  1. Today
  2. Yesterday
  3. leonucadomi
    dimjogline plus in dimension ... help
    I love this, it's excellent, thank you
  4. leonucadomi
  5. Nikon
    Multi offset - drawing stairs
    I would add: I'm not a lisp programmer... ; Original by Emmanuel Delay + additions (defun c:MuOffLay ( / ss pt3 i off_dst obj elast pickset1 old_dst str_prompt) ;; creating a new layer (if (not (tblsearch "LAYER" "OffsetLines")) (command "_-layer" "_make" "OffsetLines" "_color" "1" "OffsetLines" "") ) ;; memorizing the distance (setq old_dst (getenv "MULTIOFF_LASTDST")) (if old_dst (progn (setq str_prompt (strcat " Offset Distance <" old_dst ">: ")) (setq off_dst (getreal str_prompt)) (if (not off_dst) (setq off_dst (atof old_dst)) ) ) (setq off_dst (getdist " Offset Distance: ")) ) (setenv "MULTIOFF_LASTDST" (rtos off_dst 2 3)) (setq pt3 (getpoint " Offset point: ")) (setq pickset1 (ssadd)) (princ " Select objects: ") (setq ss (ssget)) (setq i 0) (while (< i (sslength ss)) (setq obj (ssname ss i)) (command "_.offset" off_dst obj pt3 "") (setq elast (entlast)) (command "_.chprop" elast "" "_la" "OffsetLines" "_color" "1" "") (ssadd elast pickset1) (setq i (1+ i)) ) (sssetfirst nil pickset1) (princ) )
  6. GLAVCVS
    And this is the small variation that best fits what @leonucadomi is asking for, I think. With the peculiarity that the "jog" will be placed where the selection is made with the pickbox. ; Original by RonJonP, edited by P. Kenewell and GLAVCVS (defun c:ltx (/ e o s le to l) (setvar "cmdecho" 0) (command "._undo" "_be") (while (and (setq e (car (setq l (entsel "\rSelect a TEXT, MTEXT or DIMENSION...")))) (wcmatch (cdr (assoc 0 (setq le (entget e)))) "*TEXT,DIMENSION")) (setq o (vlax-ename->vla-object e)) (cond ((= "TEXT" (setq to (cdr (assoc 0 le)))) (vla-put-textstring o (strcat "%%O" (vl-string-subst "" "" (vl-string-subst "" "%%O" (vla-get-textstring o)) ) ) ) ) ((= "MTEXT" to) (vla-put-textstring o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textstring o)) ) ) ) ) ((= "DIMENSION" to) (if (not (tblsearch "APPID" "ACAD_DSTYLE_DIMJAG_POSITION")) (regapp "ACAD_DSTYLE_DIMJAG_POSITION") ) (entmod (append le (list (list -3 (list "ACAD_DSTYLE_DIMJAG_POSITION" '(1070 . 387) '(1070 . 3) '(1070 . 389) (cons 1010 (cadr l))))))) (if (= (vla-get-textoverride o) "") (vla-put-textoverride o "\\O<>") (vla-put-textoverride o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textoverride o)) ) ) ) ) ) ) ) (command "._undo" "_end") (setvar "cmdecho" 1) (princ) )
  7. GLAVCVS
    This will do what you want by selecting multiple objects in the selection set. ; Original by RonJonP, edited by P. Kenewell and GLAVCVS (defun c:ltx (/ o s le to p1 p2 pIns) (setvar "cmdecho" 0) (command "._undo" "_be") (if (setq s (ssget ":L" '((0 . "*TEXT,DIMENSION")))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq o (vlax-ename->vla-object e)) (cond ((= "TEXT" (setq to (cdr (assoc 0 (setq le (entget e)))))) (vla-put-textstring o (strcat "%%O" (vl-string-subst "" "" (vl-string-subst "" "%%O" (vla-get-textstring o)) ) ) ) ) ((= "MTEXT" to) (vla-put-textstring o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textstring o)) ) ) ) ) ((= "DIMENSION" to) (if (not (tblsearch "APPID" "ACAD_DSTYLE_DIMJAG_POSITION")) (regapp "ACAD_DSTYLE_DIMJAG_POSITION") ) (setq p1 (cdr (assoc 13 le)) p2 (cdr (assoc 14 le)) pIns (polar (cdr (assoc 10 le)) (angle p2 p1) (* (distance p1 p2) 0.8)) x (entmod (append (entget e) (list (list -3 (list "ACAD_DSTYLE_DIMJAG_POSITION" '(1070 . 387) '(1070 . 3) '(1070 . 389) (cons 1010 pIns)))))) ) (if (= (vla-get-textoverride o) "") (vla-put-textoverride o "\\O<>") (vla-put-textoverride o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textoverride o)) ) ) ) ) ) ) ) ) (command "._undo" "_end") (setvar "cmdecho" 1) (princ) )
  8. Change if to while. (if (setq s (ssget ""_+.:E:S" '((0 . "*TEXT,DIMENSION")))) .. runs once ) (while (setq s (ssget "_+.:E:S" '((0 . "*TEXT,DIMENSION")))) ... repeats while you have an entity selected. have to right click or enter to exit loop )
  9. leonucadomi
    I have already managed to change the selection to individual and cancel the zoom but to repeat the routine I use repeat 100 (....) I don't know any other way
  10. Its incomplete code and only uses vla-object names showing best practice for using cond. Use the original code setting e type outside the cond to check instead of using enget for each cond check. with dimensions you use entget three times, mtext two times. its probably only saving ms of time. ; Original by RonJonP, edited by P. Kenewell and GLAVCVS (defun c:ltx (/ o s pt i p1 p2 le typ) (setvar "cmdecho" 0) (command "._undo" "_be") (if (setq s (ssget ":L" '((0 . "*TEXT,DIMENSION")))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq typ (cdr (assoc 0 (entget e)))) (setq o (vlax-ename->vla-object e)) (cond ((= "TEXT" typ) ... ) Every time you are using enget its returning something like this. ( (0 . "MTEXT") ; saving this bit (5 . "1F2") (330 . <owner>) (100 . "AcDbEntity") (67 . 0) (8 . "TextLayer") (100 . "AcDbMText") (10 100.0 200.0 0.0) (40 . 2.5) (41 . 50.0) (71 . 1) (72 . 5) (1 . "This is a multiline text") (7 . "Standard") (210 0.0 0.0 1.0) (11 100.0 200.0 0.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (73 . 1) (44 . 0.0) (45 . 0.0) (90 . 0) (91 . 1) (92 . 0) (93 . 0) (94 . 0) (95 . 0) )
  11. leonucadomi
    This is what I need, I just would like it to be for selecting a single selection (entsel) and not zoom, Just select a dimension and a point for the jogline and repeat the routine.
  12. leonucadomi
    a default location near any arrow
  13. leonucadomi
    something is wrong
  14. Is it possible not to specify breakpoints, but just make a break to the right of the text?
  15. Just sharing a simple script I just wrote, I don't have a question When drawing the hidden lines of stairs steps (the overlap of the lower step hidden under the step above) I thought: I would like to select all the steps; multi offset them; the offset lines should be selected and gripped, so that I can set them in a different layer (a layer with LType Hidden) ... But feel free to comment, improve, ... ;; Multi Offset. New objects get selected and gripped. ;; For example to make the hidden stairs steps... Select all (defun c:moff ( / sel ss pt3 i off_dst obj elast pickset1) (setq off_dst (getdist "\nOffset Distanct: ")) (setq pt3 (getpoint "\nOffset point: ")) (setq pickset1 (ssadd)) (princ "\nSelect objects: ") (setq ss (ssget)) (setq i 0) (repeat (sslength ss) (setq obj (ssname ss i)) (command "offset" off_dst obj pt3 "") (setq elast (entlast)) ;; (ssadd elast pickset1) (setq i (+ i 1)) ) ;; now grip the pickset (the newly made objects) (sssetfirst nil pickset1) )
  16. GLAVCVS
    I think I forgot something important: when there are multiple selections, it's necessary to show the user which object will be modified in each case. Below, I've included the complete code with a zoom utility to show the user the next object to modify. ; Original by RonJonP, edited by P. Kenewell and GLAVCVS (defun c:ltx (/ o s pt i p1 p2 le) (setvar "cmdecho" 0) (command "._undo" "_be") (if (setq s (ssget ":L" '((0 . "*TEXT,DIMENSION")))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq o (vlax-ename->vla-object e)) (cond ((= "TEXT" (cdr (assoc 0 (entget e)))) (vla-put-textstring o (strcat "%%O" (vl-string-subst "" "" (vl-string-subst "" "%%O" (vla-get-textstring o)) ) ) ) ) ((= "MTEXT" (cdr (assoc 0 (entget e)))) (vla-put-textstring o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textstring o)) ) ) ) ) ((= "DIMENSION" (cdr (assoc 0 (entget e)))) (if (not (tblsearch "APPID" "ACAD_DSTYLE_DIMJAG_POSITION")) (regapp "ACAD_DSTYLE_DIMJAG_POSITION") ) (command "_zoom" "_w" (setq i (cdr (assoc 10 (setq le (entget e))))) (polar i (angle (setq p2 (cdr (assoc 14 le))) (setq p1 (cdr (assoc 13 le)))) (distance p1 p2))) (if (setq pt (getpoint "\rJOG: Pick a point on the DIMENSION line")) (entmod (append (entget e) (list (list -3 (list "ACAD_DSTYLE_DIMJAG_POSITION" '(1070 . 387) '(1070 . 3) '(1070 . 389) (cons 1010 pt)))))) ) (if (= (vla-get-textoverride o) "") (vla-put-textoverride o "\\O<>") (vla-put-textoverride o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textoverride o)) ) ) ) ) ) ) ) ) (command "._undo" "_end") (setvar "cmdecho" 1) (princ) )
  17. GLAVCVS
    To indicate the 'jog' position 1 to 1, insert this code after the clause ((= "DIMENSION"... (entget e) )))) (if (not (tblsearch "APPID" "ACAD_DSTYLE_DIMJAG_POSITION")) (regapp "ACAD_DSTYLE_DIMJAG_POSITION") ) (if (setq pt (getpoint "\nJOG: Pick a point on the DIMENSION line")) (entmod (append (entget e) (list (list -3 (list "ACAD_DSTYLE_DIMJAG_POSITION" '(1070 . 387) '(1070 . 3) '(1070 . 389) (cons 1010 pt)))))) )
  18. GLAVCVS
    Hi Do you want to place the 'jog', indicating its location in each case, or in a predetermined location?
  19. Last week
  20. CyberAngel
    Text box auto resize
    I downloaded the code and ran it. No problem here. I made sure to change the Defined Width property and to add a mask and a frame. That way the change is obvious once it happens. Is it possible you're using it on text and not mtext? Because the function excludes anything that's not mtext.
  21. shokoufeh
    Automatically add text to a table
    Great. It worked. Thanks
  22. ghuuuu
    I think Lee Mac is onto something, I just can't make it work just like IndianaJackson said, nothing happened. Did anyone manage to make it work?
  23. Also you can return the vla-object list with foreach by wrapping it in mapcar. eliminating having to use (setq o (vlax-ename->vla-object e)). Pulling the vla-object name before the cond means your checking the variable rather then check the entity up to 3 times. ; Original by RonJonP, edited by P. Kenewell, updated by Mhupp (defun c:ltx (/ D O S) (vl-load-com) (setq D (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark D) (if (setq s (ssget ":L" '((0 . "*TEXT,DIMENSION")))) (foreach o (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))) (setq typ (vla-get-ObjectName o)) (cond ((= typ "AcDbText") (vla-put-textstring o (strcat "%%O" (vl-string-subst "" "" (vl-string-subst "" "%%O" (vla-get-textstring o))))) ) ((= typ "AcDbMText") ... ) ((= typ "AcDbDimension") ... ) ) ) ) (vla-endundomark D) (princ) ) -edit also useing the (vla-startundomark allows you to have things selected before you run the command.
  24. Good old fashioned google 1st found this not sure if helpful. https://help.autodesk.com/view/ACDMAC/2025/ENU/?guid=GUID-E0859F66-985A-4A20-BCB4-1B57D24DC100
  25. BIGAL
    Trouble displaying drawing in Viewport
    @eldon has certainly given you the correct answer. Our title blocks were an A1 sheet but we plotted hard copy & PDF most times to be a A3 sheet. The was produced by setting the scale factor in "PLOT" to 1=2 so a 1:250 viewport would be 1:500 in an A3, so objects could be scaled. So we never mixed and matched the title blocks size. Only used one size so you probably need to think about that. If you stick with A3 you can probably have 2 viewports per layout at 1:100.
  26. hello all: There are dimensions I need to do this to. I have a routine to do this It would be possible to do everything in a single selection I mean select the dimension and place the break and the line over the text I await comments and here I put the code, thank you ; Original by RonJonP, edited by P. Kenewell (defun c:ltx (/ o s) (setvar "cmdecho" 0) (command "._undo" "_be") (if (setq s (ssget ":L" '((0 . "*TEXT,DIMENSION")))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq o (vlax-ename->vla-object e)) (cond ((= "TEXT" (cdr (assoc 0 (entget e)))) (vla-put-textstring o (strcat "%%O" (vl-string-subst "" "" (vl-string-subst "" "%%O" (vla-get-textstring o)) ) ) ) ) ((= "MTEXT" (cdr (assoc 0 (entget e)))) (vla-put-textstring o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textstring o)) ) ) ) ) ((= "DIMENSION" (cdr (assoc 0 (entget e)))) (if (= (vla-get-textoverride o) "") (vla-put-textoverride o "\\O<>") (vla-put-textoverride o (strcat "\\O" (vl-string-subst "" "" (vl-string-subst "" "\\O" (vla-get-textoverride o)) ) ) ) ) ) ) ) ) (command "._undo" "_end") (setvar "cmdecho" 1) (princ) )
  27. You didn't post this in one of the code forums. I have no idea what settings you can modify, maybe you should actually post something. What type of code are you using?
  28. I am not gonna lie, its cool!!!! Maybe I can create a separate function have this as my mtext (after some polishing and maybe a menu setting). I will spend sometime and try and remove the FFL function and just keep the text function with prefix suffix, offset, and mouse movement and post it here.
