  1. Today
  2. Steven P
    Find in Notepad
    Good Morning, I have been using this to search for text in a text file, now I have been upgraded to windows 11 it doesn't work, and I can't work out what change to make. Looking for some guidance again, thanks! fnm: File name (including filepath) str: Text String delay: a delay, say 1000 mS Will open notepad and should perform a 'find' to jump to the text. It gets as far as 'find' to open the dialogue box but won't populate it or hit 'enter' to do the find, using sendkeys - which has always worked before. thanks for any help ;;To find text within a text file. ;;http://www.cadtutor.net/forum/showthread.php?102326-Open-text-file-and-jumping-to-a-line&p=694572#post694572 ; example command to call it (NotepadFind "C:\\Downloads\\test 123.txt" "findtext" 300) (defun NotepadFind (fnm str delay / obj) (vl-catch-all-apply (function (lambda () (setq obj (vlax-get-or-create-object "WScript.Shell")) (vlax-invoke obj 'Run (strcat "Notepad.exe \"" fnm "\"")) ;; or notepad++ if that is used. (setvar 'cmdecho 0) (command "_.delay" delay) ; Milliseconds. For BricsCAD users: (sleep delay) does not work. (setvar 'cmdecho 1) (vlax-invoke obj 'AppActivate "Notepad++") ; Title bar name of application. ++ for notepad++ but still works? (vlax-invoke obj 'SendKeys (strcat "^f" str "{ENTER}{ESC}")) ) ) ) (if obj (vlax-release-object obj)) )
  3. Camera command does 90% what your asking idk if it says layer states tho.
  4. Yesterday
  5. Hello Is it possible to create a camera view in a drawing that captures what is currently visible, using a LISP command instantly? For example, when I rotate a 3D object and want to take a "screenshot" of that specific view. The proposed idea is to create permanent camera icons (or similar markers) in the drawing, allowing me to click on them to instantly switch to the saved viewing position as it was captured to review area. Thank you!
  6. Start with the profiles on the vertical back plane (XZ world) then extrude. Add consruction lines to define regions. Extrude regions, substract cylinders and union it all together.
  7. Hi Bigal, Curious if had any questions.. if my description was clear. Thanks for looking into this.
  8. @cmc1212 did you ever get help I know I’m here like 9 months after your post it I’m stuck and getting desperate
  9. Reading this one, what is the objection to the engineers running a LISP? You could add it as a button, in the ribbon, or as a command to suit their preferences, and if you make it easier for them they'll use it. For example a single command to draw the rectangle and insert the block instead of 3 or 4 commands makes things quicker and easier, the engineers should jump on that (every speed improvement is after all another few seconds to go and make another coffee!)
  10. Properties 4,5,6 I can’t seem to get the right sizes or anything I saw your 2012 forum and thanks that helped me get to this point but I’m stuck now
  11. Last week
  12. If you use a reactor it is a lisp anyway and has to be ran every time you add the block, so as I suggested much easier to do a lisp that looks at the XY point and updates, a lisp will run through multiple blocks very fast and update all. Just make the lisp insert the block 1st.
  13. PGia
    Find&open files
    That seems very interesting!
  14. GLAVCVS
    Find&open files
    @PGia In case you don't mind including all the file locations you need to reference in AutoCAD's "SupportPaths" (other external paths could also be considered, but would require more code), there is another option, unorthodox but disruptive: type the name of the file to open directly into the command line (but with a small convention) I think some of the participants in this thread know what I'm talking about. If not, I'll explain it with a little code when I get home.
  15. Don't create a new reactor for every object - this is likely to severely impact performance - only one object reactor is required with a set of owning objects. Aside, you're missing the definition for your (let*) function.
  16. Lee Mac
    Find&open files
    I would also vote for Everything - it's ridiculously fast.
  17. Try Overkill
  18. My thought exactly. It looks like an Impossible Object.
  19. BIGAL
    Find&open files
    I use Everything all the time it indexes hard drives and finds a file instantly. Re Access, Word, Excel and Libre office all of these can be accessed from CAD I use Bricscad. You can for say Access not only open but actually get at the data, most common being Excel get and put. If you have a few known files you want to open all the time can either make a defun for each and load on startup or my preferred would be a sub menu in a POP menu with the file names as the description. As mentioned already using notepad is shown how in ACAD.PGP as an already defined option.
  20. rlx
    Find&open files
    I did write something once to find and launch documents but its a little over the top probably. But Bigal also had a good suggestion , a program called everything.
  21. PGia
    Find&open files
    Thanks to RLX for recommending Lee Mac's code (Lee Mac: thanks for sharing it) I just figured out how it works, and I think it's pretty close to what I need I guess I should create a command to run that code whenever I need it.
  22. PGia
    Find&open files
    Thanks for the answers. They're really very interesting. And I really liked @Steven P's Lisp for searching on Google In response to Ciberangel, I must say that I often need to edit acad.lsp and other AutoCAD support files, and I really feel like I'm wasting a lot of time doing that. Additionally, I almost always need to open Access databases that contain information related to the drawings I manage. I also manage photo banks with standardized names that I need to reference on the fly in my drawings. For these reasons, a tool to search and open these files will save me a lot of time.
  23. mhupp
    Find&open files
    Didn't have the exe in the startapp line so maybe thats why?
  24. Steven P
    Find&open files
    Didn't quite work for me - opened explorer and went to a folder - not sure why yet ... actually, take away the '/watch?v....." and it works, probably just your dodgy youtube viewing habits..
  25. mhupp
    Find&open files
    @Steven P See what this does. again will use default browser. (startapp "explorer.exe" "https://www.youtube.com/watch?v=dQw4w9WgXcQ") So above can be (defun c:GetGoogle ( / Search Page) (setq Search (getstring "Enter Serch Term: [use '+' between terms] ")) ;; get search term, '+' between words (setq Page (strcat "https://www.google.com/search?q=" Search)) ;; google + search term address (startapp "explorer.exe" page) ) -edit didn't have the exe
  26. I've never worked with reactors. I'll have to dig into it. Thanks!
  27. rlx
    Find&open files
    actually quite nice Steven , think I'm gonna add this to one of my toolbars (if there's still room that is...) for opening things I also like : https://lee-mac.com/open.html
  28. Steven P
    Find&open files
    also shell commands - I've only used that once though: (defun c:GetGoogle ( / SearchTerm PageBase) (setq SearchTerm (getstring "Enter Serch Term: [use '+' between terms] ")) ;; get search term, '+' between words (setq PageBase "(command \"shell\" \"start microsoft-edge:http://google.com/search?q=") ;; google address (setq Page (strcat PageBase SearchTerm "\")" )) ;; google + search term address (eval (read Page)) ;; open 'Page' ) Guess what this does....
