Hi everyone, I’ve been working on modifying Lee Mac’s “Extract Nested Block” routine. @Lee Mac By default, his code only extracts a nested block reference. I have expanded it so that it can also extract non-block objects (lines, arcs, etc.) located inside a nested block reference. The problem occurs when the selected object is inside one or more parent blocks that have been scaled or mirrored. In these cases, the extracted object is placed in the wrong position in model space. I know the “correct” way to solve this is to traverse the block reference hierarchy and apply all transformation matrices (scale, rotation, mirror) step by step until we reach world coordinates. However, in large DWG files with many nested blocks, this approach becomes very slow and hurts performance significantly. My question is: Is there a more efficient way to get the final WCS coordinates of a nested object, including all scaling/mirroring effects from its parent blocks, without manually multiplying all transformation matrices? Any suggestions or examples would be greatly appreciated. Thanks in advance!
Geometric center of open polyline, line
maahee replied to maahee's topic in AutoLISP, Visual LISP & DCL
(defun C:Am (/ ss num i ent entdata p1 p2 p ang p_offset oldUcs) (if (setq ss (ssget '((0 . "LINE,LWPOLYLINE,ARC,CIRCLE")))) (progn (setq oldOsn (getvar "OSMODE")) ; Save current OSNAP modes (setvar "OSMODE" 0) ; Disable all object snaps (setvar "CMDECHO" 0) ; Disable command echo (command "_.undo" "_be") (setq num (sslength ss)) (setq i 0) (repeat num (setq ent (ssname ss i)) (setq entdata (entget ent)) (if (= (cdr (assoc 0 entdata)) "LINE") (progn (setq p1 (cdr (assoc 10 entdata))) (setq p2 (cdr (assoc 11 entdata))) ;; Calculate the angle (setq ang (angle p1 p2)) ;; Perpendicular point offset (setq p (polar p1 (+ ang (/ pi 2)) 0.2)) ;; Create aligned dimension (command "DIMALIGNED" p1 p2 p) ) ) (setq i (1+ i)) ) (setvar "OSMODE" oldOsn) ; Restore previous OSNAP modes (setvar "CMDECHO" 1) ) (alert "No entities selected.") ) ;; Restore UCS (princ) ) When executing AutoLisp, it works well, but whenever the UCS is shifted, running AutoLisp causes the dimensions of the same object to shift, resulting in a discrepancy between the dimensions and the object. This difference corresponds to the change between the old UCS and the new UCS. -
lrm replied to maahee's topic in AutoLISP, Visual LISP & DCL
@devitg@Saxlle There seems to be some dissagreement of the definition of the geometric center of a polyline. Should the polyline be considered a linear object or a closed shape? If it's a linear object then the geometric center for an open polyline as shown below is (1.5,0.8) and not (1.5,0.5). There is no line from (3,0) to (0,0) that influeces the location of the geometric cener. My code above considers the polyline as a series of lines and not the bounds of a shape (which is ill defined as it is open). There is also the interpretation of how to handle a polyline that is "open" but should be considered a closed shape where the last vertex is assumed to be the same as the first vertex. In this case the polyline needs to be tested for the "closed" property and then appropriately dealt with to define a closed shape. -
Perhaps not support LOFTNORMALS yet !!!! Thanks
Saxlle replied to maahee's topic in AutoLISP, Visual LISP & DCL
Okay, this is the sub-function for calculating geometric center for open or closed polygon made from polyline. ; ******************************************************************************************* ; Sub-Function : SX:geomCenter ; Description : Geometric center for open or closed lwpolyline for 2D polygons ; Arguments: : ent - Selected entity into the drawing ; Calling function : (SX:geomCenter ent) ; Author : Saxlle ; Date : August 11, 2025 ; ******************************************************************************************* (defun SX:geomCenter ( ent / ptlist sum_x sum_y sum_area temp_area i len temp_x temp_y j cen_x cen_y cen_pt) (setq ptlist (mapcar 'cdr (vl-remove-if-not (function (lambda (x) (= (car x) 10))) (entget ent)))) ;; point list (if (and (equal (cdr (assoc 0 (entget ent))) "LWPOLYLINE") (>= (length ptlist) 3)) (progn (setq sum_x 0.0 sum_y 0.0 sum_area 0.0 temp_area 0.00 i 0 ) (repeat (setq len (length ptlist)) (if (< (1+ i) len) (progn (setq temp_area (- (* (car (nth i ptlist)) (cadr (nth (1+ i) ptlist))) (* (car (nth (1+ i) ptlist)) (cadr (nth i ptlist)))) sum_area (+ sum_area temp_area) temp_x (+ (car (nth i ptlist)) (car (nth (1+ i) ptlist))) temp_y (+ (cadr (nth i ptlist)) (cadr (nth (1+ i) ptlist))) sum_x (+ sum_x (* temp_x temp_area)) sum_y (+ sum_y (* temp_y temp_area)) i (1+ i) ) ) (progn (setq j 0 temp_area (- (* (car (nth i ptlist)) (cadr (nth j ptlist))) (* (car (nth j ptlist)) (cadr (nth i ptlist)))) sum_area (+ sum_area temp_area) temp_x (+ (car (nth i ptlist)) (car (nth j ptlist))) temp_y (+ (cadr (nth i ptlist)) (cadr (nth j ptlist))) sum_x (+ sum_x (* temp_x temp_area)) sum_y (+ sum_y (* temp_y temp_area)) ) ) ) ) (setq sum_area (/ sum_area 2)) (if (not (equal sum_area 0.0)) (setq cen_x (/ sum_x (* sum_area 6)) cen_y (/ sum_y (* sum_area 6)) cen_pt (list cen_x cen_y) ) ) (prompt (strcat "\nThe geometric center is: " (rtos cen_x 2 2) "," (rtos cen_y 2 2))) (princ) ) (progn (cond ((equal (cdr (assoc 0 (entget ent))) "LWPOLYLINE") (prompt "\nSelected entity is POLYLINE and the number of vertices are lower than 3! Need at least 3 or more vertices!") (princ) ) ((equal (cdr (assoc 0 (entget ent))) "LINE") (prompt "\nSelected entity is LINE and the center is the midpoint!") (princ) ) ) ) ) ) An example video of how it works. geomCenter.mp4 Best regards. -
Ok I have the "group by code" for descriptions. So next step is a look up for layer name to match the description. The description look would have like CIV3D description keys. Any way thought I posted try "EXPORTTOAUTOCAD" a CIV3D command to do just that convert CIV3D objects to plain Autocad objects. Here is the file to do what you want, but try export first. @devitg give it a try. spagetti.lsp
Extracting data to excel from selected objects on different layers
kidznok replied to Hsanon's topic in AutoLISP, Visual LISP & DCL
Hi, I create dwg and xslx. I add hatch, circle, text, mtext and block. If someone have time and can help with that I will be grateful Date for lisp.dwgDate for lisp.xlsx -
Just tried it, I specified Charset parameter as "unicode" and it worked well, thanks!
How to stop flip action reversing offsets in dynamic block
I think I am on top of this now, thank you for all you insightful comments . No need for additional code at this stage . -
@devitg the first two characters are already the identifiers, you can use @Lee Mac and Marco Ribar LM-MR:wcmatchx to extract it from the description. @BIGAL This is the reason why I'm trying to build this code library to avoid the export process in Civil 3D if you are doing a quick or small-scale projects since these will all end in a plain AutoCAD Template. By the way here is the complete flow of the process to create blocks and lines based on code description, I just cut the parts of Blocks and Lines Library cause it's too long. List of Line Groups here is simply a point list '(ENZ). That is why I'm trying to find other way to build a list of point groups then process it after all the csv lines are read. (if ; start the csv validation (and (setq fn (getfiled "\n" (getvar 'dwgprefix) "csv;txt;*" 16)) ; get csv file (setq cd (LM:readcsv fn)) ; read csv line thanks to @LeeMac ) ;and (progn (setq grd1 '() grd2 '() grd3 '() grd4 '() grd5 '() grd6 '() grd7 '() grd8 '() ; empty list for 8 simultaneous lines . ; and so on . . ) ;setq (foreach ln cd (if (= (length ln) 5) ; format = '( p e n z d ) (progn (setq ptn (nth 0 ln) ; point number des (nth 4 ln) ; point code plyr "0" ; default point/block layer if not in the code library tlyr "0" ; default annotation layer if not in the code library cs (/ 2.0 (getvar 'cannoscalevalue)) ; scale factor to be used for blocks hgt (/ 1.6 (getvar 'cannoscalevalue)) ; height factor to be used for annotation pt (list (atof (nth 1 ln)) (atof (nth 2 ln)) (atof (nth 3 ln))) ; insertion point ) ;setq (if (= 3 (length pt)) ; format = '( e n z ) to verify if 3D Point (setq pt (trans pt 1 0) ; convert point to ucs pt1 (list (car pt) (+ (cadr pt) (* hgt 0.6 (sqrt 2.5)))) ; text position (single line annotation) pt2 (list (car pt) (+ (cadr pt) (* hgt 0.95 (sqrt 2.5)))) ; text position (double line annotation) val (rtos (caddr pt) 2 2) ; text value based on description (default is elevation) mtp pt1 ; dummy string for annotation position ) ;setq ) ;if (cond ; First condition if Point Blocks ((= "BP" (TG:Read des "BP")) (setq plyr....)) ; If Match the Description set block preperties . ; and so on . . (t ; Else Lines ;;Start of Line List Group (cond ((or ; Set two conditions using LeeMac And Marco LM-MR:wcmatchx function (LM-MR:wcmatchx des "*@#*"....) ; Alpha-Numerical Combo (LM-MR:wcmatchx des "*@@*"....) ; Alphabet Combo ) (if (LM-MR:wcmatchx des "*L1*") ; If Match Description (progn (setq bn "HIDDEN"....) ; Set Block (Line End Points) and Line Propterties (setq grd1 (append (list pt) grd1)) ; Get Points for L1 Group ) ) (if (LM-MR:wcmatchx des "*L2*") ; If Match Description (progn (setq bn "HIDDEN"....) ; Set Block (Line End Points) and Line Propterties (setq grd2 (append (list pt) grd2)) ; Get Points for L2 Group ) ) . ; And so on . . ) (t ;Else if description is not found in the library (setq bn "HIDDEN" bs (* 0.5 cs) plyr "0" val "") ;Default Settings ) ;second T ) ;second cond ) ;first T ) ;first cond ; (if (/= val "") ; Annotation, Blocks and Lines Create if conditions are met (progn (tg:cr8mtx val tlyr hgt mtp) ; Call the function to generate annotations (tg:binsert bn pt bs ptn des plyr) ; Call the function to generate blocks ) (progn (tg:binsert bn pt bs ptn des plyr) ; Call the function to generate blocks (cond ((or ; Settings for Trigger to generate line groups (LM-MR:wcmatchx des "*L#A*") ; If Arc is ended (LM-MR:wcmatchx des "*L#C*") ; If Line is closed (LM-MR:wcmatchx des "*L#E*") ; If Line is ended ) (cond (((LM-MR:wcmatchx des "*L1*")) ; If L1 is called (TG:MKELN grd1 "GARDEN") ; Generate L1 Line List (setq grd1 '()) ; Reset L1 List after lines are generated ) ((=(LM-MR:wcmatchx des "*L2*")) ; If L2 is called (TG:MKELN grd2 "GARDEN") ; Generate L2 Line List (setq grd2 '()) ; Reset L2 List after lines are generated ) . ; And so on... . . ) ; inside cond ) ; GARDEN LINES GROUP ) ; first cond ) ; progn ) ; if val ) ; inside progn ) ; inside main ) ; foreach ln ) ; main progn ) ; main if csv ;; As of the moment (TG:MKELN LIST LAYER) Function is for Line Creation only, Arcs are not yet included since I'm still struggling on how to do it along the Line List Group. ;; What I'm trying to achieved is to create a list of point groups, if "S" or "E" or "A" is present in the code identifiers it will generate a new group of line points in the list. (setq mylist '( ("L1" '(pt1 pt2 p3....pn)) ; if Start or End is called create group ("L1" '(pt1 pt2 p3....pn)) ; if Arc is called create group ("L2" '(pt1 pt2 p3....pn)) ; another group for L2 if Start or End is called ("L1" '(pt1 pt2 p3....pn)) ; then another group for L1 if Start or End is called ) ) ;; Then process the list of lines and arcs after by calling the identifiers and corresponding group of points
The idea is that you could break down the task to individual blocks and either have the five blocks or a dynamic block that sets the correct truss size visibilty but a say 10m would be 5 individual blocks, much easier to manipulate than have some 50 visibility states. Ok so just read the length match sizes if a size is 0 then don't add it to the draw trusses. I have also thought could save the build order in a different pattern say a 26m would be (26 "2x6" "1x2" "2x6") so the 2m truss would be in the middle. A 10 would be just (10 "2x5") its easy to convert the number of in a repeat. Re angle just insert the blocks and rotate all of them in one go. Yes needs new code which time permitting will do. - Yesterday
devitg started following Group list to make separate lines and Geometric center of open polyline, line
devitg replied to maahee's topic in AutoLISP, Visual LISP & DCL
@Mahee , please give it a try , will work both for open and closed lwpolylines it get the Centroid from a temporary Region from a temporary closed polyline if poly is open get-center.LSP get-center.LSP get poly center.dwg -
@GLORY As I can get ,there are same point with same identifier (last text at csv line) Mybe you can add some new identification to group by it at same CSV Like this 1,21.188,19.762,0.000,L1S,pl1.1 4,32.984,30.378,0.000,L1,pl1.2 5,45.117,40.995,0.000,L1,pl1.3 8,57.587,50.937,0.000,L1E,pl1.4 2,31.804,7.629,0.000,L2S,pl2.1 3,44.106,18.077,0.000,L2,pl2.2 6,56.239,26.671,0.000,L2,pl2.3 7,68.878,36.782,0.000,L2E,pl2.4 9,49.168,65.549,0.000,L1S,pl3.1 10,43.612,72.164,0.000,L1,pl3.2 11,50.491,77.059,0.000,L1,pl3.3 12,55.253,70.179,0.000,L1C,pl3.4 13,41.363,59.993,0.000,L2S,pl4.1 14,34.616,68.460,0.000,L2,pl4.2 15,27.472,64.094,0.000,L2,pl4.3 16,33.954,55.495,0.000,L2C,pl4.4 Or state in a new csv which order belong to each polyline Say Line1 and 2 Group List- oredr + idfier.dwg
Sorry guys for the late reply. @devitgHere is an example of the drawing processed by the code I've been trying to work on for a while now. But it can only handle 2-Description at a time, either a combination of two different lines or a line and block combo. Let say, “L1E/L2S” or “L1S/BP” which is a point block and can no longer TRIGGER to read 3-Description csv line like “L1E/L2S/BP”, this kind of description can only plot the “BP”, it will not plot the "L1" lines calling “L1E” (the trigger) to plot L1 Group then start collection of L2 point groups. But upon checking the group list say for L1, the points are there inside that list but cannot trigger to plot the L1 group of points into lines since BP is already called in the first condition of the code. This is the reason I want to change the point collection list into groups and process the line list groups after reading all the lines in the csv. @BIGAL, thank you for your response. I also work in Civil 3D to process these kinds of data. The only problem is that you need to export it in plain AutoCAD format to arrange all the annotation etc., cause COGO are not easy to handle. Say aligning the annotation for block points to be aligned to lines or move it into desired location. Line1 and 2 Group List.dwg
Not sure about ZWCAD, but AutoCAD 2025 and newer now needs... (acet-load-expresstools) Do you have a link to specific LISP instructions for ZWCAD? Is there a LOFTNORMALS in ZWCAD?
Thanks for this. How can the large size array be used ? does it need to be passed to a function ? -
Ok that is what you get in field survey using Total stations, GPS etc so you want to string the description. Yes I have something, working on it for Bricscad. I have spent over 45+ years doing civil work, so can see what you want, the simple answer is CIV3D or Civil Site Design or Carlson, etc that is civil software, When reading a points file it will string the points via a description, add blocks matching descriptions and more. I am working on the add blocks and line work on correct layer. Your csv processed. Happy to discuss further. But I don't intend to reinvent the wheel to much.
I still think its easier to copy/array the dynamic block just setting the correct visibility state so that would be 2 3 4 5 6 only. No working out the dynamic pattern. Angle is not a problem. This is all your sizes up to length of 50 the pattern is length, how many 6s 5s 4s 3s 2s could do way more you can also change the way a length is made example 10 is 2x5 or a 6+4 ((51 8 0 0 1 0) (50 8 0 0 0 1) (49 7 1 0 0 1) (48 8 0 0 0 0) (47 7 1 0 0 0) (46 7 0 1 0 0) (45 7 0 0 1 0) (44 7 0 0 0 1) (43 6 1 0 0 1) (42 7 0 0 0 0) (41 6 1 0 0 0) (40 6 0 1 0 0) (39 6 0 0 1 0) (38 6 0 0 0 1) (37 5 1 0 0 1) (36 6 0 0 0 0) (35 5 1 0 0 0) (34 5 0 1 0 0) (33 5 0 0 1 0) (32 5 0 0 0 1) (31 4 1 0 0 1) (30 5 0 0 0 0) (29 4 1 0 0 0) (28 4 0 1 0 0) (27 4 0 0 1 0) (26 4 0 0 0 1) (25 3 1 0 0 1) (24 4 0 0 0 0) (23 3 1 0 0 0) (22 3 0 1 0 0) (21 3 0 0 1 0) (20 3 0 0 0 1) (19 2 1 0 0 1) (18 3 0 0 0 0) (17 2 1 0 0 0) (16 2 0 1 0 0) (15 2 0 0 1 0) (14 2 0 0 0 1) (13 1 1 0 0 1) (12 2 0 0 0 0) (11 1 1 0 0 0) (10 1 0 1 0 0) (9 1 0 0 1 0) (8 1 0 0 0 1) (7 0 1 0 0 1) (6 1 0 0 0 0) (5 0 1 0 0 0) (4 0 0 1 0 0) (3 0 0 0 1 0) (2 0 0 0 0 1)) - Last week
@GLORY Please upload a sample.dwg as you need it to be, at least 2 lines
GLORY started following Group list to make separate lines
Hello Everyone, I need some help; here is my list in csv 1,21.188,19.762,0.000,L1S 2,31.804,7.629,0.000,L2S 3,44.106,18.077,0.000,L2 4,32.984,30.378,0.000,L1 5,45.117,40.995,0.000,L1 6,56.239,26.671,0.000,L2 7,68.878,36.782,0.000,L2E 8,57.587,50.937,0.000,L1E 9,49.168,65.549,0.000,L1S 10,43.612,72.164,0.000,L1 11,50.491,77.059,0.000,L1 12,55.253,70.179,0.000,L1C 13,41.363,59.993,0.000,L2S 14,34.616,68.460,0.000,L2 15,27.472,64.094,0.000,L2 16,33.954,55.495,0.000,L2C And I want to make that list into something like this, (setq pt (list (nth 1 ln) (nth 2 ln) (nth 3 ln))) (setq mylist '( (("L1S" (list pt)) ("L1" (list pt))...("L1E" (list pt))) (("L2S" (list pt)) ("L2" (list pt))...("L2E" (list pt))) (("L1S" (list pt)) ("L1" (list pt))...("L1C" (list pt))) (("L2S" (list pt)) ("L2" (list pt))...("L2C" (list pt))) ) ) In order to plot the lines into groups by creating another set of group of points if the description has "S" or start at the end, say L1S for Line 1 Start. Thank you in advance.Line1 and 2 Group List.csv
lrm started following Geometric center of open polyline, line
The geometric center (a.k.a. centroid) of an open polyline is deteremined by summing the length of each line segment times the coordinates of the midpoint of the respective segment. The result is then divided by the total length of the polyline. It is NOT the average of the point locations. ; Calculates the centroid for an open lwpolyline ; lrm 8/9/2025 (defun c:pl_centroid (/ ss pt_lst sum_x sum_y sum_d n i d mid_pt centroid) (setq ss (entget (car (Entsel "\nSelect Open Polyline"))) pt_lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) ss) ) ) (setq sum_x 0 sum_y 0 sum_d 0.0 n (length pt_lst) i 0 ) (while (<= i (- n 2)) (setq d (distance (nth i pt_lst) (nth (+ i 1) pt_lst))) (setq mid_pt (mapcar '/ (mapcar '+ (nth i pt_lst) (nth (+ i 1) pt_lst)) '(2 2 2) ) ) (setq sum_x (+ sum_x (* (car mid_pt) d)) sum_y (+ sum_y (* (cadr mid_pt) d)) sum_d (+ d sum_d) i (+ i 1) ) ) (setq centroid (list (/ sum_x sum_d) (/ sum_y sum_d) ) ) (princ "\n Centroid at: ") (princ centroid) (command "_point" "_non" centroid) (princ) ) -
SELECT TEXTS OTHER THAN 3.5..HELP
To enter the value into your selection set see below. In LISP the '( ... ) lists mean it is a static list, it is read exactly as it is written, (list ... ) means that CAD will create the list if for example variables are a part of the list, and (cons ... ), also used to create a list - in this case relevant to create a dotted pair. (setq MyThing 5) '(1 2 3 4 MyThing) is read as 1 2 3 4 MyThing - and an error since it is looking for MyThing to be a string, "MyThing" (list 1 2 3 4 MyThing) is read as 1 2 3 4 5 - list has been created by the LISP (cons 1 MyThing) is read as (1 . 5) So this might help... As above though you select the text with the selection set ss, but haven't done anything with it - if you are a part way through the LISP that is all good, but just put a report in so you can see it is working as it should as you go along perhaps (sslength SS) maybe. (Oh, just me, I also amended the indents, and added where commands end if over a few lines, I find it easier to read LISPs as below, that's all) (defun c:test (/ old_err EscVP StrScale2 TxtHt StrScale ss) (setq old_err *error*) (defun *error* ( a / ) ;; Add here return cmdecho to as it was, cmdecho 1 (princ "") (setq *error* old_err) (princ) ) ; End Error Defun (setvar "cmdecho" 0) ; perhaps record the state of cmdecho before here, and reset to that value at the end (if (and (setq EntVP (car (entsel "\Seleccione VIEWPORT: "))) (= (cdr (assoc 0 (entget EntVP))) "VIEWPORT") ) ; end and (progn (setq EscVP (vla-get-CustomScale (vlax-ename->vla-object EntVP))) (setq StrScale2 (rtos (* 3.5 (/ 1 EscVP)) 2 1)) (setq TxtHt (* 3.5 (/ 1 EscVP)) ) ; a number not a string ;; added this (setq StrScale (rtos (/ 1 EscVP) 2 2)) (setq vpnum (cdr (assoc 69 (entget EntVP )))) (vl-cmdf "_.mspace") (setvar "CVPORT" vpnum) (setq ss (ssget (list(0 . "TEXT") (-4 . "<>") (cons 40 TxtHt))) ) ;;What are you doing with ss now? (Prompt (strcat "\nLa escala de La Ventana es 1/" StrScale)) (princ "\nLos textos de 3.5 en el interior de la ventana deben ser de: ") (princ StrScale2) ) ; end progn ) ; end if (setvar "cmdecho" 1) (princ) );fin defun -
Hi I think it would be easier to find the problem if you attached an example drawing. -
If your making layouts then do that then go into mspace pick the page details than pop back to pspace and fill in your title block not that hard. Yes a lisp. One of the things I have looked at is pick a point on dwg in Model space, select scale, select title block and make the layout. You could add pick the mtext for title block also. It will cost you a cup of coffee as have to hard code the title block details etc.
