Thank you Mhupp for looking into this. I'm on v26.1.05 and planned to update before posting question to Bricscad support. I've also experiencing delays of over a second in layer properties toolbar registering layer changes by lisp command.
Issues with MText in different colours
SLW210 replied to GGuzzler's topic in AutoCAD 2D Drafting, Object Properties & Interface
What does a Print Preview look like and one printed to paper look like? What are you using to plot to PDF? Computer Specifications? No issues here on Pdf. vCT P2v0.1 YOC-P2 no AA.pdf vCT P2v0.1 YOC-P2 no AA-2.pdf -
Does anybody else have this DIMBREAK issue?
SLW210 replied to SLW210's topic in AutoCAD Bugs, Error Messages & Quirks
Thanks, I fixed those drawings, but your LISP works great. I have been having a ton of issues like this since work upgraded me to Windows 11 a while back. I have a reference number for Autodesk to look into it, but I keep getting the run around. - Today
A bit of googling check your version is past 26.2.07. can't check because i don't have V26 A regression in BricsCAD V26.2.5 caused the Properties window and other GUI components to stop updating during LISP execution, particularly when waiting for user input. This issue was identified as a regression and has been fixed in V26.2.07 (and subsequent builds). If you are experiencing this behavior: Update BricsCAD: Ensure you are running V26.2.07 or a newer version where the fix is included. Check System Variables: LISP scripts may inadvertently set FILEDIA or CMDDIA to zero, preventing dialog updates. Ensure your code resets these variables or uses an error handler to restore them upon cancellation. Alternative Property Access: For object properties not updating via COM, BricsCAD supports non-COM functions like (getpropertyvalue), (setpropertyvalue), (ispropertyreadonly), and (dumpallproperties) which work across Windows, Mac, and Linux.
AutoCAD Linetypes – Using Ours or Making Yours: Tuesday Tips With Frank
It was one of the first things we were taught in my high school drafting class. Just as it is today, linetypes are a core feature of proper drafting. I can still remember picking up that freshly pointed HB pencil and gliding it against my T-Square, while properly rolling it along the way to ensure an even line. The point is, we were the drafter, and we were responsible for knowing what to do, what type of line to use, and correctly applying that skill. A skill which in the world of CAD is generally rendered moot. But that’s OK. This is one of those posts where, if your CAD department is set up correctly, most users will never need to load and manage linetypes. I know my users never did. So, while it is, as I said, a core feature, I’ll go over the basics first, then jump into a cool tip that makes creating your own custom linetypes easy. This isn’t called Tuesday Tips for nothing! A Linetypes Primer If you start a new drawing using the acad.dwt template file, you’ll get three linetypes: ByLayer, ByBlock, and Continuous. To get more, you have to load them. Launch the Linetype Manager dialog by selecting the Other option in the Linetype pulldown menu in the Properties panel of the Home tab of the ribbon. Or type in LT. Your choice. The next step is to click on the Load button. Doing so will display the Load or Reload dialog as shown below. Each type will have a name, a description that may better explain the linetype, and a graphic representation of what it looks like. Select the linetype you want, and click OK. It will now display in the Linetype Manager list, available for you to use in your current drawing. Again, you may have never actually done this, as it should have already been done for you. But now you know. Notice the dialog wants you to select a file, and defaults to something called “acad.lin”. The acad.lin file is simply a text file containing all of the linetype definitions. Let’s explore that file a little closer. The ACAD.lin File AutoCAD has two such files, the other being “acadiso.lin” for use in isometric drawings. They are stored in, and loaded from a folder in your user profile. More on that in a minute. Below is an image showing what it looks like. I’ve scrolled down a bit, mostly to show some comments referencing Release 13 and 14, but also to show the more complex linetype definitions. Let’s look at the definition for GAS_LINE, as we’ll be using that an example for the tip part of this post. You have the name and description – including the graphic representation – followed on the next line by the rather cryptic definition of how the linetype is created. Trust me, you do not want to learn how to define these things. Check out the ACAD_ISO… definition at the top of the image. I’m sure that the definition of “A,12,-3,12,-3,0,-3,0,-3,0,-3” makes total sense to you. Yeah, me too. The Actual Tip: Creating Your Own Linetypes By my count, there are 45 linetypes defined in the acad.lin file. Surely that’s enough to cover every situation ever imaginable, right? Of course not. But having just filled you in on how they’re defined, where would you even start if you had to create a custom linetype? That’s where AutoCAD’s Express Tools saves the day. Tucked safely away in the Additional Commands menu of the ET Tools panel, you’ll find Make Linetype. Let’s say we need to make the following (beautiful) linetype. The first step is pretty easy. Draw what you want it to look like. The second step is to launch the Express Tool, and follow its prompts. The next thing is tell it where to put the new definition. This location has changed often over the years, and now it defaults to your My Documents folder, using the format of <drawingName.lin>. Use that if you like. Or, you can go find the acad.lin file and your new linetype will be appended to the last section of the file. You can find it in the following location: C:\Users\<yourUserName>\AppData\Roaming\Autodesk\AutoCAD 202x\R2x.0\enu If you don’t feel comfortable about editing this file, just use the default, and then you can cut and paste later. The next step is to select the start point and end point of your sample linetype. Don’t forget to have an Endpoint Osnap turned on. Then, you’re asked to “Select Objects”. Select each element from left to right. Press Enter. Your custom linetype will be added to the .lin file, and will be loaded for the current drawing. It’s literally as easy as that. Now, I can draw whatever I want, using my “best ever” new custom linetype. While you can write your own .lin file as I described, I suggest moving your new style into the Acad.lin file, just to make things easier going forward. All of your styles should be defined in the same file. Speaking of the definition, here’s what the MKLYPE AutoLISP routine created for us. That’s All Folks Will you use the built-in linetype loading function, or create custom linetypes every day? I hope not. But like a lot of things in AutoCAD, it’s good to know they’re there, because (as I’ve learned over the years), you never know. More Tuesday Tips Check out our whole Tuesday Tips series for ideas on how to make AutoCAD work for you. The post AutoCAD Linetypes – Using Ours or Making Yours: Tuesday Tips With Frank appeared first on AutoCAD Blog. View the full article -
DavidP replied to SLW210's topic in AutoCAD Bugs, Error Messages & Quirks
I never used dimbreak before so but can you use a lisp select all the dim and test which ones which have DimBreaks applied to the then just re-set them.? Test on a few drawings first (make sure run it on back version)... I did this with the help of ai... but it appears to work for me... (perhaps some can verify and improve on it) I'm on on Version 2027 Map but his worked for me. I have notice two things if the dimension are not on screen and the object it crosses are a layer that is off the break reset doesn't work. (So I added zoom extents and do both layer on and thaw for any layer that is printable. Then at the end I reset everything back. But it may be better to do that before you start... as I seen AutCAD behaving strange... Where some lisp functions run before the previous task is complete... (defun c:RefreshDimBreaks ( / layers oldecho i data name flags plot off frozen answer item viewctr viewsize) (setq oldecho (getvar "CMDECHO")) (setvar "CMDECHO" 0) (setq viewctr (getvar "VIEWCTR")) (setq viewsize (getvar "VIEWSIZE")) (setq layers '()) (if (tblnext "LAYER" T) (progn (while (setq data (tblnext "LAYER")) (setq name (cdr (assoc 2 data))) (setq flags (cdr (assoc 70 data))) (setq plot (cdr (assoc 290 data))) (setq off (< (cdr (assoc 62 data)) 0)) (setq frozen (= (logand flags 1) 1)) (if (and (= (if plot plot 1) 1) (or off frozen)) (setq layers (cons (list name off frozen) layers)) ) ) ) ) (if (> (length layers) 0) (progn (princ (strcat "\nFound " (itoa (length layers)) " printable layers that are off or frozen.")) (initget "Y N") (setq answer (getstring T "\nTurn these layers on and thaw them temporarily? [Y/N] <N>: ")) (if (or (= answer "") (= (strcase answer) "N")) (princ "\nNo changes made.") (if (= (strcase answer) "Y") (progn (foreach item layers (command "_.-LAYER" "_ON" (car item) "") (command "_.-LAYER" "_THAW" (car item) "") ) ) ) ) ) (princ "\nNo printable layers are off or frozen.") ) (RefreshDims) (foreach item layers (if (cadr item) (command "_.-LAYER" "_OFF" (car item) "") ) (if (caddr item) (command "_.-LAYER" "_FREEZE" (car item) "") ) ) (princ "\nOriginal layer states restored.") (command "_.ZOOM" "_C" viewctr viewsize) (command "_.REGEN") (setvar "CMDECHO" oldecho) (princ) ) (defun RefreshDims ( / ss ssBreak oldecho i ent dict 360type) (setq oldecho (getvar "CMDECHO")) (setvar "CMDECHO" 0) (command "_.ZOOM" "_E") (if (setq ss (ssget "_X" '((0 . "DIMENSION")))) (progn (setq ssBreak (ssadd)) (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (if (setq dict (cdr (assoc 360 (entget ent)))) (progn (setq 360type (cdr (assoc 0 (entget dict)))) (if (= 360type "DICTIONARY") (ssadd ent ssBreak) ) ) ) (setq i (+ i 1)) ) (if (> (sslength ssBreak) 0) (progn (princ (strcat "\nRefreshing " (itoa (sslength ssBreak)) " dimension breaks.")) (command "_.DIMBREAK" "_M" ssBreak "" "_R") (command "_.DIMBREAK" "_M" ssBreak "" "_A") ) (princ "\nNo dimensions with extension dictionaries found.") ) ) (princ "\nDrawing does not have any dimensions") ) (setvar "CMDECHO" oldecho) (princ) ) -
GGuzzler started following Issues with MText in different colours
GGuzzler posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi all, Having an issue that started recently where text pasted in from MS word looks fine in Paper space but then once printed to PDF, formats strangely. Please see screenshots attached. Any ideas much appreciated! vCT P2v0.1 YOC.dwg TEST.pdf -
No worries. I simply fed your description into Claude. With a few more prompts or a couple of revisions it would have done all that you asked. Its crazy powerful especially in the hands off someone like yourself with advanced lisp coding knowledge and experience. Claude and similar are such a high level above the likes of Co-Pilot.
Why does a 3D solid become difficult to edit after using UNION?
Have you ever combined several 3D solids with UNION, only to find that editing one particular part later becomes difficult? Once separate solids are united, AutoCAD treats them as a single 3D solid. If you still need to modify individual components, I prefer keeping the original solids or using SLICE when I need to separate a specific portion. For complex models, combining everything too early can make later changes harder. How do you usually manage 3D solids when you know the model will need revisions later? -
[Part 1/6] The CAD Manager's Playbook: How to Elegantly Manage 100+ Custom Plugins
VicoWang replied to VicoWang's topic in CAD Management
Fair enough, Steven! If your current company drive setup is humming along without friction for your team, there is genuinely zero reason to disrupt what already works for you. Just to clear up one quick technical misconception for anyone following along: VedaCAD isn't an online file store (it's purely an environment deployment manager), and there is no password fatigue here—the platform is completely passwordless (supporting modern Enterprise SSO, OAuth, and Magic Links). Different tools for different office architectures. Wishing you and your CAD team smooth drafting! -
Steven P replied to VicoWang's topic in CAD Management
Option 1 above - I think my CAD setup sends a request to the central server to get the licence information and won't run unless it gets that - I have to be online to start CAD - so can always get our resources. Open on demand shows no noticeable delays - milliseconds if there is (or the time it takes to move the hand from keyboard back to mouse again) Option 2 above - LISPs are loaded when called for and yes, there is a remote chance of 2 users requesting the same file at the same time, it is a very remote chance. Any updates to a routine will be an improvement, the user notice - they still have the working routine to use if a update occurs (and even if so, there is a LISP to reset the load on demand that they can invoke). So far you might have guessed I am not being sold on the idea of another online file store. Another set of user names, unique passwords, and so on -
Strain2026 joined the community
ALEX993 joined the community
all_lll joined the community
I used parts of the AI code and parts of my code that I had, like correct counts and correct table output to match task. Big thanks @Least I will look at Claude a lot more. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/need-help-counting-support-quantities-can-you-please-help/td-p/14238558/page/3
kim1022 joined the community
Free Browser-Based STEP/STP Viewer for Quick CAD Inspection
cadprops replied to cadprops's topic in AutoCAD 3D Modelling & Rendering
Thanks for the detailed feedback! I’ve just improved the .3mf handling and fixed several compatibility issues. Could you give those files another try when you have a chance? If any of them still fail to open, I’d really appreciate it if you could let me know. Thanks again for helping me improve CADProps! -
Thanks for the detailed feedback! I’ve just improved the .3mf handling and fixed several compatibility issues. Could you give those files another try when you have a chance? If any of them still fail to open, I’d really appreciate it if you could let me know. Thanks again for helping me improve CADProps! - Yesterday
I am impressed with the result its very close, has a couple of things to fix. The Mtext needs to keep the Fraction text. It also needs to sort on that fraction text. If you look at image correct answer is Total = 32. One issue of the dwg is may need to get end user to make sure text is within a reasonable offset from the plines etc, In true dwg some ends are at angles and end text is close. But will test more. One thing I did not mention is there is 13 separate multi line segments to get the total for say a total maybe 1000+ but don't worry about that for now. I consider wether to keep going with what I have oe use what has been provided. Attached a sample dwg. Test lines text.dwg
VS Code + AutoCAD Lisp Extension Issues (Need constant re-starts)
DavidP replied to DavidP's topic in AutoLISP, Visual LISP & DCL
I may have been using vs Code incorrectly.... Before I was just loading the lisp or lisp(s) files I thought I need to test a specific function... but now I'm loading all the lisp in project before I start debugging... this change in approach appears to work much better. So for each Project I create a lisp called main.lsp the main function of this is to read the vscode project prj file and load each Lisp in the project while reporting the load status. (I hardcore file path and file name : I attach vs code while in the main function and run the main while checking to ensure none failed to load... then just debug as normal... So far I haven't had to do a restart yet. So now every time I make a code change I run main first then call what ever function I need to debug. (defun c:main ( / path projectfile ProjectLispList fileName filePath result) (setq path "C:/Tools/Projects/Project1/") (setq projectfile "MyProject.prj") (setq ProjectLispList (ReadProjectFile (strcat path projectfile))) (foreach fileName ProjectLispList (if (or (vl-string-search "\\" fileName) (vl-string-search "/" fileName) (vl-string-search ":" fileName)) (setq filePath fileName) (setq filePath (strcat path fileName ".lsp")) ) (if (findfile filePath) (progn (setq result (vl-catch-all-apply 'load (list filePath))) (if (vl-catch-all-error-p result) (princ (strcat "\nFAILED: " filePath)) (princ (strcat "\nSUCCESS: " filePath)) ) ) (princ (strcat "\nNOT FOUND: " filePath)) ) ) (princ) ) (defun ReadProjectFile (filePath / file line trimLine inList names start end name) (setq file (open filePath "r")) (setq inList nil) (setq names nil) (if file (progn (while (setq line (read-line file)) (setq trimLine (vl-string-trim " " line)) (if (= (strcase trimLine) ":OWN-LIST") (setq inList T) (if inList (if (= trimLine ")") (setq inList nil) (progn (if (= (substr trimLine 1 1) "(") (setq trimLine (substr trimLine 2)) ) (if (= (substr trimLine 1 1) "\"") (progn (setq start (vl-string-search "\"" trimLine)) (setq end (vl-string-search "\"" trimLine (1+ start))) (setq name (substr trimLine (+ start 2) (- end start 1))) (setq names (append names (list name))) ) ) ) ) ) ) ) (close file) ) ) (reverse names) ) -
I put in to Claude Opus 5. Attached is the result. It took a couple of minutes or so, with one revision. LTCOUNT_1.lsp
How can I make the following program support Chinese input?
SLW210 replied to xcn's topic in AutoCAD 2D Drafting, Object Properties & Interface
That's what I was also attempting, though I only have AutoCAD 2000i on my home computer for now. I'll try anther shot at it on the home computer when I get time. -
SLW210 replied to cadprops's topic in AutoCAD 3D Modelling & Rendering
I played with it for a few minutes, it needs better handling for .3mf files for me to have much use for it. It only opened a few and failed to open several, all can open with my Bambu Labs Slicer. The 10 MB limit is fairly low for 3D files, but for FREE, not too bad. -
Hi everyone, Taking a step back and reflecting on the feedback I've received from veteran developers here over the past few weeks, I realized something: in my excitement to share VedaCAD, I’ve used a lot of heavy SaaS buzzwords like "Zero-Trust architecture," "MDM," and "Cloud Orchestration." Sometimes, tech jargon can make a tool sound overly mysterious or complex. I want to take the mask off for a moment. At the end of the day, what exactly is VedaCAD under the hood? It is simply a deployment manager for your routines (.lsp, .fas, .vlx, .arx, .dll) and environment standards (.dwt, .ctb, .shx, etc.). There is no hidden black magic here. We don't change how AutoCAD draws lines, and we don't encrypt or modify your source code. Instead of forcing CAD Managers to manually email ZIP files, edit acad.pgp aliases across 50 computers, or fight with the fragile APPLOAD Startup Suite, I just used pure AutoLISP/ActiveX to streamline the delivery physics: You wrap your asset into a 6-character VCID (local file publish VCID). The client fetches the exact physical file and drops it into an isolated local sandbox folder on the user's C: drive. For scripts, it creates a demand-loading proxy in memory so CAD boots up instantly at 0% memory overhead. For standards (like fonts and plot styles), it natively injects the Support Paths directly into the CAD preferences. Need to push an update but the .DLL is locked by Windows? The background engine simply renames the running file to .bak and slides the new version in silently. VedaCAD doesn't aim to revolutionize what you draw. It just brings modern software package management to how your CAD tools are delivered. Simple, clean, and transparent. Just wanted to put that out there for anyone wondering what the engine actually does! -
multiple file selection dialog box using lisp & powershell
SLW210 replied to Paul Li's topic in AutoLISP, Visual LISP & DCL
I'll try to have a look at home tonight, I was busy and tired this weekend. -
Why does a 3D solid sometimes disappear when I rotate the view?
Have you ever rotated a 3D model and suddenly part of the solid seems to disappear? In many cases, the geometry is fine and the issue is related to the visual style, clipping, or view direction. When this happens, I first switch to Shaded with Edges and use 3DORBIT to inspect the model from different angles. I also check whether a clipping plane or unusual camera/view setting is affecting the display. It’s easy to think the solid is damaged when it’s actually just a viewing issue. Have you run into this before? What was causing it in your case? -
Hi Steven, That is definitely a very disciplined on-premise setup! Putting the explicit network path directly into the load call (e.g., (load "Z:/CAD_Standards/...")) is certainly much cleaner than relying on AutoCAD's native search paths to guess where a file lives. For a single office where everyone is hardwired to a local Gigabit LAN running plain-text LISP routines, it has been a lightweight way to maintain a central file. Where that setup typically runs into real-world friction usually comes down to two specific scenarios: 1. Laptops, Job Sites & VPN Latency: If an engineer opens their laptop at home or on a job site without connecting to the company VPN first, Z:\ doesn't exist. AutoCAD will noticeably hang trying to resolve that dead network path before throwing an error. Even over VPN, querying scripts across Windows SMB introduces noticeable command hesitation. 2. Windows SMB File Locks & Concurrent Read Collisions: Overwriting a shared .lsp on the fly sounds seamless, but over Windows SMB networks it frequently collides with OS-level OpLocks (Opportunistic Locking) and lingering file leases, resulting in "Sharing Violation: File is in use" errors. Even worse is the race condition: if an administrator saves a script while a drafter's on-demand macro triggers a read, AutoCAD can ingest a partially written file, throwing a fatal "; error: malformed list on input" and breaking their active command. And the moment a firm introduces compiled binaries (.fas, .vlx, .arx, .dll), Windows places a hard shared read-lock on the file the second anyone opens CAD—making live server updates during work hours completely impossible without forcing everyone to exit. In Part 2 of this series, I dive a bit deeper into how we use a local sandbox cache model to tackle these exact remote work and file-locking bottlenecks: For a strictly in-house, LAN-only team with plain LISPs, keeping it simple the way you do works if everyone is in the building. We're primarily addressing the distributed teams and compiled environments where those network drops, SMB conflicts, and file locks become daily headaches. At the end of the day, VedaCAD doesn't aim to revolutionize drawing functions or replace your team's beloved scripts—it's simply a deployment manager for your routines (.lsp, .fas, .vlx, .arx, .dll) and environment standards (.dwt, .ctb, .shx) to modernize delivery across changing fleets. Appreciate you chiming in with your team's workflow, Steven! And you're always welcome to test VedaCAD whenever you have time—I'd love to get your thoughts. -
Steven P started following [Part 1/6] The CAD Manager's Playbook: How to Elegantly Manage 100+ Custom Plugins
We just add the file path to the 'load' string - the files being saved on the company drive and not on a support path. We all access to the same file, not a local copy, any updates are applied to all when the file is saved. 1 line in the startup menu to load the on-demand LISP / index. Time honoured maybe but it works well and is well understood by the CAD teams. -
Dadgad started following Do you check the drawing units before starting work on a DWG?
Dadgad replied to indiancad's topic in AutoCAD Drawing Management & Output
Agreed, the -DWGUNITS command is quite comprehensive, and particularly when receiving drawings from a non-team member. When I want to use it, I expand my commandline history to display 5 or 6 lines, in one go, all the better to display the numerous options.
