  1. Today
  2. Hi CivilTechSource , I test your code but if you test it in my dwg will see that calculate a2 area as trapezoid !!! Thanks
  3. Hello! I am working in AutoCAD 2007/2008 and opened my AutoCAD this morning to find myself stuck in the TableBuilder screen which is odd because I never use TableBuilder. Anyway, can someone please help me leave the TableBuilder screen and return to my home screen where all of my tool icons reside? Thank you, Dave
  4. We are in 2025, do we still need to show the work? Would it not be easier to write a lisp that prompts you to select each side of polygon by specifying starting and end point and then you can have the lisp do a check between if trapezoid or parallelogram and then put in text the formula substituting the lengths? The below is AI generated code that seems to work fine in terms of differentiating between triangle rectangle trapezoid and parallelogram. The mtext showing the work has some boxes not sure why. (defun C:POLYAREA (/ pt1 pt2 pt3 pt4 pts shape-type area calc-text insert-pt) ;; Function to calculate distance between two points (defun get-distance (p1 p2) (sqrt (+ (expt (- (car p2) (car p1)) 2) (expt (- (cadr p2) (cadr p1)) 2)))) ;; Function to calculate area using shoelace formula (defun shoelace-area (point-list) (setq n (length point-list)) (setq area 0.0) (setq i 0) (while (< i n) (setq j (if (= i (1- n)) 0 (1+ i))) (setq xi (car (nth i point-list))) (setq yi (cadr (nth i point-list))) (setq xj (car (nth j point-list))) (setq yj (cadr (nth j point-list))) (setq area (+ area (* xi yj))) (setq area (- area (* xj yi))) (setq i (1+ i))) (abs (/ area 2.0))) ;; Function to check if vectors are parallel (for parallelogram/rectangle check) (defun vectors-parallel (v1 v2 tolerance) (setq cross-product (abs (- (* (car v1) (cadr v2)) (* (cadr v1) (car v2))))) (< cross-product tolerance)) ;; Function to check if vectors are perpendicular (for rectangle check) (defun vectors-perpendicular (v1 v2 tolerance) (setq dot-product (+ (* (car v1) (car v2)) (* (cadr v1) (cadr v2)))) (< (abs dot-product) tolerance)) ;; Function to get vector from two points (defun get-vector (p1 p2) (list (- (car p2) (car p1)) (- (cadr p2) (cadr p1)))) ;; Function to identify quadrilateral type (defun identify-quad (p1 p2 p3 p4) (setq v1 (get-vector p1 p2)) ; Side 1 (setq v2 (get-vector p2 p3)) ; Side 2 (setq v3 (get-vector p3 p4)) ; Side 3 (setq v4 (get-vector p4 p1)) ; Side 4 (setq tolerance 0.001) ;; Check if opposite sides are parallel (setq opposite1-parallel (vectors-parallel v1 v3 tolerance)) (setq opposite2-parallel (vectors-parallel v2 v4 tolerance)) (cond ;; Rectangle: opposite sides parallel AND adjacent sides perpendicular ((and opposite1-parallel opposite2-parallel (vectors-perpendicular v1 v2 tolerance)) "Rectangle") ;; Parallelogram: opposite sides parallel ((and opposite1-parallel opposite2-parallel) "Parallelogram") ;; Trapezoid: one pair of opposite sides parallel ((or opposite1-parallel opposite2-parallel) "Trapezoid") ;; General quadrilateral (t "Quadrilateral"))) ;; Function to create calculation text for triangle (defun triangle-calc-text (p1 p2 p3 area) (setq a (get-distance p1 p2)) (setq b (get-distance p2 p3)) (setq c (get-distance p3 p1)) (setq s (/ (+ a b c) 2.0)) ; semi-perimeter (setq sa (- s a)) (setq sb (- s b)) (setq sc (- s c)) (strcat "TRIANGLE AREA CALCULATION\\P" "Using Heron's Formula:\\P" "Side a = " (rtos a 2 3) " units\\P" "Side b = " (rtos b 2 3) " units\\P" "Side c = " (rtos c 2 3) " units\\P" "Semi-perimeter s = " (rtos s 2 3) " units\\P" "Area = √(s(s-a)(s-b)(s-c))\\P" "Area = √(" (rtos s 2 3) "×" (rtos sa 2 3) "×" (rtos sb 2 3) "×" (rtos sc 2 3) ")\\P" "Area = √" (rtos (* s sa sb sc) 2 3) "\\P" "Area = " (rtos area 2 3) " square units")) ;; Function to create calculation text for rectangle (defun rectangle-calc-text (p1 p2 p3 p4 area) (setq width (get-distance p1 p2)) (setq height (get-distance p2 p3)) (strcat "RECTANGLE AREA CALCULATION\\P" "Width = " (rtos width 2 3) " units\\P" "Height = " (rtos height 2 3) " units\\P" "Area = Width × Height\\P" "Area = " (rtos width 2 3) " × " (rtos height 2 3) "\\P" "Area = " (rtos area 2 3) " square units")) ;; Function to create calculation text for parallelogram (defun parallelogram-calc-text (p1 p2 p3 p4 area) (setq base (get-distance p1 p2)) ;; Calculate height using area formula: Area = base × height (setq height (/ area base)) (strcat "PARALLELOGRAM AREA CALCULATION\\P" "Base = " (rtos base 2 3) " units\\P" "Height = " (rtos height 2 3) " units\\P" "Area = Base × Height\\P" "Area = " (rtos base 2 3) " × " (rtos height 2 3) "\\P" "Area = " (rtos area 2 3) " square units")) ;; Function to create calculation text for trapezoid (defun trapezoid-calc-text (p1 p2 p3 p4 area) (strcat "TRAPEZOID AREA CALCULATION\\P" "Using coordinate method (Shoelace formula)\\P" "Point 1: (" (rtos (car p1) 2 3) ", " (rtos (cadr p1) 2 3) ")\\P" "Point 2: (" (rtos (car p2) 2 3) ", " (rtos (cadr p2) 2 3) ")\\P" "Point 3: (" (rtos (car p3) 2 3) ", " (rtos (cadr p3) 2 3) ")\\P" "Point 4: (" (rtos (car p4) 2 3) ", " (rtos (cadr p4) 2 3) ")\\P" "Area = ½|∑(xᵢyᵢ₊₁ - xᵢ₊₁yᵢ)|\\P" "Calculation: ½|(" (rtos (car p1) 2 3) "×" (rtos (cadr p2) 2 3) "-" (rtos (car p2) 2 3) "×" (rtos (cadr p1) 2 3) ") + " "(" (rtos (car p2) 2 3) "×" (rtos (cadr p3) 2 3) "-" (rtos (car p3) 2 3) "×" (rtos (cadr p2) 2 3) ") + " "(" (rtos (car p3) 2 3) "×" (rtos (cadr p4) 2 3) "-" (rtos (car p4) 2 3) "×" (rtos (cadr p3) 2 3) ") + " "(" (rtos (car p4) 2 3) "×" (rtos (cadr p1) 2 3) "-" (rtos (car p1) 2 3) "×" (rtos (cadr p4) 2 3) ")|\\P" "Area = " (rtos area 2 3) " square units")) ;; Main program starts here (princ "\\nPolygon Area Calculator") (princ "\\nSelect points in order (clockwise or counterclockwise)") ;; Get first point (if (setq pt1 (getpoint "\\nSelect first point: ")) (progn ;; Get second point (if (setq pt2 (getpoint pt1 "\\nSelect second point: ")) (progn ;; Get third point (if (setq pt3 (getpoint pt2 "\\nSelect third point: ")) (progn ;; Check if user wants to add a fourth point (setq pt4 (getpoint pt3 "\\nSelect fourth point (or press Enter for triangle): ")) (if pt4 ;; Four points - quadrilateral (progn (setq pts (list pt1 pt2 pt3 pt4)) (setq shape-type (identify-quad pt1 pt2 pt3 pt4)) (setq area (shoelace-area pts)) ;; Create appropriate calculation text (cond ((= shape-type "Rectangle") (setq calc-text (rectangle-calc-text pt1 pt2 pt3 pt4 area))) ((= shape-type "Parallelogram") (setq calc-text (parallelogram-calc-text pt1 pt2 pt3 pt4 area))) (t (setq calc-text (trapezoid-calc-text pt1 pt2 pt3 pt4 area)))) (princ (strcat "\\nShape identified: " shape-type)) (princ (strcat "\\nArea: " (rtos area 2 3) " square units"))) ;; Three points - triangle (progn (setq pts (list pt1 pt2 pt3)) (setq shape-type "Triangle") (setq area (shoelace-area pts)) (setq calc-text (triangle-calc-text pt1 pt2 pt3 area)) (princ (strcat "\\nShape identified: " shape-type)) (princ (strcat "\\nArea: " (rtos area 2 3) " square units")))) ;; Get insertion point for MText (if (setq insert-pt (getpoint "\\nSelect point to insert calculation text: ")) (progn ;; Create MText entity (entmake (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 insert-pt) ; insertion point (cons 40 2.5) ; text height (cons 41 50.0) ; reference rectangle width (cons 71 1) ; attachment point (top left) (cons 72 5) ; drawing direction (cons 1 calc-text) ; text string (cons 7 "STANDARD") ; text style (cons 210 '(0.0 0.0 1.0)))) ; normal vector (princ "\\nCalculation text inserted successfully!")) (princ "\\nText insertion cancelled."))) (princ "\\nThird point required.")) (princ "\\nSecond point required.")) (princ "\\nFirst point required.")) (princ)) ) ) ;; Command to run the function (princ "\\nPolygon Area Calculator loaded. Type POLYAREA to run.") (princ)
  5. BREAKUP is somewhat different from EXPLODE. BREAKUP is used to break a single object into its component parts without losing the original object’s properties. This command is particularly useful for complex objects like polylines, blocks, or other grouped entities. It allows you to manipulate individual components of an object while maintaining the overall integrity of the drawing. Not really sure what the real world difference would be if the "properties" are not needed after exploding. IIRC, it's useful for EXPLODING i.e. some of the Symbols, etc. from Mechanical and other verticals without losing the properties.
  6. CivilTechSource
    Help with Diesel Expression
    Thank you so much! After playing with lisp for over a two months now I am so happy that I can understand the above!
  7. Hi devitg, You delete parts of the original code . I use ; Set scale and text height (setq scl (getvar "useri1")) (setq ht (* 0.00003 scl)) To set the scale for a lot of the lisp I use , and I need this part too (initget "1 2") ;;; (setq t_spc (getkword "\n Insert calculations[1.Modelspace/2.Paperspace]? <1>: ")) I test the code you upload but The calculation on trapezoid is not fixed because can not understand that the paralilogram (a2) is not a trapezoid (a1) because the code check only if the lines is pararell and calculate the area of the trapezoid. Perhaps need son anngle check to understamd if it is paralilogram or trapezoid. Thanks
  8. MeGuinness
    text offset
    thanx for your reply, I'm new to inventor... learning , can you explain what to do with the file you shared please. thanx again
  9. The get area by co-ordinates method is a known mathematical formula why not just paste that into your dwg as a statement. Have a test shape like a square, with the example of calculations. Second comment this has been asked for before many years ago, it must be a particular country land title standard that must be shown. Sorry no idea where to start looking for the previous posts, maybe here or Forums/Autodesk.
  10. Yesterday
  11. BIGAL
    text offset
    Use Seants text to geom. or TXTEXP a built in explode text. TXTEXP Arial bold with a Oblique of 10. Then pedit multi, then extrude. Text 2 geom.zip
  12. One of the others ways to do this is to use a lisp and break the string into individual bits. As you have a "-" as a common item in the string you can blow it apart and rejoin. Thanks to Lee-mac parse lsp. Something like this. ; Parse string to a list ny Lee-mac (defun csv->lst (str ans / pos ) (if (setq pos (vl-string-position ans str)) (cons (substr str 1 pos) (csv->lst (substr str (+ pos 2)) ans)) (list str) ) ) (setq str "XXX-ZINC-XX-XX-DR-C-01000_S278 Sections") ; use (getvar 'dwgname) (setq newstr "" x 0) (setq ans (csv->lst str 45)) (repeat (- (length ans) 2) (setq newstr (strcat newstr (nth x ans) "-")) (setq x (1+ x)) ) (setq newstr (strcat newstr (nth x ans))) Ps ; tab 9 space 32 (chr 32) comma 44 semicolon 59 slash / 47 - 45
  13. Lisp give the correct Area The lsp have some error , I fix it as far as I know to do . See text file atached , dwg and lisp fixed You have to arrange ; Set scale and text height (setq scl (getvar "useri1")) (setq ht (* 0.00003 scl)) As you need fixed area-cal.LSP to check.txt get area by calculation.dwg
  14. I need to insert the calculation ananylic in specific drawings. If someone check the drawing ,need to know how I do the calculations.Thats why I want to update this code. Thanks
  15. @mhy3sx please upload the sample DWG with a mtext sample Mean while try the lisp file , it will put the area value at each polyline geografic center get area by calculation.dwg get-area.LSP
  16. MeGuinness
    text offset
    using inventor 2023
  17. MeGuinness
    text offset
    hi guys , is there a way to offset text ? i created the letters and then used the extruder command...cut..so to have the letters embossed to a surface, now i need to create the same letters but 4 mm thick that need to be snapped in on the surface embossed slots, i need to reduce the size slightly so the fit in the slots ...im able to offset anything that i created using LINES or Circle but not the letters . any help appreciated. thanx
  18. @mhy3sx Where you need to put area value .
  19. Someone just asked me about this command (BREAKUP) never heard of it, nothing on YT. I found this in the help file.. Is Explode not politically correct?
  20. @CivilTechSource sure thing. I actually figured out the 'misbehavior' based on an earlier response (it was me being stupid of course). I would love to add another grip to this thing to move the magenta part up and down from either the top or the bottom of the magenta, and have the grips 'slide' with the thing. So if I move the magenta part up with the top grip, the bottom grip goes along for the ride. Then if I slide back down with the bottom grip, the top grip goes along for the ride. I've done that EXCEPT after one round of back and forth it started acting wonky so I went back to the single Move. When I say "bottom", I mean the grip that stays at the bottom of the magenta, not the bottom of the overall block where the Basepoint is. Obviously that starts at the same spot if the block has been reset (notice this one has NOT been reset), but once the magenta moves up, I want the Basepoint to stay put and the "bottom" grip to stay at the bottom of magenta. Seems like it should be so easy but I keep not quite getting it right. I'll see if I can find my last attempt before I went back to this single Move version, but this does have the color differentiated. Thank you jack2.dwg
  21. I dont want to insert the calculations in table.I want to insert as mtext. And I want the calculations with the dimension of eatch polygon not by coordinates. Any ideas Thanks
  22. Makes me think of AreaG from GP_: Maybe you can take some inspiration on the calculations in his code?
  23. Can you highlight at a different color what needs to move up please that would help.
  24. I am trying to write a diesel expression that will extract the first part of the drawing file name. Full Drawing File Name: XXX-ZINC-XX-XX-DR-C-01000_S278 Sections First Part: XXX-ZINC-XX-XX-DR-C- My question: Is there a smarter way to extract the first part rather than relaying on the number of characters? If everyone is following the correct naming protocol it would be 20 characters but sometimes you have people instead of -C- they put -CE- so I am wondering is there a way to future proof it. Thank you. $(substr,$(getvar,"dwgname"),1,20)
  25. I have a code to calculate and write the area of close polygons. I want to update the code to support in calculations rectangular parallelepiped. The problem is that in trapezoid calculation is a bug and if i select a rectangular parallelepiped calculate the area as trapezoid. Can someone fix the code? (defun c:areacal ( / AcDoc Space nw_style js nb ent dxf_ent ptlst n old_textsize count app_txt surf cum_area pt_ins val_txt lst_bis l_4d max_d pos pt1 pt2 pt3 d1 d2 h t_spc nw_obj ent_text key label scl ht *error*) (vl-load-com) ; Define error handler (defun *error* (msg) (if (not (member msg '("Function cancelled" "quit / exit abort"))) (princ (strcat "\nError: " msg)) ) (setvar "OSMODE" 9) (mapcar 'setvar '("clayer" "cecolor" "celtype" "celweight") (list "0" "BYLAYER" "BYLAYER" -1)) (if old_textsize (setvar "TEXTSIZE" old_textsize)) (vla-endundomark AcDoc) (princ) ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (vla-startundomark AcDoc) (setvar "OSMODE" 0) ; Set scale and text height (setq scl (getvar "useri1")) (setq ht (* 0.003 scl)) ; Create ΚΕΙΜ_Layout layer if it doesn't exist (if (null (tblsearch "LAYER" "ΚΕΙΜ_Layout")) (vlax-put (vla-add (vla-get-layers AcDoc) "ΚΕΙΜ_Layout") 'color 7) ) ; Create ΚΕΙΜ_Layout text style if it doesn't exist (if (null (tblsearch "STYLE" "ΚΕΙΜ_Layout")) (progn (setq nw_style (vla-add (vla-get-textstyles AcDoc) "ΚΕΙΜ_Layout")) (mapcar '(lambda (pr val) (vlax-put nw_style pr val) ) (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag) (list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 0.0 1.0 0.0) ) ) ) ; Prompt for label prefix (setq label (getstring "\nInsert prefix (π.χ A,B,C..,etc): ")) (if (eq label "") (setq label "E")) ; Select polylines (prompt "\nSelect polylines one by one (press Enter to finish): ") (setq js (ssget '((0 . "LWPOLYLINE") (-4 . "<AND") (-4 . "&") (70 . 1) (-4 . ">") (90 . 2) (-4 . "<") (90 . 5) (-4 . "AND>")))) (if js (progn (repeat (setq nb (sslength js)) (setq ent (ssname js (setq nb (1- nb))) dxf_ent (entget ent) ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent)) n (length ptlst) ) (if (eq n 4) (if (and (not (equal (rem (angle (car ptlst) (cadr ptlst)) pi) (rem (angle (caddr ptlst) (cadddr ptlst)) pi) 1E-08)) (not (equal (rem (angle (cadr ptlst) (caddr ptlst)) pi) (rem (angle (cadddr ptlst) (car ptlst)) pi) 1E-08)) ) (ssdel ent js) ) ) ) ) ) (cond ((and js (> (sslength js) 0)) (sssetfirst nil js) (initget "Yes No") (if (not (eq (getkword "\n Insert calculations [Yes/No]? <Yes>: ") "No")) (progn (sssetfirst nil nil) (setq old_textsize (getvar "TEXTSIZE") count 0 app_txt "" cum_area 0.0 ) (setvar "TEXTSIZE" ht) ; Process polylines sequentially (0 to n-1) (setq nb 0) (while (< nb (sslength js)) (setq ent (ssname js nb) dxf_ent (entget ent) ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent)) n (length ptlst) pt_ins (list (/ (apply '+ (mapcar 'car ptlst)) n) (/ (apply '+ (mapcar 'cadr ptlst)) n)) val_txt (if (eq n 3) (progn (setq lst_bis (append (cdr ptlst) (list (car ptlst))) l_4d (mapcar 'distance ptlst lst_bis) max_d (apply 'max l_4d) pos (vl-position max_d l_4d) pt1 (nth pos ptlst) pt2 (nth pos lst_bis) pt3 (car (vl-remove pt2 (vl-remove pt1 ptlst))) d1 (distance pt3 (inters pt1 pt2 pt3 (polar pt3 (+ (angle pt1 pt2) (* pi 0.5)) (distance pt1 pt2)) nil ) ) surf (* (atof (rtos max_d 2 2)) (atof (rtos d1 2 2)) 0.5) cum_area (atof (rtos (+ surf cum_area) 2 3)) ) (strcat label (itoa (setq count (1+ count))) " = " "1/2 x " (rtos max_d 2 2) " x " (rtos d1 2 2) " = " (rtos surf 2 2) " τ.μ.\\P" ) ) (if (and (equal (abs (- (rem (angle (car ptlst) (cadr ptlst)) pi) (rem (angle (car ptlst) (cadddr ptlst)) pi))) (* 0.5 pi) 1E-08) (equal (abs (- (rem (angle (cadr ptlst) (caddr ptlst)) pi) (rem (angle (caddr ptlst) (cadddr ptlst)) pi))) (* 0.5 pi) 1E-08) ) (progn (setq d1 (atof (rtos (distance (car ptlst) (cadr ptlst)) 2 2)) d2 (atof (rtos (distance (cadr ptlst) (caddr ptlst)) 2 2)) surf (atof (rtos (* d1 d2) 2 2)) cum_area (atof (rtos (+ surf cum_area) 2 2)) ) (strcat label (itoa (setq count (1+ count))) " = " (rtos d1 2 2) " x " (rtos d2 2 2) " = " (rtos surf 2 2) " τ.μ.\\P" ) ) (progn (if (equal (rem (angle (car ptlst) (cadr ptlst)) pi) (rem (angle (caddr ptlst) (cadddr ptlst)) pi) 1E-08) (setq d1 (atof (rtos (distance (car ptlst) (cadr ptlst)) 2 2)) d2 (atof (rtos (distance (caddr ptlst) (cadddr ptlst)) 2 2)) h (atof (rtos (distance (car ptlst) (inters (car ptlst) (polar (car ptlst) (+ (angle (car ptlst) (cadr ptlst)) (* 0.5 pi)) 1.0) (caddr ptlst) (cadddr ptlst) nil)) 2 2)) ) (setq d1 (atof (rtos (distance (cadr ptlst) (caddr ptlst)) 2 2)) d2 (atof (rtos (distance (car ptlst) (cadddr ptlst)) 2 2)) h (atof (rtos (distance (cadr ptlst) (inters (cadr ptlst) (polar (cadr ptlst) (+ (angle (cadr ptlst) (caddr ptlst)) (* 0.5 pi)) 1.0) (car ptlst) (cadddr ptlst) nil)) 2 2)) ) ) (setq surf (atof (rtos (* (+ d1 d2) h 0.5) 2 2)) cum_area (atof (rtos (+ surf cum_area) 2 2)) ) (strcat label (itoa (setq count (1+ count))) " = 1/2 x (" (rtos d1 2 2) " + " (rtos d2 2 2) ") x " (rtos h 2 2) " = " (rtos surf 2 2) " τ.μ.\\P" ) ) ) ) app_txt (strcat app_txt val_txt) ) (entmake (list '(0 . "TEXT") '(100 . "AcDbEntity") (cons 8 "ΚΕΙΜ_Layout") '(100 . "AcDbText") (cons 10 pt_ins) (cons 40 ht) (cons 1 (strcat label (itoa count))) (cons 50 (angle '(0 0 0) (getvar "UCSXDIR"))) '(41 . 1.0) '(51 . 0.0) (cons 7 "ΚΕΙΜ_Layout") '(71 . 0) '(72 . 1) (cons 11 pt_ins) (assoc 210 dxf_ent) '(100 . "AcDbText") '(73 . 2) ) ) (setq nb (1+ nb)) ) (initget "1 2") (setq t_spc (getkword "\n Insert calculations[1.Modelspace/2.Paperspace]? <1>: ")) (cond ((eq t_spc "2") (vla-put-ActiveSpace AcDoc acPaperSpace) (vla-put-MSpace AcDoc :vlax-false) (setq Space (vla-get-PaperSpace AcDoc)) (setvar "TEXTSIZE" 2.5) ) (T (vla-put-ActiveSpace AcDoc acModelSpace) (if (not (eq (getvar "TILEMODE") 1)) (vla-put-MSpace AcDoc :vlax-true)) (setq Space (vla-get-ModelSpace AcDoc)) (setvar "TEXTSIZE" ht) ) ) (setq nw_obj (vla-addMtext Space (vlax-3d-point (trans (getvar "VIEWCTR") 1 0)) 0.0 (strcat app_txt label "ολ = " (rtos cum_area 2 2) " τ.μ.") ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'StyleName 'Layer 'Rotation) (list 1 (getvar "TEXTSIZE") 5 "ΚΕΙΜ_Layout" "ΚΕΙΜ_Layout" 0.0) ) (setq ent_text (entlast) dxf_ent (entget ent_text) dxf_ent (subst (cons 90 1) (assoc 90 dxf_ent) dxf_ent) dxf_ent (subst (cons 63 255) (assoc 63 dxf_ent) dxf_ent) ) (entmod dxf_ent) (while (and (setq key (grread T 4 0)) (/= (car key) 3)) (cond ((eq (car key) 5) (setq dxf_ent (subst (cons 10 (trans (cadr key) 1 0)) (assoc 10 dxf_ent) dxf_ent)) (entmod dxf_ent) ) ) ) (setvar "TEXTSIZE" old_textsize) ) (T (sssetfirst nil nil) (princ "\nFunction canceled")) ) ) (T (princ "\nSelected items are invalid")) ) ; Reset system variables (mapcar 'setvar '("clayer" "cecolor" "celtype" "celweight") (list "0" "BYLAYER" "BYLAYER" -1)) (setvar "OSMODE" 9) (vla-endundomark AcDoc) (princ) ) Thanks test.dwg
  26. @CivilTechSource I'm looking to Move actually. I'm not really showing the cylinder that well, but the cylinder pokes out the bottom and pushes basically that whole box part upwards. Thank you for checking in on it though!
  27. You should be using Stretch instead of Move. Move will just move your block and it will not extend it as you mentioned. Is this what you are after? jack.dwg
