ronjonp started following Break Polyline at different depth
ronjonp replied to Mohamed Haytham's topic in AutoLISP, Visual LISP & DCL
Another for fun: (defun c:foo (/ a b el l s) ;; RJP » 2025-07-21 ;; Creates separate polyline segments preserving widths etc.. (cond ((setq s (ssget '((0 . "LWPOLYLINE")))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq el (entget e)) (setq a (append (reverse (member '(100 . "AcDbPolyline") (reverse el))) '((90 . 2)))) (setq b (vl-remove-if-not '(lambda (x) (member (car x) '(10 40 41 42))) el)) (while (cddddr b) (setq l nil) (setq l (list (car b) (cadr b) (caddr b) (cadddr b))) (setq b (cddddr b)) (entmakex (append a (append l (list (car b) (cadr b) (caddr b) (cadddr b))))) ) (entdel e) ) ) ) (princ) ) -
Nikon replied to Mohamed Haytham's topic in AutoLISP, Visual LISP & DCL
Try this code ;; author ::Jaifl:: ;; divides polylines into separate segments, preserving thickness, color, layer (defun c:SplitPlSeg ( / ss i ent elist points widths bulges n j p1 p2 w1 w2 bulge color layer ltype lweight transp) (setq ss (ssget '((0 . "LWPOLYLINE")))) (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq elist (entget ent)) (setq color (assoc 62 elist)) (setq layer (assoc 8 elist)) (setq ltype (assoc 6 elist)) (setq lweight (assoc 370 elist)) (setq transp (assoc 440 elist)) (setq points '() widths '() bulges '()) (foreach x elist (cond ((= (car x) 10) (setq points (append points (list (cdr x))))) ((= (car x) 40) (setq widths (append widths (list (cdr x))))) ((= (car x) 41) (setq widths (append widths (list (cdr x))))) ((= (car x) 42) (setq bulges (append bulges (list (cdr x))))) ) ) (setq n (length points)) (setq j 0) (while (< j (1- n)) (setq p1 (nth j points)) (setq p2 (nth (+ j 1) points)) (setq w1 (nth (* j 2) widths)) ; Start width (setq w2 (nth (1+ (* j 2)) widths)) ; End width (setq bulge (if (< j (length bulges)) (nth j bulges) 0.0)) (setq newent (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") layer ) (if color (list color) '()) (if ltype (list ltype) '()) (if lweight (list lweight) '()) (if transp (list transp) '()) (list (cons 100 "AcDbPolyline") (cons 90 2) (cons 70 0) (list 10 (car p1) (cadr p1)) (cons 40 w1) (cons 41 w2) (cons 42 bulge) (list 10 (car p2) (cadr p2)) (cons 40 w2) (cons 41 w2) ) ) ) (entmake newent) (setq j (1+ j)) ) (entdel ent) ; delete the original polyline (setq i (1+ i)) ) ) (princ "There are no selected polylines.") ) (princ) ) -
Mohamed Haytham started following Break Polyline at different depth
Hi, It would be great if you can help me with the following. I have multiple polylines where they have different widths (Originally creating by fillet a line with width 1 and a line with width 2). Is there a way to split them to the original state where the are 2 lines and each has it's actual widths? I am attaching a file with the issue, and the expected solution, but this is only file with 2 polylines as an example, but this issue is happening with a file having more than 1000 polyline. Break Polyline at different depth.dwg
How to Extend Lines to shape 2D Polyline
SLW210 replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
AutoCAD refuses to double extend for some reason. - Yesterday
Danielm103 started following Extract Block Icons with Python
updating samples, this one is cool import traceback from pyrx import Rx, Ge, Gs, Db, Ap, Ed import wx import os # extract the image and save it def extractThumbnailsFromDb(db: Db.Database, path: str, targetpath: str): path_without_extension, _ = os.path.splitext(path) dwgname = os.path.basename(path_without_extension) bt = Db.BlockTable(db.blockTableId()) for name, id in bt.asDict().items(): blk = Db.BlockTableRecord(id) if ( blk.isLayout() or blk.isAnonymous() or blk.isFromExternalReference() or blk.isFromOverlayReference() ): continue img: wx.Image = Gs.Core.getBlockImage(id, 128, 128, 1.0, [0, 0, 0]) img.SaveFile("{}/{}_{}_128.png".format(targetpath, dwgname, name), wx.BITMAP_TYPE_PNG) # read the database in its own function so the database object # gets disposed after the blocks (gc is fifo) def extractThumbnails(path: str, targetpath: str): db = Db.Database(False, True) db.readDwgFile(path) db.closeInput(True) extractThumbnailsFromDb(db, path, targetpath) # register a new command # ensure the targetpath exists @Ap.Command() def doit(): try: targetpath = "E:/temp/icons" os.makedirs(targetpath, exist_ok=True) for path in Ap.Application.listFilesInPath("E:\\temp", ".dwg"): extractThumbnails(path, targetpath) except Exception as err: traceback.print_exception(err)
- 1
ScottMC replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
BIGAL that helps for sure! All the more inspires me to dig deeper into your posts/tips period. - Last week
I just started to do some VB in SolidWorks. So this is my first try: Option Explicit Dim swModel As SldWorks.ModelDoc2 Sub main() Dim aLine As SldWorks.SketchSegment Dim line As Object Set swModel = Application.SldWorks.ActiveDoc swModel.SketchManager.Insert3DSketch True 'tetrahedron side length Dim L As Double 'doh... number of segments Dim segs As Integer L = 10 segs = 22 Dim Xa, Ya, Za As Double 'point A is in the origin Xa = 0 Ya = 0 Za = 0 Dim Xb, Yb, Zb As Double 'point B is along Ox Xb = L Yb = 0 Zb = 0 Dim Xc, Yc, Zc As Double 'point C is in xOy plane Xc = L / 2# Yc = L * Sqrt(3) / 2# Zc = 0 Dim Xv, Yv, Zv As Double ' point V is right above the centroid of ABC Xv = L / 2# Yv = L * Sqrt(3) / 6 Zv = L * Sqrt(6) / 3# Dim i As Integer 'point1 walks along AV Dim Dx1, Dy1, Dz1, Dx2, Dy2, Dz2 As Double Dx1 = (Xv - Xa) / segs Dy1 = (Yv - Ya) / segs Dz1 = (Zv - Za) / segs 'point2 walks along BC Dx2 = (Xc - Xb) / segs Dy2 = (Yc - Yb) / segs Dz2 = (Zc - Zb) / segs 'point3 walks along BV Dim Dx3, Dy3, Dz3, Dx4, Dy4, Dz4 As Double Dx3 = (Xv - Xb) / segs Dy3 = (Yv - Yb) / segs Dz3 = (Zv - Zb) / segs 'point4 walks along CA Dx4 = (Xa - Xc) / segs Dy4 = (Ya - Yc) / segs Dz4 = (Za - Zc) / segs 'point5 walks along CV Dim Dx5, Dy5, Dz5, Dx6, Dy6, Dz6 As Double Dx5 = (Xv - Xc) / segs Dy5 = (Yv - Yc) / segs Dz5 = (Zv - Zc) / segs 'point6 walks along AB Dx6 = (Xb - Xa) / segs Dy6 = (Yb - Ya) / segs Dz6 = (Zb - Za) / segs 'draw those lines: For i = 0 To segs 'lines between point1 and point2: Set aLine = Draw(Xa + Dx1 * i, Ya + Dy1 * i, Za + Dz1 * i, Xb + Dx2 * i, Yb + Dy2 * i, Zb + Dz2 * i) 'the lines between point3 and point4: Set aLine = Draw(Xb + Dx3 * i, Yb + Dy3 * i, Zb + Dz3 * i, Xc + Dx4 * i, Yc + Dy4 * i, Zc + Dz4 * i) 'the segments between point5 and point6 Set aLine = Draw(Xc + Dx5 * i, Yc + Dy5 * i, Zc + Dz5 * i, Xa + Dx6 * i, Ya + Dy6 * i, Za + Dz6 * i) Next i ' Close sketch swModel.SketchManager.InsertSketch True 'swModel.ClearSelection2 True End Sub Function Draw(X1, Y1, Z1, X2, Y2, Z2 As Double) As SldWorks.SketchSegment Set Draw = swModel.SketchManager.CreateLine(X1, Y1, Z1, X2, Y2, Z2) End Function
GLAVCVS replied to SLW210's topic in AutoLISP, Visual LISP & DCL
Hi, Here’s a preview of what the new Offsetea will look like. Sorry for the delay — I’ve had other things to take care of. Still, I believe the wait will be worth it. Each improvement leads to another... but I think I'm going to stop here I still need to fine-tune a few things, but the final result will be very close to what you see in the clip: -Projection of straight line segments -3 projection modes for arc segments (one of them is the same as the one Evgeny proposed in his code) + 1 custom mode that I still have to write. Switching between modes is as simple as pressing keys 1, 2, 3, or 4 -Snapping to adjust position with the cursor -Real-time "texting" using grread in all cases -Voice assistance to provide useful info I'll try to finish it this week, but I can’t promise anything — I’ve got quite a bit of work. Still, I hope that with this small preview I’ve earned a bit of your patience Offsetea Reloaded.mp4 -
mhupp replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
Going to have to click a little then. or use fence like BIGAL shows. -
BIGAL replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
Looks good, next option would be "Add breaklines" to make the TIN take into account edges.
Consider this link with multiple solutions https://www.theswamp.org/index.php?topic=53993.0 -
What version of AutoCAD Electrical? Unless it's changed, you go to Drawing Properties under the Drawing Format tab and select "Vertical" under Ladder Defaults. Maybe this will help... AutoCAD Electrical 2025 Help | To Work With Ladders | Autodesk
How to deploy list of Lisps to everyone in the organisation - AutoCAD LT
Sorry BigAl, I was forgetting BricsCAD - I've never used it so no sure what it has and doesn't -
Thanks, that works better -
GLAVCVS replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
I spoke too fast -
Mountain_XD replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
I agree with you but what if there are a lot of polylines and lines? -
check your 'projmode if 'extend too' entity is on a different 'Z' I like [2] -
mhupp started following How to Extend Lines to shape 2D Polyline
You don't need a lisp for that. just the extend command. -
Oh, explode will create polylines and faces
KraZeyMike started following Lee Mac
There’s a sample point drawing on github TIN, Major and Minor and have transparency, but they are currently hard coded to TIN 50%, Minor 50%, Major %100
Danielm103 started following An Open-source TIN entity
Just having some fun… A custom object that does triangulation and contours. Its very fast (I think) I’ve only tested on one drawing; Binaries are in the release folder here (AutoCAD 2025-2026, ZwCAD 2025-2026, GstarCAD 2026) https://github.com/CEXT-Dan/ArxTin Command: TINNER Select objects: Specify opposite corner: 41769 found Select objects: Enter a major contour interval: 100 Enter a minor contour interval: 10 CArxTinUIApp::CArxTinUIApp_tinner Done , 0.000235 seconds Command: LIST Select objects: CEXTDBTIN Layer: "tin" Space: Model space Color: BYLAYER Linetype: "Continuous" Handle = cb4cf Number of points: 41769 Number of triangles: 82720 Minimum elevation: 5503.992569 Maximum elevation: 7060.996567 2D area: 37224000.000000 3D area: 47335595.172935
Please help me Extend Lines to Polyline. Thanks so much ! Extend Lines to Polyline.dwg
@Steven P did trusted paths above including check if running Bricscad which does not have trusted paths. Another way to push lisps to a pc is you can via lisp unzip a ZIP file to a location, advantage is only one file rather than copying a whole directory. I use this as part of install lisps. Its super fast. Just need a "Filename" (startapp (strcat "powershell -command Expand-Archive -Path '" filename "' -DestinationPath 'C:/xxx-CAD-TOOLS' -FORCE")) (alert "programs unzipped to C:/xxx-CAD-TOOLS") -
@GLAVCVS & @leonucadomi have a look at this it,s not code solution but rather a number of defuns to talk to Excel, read and write plus more. I keep adding functions. Alan Excel library.lsp
