Change a length of line by feeding a new end point to the association list.
Dayananda posted a topic in AutoLISP, Visual LISP & DCL
I can get the Association list of a line with entget . Please help me feed to new values to this list. - Today
Need a routine lisp for bearing & azimuth in realtime.
Tsuky replied to oliver's topic in AutoLISP, Visual LISP & DCL
I relied on your pictures... ??? In your picture: I see for degrees: Deg/Min/Sec - Clockwise (on) - South 90d0' If not correct change ANGDIR, ANGBASE and AUNITS in: (mapcar 'setvar '("DIMZIN" "ANGDIR" "ANGBASE" "AUNITS" "AUPREC" "LUPREC" "LUNITS") (list 0 1 (* pi 1.5) 1 3 2 2)) - Yesterday
mhupp replied to oliver's topic in AutoLISP, Visual LISP & DCL
oliver replied to oliver's topic in AutoLISP, Visual LISP & DCL
I really appreciate your help..there's a little minor adjustment ( "the bearing it should be from North base" ) i'd try to figure it out. Thanks and have a good day everyone. God blessed us all. -
AutoLISP to print Custom Paper Size dynamically from Polyline/Layout geometry (ex: a3 extended,...)
BIGAL replied to cando's topic in AutoLISP, Visual LISP & DCL
My first comment is when you hard print the pdf you have to pick a paper size so why would you not just pick a paper size to start with ? I do not understand the Custom scale size needed. In the world you are normally metric or imperial paper sizes. You can easily with a lisp etc plot a standard sheet size in a layout that has a Viewport at the correct scale. I think that is the step your not understanding, many example code does exist. For me a couple of choices make multiple layouts at scale walking along a pline, make multiple rectangs in Model at a scale matching viewports and title blocks in layouts. In this image select a title block and scale pick on Model and correct layout is made. A rectang is drawn in the model showing the result so you can accept or erase and run again. You can move and rotate the rectang before making the matching layout. -
Extents of a part, creating a bounding box
Maybe this give it a try, https://www.lee-mac.com/ssboundingbox.html -
Automating schedules, dates, etc. on the plot.
BIGAL replied to Discus84's topic in AutoCAD Drawing Management & Output
I agree with you @SLW210 this was our plot stamp added to our std title block. It was set to a small size but showed when it was plotted not as per the revision date. -
SLW210 replied to cando's topic in AutoLISP, Visual LISP & DCL
Maybe this one? Solved: Automatic Papersize - Autodesk Community -
marko_ribar started following Need a routine lisp for bearing & azimuth in realtime.
marko_ribar replied to oliver's topic in AutoLISP, Visual LISP & DCL
FYI... You can call osnap menu while using (grread) in (while) loop... Read this message : https://www.theswamp.org/index.php?topic=12813.msg580708#msg580708 And further more, I'd read complete topic - there are many examples, but you need to be logged to download routines posted with messages... -
SLW210 replied to oliver's topic in AutoLISP, Visual LISP & DCL
See the links in this post for information on using snaps with grread. (The entire thread is a good read) -
lalir joined the community
I don't really see the point of the dynamic mode in your function, especially if you want to snap to objects. This would seem to me to be sufficient and would resolve the osnap. (vl-load-com) (defun c:label_bearing ( / l_var AcDoc Space nw_style nw_obj pt1 pt alpha len_l m_pt val_txt) (setq l_var (mapcar 'getvar '("DIMZIN" "ANGDIR" "ANGBASE" "AUNITS" "AUPREC" "LUPREC" "LUNITS" "TEXTSIZE"))) (initget "Bearing Degrees") (if (eq (getkword "\nResult in [Bearing/Degrees]?<Bearing>: ") "Degrees") (mapcar 'setvar '("DIMZIN" "ANGDIR" "ANGBASE" "AUNITS" "AUPREC" "LUPREC" "LUNITS") (list 0 1 (* pi 1.5) 1 3 2 2)) (mapcar 'setvar '("DIMZIN" "ANGDIR" "ANGBASE" "AUNITS" "AUPREC" "LUPREC" "LUNITS") (list 0 1 (* pi 0.5) 4 3 2 2)) ) (setvar "TEXTSIZE" (* (getvar "VIEWSIZE") 0.015)) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (vla-startundomark AcDoc) (cond ((null (tblsearch "STYLE" "BEARING")) (setq nw_style (vla-add (vla-get-textstyles AcDoc) "BEARING")) (mapcar '(lambda (pr val) (vlax-put nw_style pr val) ) (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag) (list "romand.shx" 0.0 0.0 1.0 0.0) ) ) ) (setq nw_obj (vla-addMtext Space (vlax-3d-point '(0.0 0.0 0.0)) 0.0 "" ) ) (initget 1) (setq pt1 (getpoint "\nPick base point: ")) (initget 1) (setq pt (getpoint pt1 "\nPick other point: ")) (entmake (list (cons 0 "LINE") (cons 10 pt1) (cons 11 pt))) (setq alpha (angle pt1 pt) len_l (distance pt1 pt) m_pt (mapcar '* (mapcar '+ pt1 pt) '(0.5 0.5 0.5)) val_txt (vl-string-subst "%%d" "d" (strcat (angtos alpha) "\\P " (rtos len_l) " m")) ) (if (and (> alpha (* pi 0.5)) (<= alpha (* pi 1.5))) (setq alpha (+ alpha pi)) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation 'TextString 'Color) (list 5 (getvar "TEXTSIZE") 5 m_pt "BEARING" (getvar "CLAYER") alpha val_txt 2) ) (vla-endundomark AcDoc) (mapcar 'setvar '("DIMZIN" "ANGDIR" "ANGBASE" "AUNITS" "AUPREC" "LUPREC" "LUNITS" "TEXTSIZE") l_var) (prin1) ) However, if you absolutely want the dynamic mode with the possibility of osnap, here is the redesigned function attached. ("osmode" must be defined beforehand, no possibility to force it when using the function) My management is succinct: only: "_end" "_mid" "_cen" "_nod" "_qua" "_int" "_ins" "_per" "_tan" "_nea" For a more elaborate management see perhaps the LeeMac function label_bearing.lsp -
Discus84 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Suppose I have a part like this: This has to be placed in an assembly, therefore it would be nice to have a bounding box around it in order to find extents and centerlines. Regards, Lu -
Must have deleted from my other post, But how grread works I don't know if you can use snaps. every time you move the mouse it updates the point and calculation. maybe Tsuky knows of a way. -
Dahzee started following AutoLISP to print Custom Paper Size dynamically from Polyline/Layout geometry (ex: a3 extended,...)
Dahzee replied to cando's topic in AutoLISP, Visual LISP & DCL
@cando I think you will find this is the big drawback of the way AutoCAD (and all of its clones) creates page setups and sizes. This wasn't really a problem when everything was actually printed onto standard paper sizes, but now we have PDFs, which can have much more varied page sizes. This highlights the limitations of the way printing is achieved in AutoCAD. I'm not saying there is anything wrong with the way AutoCAD prints; it just has limitations with custom pages. I think it is exacerbated with there being very limited access programmatically to the whole print/page setup. As you can appreciate, there is a lot of flexibility in the setup of multiple pages and scales the way it works at the moment, so someone would have to think long and hard about another way of achieving everything you have already and then incorporating another way of having custom pages into it. Sorry if that isn't what you wanted to hear. -
Text temporarily disappearing
SLW210 replied to Rooster's topic in AutoCAD 2D Drafting, Object Properties & Interface
Which Add-On if you don't mind sharing? I only have one right now loaded, but have a few waiting on IT to install. Could still be related to Windows updates. -
I would keep leaning on the powers that be to get proper .dwgs or at least vector PDFs. Other than that, I most recently converted some raster PDF's to PNG enhanced and cleaned up in GIMP and used Raster Tools in AutoCAD to create AutoCAD objects, worked okay.
SLW210 replied to Discus84's topic in AutoCAD Drawing Management & Output
You should use the Plot Stamp to add the plotted/printed date, the date on the drawing should always remain the same, each revision gets a date as well and also should remain the same throughout the history of the drawing. -
The question was AutoCAD and was 12 years ago. To add, not much help just stating a program has a feature without any other context. Though there is the ability to adjust linetypes in MicroStation, the usual remedy is to break the line in most cases, same as AutoCAD.
I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. In the future please post in the appropriate forum. -
Body: Hi everyone, I am looking for a LISP routine or a workflow to automate the printing process for non-standard sheet sizes. The problem: I frequently work with layouts of varying dimensions. Currently, I have to manually create a new "Custom Paper Size" in the Plotter Configuration (.pc3) every time I encounter a new size, which is very time-consuming. My goal: I need a Lisp that allows me to select a rectangular area (or a closed Polyline) representing the plot boundary. The routine should then: Detect the width and height of the selection. Automatically generate (or set) a matching custom paper size for the PDF plotter. Set the plot scale to 1:1 (1 mm = 1 drawing unit). Has anyone achieved this automation or can suggest a workaround? Thanks in advance!
cando joined the community
this code..work perfectly... val_txt (vl-string-subst "%%d" "d" (strcat (angtos (- (/ pi 2) alpha) 4 3) "\\P " (rtos len_l) " m")) but some little adjustment the osnap was not working.. much better if we have an option to select..BEARING OR DEGREES from my previous post. Have a good day.. thanks. 13.01.2026_16.24.06_REC.mp4 -
Nice Tsuky tho i use this when setting multiple variables. less likely to get the order mixed up if their is only one list. (setq vars '(DIMZIN ANGDIR ANGBASE AUNITS AUPREC LUPREC LUNITS TEXTSIZE) ;list of variables vals (mapcar 'getvar vars) ;store old values ) (mapcar 'setvar vars (list 0 1 (* pi 0.5) 4 3 2 2)) ;set new values ... (mapcar 'setvar vars vals) ;restore old values @oliver i think you want North to be 0 instead of East? so you have to subtract that from the angle in angtos. updating this line should give you what your looking for. val_txt (vl-string-subst "%%d" "d" (strcat (angtos (- (/ pi 2) alpha) 4 3) "\\P " (rtos len_l) " m")) -
Pattharin joined the community
arkiNat joined the community
Nope. Revit works on Parameters. Try to read about Types and Instance Parameters as well as Project Information. These are the things that are to be used in your title blocks. As well as Visibility Parameters for your Key Plan.
Thank you the code is perfectly fine and work..but some a little adjustment here some photos and hope the osnap works this time.. 13.01.2026_09.37.04_REC.mp4 -
I should have used acdbAngToS which honors AUNITS
