  2. granat
    xdrx
  3. I'm not going to troubleshoot it since Powershell is blocked at work, but if the load has that error, then it's something in the Code, probable in the DCL write-line part.
  4. Thank you for the reminder, this is long-term content for search engines. At least I know there are several WhatsApp groups in the AEC field, and I guess there should still be some users. What methods do you mainly use?
  5. Not so sure on that one, CAD engineers don't get work phones so often, so whatsapp not so useful to keep up to date with a file repository.
  6. String too long - just a guess, file path and file name string length? - going back old school when we had 256? characters for it all - but just a guess
  7. SLW210
    Error in Drawing file
    This thread was started 5 months ago and there was never a response to original questions. My WAG is @BIGAL's suggestion of RECOVER did the trick.
  8. SLW210
    xdrx
    Good catch!
  9. Many work computers are likely limited for using Powershell. Unrelated to Powershell being blocked, I get an error loading. error: string too long on input
  10. Today
  11. I was just suggesting a rewrite, though I think maybe it is just a Unicode issue so it might be altered. That's what I came back with on an internet search for change AutoCAD LISP from English input to Chinese and the articles I read stated Chinese has double-byte Unicode, the GRREAD may also be an issue. LISPSYS=2 is necessary. Is this on a Chinese Simplified version of AutoCAD, Windows , etc.? Give some more detailed information on the setups this will be used. I just started studying Chinese a few weeks ago, so I want be a ton of help on that end and haven't got into the characters yet.
  12. Just a quick update on this experiment: An AEC startup working on automated 2D quantity takeoff reached out to me today. They’ve been using AI to extract drawing data, but have been hitting a wall with geometric precision, and wanted to see if the v-code RPN approach could work for their 2D pipeline. When I started experimenting with v-code, the whole point was to slash token bloat and eliminate coordinate hallucinations through a deterministic stack machine (the 3D CSG solid in the sandbox was just a visual way to demonstrate the stack collapsing into geometry). Seeing a team take that core concept and explore applying it to real-world 2D data extraction has been an unexpected and very encouraging surprise.
  13. Welcome to join the VedaCAD WhatsApp group: https://chat.whatsapp.com/BsM62YEol9SHdKoWxaeW1D
  14. @BIGAL The goal isn’t just to change color. This AutoLISP routine is an interactive character-level editor for a single-line TEXT entity. It lets you: 1. Select an existing TEXT object. 2. Move the mouse along the text to highlight a range of characters. 3. Type replacement characters. 4. Press Enter or Space to replace the highlighted range in the original text. The temporary red text created by ht:paint is only a visual highlight of the selected character range. It is not meant to permanently change color.
  15. Not sure what your trying to achieve. Could you describe more. If it's about changing color then just use mtext.
  16. Yesterday
  17. Attached is an improved version of getfiled that implements powershell with the option to select single or multiple files returning a list of the selected item(s): Examples: (pl:getfiledps "Select Files" (getvar"dwgprefix") "dwg" 0) ; for single selection of file type dwg (pl:getfiledps "Select Files" (strcat (getenv "userprofile") "\\downloads") "dwg;dxf" 1) ; for multiple selection of file types dwg & dxf Feedback & comments are welcome. pl_getfiledps.lsp
  18. Danielm103
    xdrx
    if you're running Civil 3D 2019, then xdrx.x64.25.arx is not the correct version, it would be xdrx.x64.23.arx
  19. I came up with it. If it could be completely rewritten, that would be great.
  20. SLW210
    xdrx
    I haven't seen the person that was posting here promoting that in a while, but you might try messaging them here or their website. @XDSoft
  21. I forgot to mention, for keeping up with the revisions we have Excel drawing lists with the Drawing names, dates and latest revision number on the network. P&IDs keep a dated track of each and every revision in cast things get put back to an older revision.
  22. From where did that LISP originate? Mandarin? Glancing through that LISP a little, I am almost positive the best way would be to completely write something new.
  23. Danielm103
    KDTree as a NET application.
    Well done, nice use of Parallel.For! Kdtree’s are definitely a must have in the CAD programmer’s tool box.
  24. ymg3
    @Danielm103 Well I did managed to scrape some milliseconds. However not where it counts in the pairing. Most of the gain in collection of entities. So in the end it is still gile's code. ymg Command: PAIRKD --------- TIMING ------------------------------- Collecting entities: 236 milliseconds Building kdTree: 67 milliseconds Pairing lines and texts: 34 milliseconds Coloring lines and texts: 123 milliseconds Total Elapsed Time: 460 milliseconds Total Number of Groups: 102 using System; using System.Collections.Generic; using System.Diagnostics; using System.Linq; using System.Threading.Tasks; using Gile.AutoCAD.R20.Geometry; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; using AcAp = Autodesk.AutoCAD.ApplicationServices.Core.Application; [assembly: CommandClass(typeof(PairLinesWithTextsR17.Commands))] namespace PairLinesWithTextsR17 { public class Commands { private struct EntityPosition { public Entity Entity { get; } public Point3d Position { get; } public EntityPosition(Entity entity, Point3d position) { Entity = entity; Position = position; } } [CommandMethod("PAIRKD")] public void ParallelPairTextsWithLines3() { // Force GC collection prior to timing to avoid GC halts during execution GC.Collect(); GC.WaitForPendingFinalizers(); Stopwatch stopwatch = Stopwatch.StartNew(); Document doc = AcAp.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; RXClass lineClass = RXObject.GetClass(typeof(Line)); RXClass textClass = RXObject.GetClass(typeof(DBText)); // Pre-allocate generous capacity to prevent memory reallocations List<EntityPosition> midLines = new List<EntityPosition>(16384); List<EntityPosition> textList = new List<EntityPosition>(16384); using (doc.LockDocument()) using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction()) { LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead); ObjectId lineLayerId = lt.Has("1") ? lt["1"] : ObjectId.Null; ObjectId textLayerId = lt.Has("4") ? lt["4"] : ObjectId.Null; BlockTableRecord modelSpace = (BlockTableRecord)tr.GetObject( SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead); // 1. Fast Collection Phase foreach (ObjectId id in modelSpace) { RXClass rxClass = id.ObjectClass; if (rxClass == lineClass) { Line line = (Line)tr.GetObject(id, OpenMode.ForRead); if (line.LayerId == lineLayerId) { Point3d midPoint = new Point3d( (line.StartPoint.X + line.EndPoint.X) * 0.5, (line.StartPoint.Y + line.EndPoint.Y) * 0.5, (line.StartPoint.Z + line.EndPoint.Z) * 0.5 ); midLines.Add(new EntityPosition(line, midPoint)); } } else if (rxClass == textClass) { DBText text = (DBText)tr.GetObject(id, OpenMode.ForRead); if (text.LayerId == textLayerId) { Point3d pos = (text.Justify == AttachmentPoint.BaseLeft) ? text.Position : text.AlignmentPoint; textList.Add(new EntityPosition(text, pos)); } } } EntityPosition[][] textGroups = textList .GroupBy(t => ((DBText)t.Entity).TextString) .Select(g => g.ToArray()) .ToArray(); long t1 = stopwatch.ElapsedMilliseconds; // 2. KdTree Construction KdTree<EntityPosition> lineTree = new KdTree<EntityPosition>(midLines, ml => ml.Position, 2); long t2 = stopwatch.ElapsedMilliseconds; // 3. Parallel pairing (Math + Spatial Search) int numGroups = textGroups.Length; HashSet<Entity>[] uniqueGroupEntities = new HashSet<Entity>[numGroups]; Parallel.For(0, numGroups, i => { EntityPosition[] group = textGroups[i]; HashSet<Entity> uniqueSet = new HashSet<Entity>(group.Length * 2); for (int j = 0; j < group.Length; j++) { EntityPosition textItem = group[j]; uniqueSet.Add(textItem.Entity); Entity nearestLine = lineTree.GetNearestNeighbour(textItem.Position).Entity; uniqueSet.Add(nearestLine); } uniqueGroupEntities[i] = uniqueSet; }); long t3 = stopwatch.ElapsedMilliseconds; // 4. Sequential Database Modification Phase for (int i = 0; i < numGroups; i++) { int colorIndex = (i % 255) + 1; HashSet<Entity> uniqueSet = uniqueGroupEntities[i]; foreach (Entity entity in uniqueSet) { if (entity.ColorIndex != colorIndex) { if (!entity.IsWriteEnabled) { entity.UpgradeOpen(); } entity.ColorIndex = colorIndex; } } } long t4 = stopwatch.ElapsedMilliseconds; stopwatch.Stop(); ed.WriteMessage($"\n--------- TIMING -------------------------------"); ed.WriteMessage($"\nCollecting entities: {t1} milliseconds"); ed.WriteMessage($"\nBuilding kdTree: {t2 - t1} milliseconds"); ed.WriteMessage($"\nPairing lines and texts: {t3 - t2} milliseconds"); ed.WriteMessage($"\nColoring lines and texts: {t4 - t3} milliseconds\n"); ed.WriteMessage($"\nTotal Elapsed Time: {t4} milliseconds"); ed.WriteMessage($"\nTotal Number of Groups: {numGroups}"); tr.Commit(); } } } } pairkd.dll
  25. Thanks @SLW210 for editing. I couldn't figure out how to format the code, but now I know how!
  26. Last week
  27. Paul Li
    could you share your dwg?
  28. Likewise, we save a full copy of the as issued drawings, plus the PDF mark ups and check prints each in a separate folder. Unless specified otherwise all our files are suffixed with the revision code. Mark ups and check prints are in sequentially numbered and dated folders - so we can always go back. Typical folders: 1.0 Working Drawings 2.0 Check Prints - 2.1 Check Print 01-01-26 - 2.2 Check Print 15-03-26 3.0 Markups - 3.1 Markup 01-01-26 - 3.2 Markup 10 -03-26 4.0 Previous Versions And of course if there is a significant change between issues, I'll save the before and after away somewhere safe We usually issue PDFs during the project and if required the as-builts as dwgs right at the end I believe that the construction cloud saves each save as a new version whether it is a new revision or not
  29. Please use code tags in the future. (<> in the text editor) and please post the code formatted.
