  1. Today
  2. Here’s example from a different drawing where I tested both approaches. In this case, the shrinkwrap command wasn’t able to generate a boundary at all and returned a “failed to create shrinkwrap” message for this selection. Using the same input, I tried an alternative approach i.e. EGBoundary and was able to generate a clean, continuous outer boundary for the full shape. Sharing the comparison and .dwg file itself here. From what I’ve tested so far, the settings command seems to give a bit more control over things like automatic and manual tolerance handling as well as output customization (layer, color, etc.), which probably helps in these more complex cases. I’m still exploring it, but that flexibility seems to make a difference compared to the standard commands. For Clarification:- I am using AutoCAD Architecture 2026 and EGBOUNDARY for AutoCAD listed on their website. Part 6 Assm.dwg
  3. Ok just ran all 488 values and there may be a problem in your sample dwg the Chainage labels are not at correct chainage compared to the start point. I looked and the block did not align properly so checked the distance from start point for a random label and the blocks inserted are at the chainage but your label is not. The blue line is a circle with the radius set to the correct chainage you can see goes through middle of block but label does not match. So here is some code, note the blocks have been made 1 unit in length. I also changed the Excel to work out the mid point yes can be done with lisp but really why not use Excel. The dwg attached shows the problem. The Excel I used is attached. Yes part two needs to be done but need some answers to what I see as lots of problems in future dwg's. Drawing1-test.dwg test.lsp Book1.xlsx
  4. @mhupp Command: Command: AP APPLOAD PIPE_InsertBlockFromCSV1.lsp successfully loaded. Command: Type InsertBlocksFromCSV or IBC to run. Command: Command: INSERTBLOCKSFROMCSV ; error: bad DXF group: (41)
  5. @BIGAL those chainage only for refernce as the final output is totlay different those are only to place dwc and pcc i was try to scale down the blcok but the size of block are comiing short i am not able understand what is the wrong on this i just need those block will place between those chainages whicha re mentioned in excel sheet otherwise i have to place manualy and i have lots of file like this actually this is the chainage which means if we 250.408-250.420=12meter so my dwc pipe length is 12m at this point what i do i was calculate mid difference of those chainage and i was place mid chiange in autocad (as seen my dwg u can check)now i run the lisp which place those block like the align command it work so in taht portion dwc length should be 12 meters 6meters from each side of that 250414 but the isse is block length comming 8m instead of 12soemwhere the differnce is 2m somewhere 4 as the y scale is only for width so thats the not issue because i will change it by selecting all one time also i am not able to uderstand what u mean for 'scaled like 10 x timee' is anything wrong in my block? sample.dwg
  6. Yesterday
  7. I am working on something. Its almost there reads data from Excel direct. Yes inserts correct a block 12 long. Just a bit busy with other stuff. maybe later today. Ok a another comment to get the correct position for the block easiest way is using getpointatdist function. So must work out the start chainage of the pline then each point is easy to work out as you have a Midpoint value. I can see a problem and don't know why your distances are in mm. More importantly is the text must have 3 decimal places and this is a problem when a Chainage is xxx01, no third decimal. (setq ch "12301") (/ (atof ch) 1000.) 12.301 SHOULD BE 123.01 Is there a reason the text can not be a true metre text "123.456" then can have any number of decimals.
  8. All the dxf data can be handled with atof instead of checking numberp (atof "10") ; => 10.0 (atof "-10.5") ; => -10.5 (atof "12abc") ; => 12.0 starts with a number will also return a real. (atof "abc123") ; => 0.0 (atof "hello") ; => 0.0 might not have gotten the right file the csv only has 3 columns so (if (< (length data) 6) is always be true and i don't think (continue) is used in lisp should be giving you an error. (if (< (length data) 6) (setq skip nil) (setq skip T) ) (if skip (progn (setq blkname (nth 0 data)) ... ) ;progn (princ (strcat "\nBlock definition '" blkname "' not found in the drawing. Skipping.")) ) PIPE_InsertBlockFromCSV.lsp
  9. @BIGAL i was try to scale down the blcok but the size of block are comiing short i am not able understand what is the wrong on this i just need those block will place between those chainages whicha re mentioned in excel sheet otherwise i have to place manualy and i have lots of file like this actually this is the chainage which means if we 250.408-250.420=12meter so my dwc pipe length is 12m at this point what i do i was calculate mid difference of those chainage and i was place mid chiange in autocad (as seen my dwg u can check)now i run the lisp which place those block like the align command it work so in taht portion dwc length should be 12 meters 6meters from each side of that 250414 but the isse is block length comming 8m instead of 12soemwhere the differnce is 2m somewhere 4 as the y scale is only for width so thats the not issue because i will change it by selecting all one time also i am not able to uderstand what u mean for 'scaled like 10 x timee' is anything wrong in my block?
  10. Please share some examples where the SHRINKWRAP is failing in Civil or Architecture, maybe a solution can be found. EGBOUNDARY sounds like a great solution for you, hopefully it's a good enough replacement for others looking to replace TotalBoundary and SuperBoundary.
  11. your question has helped me solve a problem in my autocad drawing file, so i would like to thank you for that.
  12. asos2000
    Layer Table (Lines and Text)
    My 5 cent (defun c:LLD () (c:LayerLegend)) (defun c:LayerLegend ( / df i l ln p1 pt sp DSC ENT NM ) ;; Lee Mac 2011 (vl-load-com) (if (and (setq pt (getpoint "\nSpecify Point for Legend: ")) (setq ln (* 100 (getvar 'TEXTSIZE))) ;(getdist "\nSpecify Length of Lines: " pt)) (setq pt (trans pt 1 0)) (setq i -1) (setq sp (* 2.5 (getvar 'TEXTSIZE))) ) (while (setq df (tblnext "LAYER" (null df))) (if (/= 16 (logand 16 (cdr (assoc 70 df)))) (setq l (cons (cdr (assoc 2 df)) l)) ) (setq l (acad_strlsort l)) )) (foreach n l (setq ent (vlax-ename->vla-object (tblobjname "LAYER" n))) (setq dsc (vlax-get-property ent 'Description)) (setq nm (vlax-get-property ent 'name)) (setq lc (itoa (vla-get-color ent ))) (entmakex (list (cons 0 "LINE") (cons 8 n) (cons 6 "ByLayer") (cons 62 256) (cons 10 (setq p1 (polar pt (* 1.5 pi) (* (setq i (1+ i)) sp))) ) (cons 11 (polar p1 0. ln)) (cons 370 -1) ) ) (entmakex (list (cons 0 "TEXT") ;*** (cons 1 (strcat n " : " lc " : " dsc)) ;* (the string itself) (cons 6 "BYLAYER") ; Linetype name (cons 7 (getvar 'TEXTSTYLE)) ;* Text style name, defaults to STANDARD, not current (cons 8 n) ; layer (cons 10 p1) ;* First alignment point (in OCS) (cons 11 p1) ;* Second alignment point (in OCS) (cons 39 0.0) ; Thickness (optional; default = 0) (cons 40 (getvar 'TEXTSIZE)) ;* Text height (cons 41 1.0) ; Relative X scale factor, Width Factor, defaults to 1.0 (cons 62 256) ; color (cons 71 0) ; Text generation flags (cons 72 0) ; Horizontal text justification type (cons 73 1) ; Vertical text justification type (cons 210 (list 0.0 0.0 1.0)) (cons 370 -1) ))) (princ) )
  13. Ah got it — thanks for clarifying that, I wasn’t aware the Architecture toolset was included. That makes sense. I also had a chance to try the shrinkwrap command on a different setup (a friend using Civil), and saw similar behavior in the more detailed regions. From the result you shared, it does get quite close, but I’m still seeing some irregularities around the boundary in those complex areas, especially in some of my other projects. That’s been the tricky part in my case — getting a consistently clean outer boundary across the full shape. I’ve been testing EGBoundary across different setups — it’s been working consistently for me in AutoCAD and BricsCAD so far. I haven’t personally tried it yet in GstarCAD or ZWCAD, though I’ve seen them mentioned as compatible with GstarCAD and ZWCAD on their official website. Really appreciate you taking the time to test and share that. Thank you !!
  14. BIGAL
    Hello everyone!
    @mhupp Layer Filters the "Architect" shows "layers 1 & Layer 2" only. Sorry don't have code, but a google revealed in one post of so many suggestions.
  15. Last week
  16. Firstly your block is 9.4 long so, at a scale of 12 its 12x9.4 in length. So 1st step is scale down the block by 0.1 and resave then it is basically 1 unit long so a scale of 12 will be a fraction under a true 12 length. The other question is then what sclae factor to use for the Y value but this can be calculated as a factor of the scale and block height Y so they are all the same height. If you want it to be a true 1 unit can rescale to match that and save block. Hint 1.05843568371114 I don't have a problem working out the length or the insertion point. Those values are in your Excel example. You just need to work out the chainage of the start end of the pline. For me I would just start brand new code easier, will see what I can do and will read the Excel direct.
  17. mhupp
    Hello everyone!
    Still don't know what your talking wanting. you can only select things on the layers. this will make a selection set of whats on those layers and on current tab. (setq ss (ssget "X" (list (cons 410 (getvar "CTAB")) (cons 8 "Layer[12]")))) (sssetfirst nil ss)
  18. @BIGAL actually this is the chainage which means if we 250.408-250.420=12meter so my dwc pipe length is 12m at this point what i do i was calculate mid difference of those chainage and i was place mid chiange in autocad (as seen my dwg u can check)now i run the lisp which place those block like the align command it work so in taht portion dwc length should be 12 meters 6meters from each side of that 250414 but the isse is block length comming 8m instead of 12soemwhere the differnce is 2m somewhere 4 as the y scale is only for width so thats the not issue because i will change it by selecting all one time also i am not able to uderstand what u mean for 'scaled like 10 x timee' is anything wrong in my block?
  19. The DWC block has a insertion point at mid point, Still not sure about the wrong length and 4m dist. Can you also provide a dwg with before and after so can see how say first 3 blocks should look. add the excel data as MTEXT etc. Yes can read the Excel direct no need for a CSV. Ok understand in Excel from 250.408 to 250.420 so point is (250.408+250.420)/ 2.0 where label is. So need to establish start chainage of pline 250414 compared to start distance away and get that start point X&Y. Your DWC block appears to be scaled like 10 x times. Why is it not 1 unit long say actual is 0.9447 that fits in 1 unit. The scale for 12 would be just that. Also what is Y scale ? Does the block have a fixed height, Y ? Again edit block 1st. Then can do some code to match.
  20. Steven P
    TEXT REQUIRED
    Not sure for ZWCAD, but it Tamil font installed on your computer, you should be able to access it if it is
  21. in autocad i need to place block which was align in x scale i have lisp code too but the isseu is the block is placing wrongly i was place mid chainage of the point where i need to place those block but always it placing wrongly l;ike first length of my block is 12m but the code placing 8m 4 m each side i was attached all the input i have can anyone fix this Drawing2.dwg block.dwg PIPE_PlotBlocksFromCSV.lsp PIPE_Block.csv.xls.csv Book1.xlsx
  22. sd2006
    Hello everyone!
    @mhuppIt's like this For example , I have layer 1, layer 2 , layer 3 And I want to select layers 1 and 2, add them to the newgroup filter, and name it something like "architect".
  23. I NEED TO TYPE TAMIL FONT HOW TO DO IN ZWCAD
  24. As I mentioned already, AutoCAD Architecture is FREE with the Toolset. All you need to do is download it. Architecture Toolset in Autodesk AutoCAD | Features This looks like something Bricscad should incorporate as well. That's the reason I stopped working on the LISP, but I will probably try to get it finished up anyway.
  25. Thanks for sharing that and testing it. I’m currently using AutoCAD 2026 (standard), and from what I can see, the AECLINEWORKSHRINKWRAP functionality isn’t available in this version. It looks like it’s part of the Architecture/Civil toolsets, so accessing it would mean moving to something like Civil 3D or the AEC Collection, which is quite a big upgrade just to use this specific functionality. Really appreciate you taking the time to test it though.
  26. Thanks for pointing that out — I gave it a try on the same drawing. It actually handled the case surprisingly well and produced a clean outer boundary for the full shape, even with the gaps and more complex areas where the other approaches were struggling. Sharing the result here.
  27. Like @SLW210 I think you would be better off with a Windows Intel PC. Other CAD software that has MAC software is often reported as having niggly problems. Until there is a true MAC OS based say Autocad those problems may continue, in saying that there are some true MAC CAD programs out there. Autocad MAC has existed for like 30 years and still no true native version.
  28. Here is the result of the AECLINEWORKSHRINKWRAP in Archtecture. Engine Part Assembly_ArchSWrap.dwg
