No - the messages printed by the (ssget) function ignore NOMUTT; there are likely many other commands/functions which ignore NOMUTT - it depends on how they were implemented and whether NOMUTT/CMDECHO was considered when outputting messages.
Looking for Effective Strategies from a Church Marketing Agency
ReMark replied to oddssatisfy's topic in Autodesk Software General
Why is this topic posted under the heading "AutoDesk Software General"? It should be in the Chat forum, shouldn't it? -
No - as you cannot intercept the evaluation of the (ssget) function.
Topico joined the community
Searching multiple dwg files for text
EleenD03 replied to clowe-thcp's topic in AutoCAD Drawing Management & Output
I've been down this rabbit hole before. Relying on Windows Explorer is so hit-or-miss since AutoCAD started compressing the files—it usually only works if you're strictly using TrueType fonts. If you don't want to mess with LISPs or expensive software, sometimes the easiest workaround is to just extract the data/images to a more searchable format. I found a site called https://wordimageextractor.com/ recently when I needed to pull assets out of a project doc to cross-reference things—it’s actually a pretty smooth way to handle those 'how do I find what's inside this file' moments without having to open everything one by one. For the DWGs specifically, though, Lee Mac’s BFIND is definitely the gold standard if you're comfortable loading a LISP routine! -
ilogo joined the community
tombu started following paperspace/wireframe issue and cui panel image
cui panel image
tombu replied to mohammadreza's topic in The CUI, Hatches, Linetypes, Scripts & Macros
If you're going to share it having all the PNG files converted to transparent then add them to a custom DLL file. I'd recommend copying Acad.dll to the same name as your custom CUI file with the DLL extension instead as that's where the CUI file will look first for the icon. That way you can add all your PNG files into it for you new commands and still reference AutoCAD commands in your custom CUI file as well. Much easier to share a single DLL file than a folder full of PNG files. Changes to Using Resource DLLs with CUIx Files https://help.autodesk.com/view/OARX/2025/ENU/?guid=GUID-7103E61A-8317-4834-BB00-0FE23AEB020F If you're going to share any customization files it's best to make sure all those files are in both the proper Support and Trusted paths. That way all users can access them, and you never have to include paths to them in any of your customization files. That way if you had it installed both in your office and at home where your (Support and Trusted) file folders would have different paths everything would still work the same. Lots of free online tools for converting images to PNG files with transparent backgrounds like: https://www1.lunapic.com/editor/?action=transparent -
You're going to need a different layout for that. Most important thing to learn is creating layouts with templates you can import into other drawings. Once you have them you'll be able to drawings much faster since you shouldn't ever need to do it again. The link to AutoCAD Foundations in AutoCAD Help below is the best place to start. Organize and Output a Design with Layouts (AutoCAD Foundations) https://help.autodesk.com/view/ACD/2026/ENU/?guid=ACD_FOUNDATIONS_MAIN12 AutoCAD provides the best help of any software I know of but as it's hundreds of commands, settings and features that are added to every year you need to dedicate time every day to go through all the help and tutorials you can. Most of us that have spent decades using AutoCAD and it's verticals still don't claim to know it entirely, it's a journey that keeps gets more comfortable as you go along.
oddssatisfy replied to oddssatisfy's topic in Autodesk Software General
thanks in advance for any help -
oddssatisfy posted a topic in Autodesk Software General
Hi everyone, I’m exploring ways to grow our church community and improve engagement both online and offline. We’ve tried basic social media posts and flyers, but results have been limited. I’m curious if anyone has experience working with a church marketing agency and what specific strategies they used that were effective. How do these agencies help with outreach, event promotion, or increasing attendance? Are there particular tools or campaigns that worked well for your church? Any insights, recommendations, or lessons learned would be greatly appreciated! -
A wrapper for ssget function
NirantarVidyarthee replied to samifox's topic in AutoLISP, Visual LISP & DCL
Thank you Lee Mac for prompt response. Any thoughts about 3? -
alb joined the community
What’s the Best Order for Watching Best Friends Planet?
Hey everyone! I’m diving into the Best Friends Planet series and I’m a bit confused about the ideal viewing order. There are so many episodes, specials, and spin-offs, and I want to experience the story in the way that makes the most sense. Should I watch them by release date, chronological storyline, or is there a recommended fan order that enhances the plot and character development? I’d love to hear your thoughts, tips, or any guides you’ve used. Sharing your personal experiences would be super helpful too! -
(vl-catch-all-apply) is used to catch the error when the user presses Esc during the selection prompt, ensuring NOMUTT is set back to 0.
NirantarVidyarthee started following A wrapper for ssget function
I am aware that I am reviving a decade old post. But I found it helpful in understanding the wrapper function. As an example of good programming technique I am studying and exploring this function in more details. As a result, I have some doubts that I need to be cleared as part of my learning process: 1. What is the purpose of using (vl-catch-all-apply) function? I believe there are no errors that cause the (ssget) function to abort. So what error is this function handling? I am not very experienced user, so I may be missing some situations. 2. If I use (apply) instead of (vl-catch-all-apply) and comment the statement (vl-catch-all-error-p), I do not see any difference in the output. Am I missing something? Here is the modified function. (defun M:LM:ssget ( msg params / sel ) (princ msg) (setvar 'nomutt 1) (setq sel (apply 'ssget params)) ; (vl-catch-all-apply) replaced with (apply) (setvar 'nomutt 0) ;;; - Commented (if (not (vl-catch-all-error-p sel)) sel) sel ; Added to ensure return value ) 3. there is one minor problem. When using (ssget) if you start window selection and press enter without clicking second corner point an error message is displayed and select object prompt is repeated. In this function, the error message is displayed but prompt is not repeated causing confusion if the command has ended although selection cursor is displayed to know that the selection is continuing. Is there a way to re-display the msg AFTER the error message to avoid confusion? 4. A related question: I believe problem 3 is because the function (vl-catch-all-error-p) ignores NOMUTT. What are other commands / functions that are not affected by NOMUTT? -
Isaac26a started following Select all points on polyline
Isaac26a replied to Kevin Malone's topic in AutoLISP, Visual LISP & DCL
I know this is an old thread but here it is my fifty cents attempt, I was looking for a created solution but had to complete it, thanks to all ;;; By Isaac A. 20251219 ;;; https://www.cadtutor.net/forum/topic/73414-select-all-points-on-polyline/ ;;; Point on Polyline 'ptopl' (vl-load-com) (defun c:ptopl (/ a b c d dw l oc os) (vla-startundomark (setq dw (vla-get-activedocument (vlax-get-acad-object)))) (setq oc (getvar 'cmdecho) os (getvar 'osmode) ) (setvar 'cmdecho 0) (setvar 'osmode 0) (princ "\nSelect the polylines that touch the points") (setq l (ssget (list (cons 0 "LWPOLYLINE")))) (if l (progn (setq a 0 ) (while (< a (sslength l)) (setq b (entget (ssname l a)) c (append c (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) b))) a (1+ a) ) (setq d (ssget "F" c (list (cons 0 "Point")))) (sssetfirst nil d) ) ) (princ "\nThere are no selected polylines") ) (setvar 'cmdecho oc) (setvar 'osmode os) (vla-endundomark dw) (princ) ) ;;; End ptopl - Last week
Associative Textbox (Lee Mac)
SANDIP PAITAL replied to sachindkini's topic in AutoLISP, Visual LISP & DCL
Dear Sir, one request AssociativeTextboxV1-3 programming two modification required , Select Text or Mtext (Option required Select all text (A) or Single text pick) and all text or single text are layer name TBOX. -
Cleaning up the file
I have seen a dwg with a complete project inside the current dwg which had nothing to do with the dwg being worked on. Look for $AC.... blocks these can be very extensive in size. You need to insert explode erase then can purge. Do you get a blank screen with Zoom Extents ? This is indicating that something is way out there normally in a corner and can be a complete dwg. The only real way to fix is to look at the dwg, understand company copy right problem but you can PM or email via a PM to people here who will look at the dwg and let you know what they find. -
You are right its a bit fudgy but you can read a CSV made by Excel, you would have to count lines as row number, then using say lee-mac parse lisp break the line down into individual values representing cells then use a (nth x excelline) where x is the column number in Excel. Like wise make a csv then open in excel. If LT supports you can use (startapp to open Excel and provide the CSV file path & name so it opens it within your lisp saving a step. oh depending on where you are in the world Excel uses a comma or a semicolon for CSV files.
There is an extensive post about this question its out to 6 pages with various people offering suggestions, I think that GP may have posted there as well. Now where is it
Alona joined the community
I draw my drawings in model space, but when I go to paper space, the viewport is in landscape mode and I need portrait. I was able to change it to portrait but now the wireframe (?) is still in landscape mode and I can't get it to change. In addition to that, what I see in my viewport some of my text and titleblock info doesn't show up but it does in model space. I have never had these issues before. I am using autocad 2022.
I use ACAD 2012 -
HARD ORTHO
I have ortho on, however I can still pull, push and stretch diagonally.. Unless this is how it's supposed to be. What I'm after is being able to only draw and stretch objects at right angles. Thanks! -
Thoughts on Leadership and Experience in Education
Hello everyone. I’ve been exploring profiles of educational leaders recently and am curious about how their diverse experiences shape their approach. One figure who stands out is Grady Gaston, whose career path and achievements seem to reflect a strong commitment to innovation and student success. How do leaders like this balance administrative responsibilities with community engagement and mentoring? What strategies have you seen work best in fostering growth and collaboration within educational institutions? I’d love to hear perspectives on how professional background influences leadership style, especially in contexts similar to those navigated by Grady Gaston. -
Confused by scale issue when set to 1:1_1
CyberAngel replied to Bob658's topic in AutoCAD 2D Drafting, Object Properties & Interface
To test my memory, I opened the default drawing, created a new scale 1:1, and drew a couple of objects and a dimension. I made the dimension annotative and gave it the 1:1 scale. I copied those objects to the clipboard. Then I opened a second new drawing, which had our template settings, including a 1:1 scale. I pasted the objects from the clipboard into the second drawing. You'll never guess what happened. The pasted dimension had a scale of 1:1_1. In other words, that's the type of name AutoCAD gives a duplicate scale when it doesn't want you to rename an arbitrarily large group of settings. Does that shed any light on the issue? -
There are some free and paid apps in the Autodesk Appstore that really do a super job. Not sure if they work on AutoCAD 2010 though and OP refuses to respond to my question on what CAD they use.
