dimjogline plus in dimension ... help
To indicate the 'jog' position 1 to 1, insert this code after the clause ((= "DIMENSION"... (entget e) )))) (if (not (tblsearch "APPID" "ACAD_DSTYLE_DIMJAG_POSITION")) (regapp "ACAD_DSTYLE_DIMJAG_POSITION") ) (if (setq pt (getpoint "\nJOG: Pick a point on the DIMENSION line")) (entmod (append (entget e) (list (list -3 (list "ACAD_DSTYLE_DIMJAG_POSITION" '(1070 . 387) '(1070 . 3) '(1070 . 389) (cons 1010 pt)))))) ) -
Hi Do you want to place the 'jog', indicating its location in each case, or in a predetermined location? - Today
ACE D joined the community
Lee Mac started following Text box auto resize
gerundg joined the community
I downloaded the code and ran it. No problem here. I made sure to change the Defined Width property and to add a mask and a frame. That way the change is obvious once it happens. Is it possible you're using it on text and not mtext? Because the function excludes anything that's not mtext.
tphu0022 joined the community
Automatically add text to a table
shokoufeh replied to shokoufeh's topic in AutoLISP, Visual LISP & DCL
Great. It worked. Thanks -
Monster joined the community
I think Lee Mac is onto something, I just can't make it work just like IndianaJackson said, nothing happened. Did anyone manage to make it work?
mhupp started following dimjogline plus in dimension ... help
mhupp replied to leonucadomi's topic in AutoLISP, Visual LISP & DCL
Also you can return the vla-object list with foreach by wrapping it in mapcar. eliminating having to use (setq o (vlax-ename->vla-object e)). Pulling the vla-object name before the cond means your checking the variable rather then check the entity up to 3 times. ; Original by RonJonP, edited by P. Kenewell, updated by Mhupp (defun c:ltx (/ D O S) (vl-load-com) (setq D (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark D) (if (setq s (ssget ":L" '((0 . "*TEXT,DIMENSION")))) (foreach o (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))) (setq typ (vla-get-ObjectName o)) (cond ((= typ "AcDbText") (vla-put-textstring o (strcat "%%O" (vl-string-subst "" "" (vl-string-subst "" "%%O" (vla-get-textstring o))))) ) ((= typ "AcDbMText") ... ) ((= typ "AcDbDimension") ... ) ) ) ) (vla-endundomark D) (princ) ) -edit also useing the (vla-startundomark allows you to have things selected before you run the command. - Last week
Good old fashioned google 1st found this not sure if helpful. https://help.autodesk.com/view/ACDMAC/2025/ENU/?guid=GUID-E0859F66-985A-4A20-BCB4-1B57D24DC100 -
@eldon has certainly given you the correct answer. Our title blocks were an A1 sheet but we plotted hard copy & PDF most times to be a A3 sheet. The was produced by setting the scale factor in "PLOT" to 1=2 so a 1:250 viewport would be 1:500 in an A3, so objects could be scaled. So we never mixed and matched the title blocks size. Only used one size so you probably need to think about that. If you stick with A3 you can probably have 2 viewports per layout at 1:100.
leonucadomi started following dimjogline plus in dimension ... help
hello all: There are dimensions I need to do this to. I have a routine to do this It would be possible to do everything in a single selection I mean select the dimension and place the break and the line over the text I await comments and here I put the code, thank you ; Original by RonJonP, edited by P. Kenewell (defun c:ltx (/ o s) (setvar "cmdecho" 0) (command "._undo" "_be") (if (setq s (ssget ":L" '((0 . "*TEXT,DIMENSION")))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq o (vlax-ename->vla-object e)) (cond ((= "TEXT" (cdr (assoc 0 (entget e)))) (vla-put-textstring o (strcat "%%O" (vl-string-subst "" "" (vl-string-subst "" "%%O" (vla-get-textstring o)) ) ) ) ) ((= "MTEXT" (cdr (assoc 0 (entget e)))) (vla-put-textstring o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textstring o)) ) ) ) ) ((= "DIMENSION" (cdr (assoc 0 (entget e)))) (if (= (vla-get-textoverride o) "") (vla-put-textoverride o "\\O<>") (vla-put-textoverride o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textoverride o)) ) ) ) ) ) ) ) ) (command "._undo" "_end") (setvar "cmdecho" 1) (princ) )
Linking viewport to what it shows
SLW210 replied to Someone_Pro's topic in AutoCAD Drawing Management & Output
You didn't post this in one of the code forums. I have no idea what settings you can modify, maybe you should actually post something. What type of code are you using? -
groutiles joined the community
Function to calculate Mtext Justification based on Rotation
I am not gonna lie, its cool!!!! Maybe I can create a separate function have this as my mtext (after some polishing and maybe a menu setting). I will spend sometime and try and remove the FFL function and just keep the text function with prefix suffix, offset, and mouse movement and post it here. -
Someone_Pro replied to Someone_Pro's topic in AutoCAD Drawing Management & Output
Thank you for your reply! I was not the one who developed the code so I can only modify the sittings as they are. And it'll only let me freeze or thaw layers. I was hoping I can just freeze the VP layer to stop what's inside from printing when lunching the code. But it seems that won't be possible. -
If you were to use an A2 paper size at 1 to 50, the viewport areas should be much closer.
The difference of scaling between metric paper sizes is the square root of two. So you would have to scale the A3 to 70.7143 for the two sheets to match. However, with the paper margins and any title block requirements, the actual scaling could alter so that the viewport areas would match.
Changing font face/style at once
qwer replied to jay-d's topic in AutoCAD Drawing Management & Output
(defun c:ResetMTXT () (prompt "\nSelect multiple MTEXT entities to modify their content...") ;; Get selection of MTEXT entities (setq sel (ssget "_:S" '((0 . "MTEXT")))) ;; Filter only MTEXT objects ;; Check if there are selected entities (if sel (progn ;; Loop through all selected entities (setq count (sslength sel)) ;; Get count of selected entities (setq i 0) ;; Initialize iteration index (while (< i count) ;; Get the current entity (setq ent (ssname sel i)) ;; Get entity at index i (setq ename (entget ent)) ;; Retrieve entity properties ;; Extract the raw text value from associated code 1 (setq mtextContent (cdr (assoc 1 ename))) ;; Get the plain text content ;; Check if text contains both `;` and `}` (if (and (vl-string-search ";" mtextContent) (vl-string-search "}" mtextContent)) (progn ;; Get positions of `;` and `}` (setq startPos (+ (vl-string-search ";" mtextContent) 1)) ;; Position after `;` (setq endPos (vl-string-search "}" mtextContent)) ;; Position of `}` ;; Extract substring (include the last character by extending the length) (setq extractedContent (substr mtextContent startPos (+ (- endPos startPos) 1))) ;; Remove all occurrences of `;` (setq cleanedContent (vl-string-subst "" ";" extractedContent)) ;; Replace all occurrences of `\P` with newline characters (`\n`) (setq formattedContent cleanedContent) (while (vl-string-search "\\P" formattedContent) ;; Loop to replace all occurrences (setq formattedContent (vl-string-subst "\n" "\\P" formattedContent)) ) ;; Clear and set the new formatted content in the MTEXT entity (setq newEname (subst (cons 1 formattedContent) (assoc 1 ename) ename)) ;; Update group 1 (entmod newEname) ;; Modify the entity in the drawing (entupd ent) ;; Update the entity in the drawing ) ;; Feedback if delimiters are missing (prompt (strcat "\nMTEXT entity at index " (itoa i) " does not contain both ';' and '}' characters.")) ) ;; Increment index to proceed to the next entity (setq i (1+ i)) ) ;; Notify user that processing is complete (prompt "\nAll selected MTEXT entities processed and updated successfully.") ) ;; Error if no MTEXT entities are selected (prompt "\nNo MTEXT entities selected.") ) (princ) ;; Quiet exit ) (princ "\nCommand 'ResetMTXT' loaded. Type ResetMTXT to run it.") (princ) -
grain started following Trouble displaying drawing in Viewport
I have a drawing made in model space and displayed at 1:100 in an A4 Viewport Landscape layout. No problem, but when I open a second layout using an A3 paper size I assumed the drawing would automatically fit if scaled at 1:50, however, the drawing appears cropped. Please help me understand what I may be expecting or doing wrong.
qwer joined the community
where do you find Penn Foster Cad files for coursework?
ReMark replied to LrdDracul's topic in Student Project Questions
Those course (i.e. - project) files would only be available to actual paying students although if you were to search through the many threads re: Penn-Foster you could conceivably find individual project files students have posted copies of over the years. For example, the Oleson Village Project. What is your interest in the files? -
You can turn the viewport off and everything in it will not plot. Frozen layers will still plot, you need to turn them off. -
gaspibarna joined the community
Emmanuel Delay replied to shokoufeh's topic in AutoLISP, Visual LISP & DCL
I think this is what you want. Command ATTT (vl-load-com) ;; ATTT for Add Text To Table (defun c:ATTT ( / rowstart obj texts i x x_vals x_vals_sorted) (setq rowstart (getint "\nStart Row (row 1 = the row of 000): ")) (setq obj (vlax-ename->vla-object (car (entsel "\nPick table: ")))) (princ "\nSelects the green title objects: ") (setq texts (ssget (list (cons 0 "TEXT") (cons 8 "TEXT-0.3")))) (setq x_vals (list)) (setq i 0) (repeat (sslength texts) (setq x (nth 0 (cdr (assoc 10 (entget (ssname texts i)))))) (setq x_vals (append x_vals (list x))) (setq i (+ i 1)) ) ;; sort the x-values (setq x_vals_sorted (vl-sort-i x_vals '<)) (setq i 0) (setq col 0) (repeat (sslength texts) (setq text (ssname texts (nth i x_vals_sorted))) (setq title (cdr (assoc 1 (entget text)))) (setq row (+ i rowstart)) (vla-settext obj row col title) (setq i (+ i 1)) ) (princ) ) -
If you just want to add to end of a table it is easy as there is a function of Vla-insertrow so just do that for the extra text you want I would look at a selection set. So can do in random order or some sorted list of the selection set. Could then read the entire table and resort it if required.
Emmanuel Delay started following Automatically add text to a table
I think based on something Bigal wrote, link in the code. Command TEST (feel free to rename) - User selects the table - User picks the start row. Fill in 1 for the row of 000, Fill in 2 for the row of 001, ... (you can hardcode this (setq row 1) if you will always start with 1 - User selects the title objects, the green text objects "GENERAL NOTES 0" ... one by one ;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/user-text-to-existing-table-cells/td-p/12238012 ;;You can get tables using ssget. ;; ;;I just posted this, the 0 0 is the title, 1 1 is 1st cell in header (vl-load-com) (defun c:test ( / obj rows cols row col value_ cellvalue) (setq obj (vlax-ename->vla-object (car (entsel "\nPick table: ")))) (setq rows (vlax-get-property obj 'rows)) (setq cols (vlax-get-property obj 'columns)) ;; get value of a cell ;;(setq col (getint "\nColumn: ")) ;;(setq row (getint "\nRow: ")) ;;(setq cellvalue (vlax-variant-value (vla-GETCELLVALUE OBJ row col))) ;;(princ "\n") ;;(princ cellvalue) ;;;;;;;;;;;; (setq col 0) (setq row (getint "\nStart Row (row 1 = the row of 000): ")) (princ "\nNow select texts: ") (while (setq title_obj (entsel "\ntitle object: ")) (setq title (cdr (assoc 1 (entget (car title_obj))))) ;;So if you know where "REVISION" is row & column can check easy then use next to put values. (vla-settext obj row col title) (setq row (+ row 1)) ) ) Happy with this? We can quite easily let you select all the all the frames, and read all the Text objects on layer "TEXT-0.3", sort from left to right, ... then auto fill in the table If you want -
LrdDracul started following where do you find Penn Foster Cad files for coursework?
LrdDracul posted a topic in Student Project Questions
I have looked everywhere for coursework cad files and haven't found anything. any help would be appreciated It tells you to go to 'X' file, but it doesn't exist. -
Someone_Pro started following Linking viewport to what it shows
Hello, Can anyone help me with my dilemma. I'm doing AutoCAD automation and I want a schedule to not shows at time but show at other times. The schedule is shown through a viewport. I have tried making a costume viewport layer for it and freezing it. But freezing the layer of the vp does not seem to stop what inside the vp from printing. So is there an option to link the viewport to what it shows so if I freeze the vp layer it won't print what it shows.
CADTutor started following New user registrations
Hi All, This is just to let you know that we have recently had a problem with the validation of new user registrations. This meant that some people will not have been able to register for the forum. This must have been frustrating and I apologise for any inconvenience this may have caused. The problem with the anti-spam controls has now been fully resolved and all visitors are now able to register. Thanks for your continued support, David
- 1
Dynamic blocks with alignement parameter and attribute text
Alain.j posted a topic in AutoCAD Drawing Management & Output
How to keep attribute's text horizontal (rotation =0) by dynamic blocks with alignement parameter ? i see a lot of info for keeping text horizontal by block rotation but not for block alignement.
