "_X")) (setq newents '()) (setq j 0) (while (< j (sslength after)) (setq ent (ssname after j)) (if (not (ssmemb ent before)) (setq newents (cons ent newents)) ) (setq j (1+ j)) ) (foreach e newents (setq entdata (entget e)) (cond ((= (cdr (assoc 0 entdata)) "LINE") (setq z1 (nth 2 (cdr (assoc 10 entdata)))) (setq z2 (nth 2 (cdr (assoc 11 entdata)))) (setq zList (cons z1 zList)) (setq zList (cons z2 zList)) ) ((member (cdr (assoc 0 entdata)) '("ARC" "CIRCLE" "ELLIPSE") ) (setq z1 (nth 2 (cdr (assoc 10 entdata)))) (setq zList (cons z1 zList)) ) ) ) (setq ztotal 0) (if (< 0 (length zList)) (progn (foreach z zList (setq ztotal (+ ztotal z))) (setq zmid (/ ztotal (length zList))) (command "_.MOVE" obj "" '(0 0 0) (list 0.0 0.0 (* zmid -1)) ) ) ) (foreach e newents (entdel e)) ) ) ) ) And also is there a way to use ssget to select only entities that have non-zero Z values? -
That would get most of the simpler entities such as lines, text, circles and so on. LWPolylines you can add another "or": '(-4 . "<>") (cons 38 0.0) and so on building up the selection set filter that way: (ssget (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") )) For 3d polylines, for example, so long as the first point (first dxf code 10 in the entity description) isn't at zero elevation it should also grab them too. However if this only removes lines, LWPolylines, circles, arcs, texts, ellipses... it should reduce the amount of processing. Depends how you are doing it but the blocks might be your slow point. -
mhupp started following Performance helps for Large-Scale Z-Flattening (Z0) AutoLISP Routine?
Can't really tell you how to optimize code you didn't post, but when people first get into lisp the rely heavily on command because its follows what you would type into the command line. It become apparent in a loop processing 1000's of entity's that its quite inefficient. rather then using entmod or some other way to update model. If flatten doesn' work also try the command Change > elevation > 0 -
yes flatten is not working sometimes block, pline, dimension. So ı need this lisp. this lips so limited. for exaple there are multiple 10 dxf data in POLYLINE. I need something more comprehensive -
I guess the flatten command has some limitations for you (I've never been 100% with trusting flatten) -
Steven P started following Performance helps for Large-Scale Z-Flattening (Z0) AutoLISP Routine?
Here is a quick example, (ssget (list '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "OR>") )) Should select the more simple entities not at 0 elevation - not sure it will work for 3d polylines for example, but should be OK for lines, circles, arcs and so on and apply similar to others? -
Hi everyone, I'm working with a large AutoLISP routine that sets the Z elevation of all objects to 0 — similar to a custom Z0 command. It handles a wide range of entity types including: LINEs, ARCs, CIRCLEs, POLYLINEs (both 2D and 3D), LWPOLYLINEs, SPLINEs, HATCHes, TEXT, MTEXT, DIMENSIONs, INSERTs (blocks), including nested block content, and REGION entities. What it does: For each entity, I check its Z elevation and flatten it: For regular entities, I modify their coordinate group codes (10, 11, etc.) using entmod, or use vla-put-elevation where applicable. For INSERTs, I dive into their nested entities and apply the same logic. For REGIONs, I currently copy and explode them temporarily, analyze the resulting geometry to determine the average Z, then move the original REGION to Z=0. My problem: The command works fine, but performance is a major issue, especially on complex or large drawings. What are the best ways to optimize performance for a routine like this? Is there a better way to flatten REGIONs without exploding them? Specifically, is there a way (maybe via a filter or a helper LISP) to select only entities whose Z coordinate is not zero? That would allow me to skip processing objects that are already flat and significantly improve performance. Thanks a lot in advance for any suggestions!
Keep Only the Longest Overlapping Line/Polyline
thanks @SLW210. - Yesterday
CUI Input Text Field?
BIGAL replied to CivilTechSource's topic in The CUI, Hatches, Linetypes, Scripts & Macros
if you want a radio button pick have a look at my Multi radio buttons.lsp it can hold about 20 values vertically. once you pick I use Ldata to save the value in a dwg, in the multi R you can set the button to the current value. In a pop menu would be just a load a lisp as normal all the values being in it that lisp. -
@masterfal one of the answers you are looking for is Strucplus, it is an Aus product just like me. Its been around for like 40 years has lots of good steel connection drafting tools. I have a manual & code but its back in that era and I am sure it has been improved over time, has concrete as well. I have some concrete slab on ground stuff. Draw beams, Waffle slabs, etc. Did some stuff at one stage for tilt panels. I used to have choose concrete beam types and matching blocks, these were chosen via pop image menu's. As suggested there is a lot of stuff out there just have to find it. Did you google "reinforced concrete beams Autocad lisp". Send me a PM with your email and can talk more Aussie time. I am near Newcastle.
Saxlle started following CUI Input Text Field?
Saxlle replied to CivilTechSource's topic in The CUI, Hatches, Linetypes, Scripts & Macros
Hi @CivilTechSource, Here is the an example how you can do it on different approach. In AutoCAD exist "blackboard", where you can store the desired value where you can than use that value in the other open drawings (more about blackboard: About Sharing Data Between Namespaces (AutoLISP)). In this example, I have a "text size values.txt" file with different heights. It can be update with other height values. 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 So, after run this function, you will first choose the file with values (in this case "text size values.txt"), than pick the desired value and add it to blackboard. (prompt "\nCall function: (getValueFromListBlackboard)") (princ) ;; Add any value from list to the "blackboard" (defun getValueFromListBlackboard ( / *dcl_id* *file_name* *op* *lst* *textSize* *path* *file* *line* *rval*) (setq *path* (getfiled "Open the txt file with list of values"" "txt" 0) *file* (open *path* "r") ) (if *file* (progn (while (setq *line* (read-line *file*)) (setq *lst* (append *lst* (list *line*))) ) (close *file*) ) ) (setq *file_name* (vl-filename-mktemp "textHeight.dcl") *op* (open *file_name* "w") ) (write-line "textHeight :dialog { label = \"Select Text Heights\"; :list_box { key = \"tx\"; multiple_select = true; height = 20; width = 30; } :row { :button { label = \"Pick text height\"; key = \"bth\"; fixed_width = true; } :button { label = \"Cancel\"; key = \"cancel\"; mnemonic = \"C\"; alignment = centered; fixed_width = true; is_cancel=true; } } }" *op*) (close *op*) (setq *dcl_id* (load_dialog *file_name*)) (if (not (new_dialog "textHeight" *dcl_id*)) (exit) ) (action_tile "cancel" "(done_dialog 0)") (start_list "tx") (mapcar 'add_list *lst*) (end_list) (defun return_value () (setq *rval* (nth (atoi (get_tile "tx")) *lst*)) ) (action_tile "bth" "(return_value) (done_dialog 1)") (start_dialog) (unload_dialog *dcl_id*) (vl-file-delete *file_name*) (vl-bb-set '*textSize* *rval*) (vl-bb-ref '*textSize*) ) After you pick the desire height, you can change it in all open drawings for any text. In this case, I made a little lisp for that and I need it to call every time in different drawing (except if you don't want to make it in support file search path or to be autoloaded every time when AutoCAD is started). (defun c:CTH ( / data) (setq data (entget (car (entsel "\nSelect the text:")))) (entmod (subst (cons 40 (atof (vl-bb-ref '*textSize*))) (assoc 40 data) data)) ) An example video of how it works you can see below. ChangeTextWithValueFromBlackboard.mp4 Maybe in this you can get some idea how to make it work in your case. Also, you can add "getValueFromListBlackboard" to CUI and make it easier to call. Best regards. -
Extract vertices from a 3DSolid using ACIS data.
Danielm103 replied to dexus's topic in AutoLISP, Visual LISP & DCL
I had partially worked out at one time, at least enough to get the vertices, with Owen Wengerd’s acis-decode function for lisp. Just filter ("point" "$-1" "-1" "$-1" "100" "100" "0" "#") -> ("point" "100" "100" "0") -> -(100.0 100.0 0.0) Ideally, it would be better to filter out the edges, so you know what point connects to what. I think each $INT represents a line number example, the first face points to the next face on line 6... -
dexus replied to dexus's topic in AutoLISP, Visual LISP & DCL
Thanks Daniel, that does look like a convenient way to do it. I don't know how to use the ARX stuff though, never got into that. Too bad there isn't a AssocPersSubentIdPE function in lisp! -
Structural drafting tools
CivilTechSource replied to masterfal's topic in AutoLISP, Visual LISP & DCL
Have you tried checking the AutoDesk App store? I do recall seeing a rebar drafting plugin. -
masterfal started following Structural drafting tools
Hi All, I currently do structural drafting (mainly residential) and have been doing that for quite a number of years now and in that time i have noticed that there are not a great deal of tools available - built into autocad or otherwise. they have stuff for mechanical, architectural, electrical, plumbing etc but doesn't seem to be much for structural. would be cool if there was stuff to help with drawing footings or reinforcement in slabs or stuff to help with detailing. Anyway i was just wondering if anyone had anything specifically useful for structural drafting that they use that they would be happy to share? Something i use all the time is this steel lisp routine (attached) which includes all the common steel member sizes used in australia which you can add in cross section view, top view or side view. Would be good if could add t-bars in there somehow too. had little look but couldn't work out exactly how to do it. i can edit the shapes that are currently in place but not sure how to add in new shapes and sizes.. edit - with this stl routine it was originally set up to also load a US version of the member sizes but i've tweaked it so STL only opens the aus version as i have no need for US sizes. i think the info for the US sizes are still there so if you want those you will need to amend the routine slightly Stl.zip
You dont need to load all the lisps, if you use say a custom lisp and auto load it, inside you have all your Le lisps set via AUTOLOAD so when you type the command it loads the correct lisp. I have like 15 of them. Type "zzz" etc (autoload "COPY0" '("COPY0")) (autoload "COPYCOMMAND" '("ZZZ")) (autoload "COVER" '("COVER")) (autoload "DIMFLIP" '("DIMFLIP")) (autoload "DRAWXFALL" '("DRAWXFALL")) (autoload "DRAWPIPE" '("DRAWPIPE"))
UnFormat.lsp does not work in Autocad 2021
Can the code not depend on the values of "LISPSYS" (0, 1, 2)? -
Not in my experience, but it's possible. -
That's a point - forget what I said. -
But after changing LISPSYS, the code only worked after restarting Autocad... So it's impossible to configure it in the code?
