  1. Today
  2. Must it be a dynamic block ? Have a look at this video. Do windows.mp4
  3. Update V2: https://drive.google.com/file/d/1tKI38W60KEjrlQ-NF4Rh-gctgxSd8HQf/view?usp=drive_link
  4. Hi, the 1 and 2 face templates work. The 3 face templates are squared in yellow, one is parametric sketch, the other is a dynamic block, completely messed up now. Seems easier to apply strech action in a dynamic block but I still have to apply TONS of constraints (coincident points, parallel...) I understood I can mass apply them with AUTOCONSTRAIN, but still needs a lot of adjustment and clean up. At least didn't reach the "overconstrained" warining within a dynamic block. PARAMETRIC.dwg
  5. Welcome to CADTutor! Can you post a .dwg?
  6. Hi, I am struggling to make this parametric template work. It is always 1 constrain short of making it behave properly. F.ex. in the curent hair pull-off session I can't make the crossed lines stay parallel/ horizontal, the mitre angle lock at 45 degree, the parallel tilted blue lines stay equal or whatever needed to prevent skewing. Somehow I made 1 face and 2 face panel template work properly (it allready was a pain to make the two face and I dont know how I made it work) But I need also 3, 4, 5 face panels, also a corner panel. The problems come when I try to control the innermost side flanges (where the 45 degree miters are). If they are not equal,the sketch skews, but they might not be equal in some occasions. What is the correct order of applying dimensions and constrains? I know the geometry I am trying to force is completely legit (I can draw it manualy) but that is not the point, it is extremely tedious and boring when a lot of panels need to be done. Can I find ready parametric templates for this? The constraints interaction seems to make the task impossible. Regards - Emil
  7. I was looking into mesh refinement and found that increasing the smoothness level does not always improve the result. Sharp edges can become rounded, narrow features may lose their definition, and the overall shape can drift from the original geometry. This becomes particularly important when the mesh represents a component with both smooth surfaces and features that must retain their shape. For those who work with mesh-based models, how do you preserve critical edges and dimensions while increasing mesh smoothness? Do you adjust the smoothing settings, refine selected areas, or use another approach?
  8. When looking at a 3D assembly with many parts finding interference is just one part of the work. Some overlaps might be meant to happen while others show that parts are in the place where there should be space. In an assembly the problem is figuring out which interference issues are important without spending time on ones that are expected. For people who use `INTERFERE` on mechanical models how do you tell real problems from overlaps that were meant to happen? Do you look at the interference results or do you also use section views and check for space, between parts?
  9. That makes sense. If the face offset keeps causing problems, creating a new solid and using Union or Subtract sounds like a practical alternative. I suppose it depends on which approach gives a cleaner result.
  10. This SlbSelect.lsp is another ChatGpt generated app that extracts Slides (SLD) from inside a Slide Library file (SLB). When executed, the following steps occur: A File selection window appears for a Slide Library file (like acad.slb) to be selected Next a Folder selection window appears to select a location to save the extracted Slides Then the Slide file names inside the selected Slide Library is displayed in a custom dialog List Box for user selection After the selected Slides have been successfully extracted, Windows File Explorer opens to the Folder location for user review SlbSelect.lsp
  11. Yesterday
  12. "sheet stays 420 x 297 in a .dwt" not a problem various ways of doing this, simplest is have a layout "A3" which has your title sheet as only item in it. The title is at true size ie 420x297. And has say one viewport, just make a layout for each size. Where I worked that is how we did it, 20+ years using a DWT. Make sure add all your Text styles, layers, blocks and linetypes to your DWT, its easy to remove unwanted. Yes can add back in if needed. Part 2 you can use Layout copy to make new layouts with the correct title block. The obvious is delete any sizes you don't want. Part 2a layout T you can use a template for the layout so it will read a layout by name from another dwg. Ok maybe a big helper, there is code out there for making layouts automatically, as part of that the required title block can be chosen. A few choices pick a point in Model plus scale layout made, Use Rectangs as sheet outline and make multiple layouts in one go. Just ask for more detail various authors including myself. As a new person at Cadtutor this may be of interest to you. Welcome aboard. Lisp files DEC 2025.docx
  13. BIGAL
    Blocks and library
    @xurshid_viewport Just a comment I use pop menus to display blocks as you will see in an early post here. once the block dwg's are made I use a custom lisp to write most of the mnu code required just saves a bit of time., it just reads a list of dwg names some shorthhand with a full path if required and full dwg name, using a support path makes it easier. So if making lots from scratch worth the coding effort. Happy to help will need to find code been a while since I made a mnu. Using the @Paul Li code to write dwg name is handy. [->LIBRARY] [FURNITURE]^c^C^p(lay_furn);$I=FURN $I=* [SANITARY]^c^C^p(lay_furn);$I=SANIT $I=* [KITCHEN]^c^c^p(lay_furn);$I=KITCH $I=* [BATHROOM]^c^c^p(lay_furn);$I=BATH $I=* [--] [<-TREES]^c^c^p(lay_tree);$I=TREES $I=* ................... ***icon **FURN [FURNITURE:] [CTONE(CHAIR-1)]^c^cINSERT ca3ch-1 DRAG \1;;DRAG [CTONE(CHAIR-2)]^c^cINSERT ca3ch-2 DRAG \1;;DRAG [CTONE(SOFA-1)]^c^cINSERT ca3sof1 DRAG \1;;DRAG [CTONE(SOFA-2)]^c^cINSERT ca3SOF2 DRAG \1;;DRAG [CTONE(TABLE4)]^c^cINSERT ca3tbl4 DRAG \1;;DRAG [CTONE(TABLE6)]^c^cINSERT ca3tbl6 DRAG \1;;DRAG [CTONE(RTAB1)]^c^cINSERT ca3rtb1 DRAG \1;;DRAG [CTONE(RTAB2)]^c^cINSERT ca3rtb2 DRAG \1;;DRAG
  14. BIGAL
    Slide Library File Viewer
    Tried it in Bricscad V25 worked ok, a side issue it pops open the text file in Notepad which I have to close. I really don't want these TXT files being added to the chosen slb directory. They should be deleted or an option keep or delete.
  15. Hello everyone! Today, I’d like to share with you an AutoLISP routine for STEEL PLATE FABRICATION. Download: https://drive.google.com/drive/folders/1aJmLA-P5mX8ykPFYp5ShD5DTIBxQkDKm?usp=sharing
  16. mhupp
    Fillet Polylines Multiple
    Sorry Nikon I removed a call to another sub function at the start that had the vl-load-com.
  17. Trial and Error most likely, if that seems it should produce a correct solution. As mentioned previously, sometimes just creating a new 3D Solid shape as needed and Union or Subtract.
  18. Last week
  19. SLW210
    I like that one @mhupp. Luckily our waterjet and plasma don't seem to have issues, but smoothing couldn't hurt. I had the same error as Nikon, so I cleaned this up a bit. PolySmooth_1.0.lsp
  20. SLW210
    CAD Learning Game
    Seems interesting. Welcome to CADTutor!
  21. Paul Li
    Blocks and library
    @xurshid_viewportNow that you mentioned about wblocking each block as a dwg my free BlockApps actually comes with a new command called DDBlkCat which automates this process: https://marketplace.autodesk.com/apps/6d9671d7-7999-4998-b6a2-3fb959ee8a46?priceId=33599053-c530-44ac-9260-a1283eceb325
  22. xurshid_viewport
    Blocks and library
    @peterg one thing that caught me out when I started with LT: the Blocks palette on the "Current Drawing" tab only lists blocks that live inside the drawing you have open. If you made the blocks in a drawing and then purged or never saved it, they are gone from the panel, and a new drawing will not show them either. What I do now is save each block to its own file with WBLOCK into one folder, for example D:\Blocks\Doors and D:\Blocks\Furniture. In the Blocks palette there is a Library tab, and you can point it at that folder, so every file in it shows up as an insertable block in any drawing. LT 2022 has it, I use it daily for doors and windows. Tool palettes work too if you prefer dragging from a panel.
  23. I was modifying an existing 3D solid using SOLIDEDIT and ran into a situation where offsetting a face became difficult. The selected face was straightforward, but the surrounding geometry made the result less predictable than expected. I’m particularly interested in cases where the offset creates intersections with adjacent faces or causes the operation to fail, even though the requested distance seems reasonable. For those who use SOLIDEDIT regularly, how do you diagnose whether the problem comes from the face geometry, the offset distance, or the surrounding solid? Do you try another face-editing operation first, or modify the geometry another way?
  24. Nikon
    After applying the code and selecting the object, the closed polyline is split into separate lines. And the code terminates with an error. ; error: no function definition: VLA-GET-ENTITYNAME
  25. Attached is code SlbShow.lsp that ChatGpt help me generate which would run on AutoCAD on Windows OS. It'll first open a file window to select an existing slide library file like acad.slb Then run a vbscript to extract the names of the slides inside the selected slide library and place this into a text file. Next, the slides inside the selected slide library will be displayed in a custom dcl made up of a row of 4 x 5 column image buttons. Finally, when an Image button is clicked another window appears showing the slide in a larger image button view. I would like to know when vbscript or wscript is restricted does the code handle this and exit properly. Any other feedback is welcome. SlbShow.lsp
  26. mhupp
    I made this to run on our CNC profiles. It would always throw a tool path error if the polyline had corners the tool couldn't fit into. Because our profiles where generated from a laser outline and then cleaned by hand. A lot of the poly segments were very small and tedious to fix. using poly fillet would update all vertex and fillets to the radius you set. so if your profile had a larger radi it would create big wings. (see example) This only fillets if the radi is smaller then the tool dia or if two joined line segments can run fillet command. creates an old red outline poly on check layer to compare against. leans heavily on vlax-curve visual lisp functions. I think this took me about 2 week on and off to write up. updating the one profile could take 10 mins to multiped hours to fix manually. switching between AutoCAD and the CNC software to see if it would throw an error or finally pass. I think it became obsolete with the update to the CNC software. example.dwg PolySmooth.lsp
  27. Hi all, I am in the early stages of developing (vibe coding) something I have been thinking about for a minute: a videogame where you CAD. It's called CADcade and I've got a whole vision for it and everything. Right now it's just some beginner lessons, a sandbox mode, and an arcade mode with 36 drafting challenges of varying difficulties. It runs in your computer browser, and one of the goals is to help students and beginners learn the basics of navigating CAD products and spatial thinking for free online. This is kind of a demo of it that I would like to get feedback on (not selling or monetizing anything). I just wanted to share it here and see what you guys think. How does it feel? Ai slop? Not enough commands? Dumb concept? Every reply helps. cadcade.net Thank you!
