  1. Today
  2. ...Continue from previous post, experiment with imperial mod, quotient, division. ##********************************************************************************************** ## 45 UDF/ Excel name: impaMQD() - Similar Excel MOD() function with optional parmeters, ## return quotient or division [opt_1Quotient_or_2Division]. ## ## Note: This function uses todec() & toimpa() as sub-functions. ## ## Notes with optional parameters: ## ## [opt_1Quotient_or_2Division] = 1 , Similar Excel QUOTIENT() function - Returns the integer ## portion of a division ## [opt_1Quotient_or_2Division] = 2 , division calculation (varDividend/varDivisor) ## ## Optional parameters other than 1 & 2 will return error #N/A ## ## Rev. 1.0 - 9/2/2025 ##********************************************************************************************** =LAMBDA(varDividend,varDivisor,[opt_1Quotient_or_2Division], LET(optN,IF(ISOMITTED(opt_1Quotient_or_2Division),0, IF(AND(opt_1Quotient_or_2Division<=2,opt_1Quotient_or_2Division>0),opt_1Quotient_or_2Division,NA())), varD1,todec(varDividend), varD2,todec(varDivisor), answrM,varD1-(varD2*INT(varD1/varD2)), answrQ,ROUNDDOWN(varD1/varD2,0), answrD,varD1/varD2, SWITCH(TRUE, optN=0,IF(AND(ISNUMBER(varDividend),ISNUMBER(varDivisor)),answrM,IF(OR(AND(ISTEXT(varDividend),ISTEXT(varDivisor)),ISNUMBER(varDivisor)),toimpa(answrM),"Error!")), optN=1,IF(OR(AND(ISNUMBER(varDividend),ISNUMBER(varDivisor)),AND(ISTEXT(varDividend),ISTEXT(varDivisor))),answrQ,IF(ISNUMBER(varDivisor),toimpa(answrQ),"Error!")), optN=2,IF(OR(AND(ISNUMBER(varDividend),ISNUMBER(varDivisor)),AND(ISTEXT(varDividend),ISTEXT(varDivisor))),answrD,IF(ISNUMBER(varDivisor),toimpa(answrD),"Error!")), NA() ) ) )
  3. Lee Mac
    Add Polyline Vertex
    Or just call MULTIPLE before calling APV.
  4. mhupp
    Add Polyline Vertex
    Since Lee's Code only has you picking a point its easy enough. Just add a call at the end of APV (line 95) to call itself again. This will force a loop that you have to hit esc to exit. - Edit This is a better option. Has undo marks. You could also set your snaps before entering the command if you want to. ;;----------------------------------------------------------------------------;; ;; Add Polyline Vertex loop ;; Dependent AddLWPolylineVertexV1-1.lsp (defun C:APVL ( / ) (vl-load-com) (princ "\nStarting Add Polyline Vertex loop. Press ESC to stop.") (vla-StartUndoMark (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))) ;(setvar 'OSMODE 3) ;End and mid point snaps (while T (C:APV) ) (princ "\nAdd Polyline Vertex Loop ended.") (vla-EndUndoMark doc) (princ) )
  5. Steven P
    Add Polyline Vertex
    So is your question really how to make these loop, keep picking points until you hit enter or escape?
  6. That title does not ring a bell. Are you referring to the Oleson Village Project specifically or another project?
  7. BIGAL
    Export mtext to Excel
    Thanks Lee yes during testing had a stuck loop a few times had to crash out CAD. Will use the full defun rather than the short version.
  8. @kidznok Check your PM
  9. CAD_Noob
    Add Polyline Vertex
    Update found this from gile https://forums.augi.com/showthread.php?68868-Adding-vertexes-to-a-polyline&p=765721&viewfull=1#post765721 can it be modified so i can pick multiple points until I exit?
  10. Does anyone have a lisp that can add multiple vertex for polyline? I found this Lisp from the great @Lee Mac and it works except that I need to be able to pick simultaneously even if it does not reside on the line then hit escape or enter when done. I will then move the added vertex to its proper location.
  11. oddssatisfy
    Display / Printing Issue
    Type GRAPHICSCONFIG → Enter → Advanced Settings → uncheck “Fade inactive geometry” (or slide it to 0%) → Apply → OK. That’s it. Your prints will instantly look exactly like they did in AutoCAD 2022 – no more extra faint lines.
  12. Yesterday
  13. Lee Mac
    You're missing the double backslash ("*\\P*") Also, note that the use of vl-string-subst with a constant starting position and wcmatch to test the content is dangerous in general as this will result in an infinite loop if the replacement string contains the find string, e.g. consider replacing "new" with "knew" - your code would loop indefinitely.
  14. Is it exporting to Excel direct or are you using the CSV ? I have a libre Calc output as well.
  15. BIGAL
    Thanks everyone, the answer sometimes is just looking at you and waving back. Need to double check help in future. (while (wcmatch txt "*\P*") (setq txt (vl-string-subst "\n" "\\P" txt 1)) ) Screen Recording 2025-11-24 093452.mp4
  16. I'm in need of assistance with the AutoCAD advanced functions project. I have tried but project is not making sense can you please help? Thanks,
  17. Why don't you upload your program here.(rogramınızı buraya yükler misiniz?)
  18. Lee Mac
    Per the documentation, (vl-string-translate) replaces by character, not by string. Hence, for the arguments you have specified, the backslash ("\\") will be replaced by the newline character ("\n") and the "P" does not have a replacement character. Instead, since you're looking to substitute one string for another, you should use the (vl-string-subst) function (in a loop so as to replace all occurrences). I have written a String Subst wrapper which you could call in the following way: (LM:stringsubst "\n" "\\P" "Abcdef\\Pghijk\\Plmnop")
  19. oddssatisfy
    Best Practices for Setting Up a Podcast Studio
    thanks in advance for any help
  20. Hi everyone, I’m planning to set up a podcast studio at home and would love some advice. I’m trying to figure out the right combination of microphones, acoustic treatment, and software to get professional-sounding recordings. Additionally, I’m curious about workflows that make editing smoother. For example, how do you efficiently integrate post-production services into your process without it becoming too costly or time-consuming? Any recommendations on tools, equipment, or tips for both beginners and experienced podcasters would be hugely appreciated.
  21. Danielm103
    You can build a lisp function in Python that will explode the MText into fragments @Ap.Command() def doit(): try: ps, id, pnt = Ed.Editor.entSel("\nSelect: ", Db.MText.desc()) mt = Db.MText(id) frags = mt.getFragments() val = "" for frag in frags: val += ' ' val += frag[Db.MTextFragmentType.kTextValue] print(frags) print(val) except Exception: print(traceback.format_exc()) [PyGe.Point3d(18.25565516926225,16.52816695203355,0.00000000000000), PyGe.Vector3d(0.00000000000000,0.00000000000000,1.00000000000000), PyGe.Vector3d(1.00000000000000,0.00000000000000,0.00000000000000), 'Hello', None, None, PyGe.Point2d(0.63669849931787,0.20327421555252), 0.2, 1.0, 0.0, 1.0, <PyDb.EntityColor object at 0x000001AD0C1D0F90>, 0, 0, 0, 0, 0, [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], 'Arial', False, False] [PyGe.Point3d(19.29427328818596,15.86150028536689,0.00000000000000), PyGe.Vector3d(0.00000000000000,0.00000000000000,1.00000000000000), PyGe.Vector3d(1.00000000000000,0.00000000000000,0.00000000000000), 'World', None, None, PyGe.Point2d(0.72960436562074,0.20327421555252), 0.2, 1.0, 0.0, 1.0, <PyDb.EntityColor object at 0x000001AD0C1D1770>, 0, 0, 0, 0, 0, [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], [PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000), PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)], 'Arial', False, False] Hello World
  22. rlx
    (defun c:t1 ( / txt1 delimiter txt2 ) (setq txt1 "Abcdef\\Pghijk\\Plmnop") (setq delimiter "\\P") (setq txt2 (pjk-Strparse txt1 delimiter)) (princ (strcat "\ntxt2 = " (vl-prin1-to-string txt2))) (princ) ) ;;; https://www.cadtutor.net/forum/topic/95913-replace-p-in-a-variable/ ;|============================================================================== Function Name: (pjk-StrParse) Arguments: str = String; String to process del = String; Delimiter to separate the string Usage: (pjk-StrParse <string> <delimter>) Returns: List; A list of strings Description: Separates a string into a list of strings using a specified delimiter string; uses recursion. ================================================================================|; (defun pjk-StrParse (str del / pos) (if (and str del) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (pjk-StrParse (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) ) ;; End Function (pjk-StrParse)
  23. I am going around in circle and not sure why. I have a Mtext a simple 3 line Mtext (setq txt "Abcdef\\Pghijk\\Plmnop") desired text for Excel a multi line cell "Abcdef\nghijk\nlmnop" thought something like this should work. Tried all sorts of combinations. Note a dbl \\ will leave the P behind but get multi lines. (setq txt (vl-string-translate "\\P" "\n" txt)) I have all the other code done putting all the object values int Excel cells. Think Dataextract.
  24. Last week
  25. In this part of the code, only the steps on the direction curve are calculated, the intersections are generated in the mssln:line subfunction. There is a problem. I found out that if I adjust z coordinate of the normal vector from 0.0 to 1e-8, I get acceptable results. But mysteriously that doesn't work if the boundary is an arc.
  26. Hi everyone, I’ve been working on a project to automate the tedious process of room quantity takeoffs (Area & Perimeter) in AutoCAD. I know how time-consuming it can be to manually measure every room and transfer data to Excel, so I developed a Lisp plugin called Quantity Surveyor Pro. It's currently v1.0 and completely free for the community. Key Features: ☻Auto-Boundary Detection: Works like the 'Boundary' command but smarter. ☻Smart Tagging: Automatically places Room Name/No tags with area & perimeter. ☻Excel Export: Exports all data to a CSV/Excel file with one click. ☻Table Generation: Creates a summary table inside AutoCAD. I would really appreciate it if you could test it and give me some feedback on how to improve it further. You can download it here: https://cadlisp.com (It supports both English and Turkish languages) Thanks in advance for your support!
  27. I know this query is old, but... Maybe for the path to multiple locations use the Traveling Salesman Problem (TSP) algorithm. @marko_ribar has a LISP on CADTutor. Bellman-Ford algorithm can handle the shortest path from a single source to all other nodes might work.
  28. I have one in C++ wrapped for lisp https://www.theswamp.org/index.php?topic=58049.msg613033#msg613033 I’d have to look at the code again, I forgot, I think I generated a tin, from the tin, create a graph of the triangle edges
