  2. Ok simple maybe I didn't use the "L" option rather, just pick 2 3 or 4 points. I can change it pretty quick to just convert a pline. A quick fix change the three lines in the code. ;;;;;;;; starts here ;(plpts) ;(setq ent (entlast)) (setq ent (car (entsel "\nPick a pline "))) Will do the front end later today. Set text size etc. Do you want a dogleg ?
  3. Yesterday
  4. you're absolutely right GLAVCVS , took out too much when I cleaned out some obsolete code. Usually I forget the 'void' function but paid special attention I didn't this time. At the expense of rlx_sf this time so it seems. Have done a few changes , renamed orientation to justification (change with letter j / J while menu is displayed) , change (background) color with b (or B) and with keys c / C & r / R decrease / increase columns & rows. Hope all the bugs are dead now... ;;; GrM - Graphic Menu , Rlx sep '25 ;;; Known limitations : keep app names short , use fixed width & height not really useful, probably gonna remove that ;;; option was intended to be able to have like a 4x4 in center of screen and not fill entire screen... maybe later.. ;;; last update : 2025-09-04 - cleaned up & connected dialog with subroutines ;;; : 2025-09-05 - did some further t&c (tweaking & cleaning) ;;; : 2025-09-06 - time for fieldtesting ;;; : 2025-09-07 - fixed a couple of 1st use issues ;;; : 2025-09-10 - included rlx_sf (defun c:GrMS ( / ;;; globals regkey regvar reg-var-list old-err screen-width screen-height GrM-NoF-Columns GrM-NoF-Rows start-toolbar cell-height cell-width x y cell-number app-list corner start-viewsize app default-button-width default-button-height ;;; test variables so I can run program without dialog tst-NoF-Rows tst-NoF-Columns tst-cell-height tst-cell-width ;;; dimscreen : view x-/y-/x+/y+/height/width/center vx- vy- vx+ vy+ vh vw vc ;;; toolbar corner points tb-x- tb-x+ tb-y- tb-y+ tb-ll tb-ul tb-lr tb-ur tb-dX tb-dY ;;; setup dialog variables setup-dialog-fn setup-dialog-fp setup-dialog-dcl setup-dialog-tl setup-dialog-rd ;;; registry GrM-NoF-Rows ;;; Number of rows in menu , left-right (vertical) Justification GrM-NoF-Columns ;;; Number of columns in menu , left-right (vertical) Justification GrM-Button-Background-Fill ;;; 100(%) means 1 vector line per unit GrM-Button-Width-Height-Ratio ;;; width-ratio 2 means cell width is 2 x cell height GrM-Max-Button-Width-Height-Ratio ;;; set on 3 (width is max 3 times button height) GrM-Max-Button-Background-Fill ;;; 0-100 (%) in steps of 10 GrM-Use-Fixed-Cell-Height ;;; boole , "0" = nope , "1" = jip GrM-Cell-Height ;;; 10 means screen width / 10 GrM-Use-Fixed-Cell-Width ;;; boole , "0" = nope , "1" = jip GrM-Cell-Width ;;; 10 means screen height / 10 GrM-Frame-Color ;;; default is "7" (white) GrM-Text-Color ;;; default is "7" (white) GrM-Background-Color ;;; colors like "8" (gray) , "143" (dirty blue) ;;; options GrM-Max-Columns GrM-Max-Rows ;;; Limmits on number of columns & row GrM-Follow-Justification GrM-Sort-On-Load ;;; Swap #rows - #cols when switching Left/Right - Top/Center/Bottom GrM-Text-Size-Factor ;;; usually 9 or 10 GrM-Toolbar-Justification ;;; left/right/top/bottom/center GrM-App-List-File GrM-Debug-Mode ;;; if "1" function inspect displays variables & values ) ;;; initialyze environment (set_reg_var_list) (princ "\nstart GrM ... ") (GrM_Init) (princ "start setup dialog\n") ;;; (chk_reg_vars) ;;; debug on;y (GrM_Setup_Dialog_Start) (GrM_Exit) (princ) ) (defun c:GrM ( / regkey regvar reg-var-list old-err screen-width screen-height GrM-NoF-Columns GrM-NoF-Rows cell-height cell-width x y cell-number app-list corner vx- vy- vx+ vy+ vh vw vc tb-x- tb-x+ tb-y- tb-y+ tb-ll tb-ul tb-lr tb-ur tb-dX tb-dY setup-dialog-fn setup-dialog-fp setup-dialog-dcl setup-dialog-tl setup-dialog-rd app default-button-width default-button-height GrM-NoF-Rows GrM-NoF-Columns GrM-Button-Background-Fill GrM-Button-Width-Height-Ratio GrM-Max-Button-Width-Height-Ratio GrM-Max-Button-Background-Fill GrM-Use-Fixed-Cell-Height GrM-Cell-Height GrM-Use-Fixed-Cell-Width GrM-Cell-Width GrM-Frame-Color GrM-Text-Color GrM-Background-Color GrM-Max-Columns GrM-Max-Rows GrM-Follow-Justification GrM-Sort-On-Load GrM-Text-Size-Factor GrM-Toolbar-Justification GrM-App-List-File GrM-Debug-Mode) ;;; initialyze environment (set_reg_var_list) (princ "\nstart GrM ... ") (GrM_Init) (princ "start toolbar\n") ;;; (chk_reg_vars) ;;; debug only (GrM_Draw_Toolbar) (if (eq GrM-Debug-Mode "1") (inspect (list 'vh 'vw 'GrM-Toolbar-Justification 'GrM-NoF-Columns 'GrM-NoF-Rows 'GrM-Use-Fixed-Cell-Height 'GrM-Cell-Height 'cell-Height 'GrM-Use-Fixed-Cell-Width 'GrM-Cell-Width 'cell-width 'GrM-Frame-Color 'GrM-Text-Color 'GrM-Background-Color ) ) ) ;;; get user input (GrM_Start_GrRead) (GrM_Exit) ;;; launch app (if app (GrM_Start_App app)) ) (defun set_reg_var_list () (setq reg-var-list (list 'GrM-NoF-Rows 'GrM-NoF-Columns 'GrM-Button-Background-Fill 'GrM-Button-Width-Height-Ratio 'GrM-Max-Button-Width-Height-Ratio 'GrM-Max-Button-Background-Fill 'GrM-Use-Fixed-Cell-Height 'GrM-Cell-Height 'GrM-Use-Fixed-Cell-Width 'GrM-Cell-Width 'GrM-Frame-Color 'GrM-Text-Color 'GrM-Background-Color 'GrM-Max-Columns 'GrM-Max-Rows 'GrM-Follow-Justification 'GrM-Sort-On-Load 'GrM-Text-Size-Factor 'GrM-Toolbar-Justification 'GrM-App-List-File 'GrM-Debug-Mode ) ) ) (defun GrM_Init () ;;; error handler (setq old-err *error* *error* GrM_Err) ;;; setup default data list (unless it exists) (create_default_data_file "c:\\temp\\GrM-Rlx.dat") ;;; init registry variables (InitDefaultRegistrySettings)(ReadSettingsFromRegistry) ;;; record viewsize at session begin (setq start-viewsize (getvar "viewsize")) ;;; get app-list if any (GrM_Preload_App_List) ;;; fixed button height / width is viewsize / factor (default = 12) (setq default-button-height (/ (getvar "VIEWSIZE") 10) default-button-width (* default-button-height 2.0)) ) (defun GrM_Err ($s) (princ (strcat "\n\n\n" $s))(GrM_Exit)(setq *error* old-err)(gc)(princ)) (defun GrM_Exit () ;;; dialog (if (not (null setup-dialog-dcl))(unload_dialog setup-dialog-dcl)) (if (not (null setup-dialog-fp))(close setup-dialog-fp)) (if (and (not (null setup-dialog-fn))(findfile setup-dialog-fn))(vl-file-delete setup-dialog-fn)) ;;; flush cache (redraw)(gc)(terpri)(princ "\r\n")(princ) ) ;;; --- Registry Settings ------------------------------- Begin Registry Settings ------------------------------- Registry Settings --- ;;; (defun InitDefaultRegistrySettings () (record "InitDefaultRegistrySettings") (setq regkey "HKEY_CURRENT_USER\\SOFTWARE\\GrM\\") ;;; regkeys must be strings ;;; ("variable name" "default value") (setq regvar '( ("GrM-NoF-Rows" "10") ;;; Number of rows in menu , left-right (vertical) Justification ("GrM-NoF-Columns" "1") ;;; Number of columns in menu , left-right (vertical) Justification ("GrM-Button-Background-Fill" "100") ;;; 100(%) means 1 vector line per unit ("GrM-Max-Button-Background-Fill" "100") ;;; value between 10-100 (%) in steps of 10 ("GrM-Button-Width-Height-Ratio" "2") ;;; width-ratio 2 means cell width is 2 x cell height ("GrM-Max-Button-Width-Height-Ratio" "3") ;;; limit on how many times the height the width of the button can be. ("GrM-Use-Fixed-Cell-Height" "0") ;;; boole , "0" = nope , "1" = jip ("GrM-Cell-Height" "") ;;; 10 means screen width / 10 ("GrM-Use-Fixed-Cell-Width" "0") ;;; boole , "0" = nope , "1" = jip ("GrM-Cell-Width" "") ;;; 10 means screen height / 10 ("GrM-Frame-Color" "7") ;;; default is "7" (white) ("GrM-Text-Color" "7") ;;; default is "7" (white) ("GrM-Background-Color" "8") ;;; colors like "8" (gray) , "143" (dirty blue) ("GrM-Max-Columns" "10") ;;; Limmits on number of columns ("GrM-Max-Rows" "10") ;;; Limmits on number of rows ("GrM-Follow-Justification" "1") ;;; Swap #rows - #cols when swapping Left/Right - Top/Center/Bottom ("GrM-Sort-On-Load" "1") ;;; Sort app-list upon load ("GrM-Text-Size-Factor" "9") ("GrM-Toolbar-Justification" "left") ;;; left/right/top/bottom/center ("GrM-App-List-File" "c:\\temp\\GrM-Rlx.dat") ("GrM-Debug-Mode" "0") ;;; hidden image button &d toggles dubug ) ) (mapcar '(lambda (x)(set (read (car x)) (cadr x))) regVar) ) (defun ReadSettingsFromRegistry () (record "ReadSettingsFromRegistry") (mapcar '(lambda (x / n v) (if (setq v (vl-registry-read regkey (setq n (car x)))) (set (read n) v) (vl-registry-write regkey n (cadr x)))) regvar)) (defun WriteSettingsToRegistry () (record "WriteSettingsToRegistry") (mapcar '(lambda (x) (vl-registry-write regkey (car x) (eval (read (car x))))) regvar)) ;;; (setq a 1 b t c "") (vl-every 'boundp (list 'a 'b 'c)) -> T ;;; (setq a 1 b nil c "") (vl-every 'boundp (list 'a 'b 'c)) -> nil (defun chk_reg_vars () (if (not (vl-every 'boundp reg-var-list)) (progn (princ "\n * reg var err - attempting to reload *") (gc) (ReadSettingsFromRegistry))) (if (not (vl-every 'boundp l)) (progn (alert " * reg var err - please reload GrM *")(exit))) ) ;;; --- Registry Settings -------------------------------- End Registry Settings -------------------------------- Registry Settings --- ;;; ;;; --- dialog section ----------------------------------- begin dialog section ------------------------------------ dialog section --- ;;; ;;; --- dialog section ----------------------------------- begin dialog section ------------------------------------ dialog section --- ;;; ; SaveDialogData evaluates all vars from %tl and returns them as a list, reset does the opposite (defun Save_Setup_Dialog_Data (%tl) (mapcar '(lambda (x) (eval (car x))) %tl)) (defun Reset_Setup_Dialog_Data (%tl %rd) (mapcar '(lambda (x y) (set (car x) y)) %tl %rd)) (defun Set_Setup_Dialog_Tiles (%tl) (mapcar '(lambda (x / v) (if (eq 'str (type (setq v (eval (car x))))) (set_tile (cadr x) v))) %tl)) (defun Setup_Dialog_Cancel () (Reset_Setup_Dialog_Data setup-dialog-tl setup-dialog-rd) (WriteSettingsToRegistry)) ;;; --- dcl plus-minus block -------------------------------------------------- ;;; _____ ;;; No. Dragons | 1| [ + ] [ - ] ;;; ----- ;;; k = key (will be prexid with eb_ & bt_ / app-list = label / w = edit box width ;;; (dcl_plus_min "rlx" "No. Dragons" "3") ;;; --------------------------------------------------------------------------- (defun dcl_plus_min (k app-list w) (strcat ":row {children_fixed_width=true;" ":text {fixed_width=true;width=10;label=\"" app-list "\";}" ":edit_box {key=\"eb_" k "\";edit_width=" w ";}" ":button {key=\"bt_" k "_plus\";label=\"+\";}" ":button {key=\"bt_" k "_min\";label=\"-\";}spacer;}" ) ) (defun dcl_button_image1 (k app-list) (strcat ":button {fixed_width=true;width=18;key=\"bt_" k "\";label=\"" app-list "\";}" ":image {fixed_width=true;width=4;color=-2;key=\"im_" k "\";}")) (defun GrM_Setup_Dialog_Create ( / f ) (record "GrM_Setup_Dialog_Create") (if (and (setq setup-dialog-fn (vl-filename-mktemp "GrM.dcl")) (setq setup-dialog-fp (open setup-dialog-fn "w"))) (mapcar '(lambda (x)(write-line x setup-dialog-fp)) (list (strcat "GrM_Setup : dialog {label=\"GrM - Setup screen (Rlx " (now) ")\";") ":text_part {key=\"tp_debug_mode\";}" ":boxed_column {label=\"Dimensions\";" " :row {" " :column {" (dcl_plus_min "nof_rows" "Rows" "3") "spacer;"(dcl_plus_min "fill" "Fill (%)" "3") "}" " :column {" (dcl_plus_min "nof_columns" "Columns" "3") (dcl_plus_min "button_width_height_ratio" "Ratio W/H " "3") "}" " }" " :row {alignment=centered;" " :column {width=10;}" " :toggle {label=\"Use fixed cell width\";key=\"tg_use_fixed_width\";}" " :edit_box {edit_width=3;key=\"eb_fixed_width\";}" " :column {width=12;}" " :toggle {label=\"Use fixed cell height\";key=\"tg_use_fixed_height\";}" " :edit_box {edit_width=3;key=\"eb_fixed_height\";}" " :column {width=2;}" " }" "}" ":boxed_row {label=\"Colors\";" (dcl_button_image1 "frame_color" "Frame") (dcl_button_image1 "text_color" "Text") (dcl_button_image1 "background_color" "Background") "}" ":boxed_radio_row {label=\"Justification\";" " :radio_button {key=\"rb_left\";label=\"Left\";}" " :radio_button {key=\"rb_top\";label=\"Top\";}" " :radio_button {key=\"rb_center\";label=\"Center\";}" " :radio_button {key=\"rb_bottom\";label=\"Bottom\";}" " :radio_button {key=\"rb_right\";label=\"Right\";}" "}" "spacer;" ":boxed_column {" " :row {:edit_box {edit_width=3;label=\"Max Col\";key=\"eb_max_columns\";}" " :edit_box {edit_width=3;label=\"Max Row\";key=\"eb_max_rows\";}" " :edit_box {edit_width=3;label=\"Max Ratio\";key=\"eb_max_ratio\";}" " :edit_box {edit_width=3;label=\"Max Fill\";key=\"eb_max_fill\";}" " :edit_box {edit_width=3;label=\"Text size\";key=\"eb_text_size_factor\";}" " }" " spacer;spacer;" " :row {:toggle {label=\"Sort app-list on load\";key=\"tg_sort_on_load\";}" " :toggle {label=\"Follow Justification\";key=\"tg_follow_Justification\";}}" "}" "spacer;spacer;" ":column {:row {fixed_width=true;alignment=centered;" " :button{key=\"bt_app_list\";label=\"App list\";}" " :button{key=\"bt_preview\";label=\"Preview\";}" " :image_button {color=dialog_background;width=0.1;height=0.1;fixed_height=true;key=\"ib_debug_mode\";label=\"&d\";}" " ok_button;cancel_button;}}" "spacer;spacer;" "}" ) ) ) (if setup-dialog-fp (close setup-dialog-fp))(gc) ;(if (setq f (findfile setup-dialog-fn)) (startapp "notepad" f)(alert (strcat "huh? " (vl-princ-to-string f)))) ) (defun GrM_Setup_Dialog_Start ( / drv) (GrM_Setup_Dialog_Create) (if (and (setq setup-dialog-dcl (load_dialog setup-dialog-fn)) (new_dialog "GrM_Setup" setup-dialog-dcl)) (progn (GrM_Setup_Dialog_Update) (GrM_Setup_Dialog_Action) (setq drv (start_dialog)) (if setup-dialog-fn (vl-file-delete setup-dialog-fn)) (cond ((= drv 0)(Setup_Dialog_Cancel)) ((= drv 1)(WriteSettingsToRegistry)(GrM_Draw_Toolbar)) ((= drv 2)(WriteSettingsToRegistry)(Preview_Toolbar)) ) ) ) ) (defun Preview_Toolbar () (GrM_Draw_Toolbar) (princ "\rPress any key to return to dialog") (vl-catch-all-apply 'grread (list nil 8 0)) (redraw) (GrM_Setup_Dialog_Start) ) (defun cycle_Justification ( / co ol i) (setq co GrM-Toolbar-Justification ol '("left" "right" "top" "center" "bottom")) (if (setq i (vl-position co ol)) (progn (if (> i 3) (setq GrM-Toolbar-Justification (nth 0 ol)) (setq GrM-Toolbar-Justification (nth (1+ i) ol)) ) (GrM_Swappie)(WriteSettingsToRegistry)(GrM_Draw_Toolbar) ) ) ) (defun cycle_color ( / c cl i) ;;; grey1 (8), blue (144), green (72), red (12), pink (244), brown (24) (setq c GrM-Background-Color cl '("8" "144" "72" "12" "214" "24")) (if (setq i (vl-position c cl)) (progn (if (> i 4) (setq GrM-Background-Color (nth 0 cl)) (setq GrM-Background-Color (nth (1+ i) cl)) ) ) ;;; user can have selected color not in color list so start with list color numero uno (setq GrM-Background-Color (nth 0 cl)) ) (WriteSettingsToRegistry)(GrM_Draw_Toolbar) ) (defun GrM_Setup_Dialog_Update () (setq setup-dialog-tl '( (GrM-NoF-Rows "eb_nof_rows") (GrM-NoF-Columns "eb_nof_columns") (GrM-Button-Background-Fill "eb_fill") (GrM-Button-Width-Height-Ratio "eb_button_width_height_ratio") (GrM-Use-Fixed-Cell-Width "tg_use_fixed_width") (GrM-Use-Fixed-Cell-Height "tg_use_fixed_height") (GrM-Cell-Width "eb_fixed_width") (GrM-Cell-Height "eb_fixed_height") ;;; options (GrM-Max-Columns "eb_max_columns") (GrM-Max-Rows "eb_max_rows") (GrM-Max-Button-Width-Height-Ratio "eb_max_ratio") (GrM-Max-Button-Background-Fill "eb_max_fill") (GrM-Text-Size-Factor "eb_text_size_factor") (GrM-Follow-Justification "tg_follow_Justification") (GrM-Sort-On-Load "tg_sort_on_load") ;;; GrM-Max-Columns GrM-Max-Rows GrM-Follow-Justification GrM-Sort-On-Load GrM-Text-Size-Factor ) ) ;;; rd = reset data (val1 val2 ...) , in case of a cancel store original values before start of dialog (if (null setup-dialog-rd) (setq setup-dialog-rd (Save_Setup_Dialog_Data setup-dialog-tl))) ;;; set edit boxes and toggle values (Set_Setup_Dialog_Tiles setup-dialog-tl) ;;; update color images (Frame , Text & Background (GrM_Update_Color_Images) ;;; update radiobuttons (Justification top/left/bottom/right (GrM_Update_Radio_Buttons) ;;; Check & set debug mode (set_tile "tp_debug_mode" (if (and GrM-Debug-Mode (eq GrM-Debug-Mode "1")) " * debug mode *" "")) ) (defun GrM_Setup_Dialog_Action () (mapcar '(lambda (x)(action_tile (car x) (cadr x))) '(("cancel" "(done_dialog 0)") ("accept" "(done_dialog 1)") ("bt_preview" "(done_dialog 2)") ("ib_debug_mode" "(Toggle_Debug_Mode)") ("eb_nof_rows" "(setq GrM-NoF-Rows $value)") ;;; GrM_IncTile - just for testing ("bt_nof_rows_plus" "(GrM_IncTile $key 1)") ("bt_nof_rows_min" "(GrM_IncTile $key -1)") ("eb_nof_columns" "(setq GrM-NoF-Columns $value)") ("bt_nof_columns_plus" "(GrM_IncTile $key 1)") ("bt_nof_columns_min" "(GrM_IncTile $key -1)") ("eb_fill" "(setq GrM-Button-Background-Fill $value)") ("bt_fill_plus" "(GrM_IncTile $key 1)") ("bt_fill_min" "(GrM_IncTile $key -1)") ("eb_button_width_height_ratio" "(setq GrM-Button-Width-Height-Ratio $value)") ("bt_button_width_height_ratio_plus" "(GrM_IncTile $key 1)") ("bt_button_width_height_ratio_min" "(GrM_IncTile $key -1)") ;;; fixed width / height ("tg_use_fixed_width" "(setq GrM-Use-Fixed-Cell-Width $value)") ("tg_use_fixed_height" "(setq GrM-Use-Fixed-Cell-Height $value)") ("eb_fixed_width" "(setq GrM-Cell-Width $value)") ("eb_fixed_height" "(setq GrM-Cell-Height $value)") ;;; color handling ("bt_frame_color" "(get_frame_color)") ("bt_text_color" "(get_text_color)") ("bt_background_color" "(get_background_color)") ;;; options ("eb_max_columns" "(setq GrM-Max-Columns $value)") ("eb_max_rows" "(setq GrM-Max-Rows $value)") ("eb_text_size_factor" "(setq GrM-Text-Size-Factor $value)") ("tg_follow_Justification" "(setq GrM-Follow-Justification $value)") ("tg_sort_on_load" "(setq GrM-Sort-On-Load $value)") ;;; toolbar Justification / justification ("rb_left" "(GrM_Set_Justification $key)")("rb_right" "(GrM_Set_Justification $key)") ("rb_top" "(GrM_Set_Justification $key)")("rb_center" "(GrM_Set_Justification $key)") ("rb_bottom" "(GrM_Set_Justification $key)") ;;; ("bt_app_list" "(done_dialog 3)") (GrM_App_List_Dialog) ("bt_app_list" "(GrM_App_List_Dialog)") ) ) ) ;;; low tec but functional (defun Toggle_Debug_Mode () (cond ((eq GrM-Debug-Mode "1") (setq GrM-Debug-Mode "0")) ((eq GrM-Debug-Mode "0") (setq GrM-Debug-Mode "1")) (t (setq GrM-Debug-Mode "0"))) (set_tile "tp_debug_mode" (if (and GrM-Debug-Mode (eq GrM-Debug-Mode "1")) " * debug mode *" "")) ) (defun GrM_Update_Color_Images () (mapcar '(lambda (i c)(GrM_SetColorImage i c)) (list "im_frame_color" "im_text_color" "im_background_color") (list GrM-Frame-Color GrM-Text-Color GrM-Background-Color))) (defun GrM_Update_Radio_Buttons () (cond ((eq GrM-Toolbar-Justification "left")(set_tile "rb_left" "1")) ((eq GrM-Toolbar-Justification "right")(set_tile "rb_right" "1")) ((eq GrM-Toolbar-Justification "top")(set_tile "rb_top" "1")) ((eq GrM-Toolbar-Justification "bottom")(set_tile "rb_bottom" "1")) ((eq GrM-Toolbar-Justification "center")(set_tile "rb_center" "1")) ) ) ;;; when Justification changes from horizontal to vertical , swap nof columns & nof rows (defun GrM_Swappie ( / i1 i2) (setq i1 (atoi GrM-NoF-Columns) i2 (atoi GrM-NoF-Rows)) (cond ;;; horizontal ((member GrM-Toolbar-Justification '("top" "center" "bottom")) (setq GrM-NoF-Columns (itoa (max i1 i2)) GrM-NoF-Rows (itoa (min i1 i2)))) ;;; vertical ((member GrM-Toolbar-Justification '("left" "right" )) (setq GrM-NoF-Columns (itoa (min i1 i2)) GrM-NoF-Rows (itoa (max i1 i2)))) ) ) ;;; gonna assume that when Justification is left or right (vertical) , the number for rows is larger ;;; than the number for columns , this is handeld by setting GrM-Follow-Justification in dialog (defun GrM_Set_Justification (k) (setq GrM-Toolbar-Justification (substr k 4)) (if (eq GrM-Follow-Justification "1") (progn (GrM_Swappie)(set_tile "eb_nof_columns" GrM-NoF-Columns)(set_tile "eb_nof_rows" GrM-NoF-Rows)) ) ) ;;; for now fixed max number of rows / columns to 10 (i is not used anymore , uses tile name instead (defun GrM_IncTile ( tl i / v cmax rmax ratmax fmax) (if (isnum GrM-Max-Columns)(setq cmax (atoi GrM-Max-Columns))(setq cmax 12)) (if (isnum GrM-Max-Rows)(setq rmax (atoi GrM-Max-Rows))(setq rmax 12)) (if (isnum GrM-Max-Button-Width-Height-Ratio)(setq ratmax (atoi GrM-Max-Button-Width-Height-Ratio))(setq ratmax 3)) (if (isnum GrM-Max-Button-Background-Fill)(setq fmax (atoi GrM-Max-Button-Background-Fill))(setq fmax 100)) (cond ;;; columns ((eq tl "bt_nof_columns_plus") (setq GrM-NoF-Columns (itoa (1+ (atoi GrM-NoF-Columns)))) (if (> (atoi GrM-NoF-Columns) cmax) (setq GrM-NoF-Columns (itoa cmax))) (set_tile "eb_nof_columns" GrM-NoF-Columns)) ((eq tl "bt_nof_columns_min") (setq GrM-NoF-Columns (itoa (1- (atoi GrM-NoF-Columns)))) (if (< (atoi GrM-NoF-Columns) 1) (setq GrM-NoF-Columns "1")) (set_tile "eb_nof_columns" GrM-NoF-Columns)) ;;; rows ((eq tl "bt_nof_rows_plus") (setq GrM-NoF-Rows (itoa (1+ (atoi GrM-NoF-Rows)))) (if (> (atoi GrM-NoF-Rows) rmax) (setq GrM-NoF-Rows (itoa rmax))) (set_tile "eb_nof_rows" GrM-NoF-Rows)) ((eq tl "bt_nof_rows_min") (setq GrM-NoF-Rows (itoa (1- (atoi GrM-NoF-Rows)))) (if (< (atoi GrM-NoF-Rows) 1) (setq GrM-NoF-Rows "1")) (set_tile "eb_nof_rows" GrM-NoF-Rows)) ;;; width / height ratio ((eq tl "bt_button_width_height_ratio_plus") (setq GrM-Button-Width-Height-Ratio (itoa (1+ (atoi GrM-Button-Width-Height-Ratio)))) (if (> (atoi GrM-Button-Width-Height-Ratio) ratmax) (setq GrM-Button-Width-Height-Ratio (itoa ratmax))) (set_tile "eb_button_width_height_ratio" GrM-Button-Width-Height-Ratio)) ((eq tl "bt_button_width_height_ratio_min") (setq GrM-Button-Width-Height-Ratio (itoa (1- (atoi GrM-Button-Width-Height-Ratio)))) (if (< (atoi GrM-Button-Width-Height-Ratio) 1) (setq GrM-Button-Width-Height-Ratio "1")) (set_tile "eb_button_width_height_ratio" GrM-Button-Width-Height-Ratio)) ;;; button background fill ((eq tl "bt_fill_plus") (setq GrM-Button-Background-Fill (itoa (+ (atoi GrM-Button-Background-Fill) 10))) (if (> (atoi GrM-Button-Background-Fill) fmax) (setq GrM-Button-Background-Fill (itoa fmax))) (set_tile "eb_fill" GrM-Button-Background-Fill)) ((eq tl "bt_fill_min") (setq GrM-Button-Background-Fill (itoa (- (atoi GrM-Button-Background-Fill) 10))) (if (< (atoi GrM-Button-Background-Fill) 10) (setq GrM-Button-Background-Fill "10")) (set_tile "eb_fill" GrM-Button-Background-Fill)) ;;; overkill...really (t (alert (strcat "\nUnknown IncTile : " (vl-princ-to-string tl) " / " (vl-princ-to-string i)))) ) ) ;;; --- color handling -------------------------------------- color handling --------------------------------------- color handling --- ;;; (defun getcolor (d) (if (or (void d) (not (isnum d)))(setq d 7)) (acad_colordlg d nil)) ;;; check color , byblock/bylayer or nil are converted to color 7 (white) (defun checkcolor (c) (if (string-p c)(setq c (strcase c t))) (cond ((member c '(0 256 "0" "256" "byblock" "bylayer")) 7) ((numberp c) c) ((string-p c)(atoi c)) (t 7))) (defun GrM_SetColorImage (tilename color / col x y ) (if (isnum color) (cond ((= (type color) 'STR) (setq col (atoi color)))((= (type color) 'INT)(setq col color))(t (setq col 7)))) (if (and (string-p color) (member (strcase color T) '("bylayer" "byblock"))) (setq col 7)) (if col (progn (setq x (dimx_tile tilename) y (dimy_tile tilename)) (start_image tilename) (fill_image 0 0 x y col) (end_image))) ) (defun get_frame_color ( / c d ) (if (setq c (acad_colordlg (atoi GrM-Frame-Color) nil)) (progn (GrM_SetColorImage "im_frame_color" c)(setq GrM-Frame-Color (itoa c))))) (defun get_text_color ( / c d ) (if (setq c (acad_colordlg (atoi GrM-text-Color) nil)) (progn (GrM_SetColorImage "im_text_color" c)(setq GrM-text-Color (itoa c))))) (defun get_background_color ( / c d ) (if (setq c (acad_colordlg (atoi GrM-background-Color) nil)) (progn (GrM_SetColorImage "im_background_color" c)(setq GrM-background-Color (itoa c))))) ;;; --- dialog section ------------------------------------ end dialog section ------------------------------------- dialog section --- ;;; ;;; (re) calculate display parameters (dim_screen) ;;; screensize = (1840.0 685.0) (PC dependent / zoom independent) ;;; viewsize = height of current screen , varies with zoom ;;; viewctr = screen center point , varies with zoom ;;; recalculate after each zoom : dx dy / vx- vy- vx+ vy+ / vc vs ss dx dy vx- vy- vx+ vy+ vh vw) (defun dim_screen ( / dx dy) (setq vc (getvar "VIEWCTR") vs (getvar "VIEWSIZE") ss (getvar "SCREENSIZE")) ;;; view (half) width & view (half) height (assist for cornerpoints calculation) (setq dx (* vs (/ (car ss) (cadr ss)) 0.5) dy (* vs 0.5)) ;;; view corner points (setq vx- (- (car vc) dx) vy- (- (cadr vc) dy) vx+ (+ (car vc) dx) vy+ (+ (cadr vc) dy)) ;;; view height en view width (setq vh (- vy+ vy-) vw (- vx+ vx-)) ;;; inspect / debug ;(inspect (list 'vx- 'vy- 'vx+ 'vy+ 'vh 'vw 'vc)) ) ;;; cell width / height depends on viewsize / #rows / #colomns / Justification ;;; if Justification = horizontal then justification can be top / center / bottom ;;; if Justification = vertical then justification can be left / right ;;; - calculate cell width / cell height ;;; if Justification = horizontal : cell width = screen width / #cols , cell height = cell width / 2 ;;; if Justification = vertical ; cell height = screen height / #rows , cell width = cell height * 2 ;;; - calculate corner points , then start from center point ;;; replaces dim_cell with GrM_Draw_Toolbar which uses data from dialog / registry variables (defun GrM_Draw_Toolbar ( / tb-hw tb-hh) ;;; have no idea why sometimes GrM_Init is skipped , dirty fix (chk_reg_vars) ;;; get view data (dim_screen) ;;; first thing I need is cell height & cell width (if (member GrM-Toolbar-Justification '("top" "center" "bottom")) ;;; horizontal (progn (cond ;;; if use fixed cell width = true ;;; (X-to-N = anything to number , allow zero = 0 , fix numer = 0) ((= GrM-Use-Fixed-Cell-Width "1") (if (not (void GrM-Cell-Width)) (setq cell-width (X-to-N GrM-Cell-Width 0 0))(setq cell-width default-button-width))) ;;; divide screen-width by number of columns ((and (= GrM-Use-Fixed-Cell-Width "0") (setq i (X-to-N GrM-NoF-Columns 0 0))) (setq cell-width (/ vw i))) (t (setq cell-width (/ vw 10.0))) ) (cond ((eq GrM-Auto-Cell-Size-Ratio "1") (setq cell-Height (* cell-width 0.5))) ;;; if use fixed cell height = true ((= GrM-Use-Fixed-Cell-Height "1") (if (not (void GrM-Cell-Height)) (setq cell-height (X-to-N GrM-Cell-Height 0 0))(setq cell-height default-button-height))) (t (setq cell-height (* cell-width 0.5))) ) (setq tb-height (* cell-height (atoi GrM-NoF-Rows))) (cond ((eq GrM-Toolbar-Justification "top") (setq tb-x- vx- tb-y- (- vy+ tb-height) tb-x+ vx+ tb-y+ vy+)) ;;; tb-hw = toolbar half width , tb-hh = toolbar half height ((eq GrM-Toolbar-Justification "center") (setq tb-hw (* (atoi GrM-NoF-Columns) cell-width 0.5) tb-hh (* (atoi GrM-NoF-Rows) cell-height 0.5)) (setq tb-x- (- (car vc) tb-hw) tb-x+ (+ (car vc) tb-hw)) (setq tb-y- (- (cadr vc) tb-hh) tb-y+ (+ (cadr vc) tb-hh)) ) ((eq GrM-Toolbar-Justification "bottom") (setq tb-x- vx- tb-y- vy- tb-x+ vx+ tb-y+ (+ tb-y- tb-height))) ) ) ;;; "vertical" (progn ;;; calculate cell-height first (cond ;;;height is width / 2 ((and (eq GrM-Auto-Cell-Size-Ratio "1") (setq i (X-to-N GrM-NoF-Rows 0 0))) (setq cell-height (/ vh i))) ;;; if use fixed cell height = true (1 "1" T) check height (zero not allowed, dont fix result ((and (= GrM-Use-Fixed-Cell-Height "1") (setq i (X-to-N GrM-Cell-Height 0 0))) (setq cell-Height i)) ;;; divide screen-height by number of rows (zero not allowed , intergers only (fix result) ((and (= GrM-Use-Fixed-Cell-Height "0") (setq i (X-to-N GrM-NoF-Rows 0 0))) (setq cell-height (/ vh i))) ;;; set default for column of 10 rows (t (setq cell-height (/ vh 10.0))) ) ;;; calclate cell-width (cond ((eq GrM-Auto-Cell-Size-Ratio "1") (setq cell-width (* cell-height 2.0))) ;;; if use fixed cell width = true (1 "1" T) check width (zero not allowed, dont fix result ((and (= GrM-Use-Fixed-Cell-Width "1") (setq i (X-to-N GrM-Cell-Width 0 0))) (setq cell-width i)) (t (setq cell-width (* cell-height 2.0))) ) ;;; find toolbar alignment point ;;; for vertical these are left / center / right ;;; calculate width of toolbar for number of columns (setq tb-width (* cell-width (atoi GrM-NoF-Columns))) (cond ((eq GrM-Toolbar-Justification "left") (setq tb-x- vx- tb-y- vy- tb-x+ (+ tb-x- tb-width) tb-y+ vy+)) ((eq GrM-Toolbar-Justification "center") (setq tb-x- (- (car vc) (* tb-width 0.5)) tb-x+ (+ (car vc) (* tb-width 0.5)) tb-y- vy- tb-y+ vy+)) ((eq GrM-Toolbar-Justification "right") (setq tb-x- (- vx+ tb-width) tb-x+ vx+ tb-y- vy- tb-y+ vy+)) ) ) ) (if (eq GrM-Debug-Mode "1") (inspect (list 'vh 'vw 'GrM-Toolbar-Justification 'GrM-NoF-Columns 'GrM-NoF-Rows 'GrM-Use-Fixed-Cell-Height 'GrM-Cell-Height 'cell-Height 'GrM-Use-Fixed-Cell-Width 'GrM-Cell-Width 'cell-width 'GrM-Frame-Color 'GrM-Text-Color 'GrM-Background-Color ) ) ) (setq cell-text-height (/ cell-height 2.0)) ;(setq tst-cell-height cell-height tst-cell-width cell-width) ;;; some more testing (x- y- x+ y+ r c co / xl yl) (Draw_Frame tb-x- tb-y- tb-x+ tb-y+ (atoi GrM-NoF-Rows) (atoi GrM-NoF-Columns) 2) ) ;;; x-=xmin, x+=ymax etc, r=rows, c=columns, co=color ;;; (setq e- (getvar "EXTMIN") e+ (getvar "EXTMAX")) ;;; (Draw_Frame (car e-)(cadr e-)(car e+)(cadr e+) 5 5 1) (defun Draw_Frame (x- y- x+ y+ r c co / xl yl pl text-size bcol fcol tcol justy ) (record "Draw_Frame") (if (and (not (void GrM-background-Color))(isnum GrM-background-Color)) (setq bcol (atoi GrM-background-Color))(setq col 142)) (if (and (not (void GrM-Frame-Color))(isnum GrM-Frame-Color)) (setq fcol (atoi GrM-Frame-Color))(setq fcol 7)) (if (and (not (void GrM-Text-Color))(isnum GrM-Text-Color)) (setq tcol (atoi GrM-Text-Color))(setq tcol 7)) (redraw)(Fill_Toolbar_Background x- y- x+ y+ bcol) ;;; create x & y list for all grid coordinates (setq xl (gnl+ x- (1+ c) (/ (abs (- x+ x-)) c)) yl (gnl- y+ (1+ r) (/ (abs (- y+ y-)) r))) ;;; draw all horizontal lines (foreach y yl (grdraw (list x- y) (list x+ y) fcol)) ;;; draw all vertical lines (foreach x xl (grdraw (list x y+) (list x y-) fcol)) ;;; draw the texts (setq pl (gmpl xl yl)) ;;; cell-text-height is cell-height / 2 (if (and (not (void GrM-Text-Size-Factor))(isnum GrM-Text-Size-Factor)) (setq text-size (/ cell-text-height (atoi GrM-Text-Size-Factor))) (setq text-size (/ cell-text-height 9)) ) ;;; bad idea : grtxt routine has its limitations so I'll adjust text justification along with toolbar Justification ;;; all text insertion points are calculated based on middle algnment so lets keep it that way for now ;(cond ((eq GrM-Toolbar-Justification "left")(setq justy "L"))((eq GrM-Toolbar-Justification "right")(setq justy "R"))(t (setq justy "M"))) (setq justy "M") (mapcar '(lambda (p s) (grtxt (strcase s) p tcol 0 justy text-size)) pl (if (vl-consp app-list) (mapcar 'vl-filename-base app-list) '("Empty"))) (princ) ) ;;; fill toolbar background ;;; next y depends on zoom factor (viewsize) , 0.1 is emperical, bigger means bigger linespacing (defun Fill_Toolbar_Background (x- y- x+ y+ c / i vws) (setq i y- vws (getvar "viewsize")) (while (<= i y+)(grdraw (list x- i)(list x+ i) c)(setq i (+ i (* 0.1 (/ vws start-viewsize)))))) ;;; makes use of dialog variable (atoi GrM-Button-Background-Fill) 10-100 in steps of 10 (defun Fill_Toolbar_Background (x- y- x+ y+ c / i vws bgf-fac) (setq i y- vws (getvar "viewsize") bgf-fac (/ 0.1 (/ (atof GrM-Button-Background-Fill) 100.0))) (while (<= i y+)(grdraw (list x- i)(list x+ i) c)(setq i (+ i (* bgf-fac (/ vws start-viewsize)))))) ;;; (setq cel-id (GrM_GetCellNumber x y)) (defun GrM_GetCellNumber (x y / id ) ;;; cell number from dialog , without accouting for page number ;(setq id (+ (* (atoi GrM-NoF-Columns) (fix (/ y cell-height))) (fix (1+ (/ x cell-width))))) (if (eq tst-Justification "horizontal") (setq id (+ (* (atoi tst-NoF-Columns) (fix (/ y tst-cell-height))) (fix (1+ (/ x tst-cell-width))))) (setq id (+ (* (atoi tst-NoF-Rows) (fix (/ y tst-cell-height))) (fix (1+ (/ x tst-cell-width))))) ) ) ;;; (GrM_GetCell-ID (list 100.0 100.0) (list 130.0 70.0) 3 3 (list 122.0 79.0)) ;;; get cell-id from point selection to use as nth for app-list (defun GrM_GetCell-ID (ul lr c r p / dy dy x y)(setq x (car p) y (cadr p)) (setq dx (/ (abs (- (car lr) (car ul))) c) dy (/ (abs (- (cadr ul) (cadr lr))) r)) (+ (/ (fix (abs (- x (car ul))))(fix dx))(* (1- (- r (/ (fix (abs (- y (cadr lr))))(fix dy)))) c)) ) ;;; (show_grid) (defun show_grid ( / x dx y dy i) (setq x (fix screen-width) y (fix screen-height)) (setq dy (/ y (atoi GrM-NoF-Rows)) dx (/ x (atoi GrM-NoF-Columns))) (setq i 0)(while (< i x)(grdraw (list i 0) (list i y) 3)(setq i (fix (+ i dx)))) (setq i 0)(while (< i y)(grdraw (list 0 i) (list x i) 3)(setq i (fix (+ i dy))))) ;;; (setq corner (GrM_GetCellCorner 5)) (defun GrM_GetCellCorner ( cell / col row) (if (= (rem cell (atoi GrM-NoF-Columns)) 0) (setq col (atoi GrM-NoF-Columns) row (1- (/ cell (atoi GrM-NoF-Columns)))) (setq col (rem cell (atoi GrM-NoF-Columns)) row (/ cell (atoi GrM-NoF-Columns)))) (list (* cell-width (1- col)) (* cell-height row))) ;;; (Dim_Box (list 400 75) cell-width cell-height) ;;; arg top left point , width , height , return list cornerpoints (defun Dim_Box (p w h) (list p (polar p 0 w) (polar p (atan h w) (sqrt (+ (expt w 2)(expt h 2)))) (polar p (/ pi 2) h))) ;;; --- GrTxt ---------------------------------------------------- GrTxt ---------------------------------------------------- GrTxt --- ;;; ;;; found this old lisp (grtxt.lsp) , don't know author but all credits are for this human from earth ;;; text string / coordinate point / color / angle / justification/ z for text height ;;; *** UPPER CASE ONLY *** (grtxt (STRCASE "Rob") (getvar "viewctr") 1 0 "M") ;;; 2025-07-29 added z for text height as parameter (defun grtxt (ts cp cl a j z / vp ltb i xp c p1 p2 lp ld n al) ;;; vertex points (setq vp '(( 1 ( 0.50 0.25))( 2 ( 0.50 0.55))( 3 ( 0.50 0.85))( 4 ( 0.50 1.00))( 5 ( 0.25 1.00)) ( 6 ( 0.00 1.00))( 7 (-0.25 1.00))( 8 (-0.50 1.00))( 9 (-0.50 0.85))(10 (-0.50 0.55)) (11 (-0.50 0.25))(12 (-0.50 0.10))(13 (-0.25 0.10))(14 ( 0.00 0.10))(15 ( 0.25 0.10)) (16 ( 0.50 0.10))(17 ( 0.50 -0.05))(18 ( 0.50 -0.45))(19 ( 0.50 -0.85))(20 ( 0.50 -1.00)) (21 ( 0.25 -1.00))(22 ( 0.00 -1.00))(23 (-0.25 -1.00))(24 (-0.50 -1.00))(25 (-0.50 -0.85)) (26 (-0.50 -0.40))(27 (-0.50 -0.05))(30 ( 0.35 0.85))(31 (-0.35 0.85))(32 (-0.35 -0.85)) (33 ( 0.35 -0.85))(40 ( 0.25 0.35))(41 (-0.25 0.35))(42 ( 0.25 -0.15))(43 (-0.25 -0.15)) (44 ( 0.00 0.45))(45 ( 0.00 -0.25))(50 ( 0.30 0.20))(51 ( 0.30 0.35))(52 ( 0.20 0.35)) (53 ( 0.20 0.20))(54 ( 0.30 0.10))(55 ( 0.30 -0.10))(56 ( 0.20 -0.10))(57 ( 0.20 0.10)) (60 (-0.30 0.20))(61 (-0.30 0.35))(62 (-0.20 0.35))(63 (-0.20 0.20))(64 (-0.30 0.10)) (65 (-0.30 -0.10))(66 (-0.20 -0.10))(67 (-0.20 0.10)))) ;;; letter table (setq ltb '(("A" 24 9 7 5 3 20 16 12) ("B" 12 15 1 3 5 8 24 21 19 17 15) ("C" 3 5 7 9 25 23 21 19) ("D" 3 5 8 24 21 19 3) ("E" 4 8 12 15 12 24 20) ("F" 4 8 12 15 12 24) ("G" 3 5 7 9 25 23 21 19 16 14) ("H" 20 -4 8 -24 16 12) ("I" 7 5 6 22 23 21) ("J" 4 19 21 23 25) ("K" 8 24 12 13 4 13 20) ("L" 8 24 20) ("M" 24 8 14 4 20) ("N" 24 8 20 4) ("O" 3 5 7 9 25 23 21 19 3) ("P" 12 15 1 3 5 8 24) ("Q" 3 5 7 9 25 23 21 19 3 -19 20 45) ("R" 20 14 12 15 1 3 5 8 24) ("S" 3 5 7 9 11 13 15 17 19 21 23 25) ("T" 4 8 6 22) ("U" 8 25 23 21 19 4 20) ("V" 8 22 4) ("W" 8 23 14 21 4) ("X" 4 -24 8 20) ("Y" 8 14 22 14 4) ("Z" 8 4 24 20) ("0" 3 5 7 9 25 23 21 19 -3 4 24) ("1" 31 7 6 22 21 23) ("2" 9 7 5 3 1 15 13 27 24 20) ("3" 9 7 5 3 1 15 13 15 17 19 21 23 25) ("4" 8 12 16 15 5 21) ("5" 4 8 12 15 17 19 21 23 25) ("6" 3 5 7 9 25 23 21 19 17 15 12) ("7" 8 4 22) ("8" 3 5 7 9 11 13 27 25 23 21 19 17 15 13 15 1 3) ("9" 25 23 21 19 3 5 7 9 11 13 16) ("<" 4 12 20) (">" 8 16 24) ("," 33 21) ("." 19 20 21 33 19) ("\'" 4 30) ("\"" 4 -30 7 31) (";" 50 51 52 53 -50 54 55 56 57 55 45) (":" 50 51 52 53 -50 54 55 56 57 55) ("\\" 8 20) ("/" 4 24) ("?" 11 10 7 5 2 1 45 22) ("|" 6 -44 45 22) ("+" 44 -45 13 15) ("=" 40 -41 43 42) ("-" 13 15) ("_" 20 24) (")" 6 2 18 22) ("(" 6 10 26 22) ("*" 40 -43 41 -42 45 44) ("&" 21 31 7 6 26 25 23 16) ("^" 10 6 2) ("%" 57 54 55 56 -57 63 60 61 62 -63 5 24) ("$" 3 5 7 9 11 13 15 17 19 21 23 25 -26 22 6) ("#" 24 -6 22 -4 1 -11 17 27) ("@" 42 15 40 44 41 13 43 45 42 17 3 5 7 9 25 23 21 19) ("!" 6 -45 22 22) ("~" 9 31 44 40 2) ("`" 8 31) ("[" 6 8 24 22) ("]" 6 4 20 22) ("{" 6 7 41 12 43 23 22) ("}" 6 5 40 16 42 21 22) (""))) ;;; text height - use z as parameter ;;;(setq z (/ (getvar "VIEWSIZE") (cadr (getvar "SCREENSIZE")) 0.1)) ;;;(setq z (/ (getvar "VIEWSIZE") 10)) (cond ;;; left justification ((eq (strcase (substr j 1 1)) "L") (setq xp (list (+ (car cp) z) (cadr cp)) i 1)) ;;; middle justification ((eq (strcase (substr j 1 1)) "M") (setq xp (list (- (car cp) (* z (strlen ts) 0.5)) (cadr cp)) i 1)) ;;; right justification ((eq (strcase (substr j 1 1)) "R") (setq xp (list (- (car cp) (* z (strlen ts) 1.5)) (cadr cp)) i 1)) ) (repeat (strlen ts) ;;; each charachter / line point list / letter point def (setq c (substr ts i 1) lp '() ld (cdr (assoc c ltb))) (while (> (length ld) 1) (setq p1 (cadr (assoc (abs (nth 0 ld)) vp)) p2 (cadr (assoc (abs (nth 1 ld)) vp)) p1 (mapcar '* (list z z) p1) p2 (mapcar '* (list z z) p2) p1 (mapcar '+ xp p1) p2 (mapcar '+ xp p2) lp (append lp (list (if (minusp (nth 0 ld)) 0 cl) p1 p2)) ld (cdr ld)) ) ;;; add rotation angle (setq n 0 al nil) (repeat (/ (length lp) 3) (setq al (cons (nth n lp) al) al (cons (polar cp (+ a (angle cp (nth (+ n 1) lp))) (distance cp (nth (+ n 1) lp))) al) al (cons (polar cp (+ a (angle cp (nth (+ n 2) lp))) (distance cp (nth (+ n 2) lp))) al)) (setq n (+ n 3)) ) (and al (grvecs (reverse al))) (setq xp (list (+ (car xp) (* z 1.5)) (cadr xp)) i (1+ i)) ) (prin1) ) ;;; --- GrTxt ---------------------------------------------------- GrTxt ---------------------------------------------------- GrTxt --- ;;; ;;; --- App list dialog ------------------------------------- App list dialog ------------------------------------- App list dialog --- ;;; ;;; Simple File Dialog ;;; f = dialog file name , p = pointer , d = dialog , app-list = list , i = input , idx = listbox index (defun GrM_App_List_Dialog ( / f p d app-list i idx regkey regvar Filli-Dat-File return-to-setup-dialog) (setq idx 0) ;;; (InitDefaultRegistrySettings)(ReadSettingsFromRegistry) ;;; first use (if (or (null GrM-App-List-File)(not (eq (type GrM-App-List-File) 'STR))) (progn (setq GrM-App-List-File (vl-filename-mktemp "app-list.dat") p (open GrM-App-List-File "w")) (close p)(gc) ) ) ;;; read data file (if (and (findfile GrM-App-List-File)(setq p (open GrM-App-List-File "r"))) (progn (while (setq i (read-line p))(setq app-list (cons i app-list)))(close p))) ;;; check data list (if (vl-consp app-list)(setq app-list (acad_strlsort app-list)) (setq app-list (list "Empty"))) ;;; create dialog (if (and (setq f (vl-filename-mktemp "filli.dcl") p (open f "w"))) (mapcar '(lambda (x)(write-line x p)) (list (strcat "app_list : dialog {label=\"App list dialog (Rlx " (now) ")\";") "spacer;:text_part {key=\"tp\";}spacer;" ":boxed_row {label=\"File list\";:column {:list_box {key=\"lb\";width=64;}}spacer;" ":column {:button {key=\"add\";label=\"Add\";}:button {key=\"del\";label=\"Del\";}" ":button {key=\"up\";label=\"Up\";}:button {key=\"down\";label=\"Down\";}:button {key=\"sort\";label=\"Sort\";}}}" ":text_part {key=\"tp_file_info\";}" "spacer; :column {:row {fixed_width=true;alignment=centered;:button{key=\"load\";label=\"Load\";}" ":button{key=\"save\";label=\"Save\";}:button{key=\"saveas\";label=\"Saveas\";}" ":button{key=\"edit\";label=\"Edit\";} ok_button;cancel_button;}}spacer;spacer;}" ) ) (princ "\nComputer says no : unable to create dialog") ) ;;; clean desk policy (if p (progn (close p)(gc))) ;;; start dialog (if (and (setq d (load_dialog f)) (new_dialog "app_list" d)) (progn ;;; fill list box (setq idx 0)(lb_upd) ;;; activate buttons (action_tile "cancel" "(done_dialog 0)")(action_tile "accept" "(done_dialog 1)") (action_tile "lb" "(setq idx (atoi $value))(lb_upd_info)") (mapcar '(lambda (x)(action_tile x "(action_key $key)")) '("add" "del" "up" "down" "sort" "load" "save" "saveas" "edit")) (setq drv (start_dialog)) (if (and f (setq f (findfile f))) (vl-file-delete f)) (cond ((= drv 0)) ((= drv 1)(WriteSettingsToRegistry)) ) ) ) ) ;;; just to have a little less code in main loop (defun action_key (k) (cond ((= k "add")(_add))((= k "del")(_del))((= k "up")(lb_mod "up"))((= k "down")(lb_mod "down")) ((= k "sort")(lb_sort))((= k "load")(_load))((= k "save")(_save))((= k "saveas")(_saveas)) ((= k "edit")(_edit_dat_file)) ) ) ;;; lb_upd = update list box (init / redraw / refresh) (defun lb_upd () (set_tile "tp" (strcat " Data file : " (vl-princ-to-string GrM-App-List-File))) (start_list "lb")(mapcar 'add_list (mapcar 'vl-filename-base app-list))(end_list) (set_tile "lb" (itoa idx)) (lb_upd_info) ) ;;; update the text part below listbox to show complete path & filename (defun lb_upd_info () (if (vl-consp app-list) (set_tile "tp_file_info" (strcat " File : " (vl-princ-to-string (nth idx app-list)))) (set_tile "tp_file_info" " File : - ") ) ) ;;; lb_sort = sort list box (defun lb_sort () (setq app-list (acad_strlsort app-list)) (start_list "lb")(mapcar 'add_list app-list)(end_list)(set_tile "lb" (itoa idx))) ;;; lb_mod = modify list box ;;; m = mode up or down ("u" or "d") , app-list = app list (global) , xl = temp list (local) ;;; idx = index (global) , i = index (local) , i1 / i2 = scrap lists (local) (defun lb_mod (m / i xl i1 i2) (setq i idx xl (vl-remove-if '(lambda (x)(= x "")) app-list)) (cond ((void i))((or (null xl)(< (length xl) 2)))((and (= i 0) (= m "up")))((and (>= i (1- (length xl)))(= m "down"))) (t (setq i1 (nth i xl)) (if (= m "up") (setq i (1- i) i2 (nth i xl)) (setq i (1+ i) i2 (nth i xl) )) (setq xl (subst "i1" i1 xl) xl (subst "i2" i2 xl) xl (subst i2 "i1" xl) xl (subst i1 "i2" xl) idx i))) (cond ((< idx 0)(setq idx 0)) ((>= idx (length xl))(setq idx (1- (length xl))))) (setq app-list xl) (lb_upd) ) ;;; --- Tiny lisp section --------------------------------- Tiny lisp section ----------------------------------- Tiny lisp section --- ;;; (defun void (x) (or (eq x nil)(and (listp x)(not (vl-consp x)))(and (eq 'STR (type x))(eq "" (vl-string-trim " \t\r\n" x))))) (defun isnum (n)(if (or (numberp n) (and (= (type n) 'STR) (distof n))) t nil)) (defun string-p (s) (if (= (type s) 'str) t nil)) (defun uc (s) (alert (strcat "Under construction : " s))) (defun now ( / s l ) (setq s (rtos (getvar "CDATE")) l '("Jan""Feb""Mar""Apr""May""Jun""Jul""Aug""Sep""Oct""Nov""Dec")) (strcat (substr s 7 2) "-" (nth (1- (atoi (substr s 5 2))) l) "-'" (substr s 3 2))) ;;; remove from list (defun rfl (e app-list) (apply 'append (subst nil (list e) (mapcar 'list app-list)))) ;;; anything to number : n = number in any format (INT/REAL/STR) , z = allow 0 (zero) , f = fix result ;;; (X-to-N "0.0" 0 0) = nil , (X-to-N "0.0" 1 0) = 0.0 , (X-to-N "0.0" 1 1) = 0 , (X-to-N "rlx" 1 1) = nil (defun X-to-N (n z f / r ) (cond ((eq (type n) 'INT )(setq r n))((eq (type n) 'REAL)(setq r n))((distof n)(setq r (distof n)))(t (setq r nil))) (cond ((not r))((and (zerop r) (member z '(0 "0" nil)))(setq r nil)))(cond ((not r) nil)((member f '(1 "1" T))(fix r))(t (float r)))) ;;; for debugging , sort of trace list (defun record (s)(setq rec-list (cons s rec-list))) ;;; (setq rec-list nil) ;;; (setq a 1 b nil) (inspect (list 'a 'b)) (defun inspect (lst / _f) (defun _f (l) (apply 'strcat (cdr (apply 'append (mapcar (function (lambda (x) (list "\n" x))) l))))) (alert (_f (mapcar '(lambda (x) (strcat (vl-symbol-name x) " = " (vl-princ-to-string (vl-symbol-value x)))) lst)))) ;; tiny lisps ;;; generate number (gnum 1 5) -> '(1 2 3 4 5) (defun gnum (s e / i l) (and (numberp s)(numberp e)(setq i s)(while (<= i e)(setq l (cons i l) i (1+ i)))) (reverse l)) ;;; i = startnumber n = number of numbers , d = difference (gnl- 100 6 12) -> (100 88 76 64 52 40) ;;; generate all x-coordinates between xmin=322.5 & xmax =347.5 , 5 columns ;;; (gnl- xmax col+1 (- xmax xmin)) ;;; (gnl- 347.5 (1+ 5) (/ (- 347.5 322.5) 5)) -> (347.5 342.5 337.5 332.5 327.5 322.5) (defun gnl- (i n d / l)(setq l (list i))(repeat (1- n)(setq l (cons (setq i (- i d)) l)))(reverse l)) ;;; same but incremental ;;; (gnl- xmin (1+ col) (- xmax xmin)) (gnl- -10 6 (- -10 10)) ;;; (gnl+ 322.5 (1+ 5) (/ (- 347.5 322.5) 5)) -> (322.5 327.5 332.5 337.5 342.5 347.5) (defun gnl+ (i n d / l)(setq l (list i))(repeat (1- n)(setq l (cons (setq i (+ i d)) l)))(reverse l)) ;;; generate midpoint list ;;; (gmpl '(10 20 30 40 ) '(100 90 80)) -> '((15 95) (25 95) (35 95) (15 85) (25 85) (35 85)) (defun gmpl (xl yl / f x y) (defun f (l)(mapcar '(lambda (a b) (+ a (/ (- b a) 2.0))) l (cdr l))) (setq x (f '(10 20 30 40))) ;;; -> '(15.0 25.0 35.0) (setq y (f '(100 90 80))) ;;; -> '(95.0 85.0) (mapcar '(lambda (yy) (mapcar '(lambda (xx)(cons xx yy)) (f '(10 20 30 40)))) (f '(100 90 80))) ;;; -> (((15.0 . 95.0) (25.0 . 95.0) (35.0 . 95.0)) ((15.0 . 85.0) (25.0 . 85.0) (35.0 . 85.0))) ) ;;; (gmpl '(10 20 30 40 ) '(100 90 80)) (defun gmpl (xl yl / f) (defun f (l)(mapcar '(lambda (a b)(+ a (/ (- (float b) (float a)) 2.0))) l (cdr l))) (apply 'append (mapcar '(lambda (y)(mapcar '(lambda (x)(list x y 0.0))(f xl)))(f yl)))) ;;; rlx_sf - sub folders : c:/temp/test -> ("c:" "temp" "test") (defun rlx_sf ( fol / i) (if (setq i (vl-string-search "\\" fol)) (cons (substr fol 1 i) (rlx_sf (substr fol (+ i 1 (strlen "\\"))))) (list fol))) ;;; rlx_mf - make folder (defun rlx_mf ( fol / sf) (defun MF (rt sf) (if sf ((lambda (fol)(vl-mkdir fol)(MF fol (cdr sf)))(strcat rt "\\" (car sf))))) (if (setq sf (rlx_sf (vl-string-translate "/" "\\" fol))) (MF (car sf) (cdr sf))) (vl-file-directory-p fol)) ;;; --- Tiny lisp section --------------------------------- Tiny lisp section ----------------------------------- Tiny lisp section --- ;;; ;;; --- File operations ------------------------------------ File operations -------------------------------------- File operations --- ;;; ;;; load / save (data) file ;;; app-list = global list for list box , app-list is global name for data file (defun _load ( / fn fp i lst def) (if (or (void GrM-App-List-File) (not (setq def (car (fnsplitl GrM-App-List-File)))) (not (vl-file-directory-p def)))(setq def "")) (if (and (setq fn (getfiled "Select a data file" def "dat" 0))(setq fp (open fn "r"))) (while (setq i (read-line fp))(setq lst (cons i lst)))) (if fp (close fp)) (if (vl-consp lst) (progn (if (and (> (length lst) 1)(member "Empty" lst)) (setq lst (vl-remove "Empty" lst))) (setq GrM-App-List-File fn) (if (eq GrM-Sort-On-Load "1") (setq app-list (acad_strlsort lst)) (setq app-list (reverse lst)) ) (lb_upd) (WriteSettingsToRegistry) ) ) ) ;;; (create_default_data_file "c:\\temp\\rlx\\rlx\\xxx.xxx") (defun create_default_data_file ( fn / split) (cond ((or (null fn) (not (eq (type fn) 'STR)) (eq fn "")) (alert (strcat "unable to create file : " (vl-princ-to-string fn)))) ((findfile fn)) (t (setq split (fnsplitl fn)) (if (not (vl-file-directory-p (car split))) (rlx_mf (car split))) (if (setq fp (open fn "w")) (progn (close fp)(gc)) (alert (strcat "unable to create file : " (vl-princ-to-string fn))) ) ) ) ) (defun GrM_Preload_App_List ( / fn fp lst) (if (and (not (void (setq fn GrM-App-List-File)))(findfile fn)(setq fp (open fn "r"))) (while (setq i (read-line fp))(setq lst (cons i lst)))) (if fp (close fp)) ;(if (vl-consp lst)(setq app-list lst)(setq app-list '("Empty"))) (if (vl-consp lst)(setq app-list (reverse lst))(setq app-list '("Empty"))) ) (defun _save ( / fn fp def ) (if (and (not (void (setq fn GrM-App-List-File)))(findfile fn)(vl-consp app-list)(setq fp (open fn "w"))) (progn ;;; remove "Empty" from list if items have been added (if (and (> (length app-list) 1)(member "Empty" app-list)) (setq app-list (vl-remove "Empty" app-list))) (foreach x app-list (write-line x fp)) (close fp) (gc) ) ) ) (defun _saveas ( / fn fp def ) (if (or (void GrM-App-List-File) (not (setq def (car (fnsplitl GrM-App-List-File)))) (not (vl-file-directory-p def)))(setq def "")) (if (and (vl-consp app-list)(setq fn (getfiled "Select a data file" def "dat" 1))(setq fp (open fn "w"))) (progn (foreach x app-list (write-line x fp))(close fp)(gc) (setq GrM-App-List-File fn)(WriteSettingsToRegistry) ) ) ) ;;; add / del to / from list ;;; update : add full path instead of filename only (defun _add ( / f d e) (setq e "lsp") (if (or (void GrM-App-List-File)(not (setq d (car (fnsplitl GrM-App-List-File))))(not (vl-file-directory-p d)))(setq d "")) (if (setq f (getfiled "Select a lisp file" d e 0)) (progn (if (or (not (vl-consp app-list)) (equal app-list (list "Empty"))) (setq app-list (list f)) (setq app-list (append app-list (list f))) ) (lb_upd) ) ) ) (defun _del () (setq app-list (rfl (nth idx app-list) app-list)) (lb_upd)) (defun _edit_dat_file ( / fn) (if (and (not (void (setq fn GrM-App-List-File)))(findfile fn)) (progn (done_dialog) (startapp "notepad" fn)(alert "Press ok when done")(GrM_App_List_Dialog)))) ;;; --- File operations ------------------------------------ File operations -------------------------------------- File operations --- ;;; (defun GrM_Start_GrRead ( / done inp) (setq done nil) (while (not done) (princ "\rSelect button or [B]ackground color,[CcRr] (+/- col/row),[J]ustification,[S]etup,[Z]oom (E/+/-),[Q]uit (Space/Enter/Esc/RM) :") (setq inp (vl-catch-all-apply 'grread (list nil 8 0))) (cond ((vl-catch-all-error-p inp)(setq done T)) ;;; point selection ((= (car inp) 3) (setq pt (cadr inp)) (setq id (GrM_GetCell-ID (list tb-x- tb-y+) (list tb-x+ tb-y-) (atoi GrM-NoF-Columns) (atoi GrM-NoF-Rows) pt)) (setq app (nth id app-list) done T)) ;;; nah, just for fun...o key cycles Justification ((or (equal inp '(2 106))(equal inp '(2 74)))(cycle_Justification)) ;;; also lots of fun...B key cycles background color ((or (equal inp '(2 66))(equal inp '(2 98)))(cycle_color)) ;;; s or S (setup) ((or (equal inp '(2 115))(equal inp '(2 83)))(GrM_Setup_Dialog_Start)) ; user pressed E of e ((member inp '((2 69)(2 101))) (command "zoom" "e")(GrM_Draw_Toolbar)) ; user pressed + ((equal inp '(2 43)) (vl-cmdf "zoom" "2x")(GrM_Draw_Toolbar)) ; user pressed - ((equal inp '(2 45)) (vl-cmdf "zoom" ".5x")(GrM_Draw_Toolbar)) ; user pressed z or Z ((member inp '((2 122)(2 90))) (vl-cmdf "'zoom" "")(GrM_Draw_Toolbar)) ;;; Enter Space or q/Q key or R-mouse button ((or (equal inp '(2 13)) (equal inp '(2 32)) (equal inp '(2 113)) (equal inp '(2 81)) (equal (car inp) 25)) (setq done T)) ; user pressed D of d - Toggle Debug Mode ((member inp '((2 68)(2 100)))(Toggle_Debug_Mode)) ;;; c (column) smaller (2 99) (GrM_IncTile "bt_nof_columns_min" 0) ((equal inp '(2 99)) (GrM_IncTile "bt_nof_columns_min" 0)(GrM_Draw_Toolbar)) ;;; K (Kolom = column) bigger (2 67) (GrM_IncTile "bt_nof_columns_plus" 0) ((equal inp '(2 67)) (GrM_IncTile "bt_nof_columns_plus" 0)(GrM_Draw_Toolbar)) ;;; r (row) smaller (2 114) (GrM_IncTile "bt_nof_rows_min" 0) ((equal inp '(2 114)) (GrM_IncTile "bt_nof_rows_min" 0)(GrM_Draw_Toolbar)) ;;; R (row) bigger (2 82) (GrM_IncTile "bt_nof_rows_plus" 0) ((equal inp '(2 82)) (GrM_IncTile "bt_nof_rows_plus" 0)(GrM_Draw_Toolbar)) ) ) (redraw) ) ;;; program assumes no self starting routines and start command is "C:" + app name (defun GrM_Start_App (app / fn) (cond ((setq fn (findfile app)) (redraw)(load fn)(eval (read (strcat "(C:" (vl-filename-base app) ")")))) (t (redraw)(princ (strcat "\nUnable to load " (vl-princ-to-string app) " ...bye"))) ) (princ) ) (vl-load-com) (princ "\nGrM - Graphic Menu - Rlx - last update 2025/09/10 (added rlx_sf)") (princ) ;;; (c:GrMs) ;;; Setup Dialog ;;; (C:GrM) ;;; Display Toolbar
  5. Hi @rlx Is it possible that you forgot to include some functions that are called from your code? For example, 'rlx_sf'?
  6. Hi I'm having trouble reconciling my understanding of your question with what I see in the example drawing. The square: doesn't it also play a role in determining the text justification? That is to say: if you select the upper right corner of the square and then specify a horizontal angle to the left, the justification should be bottom right. However, if you do the same thing starting from the lower right corner of the square, the MTEXT justification should be top right. Therefore, the idea seems to be that the MTEXT should always be positioned outside the square. Is this correct? In this case, the MTEXT angle criterion alone is not sufficient; it's also necessary to consider the object to which it refers. If all of this is correct, we would need to write a function that analyzes the geometry of the object the MTEXT refers to and determines the justification, taking the angle into account as well.
  7. Sorry to hear that; I didn't know. Agree it's better to test if you have the data needed before entmake* functions. If you're wanting to get CAD back, consider joining AUGI as Pro members get a free ADN (Autodesk Developer Network) membership, which would give you any Autodesk product to use for development. https://www.augi.com/adn-membership-offer Cheers
  8. Don't have cad anymore to test this things and cant remember if you could throw an if statement inside the entmakex function.
  9. Seems a good start. Here is what I get when running it... Command: SPL Starting point of Mleader Enter to stop : _pline Specify start point: Current line-width is 0'-0" Specify next point or [Arc/Halfwidth/Length/Undo/Width]: L Invalid point. 90 Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: Command: Existing length is 90.000 Enter new length 85 Enter label erase Select objects: 1 found Select objects: Command: ; error: Exception occurred
  10. This is way closer works for 2, 3 & 4 points may be able to add more. version 2 will add the Multi getvals dcl for arrow, text height and length. just proof of concept, its length is still off by a little bit may add a fuzz factor to get closer. ;m Draw a spline mleader mwith a length ; By AlanH Setp 2025 ; Not quite true length but close. (defun c:spl ( / ang arrowlen co-ord ent len len2 newlen num obj pt pt1 pt2 pt3 str txtht x) (defun AddMLeader (ptslst numpts newstr arrow tht / doc points i ) (setq points (vlax-make-safearray vlax-vbDouble (cons 0 numpts))) (vlax-safearray-fill points ptslst) (setq i 0) (setq curspace (vlax-get-property (vla-get-ActiveDocument (vlax-get-acad-object)) (nth (vla-get-ActiveSpace (vla-get-ActiveDocument (vlax-get-acad-object))) '(PaperSpace ModelSpace))) ) (setq mLeader (vla-AddMLeader curspace points i)) (vlax-put mleader 'dogleglength 0.0) (vlax-put mleader 'leadertype 2) (vlax-put mleader 'textstring newstr) (vlax-put mleader 'Arrowheadsize arrow) (vlax-put mleader 'Textheight tht) (princ) ) (defun plpts ( / pt) (setq pt (getpoint "\nStarting point of Mleader Enter to stop : ")) (command "_pline" pt) (while (= (getvar "cmdactive") 1 ) (command (getpoint (getvar 'lastpoint))) ) ) ;;;;;;;; starts here (plpts) (setq ent (entlast)) (setq obj (vlax-ename->vla-object ent)) (setq pt1 (vlax-curve-getstartPoint obj)) (setq ang (angle pt1 (vlax-curve-getendPoint obj))) (setq len (vlax-get obj 'length)) (setq arrowlen 4 txtht 4.0) (setq newlen (getreal (strcat "\nExisting length is " (rtos len 2 3) " Enter new length "))) (setq str (getstring "\nEnter label " T)) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent)))) (cond ((= (length co-ord) 2) (progn (setq lst '() num 5) (setq pt (nth 0 co-ord)) (setq lst (cons 0 lst)) (setq lst (cons (cadr pt) lst)) (setq lst (cons (car pt) lst)) (setq pt2 (polar pt (angle pt (nth 1 co-ord)) newlen)) (setq lst (cons 0 lst)) (setq lst (cons (cadr pt2) lst)) (setq lst (cons (car pt2) lst)) ) ) ((= (length co-ord) 3) (progn (setq lst '() x -1 num 8) (repeat 2 (setq pt (nth (setq x (1+ x)) co-ord)) (setq lst (cons 0 lst)) (setq lst (cons (cadr pt) lst)) (setq lst (cons (car pt) lst)) ) (setq pt2 (nth (- (length co-ord) 2) co-ord)) (setq len2 (vlax-curve-getdistatpoint obj pt2)) (setq len2 (- len len2)) (setq pt2 (polar pt2 (angle pt2 (last co-ord)) len2)) (setq lst (cons 0 lst)) (setq lst (cons (cadr pt2) lst)) (setq lst (cons (car pt2) lst)) ) ) ((= (length co-ord) 4) (progn (setq lst '() x -1 num 11) (repeat 3 (setq pt (nth (setq x (1+ x)) co-ord)) (setq lst (cons 0 lst)) (setq lst (cons (cadr pt) lst)) (setq lst (cons (car pt) lst)) ) (setq pt2 (nth (- (length co-ord) 2) co-ord)) (setq len2 (vlax-curve-getdistatpoint obj pt2)) (setq len2 (- len len2)) (setq pt2 (polar pt2 (angle pt2 (last co-ord)) len2)) (setq lst (cons 0 lst)) (setq lst (cons (cadr pt2) lst)) (setq lst (cons (car pt2) lst)) ) ) ) (command "erase" ent "") (addmleader lst num str arrowlen txtht) (princ) ) (C:spl)
  11. Last week
  12. After you account for '; error: too few arguments:'... Might also consider a single < comparer for limiting this to positive X quadrants, a neither 0 or pi check for all quadrants, etc: (if (and rot (< 0 rot pi)) ;check rotation angle (setq x 1) (setq x 7) ) (if (and rot (/= 0 rot) (/= pi rot)) ;check rotation angle (setq x 1) (setq x 7) ) (setq x (if (and rot (/= 0 rot) (/= pi rot)) ;check rotation angle 1 7 ) )
  13. This would create a text with top left just if the rotation angle is between 0 and 180 else it will be Bottom left. (defun create-level-mtext (pt1 rot / mtext-obj) (if (and rot (> rot 0) (< rot pi)) ;check rotation angle (setq x 1) (Setq x 7) ) (setq mtext-obj (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 8 (getvar "CLAYER")) ; Current layer (cons 100 "AcDbMText") (cons 10 pt1) ; Insertion point (cons 40 0.5) ; Text height (adjust as needed) (cons 41 0.0) ; Reference rectangle width (cons 71 x) ; Attachment point (Top Left) (cons 72 5) ; Drawing direction (cons 1 (strcat "+" (rtos level-value 2 3))) ; Text content with "+" prefix (cons 50 rot) ; Rotation angle ) ) ) mtext-obj )
  14. Hi, This might have been resolved before. But has anyone wrote a lisp or function that calculates the text anchor point based on the rotation of the text? Currently I have a lisp that will prompt the user to select FFL and then will calculate 150mm drop and prompt the user to select point to insert the text and second point to specify angle. I want to push it a step further and add a function to calculate the correct text anchor point which this should be done using the angle (i.e. if pt1X > pt2X & pt1Y>pt2Y then MtextJustify=BottomLeft). I appreciate that when Angle is 0 or 180 the justification in regards to Top & Bottom (Ignoring Left or Right) cannot be calculate due to the angle being zero, which I dont mind. See Lisp code below (defun c:LE-CalExtFFL (/ ffl-ent ffl-obj ffl-text ffl-value new-level pt-list pt user-input) ;;Set Layer (command "_layer" "_m" "-LE-E-External Levels" "") ;; Function to extract numeric value from FFL text (defun extract-ffl-value (text-string / clean-text) ;; Remove first 5 characters from the string (if (> (strlen text-string) 5) (setq clean-text (substr text-string 6)) (setq clean-text text-string) ) ;; Extract the numeric value (if (numberp (read clean-text)) (read clean-text) (progn (princ "\nError: Could not extract numeric value from FFL text.") nil ) ) ) ;; Function to create MText at specified point (defun create-level-mtext (point level-value rot / mtext-obj) ;Calculate Attachment Point based on rotation ;Place Text (setq mtext-obj (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 8 (getvar "CLAYER")) ; Current layer (cons 100 "AcDbMText") (cons 10 point) ; Insertion point (cons 40 0.5) ; Text height (adjust as needed) (cons 41 0.0) ; Reference rectangle width (cons 71 1) ; Attachment point (top left) (cons 72 5) ; Drawing direction (cons 1 (strcat "+" (rtos level-value 2 3))) ; Text content with "+" prefix (cons 50 rot) ; Rotation angle ) ) ) mtext-obj ) ;;Main program starts here------------------------------------------ ;; Prompt user to select FFL MText (princ "\nSelect the MText containing the FFL (Finished Floor Level): ") (setq ffl-ent (car (entsel))) ;; Check if a valid MText was selected (if (and ffl-ent (= (cdr (assoc 0 (entget ffl-ent))) "MTEXT")) (progn ;; Get the MText object and extract text content (setq ffl-obj (entget ffl-ent)) (setq ffl-text (cdr (assoc 1 ffl-obj))) (princ (strcat "\nFFL Text found: " ffl-text)) ;; Extract the FFL numeric value (setq ffl-value (extract-ffl-value ffl-text)) (if ffl-value (progn (setq new-level (- ffl-value 0.15)) ;; Initialize point list (setq pt-list '()) ;; Prompt for points where to place the new MText (princ "\nSelect points where to place the level text (Press Enter to finish): ") ;; Loop to collect points (while (setq pt (getpoint "\nPick point for level text (or press Enter to finish): ")) (setq pt-list (append pt-list (list pt))) (setq rotation (getangle pt "\nSpecify rotation angle for text (or press Enter for 0 degrees): ")) (if (not rotation) (setq rotation 0.0)) (create-level-mtext pt new-level rotation) ) ) (princ "\nCould not extract FFL value from the selected text.") ) ) (princ "\nError: Please select a valid MText object containing FFL information.") ) (princ) ; Clean exit ) CTS-Example Anchor Point.dwg
  15. ILoveMadoka
    Help with TRIM command
    BLACKBOX for the WIN!! Thank you so very much.. Works perfectly now. Thank you both for the input.
  16. nod684
    LAYCOL
    you're welcome.
  17. Another maybe simpler this checks for Close and Save commands. yes got help from a couple of people like Lee-mac. ; by AlanH April 2023 ;Reactor callback function (defun BeginCloseFunc (reactor lst / blocks blk efname ent2 ent3 ole olelst ssole oletit olefound ss ssvft y tabname) (setq tabname (getvar 'ctab)) ; will get "Model" etc ............ do your thing here ........ ............ can call other defuns...... (princ) ) (cond ((= (vlr-current-reaction-name) ':VLR-beginSave) (Princ "\nThis function has been triggered by a Document Save event.")) ((= (vlr-current-reaction-name) ':VLR-beginClose)(princ "\nThis function has been triggered by a Document Close event.")) ) (princ) ) (if (not _BeginCloseReactor) (setq _BeginCloseReactor (VLR-Dwg-Reactor nil '((:VLR-beginClose . BeginCloseFunc))))) (if (not _BeginSaveReactor ) (setq _BeginSaveReactor (VLR-Dwg-Reactor nil '((:VLR-beginSave . BeginCloseFunc)))))
  18. Hi alan, I think I got around the problem by checking if the file has been saved by setting a variable and clearing it when closing and also checking the DBMOD variable. Be good to know your thoughts. (vl-load-com) ;; ;; Reactor_On_Close.lsp ;; ;; Reactor to change stuff when closing a drawing. ;; ;; Another example by Lee Mac, found here: https://www.cadtutor.net/forum/topic/20069-reactor-for-dwg-close-how-to-save/?do=findComment&comment=163847 ;; ;; Author: 3dwannab ;; ;; First written: 2024.11.09 ;; Last update: 2025.09.07 ;; ;; Reactor-based routine to execute custom actions when a drawing is saved or closed. ;; On save, sets a USERS1 flag in the drawing to "SavedThisSessionCallbackBool". ;; On close, checks the USERS1 flag and DBMOD system variable to determine if actions ;; should be taken: ;; - If in model space: change background to black, deactivate plot styles, zoom extents, ;; regen viewports, and save the drawing before closing. ;; - If in paper space: deactivate viewport, zoom extents, set plot styles, and save the ;; drawing before closing. ;; Afterwards, clears the USERS1 flag. ;; ;; Also checks DBMOD flags for database, window, view, or field modifications to ensure ;; proper handling. ;; ;; TO DO ;; NA ;; ;;--------------------------------------------------------------------------- ;; OnSaveCallback ;; ;; Sets a USERS1 system variable in the active drawing to indicate that ;; the drawing has been saved during this session. This flag is later ;; used by the CloseCallBack reactor to trigger actions on closing. ;; ;; Written on 2025.09.07 by 3dwannab ;; ;; Usage: ;; Automatically called by the onsave reactor; no manual call required. ;;--------------------------------------------------------------------------- (defun OnSaveCallback (/ acDisp acDoc acObj acPref dbmodFlags dbmodVal isModelSpace minorChangeMade val) (setq acObj (vlax-get-acad-object)) (setq acDoc (vla-get-ActiveDocument acObj)) ;; set Reactor_On_Close flag in the active document (vla-SetVariable acDoc "USERS1" "SavedThisSessionCallbackBool") (princ "\nOnSaveCallback run... Reactor_On_Close set to 'SavedThisSessionCallbackBool'") ) ;;--------------------------------------------------------------------------- ;; CloseCallBack ;; ;; Checks the USERS1 system variable and the DBMOD system variable when a ;; drawing is closed. If the USERS1 flag ("SavedThisSessionCallbackBool") is ;; set and the database has meaningful changes (DBMOD flags), performs actions ;; based on whether the drawing is in model or paper space: ;; - Model space: set background to black, deactivate plot styles, zoom extents, ;; regenerate viewports, and save the drawing. ;; - Paper space: deactivate viewport, zoom extents, set plot styles, and save the drawing. ;; ;; Afterwards, clears the USERS1 flag to indicate the reactor actions have been handled. ;; ;; Written on 2025.09.07 by 3dwannab ;; ;; Usage: ;; Automatically called by the onclose reactor; no manual call required. ;;--------------------------------------------------------------------------- (defun CloseCallBack (/ acObj acDoc val) (setq acObj (vlax-get-acad-object)) (setq acDoc (vla-get-ActiveDocument acObj)) ;; get current Reactor_On_Close value (setq val (vlax-variant-value (vla-GetVariable acDoc "USERS1"))) ;; Flag for model space (setq isModelSpace (= 1 (getvar 'TILEMODE))) ;; DBMOD (System Variable) (RO) ;; 1 = Object database modified ;; 4 = Database variable modified ;; 8 = Window modified ;; 16 = View modified ;; 32 = Field modified (setq dbmodVal (getvar "DBMOD")) (setq dbmodFlags '((4 . "Database variable modified") (8 . "Window modified") (16 . "View modified") (32 . "Field modified") ) ) ;; Set minorChangeMade to T expect where DBMOD bitcode has, 1 = Object database modified (foreach flag dbmodFlags (if (/= 0 (logand dbmodVal (car flag))) (setq minorChangeMade T) ; (princ (strcat "\n" (cdr flag))) ) ) ;; if it was set to our flag, clear it (if (and (not (eq "" (vla-get-FullName acDoc))) (= val "SavedThisSessionCallbackBool") minorChangeMade ) (progn (cond ;; -------------------- ;; If in model space ;; -------------------- (isModelSpace (princ "\n[Reactor_On_Close] Model space...\n") (setq acPref (vlax-get-property acObj 'preferences)) (setq acDisp (vlax-get-property acPref 'display)) (vlax-put-property acDisp 'GraphicsWinmodelBackgrndColor 0) ;; Black bg (vla-put-ShowPlotStyles (vla-get-ActiveLayout acDoc) :vlax-false) (vla-zoomextents acObj) (vla-regen acDoc acAllViewports) (vla-saveas acDoc (vla-get-FullName acDoc)) ) ;; -------------------- ;; If in paper space ;; -------------------- (T (progn (princ "\n[Reactor_On_Close] Paper space...\n") (vla-put-ActiveSpace acDoc acModelSpace) (vla-put-mspace acDoc :vlax-false) (vla-zoomextents acObj) (vla-put-ShowPlotStyles (vla-get-ActiveLayout acDoc) :vlax-true) (vla-saveas acDoc (vla-get-FullName acDoc)) ) ) ) ; cond (vla-SetVariable acDoc "USERS1" "") ;; Clear the variable ) (princ "\nNo Reactor_On_Close flag found to clear.") ) (princ "\nCloseCallBack run.") ) ;;------------------------------------------------------- ;; c:Reactor-OnClose-on ;;------------------------------------------------------- (defun c:Reactor-OnClose-on () (if (= 'vlr-command-reactor (type onclose:reactor)) (if (vlr-added-p onclose:reactor) (princ "\n[Reactor] CloseCallBack already running\n") (progn (vlr-add onclose:reactor) (princ "\n[Reactor] CloseCallBack ON\n") ) ) (progn (setq onclose:reactor (vlr-command-reactor "onclose-reactor" '((:vlr-commandwillstart . onclose:callback)) ) ) (princ "\n[Reactor] CloseCallBack ON\n") ) ) (if (= 'vlr-command-reactor (type onsave:reactor)) (if (vlr-added-p onsave:reactor) (princ "\n[Reactor] OnSaveCallback already running\n") (progn (vlr-add onsave:reactor) (princ "\n[Reactor] OnSaveCallback ON\n") ) ) (progn (setq onsave:reactor (vlr-command-reactor "onsave-reactor" '((:vlr-commandwillstart . onsave:callback)) ) ) (princ "\n[Reactor] OnSaveCallback ON\n") ) ) (princ) ) ;;------------------------------------------------------- ;; c:Reactor-OnClose-off ;;------------------------------------------------------- (defun c:Reactor-OnClose-off () (if (= 'vlr-command-reactor (type onclose:reactor)) (progn (vlr-remove onclose:reactor) (setq onclose:reactor nil) (princ "\n[Reactor] CloseCallBack OFF\n") ) (princ "\n[Reactor] CloseCallBack not running\n") ) (if (= 'vlr-command-reactor (type onsave:reactor)) (progn (vlr-remove onsave:reactor) (setq onsave:reactor nil) (princ "\n[Reactor] OnSaveCallback OFF\n") ) (princ "\n[Reactor] OnSaveCallback not running\n") ) (princ) ) ;;------------------------------------------------------- ;; CALLBACKS ;;------------------------------------------------------- (defun onclose:callback (obj arg) (if (wcmatch (strcase (car arg)) "*CLOSE") (CloseCallBack) ) (princ) ) (defun onsave:callback (obj arg) (if (wcmatch (strcase (car arg)) "SAVE,QSAVE") (OnSaveCallback) ) (princ) ) ;;------------------------------------------------------- ;; START THE REACTORS ;;------------------------------------------------------- (if (null onclose:reactor) (setq onclose:reactor (vlr-command-reactor nil '((:vlr-commandwillstart . onclose:callback)))) ) (if (null onsave:reactor) (setq onsave:reactor (vlr-command-reactor nil '((:vlr-commandwillstart . onsave:callback)))) ) (princ "\nReactor_On_Close.lsp loaded...")
  19. An Introduction to AutoCAD Software Since it was first released, AutoCAD has been at the forefront of the CAD (computer-aided design) industry, with new features added with each update. Since then, the software has become the industry-standard design tool used by millions of professionals. Two main variants of the software are available: AutoCAD and AutoCAD LT. These contain the same core features, but AutoCAD supports both 2D and 3D drafting and has greater automation functionality, while AutoCAD LT focuses on 2D drafting, with limited 3D capabilities. This guide provides a comprehensive comparison of both products, outlining their features, functionalities, and pricing structures. With this information, you will be able to make an informed decision about which software aligns best with your projects, taking into account the project complexity, needs for 2D drafting or 3D modeling, collaboration demands, and other factors. Understanding Your CAD Design Needs To help you decide whether AutoCAD vs. AutoCAD LT can best support your business, take a moment to assess your project requirements. When comparing your software options, consider the constraints of your budget and whether a long-term investment in the more expansive features of AutoCAD would enhance productivity and reduce overall costs. 2D drafting vs. 3D modeling. The purpose of a CAD drawing is to convey information. While 3D CAD can be more enticing, this may not always be the best way to present your concept to others. For example, an electrician may only need 2D drawings in order to wire an assembly. Similarly, if only a single drawing from a single angle is needed, a 2D isometric drawing may suffice. For more complex situations, such as needing to view the design from multiple angles, 3D modeling will provide greater flexibility and improved productivity. Complexity of designs. The overall scope and level of detail can also impact whether 2D drafting or 3D modeling is the best choice for your project. 2D drafting generally works well for simple design projects, such as those with geometrically simple representations, standard colors, and basic design modifications. As the complexity of the project increases, 3D modeling may prove to be more suitable, even with its higher initial investment. This complexity may include needing to show a greater degree of depth and perspective or viewing the project from multiple angles. Collaboration needs. It is important to understand how you will be collaborating with others during the design process because this can impact which CAD software will support your needs. Some questions to consider include: Are team members in one location or at different sites, possibly in multiple countries? Will multiple users simultaneously be editing the same CAD file? What level of access control is needed during the project, such as limiting who can modify, view, or add comments/annotations to the designs? Will completed designs be shared with manufacturers, vendors, or other stakeholders? What software and CAD capabilities do various stakeholders have access to? Customization requirements. When thinking about which software will meet your needs, consider whether the core software functionality is sufficient, or if you will need to customize and extend that functionality through the use of APIs, plugins, and add-ons. AutoCAD has several different environments to help you customize and extend the software functionality. AutoCAD LT has limited customization and automation capabilities. Industry-specific toolsets. AutoCAD offers access to seven industry-specific toolsets for architecture, electrical, mechanical design, and more. These can enhance productivity by providing a range of capabilities tailored to your role and industry. These toolsets are not available in AutoCAD LT. Unleashing Design Power AutoCAD is a comprehensive 2D and 3D design, drafting, and documentation software that is trusted by architects, designers, engineers, project managers, real estate developers, and construction professionals. The software supports the design and annotation of 2D geometry, as well as 3D modeling with solids, surfaces, and mesh objects. The 3D modeling tools included in AutoCAD can also be used for easy manipulation of 2D objects. This software enhances your 2D and 3D design experience by giving you precision tools to automate drafting tasks such as placing objects with AI, comparing drawings, creating schedules, and publishing layouts. It also includes features such as parametric constraints, dynamic blocks, sheet set manager, and more. Advanced customization options in AutoCAD are available through customized workspaces, APIs, AutoLISP, and apps. The AI-generated support and solutions available with AutoCAD enables you to troubleshoot design challenges and ask questions about AutoCAD features without leaving the workspace. AutoCAD also includes specialized toolsets designed to increase productivity with enhanced features and intelligent objects. These include the Architecture toolset, Mechanical toolset, Map 3D toolset, MEP toolset, Electrical toolset, Plant 3D toolset, and Raster Design toolset. AutoCAD also includes CAD standards functionality, which provides an efficient method of checking standards. To help you stay connected with your team, the software allows you to share AutoCAD 2D and 3D DWG files across desktop, web, and mobile platforms. This enables you to work the way you want, and capture, share, and review ideas from wherever you are. You can also manage design data across projects using Autodesk Docs, the cloud-based document management and common data environment that is part of the AEC Collection. AutoCAD can be used for a wide variety of design and drafting projects, but excels at helping you design solutions that meet clients’ unique challenges. With precise drawing, advanced graphic capabilities, and a large database of templates, AutoCAD enables architects to create complex, yet efficient, architectural designs. The software provides greater control over the designs and allows you to quickly create realistic 3D models that can be explored from different angles. Robust drafting and modeling tools included in AutoCAD facilitate the creation of intricate mechanical designs. Using the software, 2D sketches can be transformed into 3D solids, simple 3D shapes can be used to create more complex ones, multiple 3D components can be combined to create assemblies, and other features. AutoCAD also supports ambitious landscape design and infrastructure projects, including tackling regenerative designs that have a positive impact on natural and human systems. The software can even be used to design infrastructure projects such as trail bridges that take into account local topographic and geographic conditions, and logistical challenges. AutoCAD LT: Streamlined and Cost-Effective 2D Drafting AutoCAD LT is a cost-effective 2D drafting solution that architects, engineers, construction professionals, and designers can use to design, draft, and document with precise 2D geometry. This lower-cost solution is primarily suitable for users working on 2D projects with a limited budget. The software has limited 3D viewing capabilities and does not offer the 3D modeling and customization options that are offered in AutoCAD. However, with AutoCAD LT, you can create a 2D isometric view of a project using the same constraints as a 3D isometric view, although this isometric design can’t be manipulated as easily as in AutoCAD. In addition, checking CAD standards in AutoCAD LT largely requires manual input, which can be time-consuming and may lead to errors. However, AutoLISP routines can be created—in both AutoCAD LT and AutoCAD—to automate these tasks and reduce the time needed to complete the task. AutoCAD LT does offer collaborative tools for sharing and annotating drawings across desktop, web, and mobile platforms. The streamlined interface of AutoCAD LT is also intuitive and customizable, which is ideal for creating quick design iterations, and the software supports workflow automation using AutoLISP. AutoCAD A subscription to AutoCAD® includes access to specialized toolsets for architectural, electrical, mechanical design professionals, and more. Enables: 2D drafting, drawings, and documentation 3D modeling and visualization The ability to set and monitor CAD standards The flexibility to build, customize, and run discipline-specific routines Collaboration on the web and mobile to capture, share, and review ideas on the go You can: Detect objects to convert into instances of a block Quickly search for and convert objects into instances of a block with suggestions from block libraries Automatically place blocks based on where you’ve previously placed them Find and replace blocks based on other blocks in your drawing Utilize AutoLISP programs to automate repetitive tasks and enhance workflows Extend AutoLISP programs with third-party automation libraries, and utilize specialized editors to write and debug programs Create and edit dynamic 2D geometry with parametric constraints Design and edit 3D models with solids, surfaces, & mesh objects Render 3D models with lighting, materials, & visual styles Annotate drawings with traces, text, dimensions, leaders, & tables Customize the ribbon and tool palettes Attach and import data from PDF files Share and use data from DGN files, Navisworks, Bing, and Esri’s ArcGIS® Basemaps Automate counting objects and blocks Share drawings with colleagues directly from AutoCAD Stay informed of relevant file changes with details of multi-user activities in a DWG file Import feedback and incorporate changes with Autodesk AI Learn new features and workflows to work faster with My Insights Customize with add-on apps and APIs Extract object data to tables A subscription to AutoCAD includes: AutoCAD Web Exclusive web functionality for AutoCAD subscribers including AutoLISP API on the web and batch plot to PDF(s) Seven industry-specific specialized toolsets Access to the Autodesk App Store with over 1000 third-party apps for AutoCAD AutoCAD LT A subscription to AutoCAD LT® equips professionals with precision 2D drafting tools. Enables: 2D drafting, drawings, and documentation Collaboration on the web and mobile to capture, share, and review ideas on the go You can: Quickly search for and convert objects into instances of a block Automatically place blocks based on where you’ve previously placed them Utilize AutoLISP programs to automate repetitive tasks and enhance workflows Create and edit 2D geometry Annotate drawings with traces, text, dimensions, leaders, & tables Customize the ribbon and tool palettes Attach and import data from PDF files Share and use data from DGN files, Navisworks, Bing, and Esri’s ArcGIS® Basemaps Automate counting objects and blocks Share drawings with colleagues directly from AutoCAD LT A subscription to AutoCAD LT includes: AutoCAD Web Making the Choice: Which AutoCAD is Right for You? One of the key considerations in selecting the best software is thinking about your project needs. If your projects involve complex 3D designs or require advanced customization and automation, AutoCAD is a better choice. You will also want to think about your workflow. For example, if you will be collaborating with others on projects, AutoCAD’s advanced features and collaboration tools can be useful. You should also consider your budget. AutoCAD LT is a more cost-effective option, primarily designed for those who need 2D drafting capabilities. AutoCAD LT does allow for 2D isometric drawing, so if you don’t need to view a drawing from multiple angles, this software may work for your projects. AutoCAD and AutoCAD LT are both available as a free trial, which last 15 days. The trial software is the same as the subscription, with the full features and toolsets. The trial software will automatically expire after the end of the trial period. After that, you can purchase a monthly, annual, or three-year subscription. For short-term or day-to-day needs, consider using AutoCAD via Autodesk Flex, which is a pay-as-you-go option that lets you pre-purchase tokens to access any product available with Flex for a daily rate. Rates vary based on the product used. Flex is a great option for team members or individuals who need to Conclusion: Empowering Your Design Journey with AutoCAD When selecting a CAD design software, it is essential that you first consider your project needs, budgetary constraints, and expected collaboration demands before making your choice. This will ensure that the software you choose enhances productivity and supports optimal workflows. To learn more about AutoCAD and AutoCAD LT, explore Autodesk’s resources. Frequently Asked Questions About the Differences Between AutoCAD and AutoCAD LT Question: What are the differences between AutoCAD LT and the full version of AutoCAD? AutoCAD LT is a cost-effective and powerful 2D CAD software used for precision drafting and documentation. AutoCAD includes the same features as AutoCAD LT plus additional productivity features such as 3D modeling and automation of repetitive processes. AutoCAD offers greater customization and automation options with add-on apps and APIs. In addition, AutoCAD includes seven toolsets for tasks in architecture, mechanical design, electrical design, plant design, plumbing, converting raster images, geographic information systems, and 3D mapping. Question: What 3D capabilities does AutoCAD LT have? AutoCAD LT is primarily a 2D drafting solution, but the software supports the creation of 2D isometric designs that provide a 3D view. However, in AutoCAD LT, these isometric designs are not as easily manipulated as in AutoCAD. Question: What are the API and automation capabilities of AutoCAD vs. AutoCAD LT? Both AutoCAD LT and AutoCAD allow you to customize your interface and automate your workflows with AutoLISP programming. AutoCAD offers more robust automation capabilities, including API development and debugging. Question: What Autodesk AI capabilities exist today in AutoCAD? Autodesk AI helps AutoCAD users accelerate previously tedious and repetitive tasks, unlocking more time for creation and exploration. AutoCAD productivity tools Markup Import and Markup Assist help drafters iterate new designs more quickly. Machine learning enables Markup Assist to identify handwritten and digital markups, detecting and executing certain instructions in markup text, making changes faster and easier. When a user needs to replace block references, Autodesk AI searches the user’s block library, suggesting similar blocks to choose from. And, as users work, My Insights: Macro Advisor provides curated tips and valuable information—at the right time and in the right context—to increase productivity. These are just a few of the AI features currently available in AutoCAD. Question: Which versions of AutoCAD or AutoCAD LT can I use on a subscription? Your AutoCAD subscription gives you access to install and use the three previous versions of AutoCAD. Available downloads are listed in your Autodesk Account after subscribing. See also previous releases available for subscribers. Question: Can I subscribe to AutoCAD or AutoCAD LT on multiple computers? With a subscription to Autodesk AutoCAD software, you can install it on up to three computers or other devices. However, only the named user can sign in and use that software on a single computer at any given time. Please refer to the Software License Agreement for more information. Download a Free Trial of AutoCAD and AutoCAD LT Get started today with a free trial of AutoCAD and AutoCAD LT. The post AutoCAD vs. AutoCAD LT: Choosing the Right Design Software for Your Needs appeared first on AutoCAD Blog. View the full article
  20. Glad it can of use!
  21. Too late
  22. have nice weekend ps updated the code a little bit (create empty data file on first use) , reset environment (cleared registry / data files) but no error... usually the error you describe has to do with nth function. But I'll do some more testing to try to reproduce the error. upd. 2025-09-07 : addressed some first use issues and couldn't resit : added 'hotkey' [C]olor to cycle background color for 'buttons'. Code above updated.
  23. Cheers, I have broken my rules... weekend and CAD is off... and now it is weekend and beer time.... CAD is still on.... No, that didn't work - I'll have a look tomorrow or Monday to see if it is my machine doing something odd. Dragon is brilliant, thanks!
  24. found the dragon somewhere on line but not sure where anymore , but I know its way above my drafting skills haha. The error is probably the default name for the dat file , on a new system it doesn't exist yet so it has to be created , but think I forgot to put that in yet , wil check it out and update the code. Creating a file c:\\temp\\GrM-Rlx.dat might fix the error for now (that is , if that caused the error) Draak3d.dwg
  25. Thanks... looking good though... (oh, you do know that one day I will ask for the dragon - very cool)
  26. yes the list is just a plain text file. Seems there still is a gremlin in the app , have to hunt it down... think starting setup dialog while toolbar is active is the culprit, probably better to have tootlbar and setup separate. I will have a look at this.
  27. All working. I assume the DAT file is just a list of LISPs, I am getting 'Bad argument value: non-negative: -1' ?
  28. Added a few options since the first version for those who like to pimp things. Same restrictons as b4 , text display is very basic , keep them short or use wider buttons , background fill is fine for standard drawings sizes , but very large units can take some time so added option in setup dialog to tweak fill percentage. Very small drawings / zoom factor also impacts fill. But then if I have to live with these limits of lisp , so do you. Very satisfying I can tell you. App can be started with c:GrM (Graphic Menu) , you probably want to fill the app list with your favorite lisp routines and app still works by loading 'MyLisp' and then assumes it starts with (c:MyLisp). Haven't tested it on a virgin system yet so hope it runs on first use. App should display toolbar with default settings and enters a grread loop , there you can select button or press S for setup , O to change orientation (left / right / top / center / bottom) and also do some zooming, oh just read the freaking command prompt. One button(key) isn't listed , D , that was for debugging. Just left it there for those who get off pressing buttons. In setup dialog top left will show if debug mode is active. You probably use it once in you life but it could be a nice template for future apps. You also can directly go to setup dialog with (C:GrMS) Well I could go on but what be the fun in that. If I did my work app should explain itself. My reason for making this is that for every job I do I make my tools on the fly and having to edit / recompile my autocad toolbar every freaking time started to irritate me and now I just pimp my own toolbar / app-list (you can save multiple toolbar data files in the app-list dialog) Well , as you should know by now : hope you have fun or else bite me (or your mother in law) Oh , if you choose center orientation I would advise to use the fixed width / height option ... or not , I'm not your mommie ...daddy? ... maybe... 2025-09-07 : updated a couple of first use issues & added 'hotkey' [C]olor to cycle different colors GrM.lsp
