  2. mhupp
    Hybrid parallel
    See if this works will tweek it tonight if something throws error. Modified version of my last code Ask user to select first and 2nd polyline Find mid points from each vertex of poly1 to poly 2 with vlax-curve-getClosestPointTo Adds those points to a dotted pair with the vertex number Creates a temp polyine with those points Find minpoints from each vertex of poly2 to poly one with vlax-curve-getClosestPointTo Processed the 2nd list of points using vlax-curve-getClosestPointTo to temp polyline Using that with vlax-curve-getParamatpoint will tell where on the tempoly if falls Sort polylist by the parma so they will be in order and removing the parama so only point data is left Delete temp polyline Create new mid polyline with all points in right order. Stuff that is doing the heavy lifting is vlax-curve-getClosestPoint and vlax-curve-getParamatpoint. this will work with polylines with arc's tho the mid point will only be lines. but everything iv seen you post they don't seem to have any arcs ;;----------------------------------------------------------------------------;; ;; POLY AVERAGE path between polylines, Finds the mid path (defun c:PA () (C:POLYAVG)) (defun c:POLYAVG (/ ent1 ent2 i ptv ptc par mid pts1 pts2 polylst tempoly) (setq ent1 (car (entsel "\nSelect first polyline: "))) (if (not (and ent1 (= (cdr (assoc 0 (entget ent1))) "LWPOLYLINE"))) (progn (princ "\nInvalid 1st selection.") (exit)) (setq ent1 (vlax-ename->vla-object ent1)) ) (setq ent2 (car (entsel "\nSelect 2nd polyline: "))) (if (not (and ent2 (= (cdr (assoc 0 (entget ent2))) "LWPOLYLINE"))) (progn (princ "\nInvalid first selection.") (exit)) (setq ent2 (vlax-ename->vla-object ent2)) ) (if (and ent1 ent2) (progn (setq pts1 '()) (setq i 0) (while (<= i (fix (vlax-curve-getEndParam ent1))) (setq ptv (vlax-curve-getPointAtParam ent1 i)) (setq ptc (vlax-curve-getClosestPointTo ent2 ptv)) (setq mid (mapcar '/ (mapcar '+ ptv ptc) '(2 2 2))) (setq pts1 (append pts1 (list mid))) (setq polylst (cons (cons mid i) polylst)) (setq i (1+ i)) ) (setq Flag (if (= (vla-get-Closed ent1) :vlax-true) 1 0)) ; Get closed status (entmake (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length pts1)) (cons 70 flag) ) (mapcar '(lambda (p) (cons 10 p)) pts1) ) ) (setq tempoly (entlast)) (setq pts2 '()) (setq i 0) (while (<= i (fix (vlax-curve-getEndParam ent2))) (setq ptv (vlax-curve-getPointAtParam ent2 i)) (setq ptc (vlax-curve-getClosestPointTo ent1 ptv)) (setq mid (mapcar '/ (mapcar '+ ptv ptc) '(2 2 2))) (setq pts2 (append pts2 (list mid))) (setq i (1+ i)) ) (foreach pt pts2 (setq ptv (vlax-curve-getClosestPointTo tempoly pt)) (setq Par (vlax-curve-getParamatpoint tempoly ptv)) (setq polylst (cons (cons pt par) polylst)) ) (setq polylst (mapcar 'car (vl-sort polylst '(lambda (a b) (< (cdr a) (cdr b)))))) (entdel tempoly) (entmake (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length polylst)) (cons 70 flag) ) (mapcar '(lambda (p) (cons 10 p)) polylst) ) ) (princ "\nNew midpoint polyline created.") ) (princ "\nSelection error.") ) (princ) )
  3. Hi GLAVCVS, can you help me? When creating a grid with Lisp, is it possible to change the text style? Specifically, change it from plain text to multiple text and add a 1.2 background mask.
  4. Today
  5. PGia
    Hybrid parallel
    I've attached it again below CPL.dwg
  6. PGia
    Hybrid parallel
    The overall view of the drawing looks like this
  7. mhupp
    Hybrid parallel
    https://www.cadtutor.net/forum/topic/98778-hybrid-parallel/page/2/#findComment-676816 The last code i posted works well on two open polylines. its just when they loop back on themselves that only checking the distance gets points get out of order. haven't had time to code but I think I have a solution creating a dotted pair list.
  8. GP_
    Hybrid parallel
    In the DWG files you posted, I can't find the polylines indicated in the images. I don't think that result was obtained with CPL. I'd like to run a test, so please attach the DWG file with the reference position in the images. Thanks
  9. Hey @Tamim I'v made a new lisp, so you have an ESP1.lsp (for the first option 1) and an ESP2R.lsp (for the last option/option 2) for the REVCLOUD. This is the codes: ; ********************************************************************** ; Functions : ESP1 (Evenly Spacing the Polylines) --> Option 1 ; Description : Evenly Spacing Polylines --> Option 1 ; Author : SAXLLE ; Date : October 29, 2025 ; ********************************************************************** (prompt "\nTo run a LISP type: ESP1 (Evenly Spacing the Polylines 1)") (princ) (defun c:ESP1 ( / myerr olderr old_osmode flag ss len lst i spacing side base_point inc ent dist_lst npt answ) (setq old_osmode (getvar 'osmode)) (defun myerr (errmsg) (setq *error* olderr) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg ".\nThe application has finished working...")) ) (setvar 'osmode old_osmode) (princ) ) (setq olderr *error* *error* myerr ) (setq flag T) (while (not (equal flag nil)) (setvar 'osmode old_osmode) (prompt "\nSelect Polylines:") (princ) (setq ss (ssget (list (cons 0 "*POLYLINE"))) len (sslength ss) lst (list) i 0 ) (repeat len (setq lst (cons (list (ssname ss i) (getpropertyvalue (ssname ss i) "Length")) lst) i (1+ i) ) ) (initget 1 "Left Right") (setq lst (vl-sort lst (function (lambda (a b) (< (cadr a) (cadr b))))) side (getkword "\nChoose the side? [Left/Right]") spacing (getreal "\nEnter the spacing value:") base_point (getpoint "\nPick the Base Point for spacing:\n") inc spacing i 0 ) (setvar 'osmode 0) (command-s "_UNDO" "begin") (while (< i (length lst)) (setq ent (car (nth i lst)) dist_lst (list) dist_lst (mapcar (function (lambda (x) (distance (car x) (cadr x)))) (mapcar 'list (setq pt_list (mapcar 'cdr (vl-remove-if-not (function (lambda (x) (= (car x) 10))) (entget (car (nth i lst)))))) (cdr pt_list))) ) (if (= side "Left") (progn (setq npt (list (- (car base_point) inc) (cadr base_point) (caddr base_point))) ;; to the Left, using "-" sign (command-s "_pline" npt (strcat "@" (rtos (car dist_lst) 2 2) "<90") (strcat "@" (rtos (- (cadr dist_lst) inc) 2 2) "<180") (strcat "@" (rtos (caddr dist_lst) 2 2) "<270") "") ) (progn (setq npt (list (+ (car base_point) inc) (cadr base_point) (caddr base_point))) ;; to the Right, using "+" sign (command-s "_pline" npt (strcat "@" (rtos (car dist_lst) 2 2) "<90") (strcat "@" (rtos (- (cadr dist_lst) inc) 2 2) "<0") (strcat "@" (rtos (caddr dist_lst) 2 2) "<270") "") ) ) (entdel (car (nth i lst))) (setq inc (+ inc spacing) i (1+ i) ) ) (command-s "_UNDO" "end") (initget 1 "Yes No Undo") (setq answ (getkword "\Do you want to continue? [Yes/No/Undo]")) (cond ((equal answ "No") (setvar 'osmode old_osmode) (setq flag nil) ) ((equal answ "Undo") (command-s "_UNDO" "") ) ) ) (prompt "\The polylines are evenly spaced!") (princ) ) ; ********************************************************************************** ; Functions : ESP2R (Evenly Spacing the Polylines 2 REVCLOUD) --> Option 2 ; Description : Evenly Spacing the Polylines 2 REVCLOUD --> Option 2 ; Author : SAXLLE ; Date : November 05, 2025 ; ********************************************************************************** (prompt "\nTo run a LISP type: ESP2R (Evenly Spacing the Polylines 2 REVCLOUD)") (princ) (defun c:ESP2R ( / old_osmode myerr olderr flag rev rev_ptlist ss lst lst_col i len sort_lst n val side spacing base_point inc ent_lst spt dist_lst ang_lst k answ) (setq old_osmode (getvar 'osmode)) (defun myerr (errmsg) (setq *error* olderr) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg ".\nThe application has finished working...")) ) (setvar 'osmode old_osmode) (princ) ) (setq olderr *error* *error* myerr ) (setq flag T) (while (not (equal flag nil)) (setvar 'osmode old_osmode) (setq rev (car (entsel "\nSelect the REVCLOUD:"))) (while (equal rev nil) (prompt "\nNothing was selected. Try again...") (setq rev (car (entsel "\nSelect the REVCLOUD:"))) ) (setq rev_ptlist (mapcar 'cdr (vl-remove-if-not (function (lambda (x) (= (car x) 10))) (entget rev))) ss (ssget "_F" rev_ptlist (list (cons 0 "*POLYLINE"))) lst (list) lst_col (list) i 0 ) (if (ssmemb rev ss) (progn (ssdel rev ss) (setq len (sslength ss)) ) ) (repeat len (setq lst (cons (list (ssname ss i) (getpropertyvalue (ssname ss i) "Length") (getpropertyvalue (ssname ss i) "Color")) lst) lst_col (cons (getpropertyvalue (ssname ss i) "Color") lst_col) i (1+ i) ) ) ;; sub-function to remove the double elements from the list (defun remove_doubles (lst) (if lst (cons (car lst) (remove_doubles (vl-remove (car lst) lst))) ) ) (setq lst_col (vl-sort (remove_doubles lst_col) (function (lambda (a b) (< (atoi a) (atoi b))))) sort_lst (list) n 0 ) (repeat (length lst_col) (setq val (nth n lst_col) sort_lst (cons (vl-sort (vl-remove-if-not (function (lambda (a) (equal val (cadr (cdr a))))) lst) (function (lambda (a b) (> (cadr a) (cadr b))))) sort_lst) n (1+ n) ) ) (setq sort_lst (cons (vl-remove (car (last sort_lst)) (last sort_lst)) sort_lst) sort_lst (vl-remove (last sort_lst) sort_lst) ) (initget 1 "Left Right") (setq side (getkword "\nChoose the side? [Left/Right]") spacing (getreal "\nEnter the spacing value:") base_point (getpoint "\nPick the Base Point for spacing:\n") inc spacing i 0 ) (setvar 'osmode 0) (command-s "_UNDO" "begin") (while (< i (length sort_lst)) (setq ent_lst (nth i sort_lst) n 0 ) (repeat (length ent_lst) (setq spt (vlax-curve-getStartPoint (car (nth n ent_lst)))) (if (not (equal (car base_point) (car spt) 5.0)) (progn (command-s "_reverse" (car (nth n ent_lst)) "") ) ) (setq dist_lst (list) ang_lst (list) dist_lst (mapcar (function (lambda (x) (distance (car x) (cadr x)))) (mapcar 'list (setq pt_list (mapcar 'cdr (vl-remove-if-not (function (lambda (x) (= (car x) 10))) (entget (car (nth n ent_lst)))))) (cdr pt_list))) ang_lst (mapcar (function (lambda (x) (angle (car x) (cadr x)))) (mapcar 'list (setq ang_list (mapcar 'cdr (vl-remove-if-not (function (lambda (x) (= (car x) 10))) (entget (car (nth n ent_lst)))))) (cdr ang_list))) dist_lst (subst (+ (nth 1 dist_lst) inc) (nth 1 dist_lst) dist_lst) k 0 ) (if (= side "Left") (progn (setq npt (list (- (car base_point) inc) (cadr base_point) (caddr base_point))) ;; to the Left, using "-" sign (setvar 'cecolor (caddr (nth n ent_lst))) (command "_pline") (while (= (getvar "CMDNAMES") "PLINE") (command npt) (repeat (length dist_lst) (command (strcat "@" (rtos (nth k dist_lst) 2 2) "<" (angtos (nth k ang_lst)))) (setq k (1+ k)) ) (command "") ) ) (progn (setq npt (list (+ (car base_point) inc) (cadr base_point) (caddr base_point))) ;; to the Right, using "+" sign (setvar 'cecolor (caddr (nth n ent_lst))) (command "_pline") (while (= (getvar "CMDNAMES") "PLINE") (command npt) (repeat (length dist_lst) (command (strcat "@" (rtos (nth k dist_lst) 2 2) "<" (angtos (nth k ang_lst)))) (setq k (1+ k)) ) (command "") ) ) ) (entdel (car (nth n ent_lst))) (setq inc (+ inc spacing) n (1+ n) ) ) (setq i (1+ i)) ) (command-s "_UNDO" "end") (initget 1 "Yes No Undo") (setq answ (getkword "\Do you want to continue? [Yes/No/Undo]")) (cond ((equal answ "No") (setvar 'osmode old_osmode) (setq flag nil) ) ((equal answ "Undo") (command-s "_UNDO" "") ) ) ) (setvar 'cecolor "256") ;; restore the color "ByLayer" (prompt "\The polylines are evenly spaced using Evenly Spacing the Polylines 2 - REVCLOUD!") (princ) ) This is the short video example how the ESP2R.lsp works. EvenlySpacingPolyline_V2.mp4 Best regards.
  10. PGia
    Hybrid parallel
    I already attached it in one of my two previous posts
  11. GP_
    Hybrid parallel
    Could you post the dwg?
  12. dexus
    Hybrid parallel
    Here is my first attempt at this problem. It creates offset lines and checks the intersections. The precision is dictated by the offsetdistance. The lower it is, the longer it takes to make the polyline and the more points it will have. But it will be more accurate. Afterwards I run this function on the resulting polyline to clean it up. ;| ; Center line - dexus ; https://www.cadtutor.net/forum/topic/98778-hybrid-parallel |; (defun c:testcl (/ ent1 lst offset offsetdistance pts r s1 s2 ss start te1 te2) (defun _polyline (pts) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 90 (length pts)) (cons 8 (getvar 'clayer)) (cons 70 0) ) (mapcar (function (lambda (x) (cons 10 x))) pts) ) ) ) (defun _side (pline pnt / cpt end target der) ; https://www.theswamp.org/index.php?topic=55685.msg610429#msg610429 (setq cpt (vlax-curve-getClosestPointTo pline pnt) end (vlax-curve-getEndParam pline) target (vlax-curve-getParamAtPoint pline cpt) der (if (and (equal target (fix target) 1e-8) (or (vlax-curve-isClosed pline) (and (not (equal (vlax-curve-getStartParam pline) target 1e-8)) (not (equal end target 1e-8))) ) ) (mapcar '- (polar cpt (angle '(0 0) (vlax-curve-getFirstDeriv pline (rem (+ target 1e-3) end))) 1.0) (polar cpt (angle (vlax-curve-getFirstDeriv pline (rem (+ (- target 1e-3) end) end)) '(0 0)) 1.0) ) (vlax-curve-getFirstDeriv pline target) ) ) (minusp (sin (- (angle cpt pnt) (angle '(0.0 0.0) der)))) ) ;; Intersections - Lee Mac ;; mod - [int] acextendoption enum of intersectwith method (defun LM:intersections ( ob1 ob2 mod / lst rtn ) (if (and (vlax-method-applicable-p ob1 'intersectwith) (vlax-method-applicable-p ob2 'intersectwith) (setq lst (vlax-invoke ob1 'intersectwith ob2 mod)) ) (repeat (/ (length lst) 3) (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn) lst (cdddr lst)) ) ) (reverse rtn) ) (defun getLength (ent) (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent)) ) (if (not (while (cond ((not (setq ss (ssget '((0 . "LWPOLYLINE"))))) (princ "\nNothing selected. Try again...\n") ) ((/= (sslength ss) 2) (princ "\nSelect 2 polylines! Try again...\n") ) ((and (setq ent1 (ssname ss 0)) (setq ent2 (ssname ss 1)) (setq ent1 (vlax-ename->vla-object ent1)) (setq ent2 (vlax-ename->vla-object ent2)) ) nil ; Stop loop ) ) ) ) (progn (setq s1 (_side ent1 (vlax-curve-getStartPoint ent2))) (setq s2 (_side ent2 (vlax-curve-getStartPoint ent1))) (setq maxlen (max (getLength ent1) (getLength ent2))) (setq offset 0.0) (setq offsetdistance (/ maxlen 1024.0)) (while (progn (setq offset (+ offset offsetdistance)) (setq te1 nil) (setq te2 nil) (setq r (cond ( (or ; Make offset (vl-catch-all-error-p (setq te1 (vl-catch-all-apply 'vlax-invoke (list ent1 'Offset (if s1 offset (- offset)))))) (vl-catch-all-error-p (setq te2 (vl-catch-all-apply 'vlax-invoke (list ent2 'Offset (if s2 offset (- offset)))))) ) (princ "\nOffset failed. ") nil ) ((setq lst (LM:intersections (car te1) (car te2) acExtendNone)) (setq len (getLength (car te1))) (setq lst (mapcar (function (lambda (pt) (list (/ (vlax-curve-getDistAtPoint (car te1) pt) len) pt))) lst)) (setq start t) (setq pts (append lst pts)) ) ((> offset maxlen) nil) ((not start) t) (start nil) ) ) (if te1 (mapcar 'vla-delete te1)) (if te2 (mapcar 'vla-delete te2)) r ) ) (if pts (_polyline (mapcar 'cadr (vl-sort pts (function (lambda (a b) (< (car a) (car b))))))) ) ) ) )
  13. Steven P
    Lisp to create bom with blocks
    8 years later....
  14. SLW210
    Hybrid parallel
    I already stated that in a few posts. All of them fail in certain situations. That's why people are still taking a shot at solving the issue. I have also already mentioned Civil/GIS programs can do this pretty well. QGIS (free/donation) has a plug-in to do this.
  15. yangchunlang
    the bom is stored in the “bom dic ”
  16. PGia
    Hybrid parallel
    Welcome back to big game hunting!
  17. PGia
    Hybrid parallel
    I was wrong. c:CPL of @GP_ is also inconsistent in some cases. CPL.dwg
  18. @Saxlle Based on this code, everything is working fine. But I need only a specific selection — the sample yellow rectangle area I mentioned earlier. Also, I need to add my idea for selecting the REVCLOUD area after the code runs. line shifting v2.dwg
  19. @BIGAL Thanks for the code
  20. Could you post a sample drawing of what you would use this on and what your looking for. Rather then picking points for the grid you could do a selection and run the bounding box (defun C:foo () (if (setq SS (ssget)) (BBOX) (command "_.RECTANG" LL UR) (prompt (strcat "El rectángulo mide: " (car L&W) " x " (cadr L&W))) ) (princ) ) ;;----------------------------------------------------------------------------;; ;; Length and Width of a Selection (defun BBox (/ ptslst) (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (vla-getboundingbox (vlax-ename->vla-object ent) 'minpt 'maxpt) (setq ptslst (cons (vlax-safearray->list minpt) ptslst) ptslst (cons (vlax-safearray->list maxpt) ptslst) ) ) (setq LL (apply 'mapcar (cons 'min ptslst)) UR (apply 'mapcar (cons 'max ptslst)) L&W (mapcar '- UR LL) ) (princ) )
  21. Yesterday
  22. Dear friend GLAVCVS, thank you so much for your reply. The routine worked perfectly. I'm very grateful for your help. Regards
  23. Hi Omar. Bienvenido Try this (defun strpto (aa / largo) (setq largo (strlen aa)) (cond ((< largo 4) aa) ((= largo 6) (strcat (substr aa 1 3) "." (substr aa 4 3))) ((= largo 7) (strcat (substr aa 1 1) "." (substr aa 2 3) "." (substr aa 5 3) ) ) (t aa) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; DatosLineas : obtiene los coeficientes necesarios para determinar las ;; rectas que definen el area a cuadricular. Las cuales son ;; de la forma : a*x + b*y = c ;; (Defun DatosLineas (p1 p2 p3 p4) (setq a1 (- (cadr p2) (cadr p1)) a2 (- (cadr p4) (cadr p2)) a3 (- (cadr p3) (cadr p4)) a4 (- (cadr p1) (cadr p3)) b1 (- (car p1) (car p2)) b2 (- (car p2) (car p4)) b3 (- (car p4) (car p3)) b4 (- (car p3) (car p1)) c1 (- (* (car p1) (cadr p2)) (* (car p2) (cadr p1))) c2 (- (* (car p2) (cadr p4)) (* (car p4) (cadr p2))) c3 (- (* (car p4) (cadr p3)) (* (car p3) (cadr p4))) c4 (- (* (car p3) (cadr p1)) (* (car p1) (cadr p3))) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Punto de la recta dada por a,b,c dada la cordenada Y ;; (Defun CalculaX (a b c y) (if (= 0.0 a) ; no hay interseccion nil (/ (- c (* b y)) a) ) ) (Defun IntersecX (/ l lista) (setq l () lista (list (CalculaX a1 b1 c1 startY) (CalculaX a2 b2 c2 startY) (CalculaX a3 b3 c3 startY) (CalculaX a4 b4 c4 startY) ) ) (while (/= lista nil) (setq x (car lista)) (if (and (/= x nil) (<= x maxX) (>= x minX)) (setq l (append l (list x))) ) (setq lista (cdr lista)) ) (list (min (car l) (cadr l)) (max (car l) (cadr l))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Interseccion dada la cordenada X ;; (Defun CalculaY (a b c x) (if (= 0.0 b) ; no hay interseccion nil (/ (- c (* a x)) b) ) ) (Defun IntersecY (/ l lista) (setq l () lista (list (CalculaY a1 b1 c1 startX) (CalculaY a2 b2 c2 startX) (CalculaY a3 b3 c3 startX) (CalculaY a4 b4 c4 startX) ) ) (while (/= lista nil) (setq y (car lista)) (if (and (/= y nil) (<= y maxY) (>= y minY)) (setq l (append l (list y))) ) (setq lista (cdr lista)) ) (list (min (car l) (cadr l)) (max (car l) (cadr l))) ) (defun dameEsquinas (e / le lp) (if (= (cdr (assoc 0 (setq le (entget e)))) "LWPOLYLINE") (foreach l le (if (= (car l) 10) (setq lp (cons (cdr l) lp)) ) ) ) (if lp (vl-sort lp '(lambda(a b) (< (car a) (car b))))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Programa principal ;; (Defun c:grilla (/ p1 p2 p3 p4 paux incx incy l h n maldato base alfa startX startY minX minY maxX maxY ) (setvar "CMDECHO" 0) (command "_.undo" "_begin") (command "osnap" "off") (command "units" "2" "3" "3" "4" "e" "n") (command "LAYER" "M" "TO-GRILLA" "C" "8" "" "") (command "style" "romand" "romand" 0 1 0 "N" "N" "N") (setq incrx 0) ;;; (setq p1 (getpoint "\nIngrese un vertice de la region ") ;;; p2 (getpoint p1 "\nIngrese el otro vertice ") ;;; ) ;;; (command "LINE" p1 p2 "") (if (not (setq e (car (entsel "\nSelecciona el marco para la grilla...")))) (exit) ) (setq l (dameEsquinas e) p1 (car l) p2 (cadr l) p3 (caddr l) l nil ) (if (> (cadr p1) (cadr p2)) ; siempre el p1 abajo (setq paux p1 p1 p2 p2 paux ) ) (setq p3 (getpoint p1 "\nIngrese punto para Ancho de la region ") l (distance p1 p3) ; calculo de puntos p3 y p4 , paralelos alfa (angle p1 p2) ; a p1 y p2 a distancia l alfa (+ (/ pi 2) alfa) ) (if (> (car p3) (car p1)) (setq alfa (+ pi alfa)) ) (if (= (car p1) (car p3)) (if (< (* (- (car p2) (car p1)) (- (cadr p3) (cadr p1))) 0.0) (setq alfa (+ pi alfa)) ) ) (setq p3 (list (+ (car p1) (* l (cos alfa))) (+ (cadr p1) (* l (sin alfa))) ) p4 (list (+ (car p2) (* l (cos alfa))) (+ (cadr p2) (* l (sin alfa))) ) ) (command "LINE" p1 p2 p4 p3 "C") ; marco exterior (if (< (cadr p3) (cadr p1)) ; punto1 siempre mas bajo (setq paux p1 p1 p3 p3 paux paux p2 p2 p4 p4 paux ) ) (setq minX (min (car p2) (car p3)) maxX (max (car p2) (car p3)) minY (cadr p1) maxY (cadr p4) l (- maxX minX) h (- maxY minY) malDato 1 ) (while (= malDato 1) (setq incx (getreal "\nIncremento malla (m) :")) (if (< (abs (/ l 3)) incrx) (print "\nIncremento muy grande") (setq malDato 0) ) ) (setq incy incx) (setq n (fix (/ minX incx)) ; posiciones donde comenzar startX (* (1+ n) incx) ; el cuadriculado n (fix (/ minY incy)) ; tanto en X como en Y startY (* (1+ n) incy) largoMax (max (distance p1 p3) ; el largo maximo de la region (distance p1 p4) ) ) (if (< minX 0) (setq startX (- startX incx)) ) (if (< minY 0) (setq startY (- startY incy)) ) (setq ff (getreal "\nIngrese Alto (mm) :")) (setq escala (getreal "\nEscala : ")) (setq alto (* (/ ff 1000) escala)) ; alto de los caracteres (setq angP1P3 (angle p1 p3) angP1P2 (angle p1 p2) angBorde (min (abs angP1P3) (abs angP1P2)) dh (min (/ incx 40.0) (/ incy 40.0)) x1 minX ; el caso en que no hay que rotar x2 maxX y1 minY y2 maxY ) (if (or (= (cadr p1) (cadr p2)) (= (car p1) (car p3)) (= (car p1) (car p2)) ) (setq revisar 0 dl (min (/ incx 30.0) (/ incy 30.0)) ) (setq revisar 1 dl (* (* alto (/ (cos angBorde) (sin angBorde))) 2) ) ) (DatosLineas p1 p2 p3 p4) (while (< startY maxY) (if (= revisar 1) (setq ptos (IntersecX) x1 (car ptos) x2 (cadr ptos) ) ) (setq coordY (rtos startY 2 0) coordY (strcat "N-" (strpto coordY)) ) (command "LINE" (list x1 startY) (list x2 startY) "") (cond ((> (- maxY startY) (* 2 alto)) (command "TEXT" (list (+ x1 dl) (+ startY dh)) alto 0 coordY ) (command "TEXT" "R" (list (- x2 dl) (+ startY dh)) alto 0 coordY ) ) ) (setq startY (+ startY incy)) ) (while (< startX maxX) (if (= revisar 1) (setq ptos (IntersecY) y1 (car ptos) y2 (cadr ptos) ) ) (setq coordX (rtos startX 2 0) coordX (strcat "E-" (strpto coordX)) ) (command "LINE" (list startX y1) (list startX y2) "") (cond ((> (- startX minX) (* 2 alto)) (command "TEXT" (list (- startX dh) (+ y1 dl)) alto 100 coordX ) (command "TEXT" "R" (list (- startX dh) (- y2 dl)) alto 100 coordX ) ) ) (setq startX (+ startX incx)) ) (if (> (distance p1 p3) (distance p1 p2)) (setq alfa angP1P3) (setq alfa angP1P2) ) (if (or (/= alfa pi) (/= alfa 0.0)) (setq alfarad (* -1 alfa) alfa (* -1 (/ (* 200 alfa) pi)) p4 (list (- (* (car p4) (cos alfarad)) (* (cadr p4) (sin alfarad))) (+ (* (car p4) (sin alfarad)) (* (cadr p4) (cos alfarad))) ) p1 (list (- (* (car p1) (cos alfarad)) (* (cadr p1) (sin alfarad))) (+ (* (car p1) (sin alfarad)) (* (cadr p1) (cos alfarad))) ) base (list 0.0 0.0) ; el origen ) ) (command "_.undo" "end") (command "_.undo" "auto" "on") ;; (command "units" "2" "3" "3" "4" "n" "y") ) The "command" calls in your code are designed for an English version of AutoCAD, and mine is in Spanish. For this reason, and due to lack of time, I haven't tested the code sufficiently. Try it yourself and then comment on the results.
  24. ReMark
    Girders run horizontally while columns are vertical. As regards all the horizontal and vertical lines it may be a result of having constructed surfaces instead of solids. I won't know for sure until I actually have a copy of your drawing. I'll send you a message with instructions.
  25. You're welcome David, happy to help.
  26. Vdietz
    Also.. are my columns supposed to have those vertical/horizontal lines?
  27. I tested your code. It does the "shutting" thing ! cool. Thanks Bigal ! I'll keep playing with it.
  28. Hello everyone. I need to improve a Lisp routine. I've had this routine for a few years; a coworker gave it to me. It's a Lisp routine for generating a coordinate grid from a selection of three points. I need to eliminate the insertion of three points (vertices). I want to be able to select a closed polyline with a single click and generate the grid. I want to keep the entire structure of the Lisp; I only want to change the vertex selection. I should mention that I have no experience programming AutoLISP. Please, if you can help me with this. (defun strpto (aa / largo) (setq largo (strlen aa)) (cond ((< largo 4) aa) ((= largo 6) (strcat (substr aa 1 3) "." (substr aa 4 3))) ((= largo 7) (strcat (substr aa 1 1) "." (substr aa 2 3) "." (substr aa 5 3))) (t aa) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; DatosLineas : obtiene los coeficientes necesarios para determinar las ;; rectas que definen el area a cuadricular. Las cuales son ;; de la forma : a*x + b*y = c ;; (Defun DatosLineas (p1 p2 p3 p4) (setq a1 (- (cadr p2)(cadr p1)) a2 (- (cadr p4)(cadr p2)) a3 (- (cadr p3)(cadr p4)) a4 (- (cadr p1)(cadr p3)) b1 (- (car p1)(car p2)) b2 (- (car p2)(car p4)) b3 (- (car p4)(car p3)) b4 (- (car p3)(car p1)) c1 (- (* (car p1)(cadr p2))(* (car p2)(cadr p1))) c2 (- (* (car p2)(cadr p4))(* (car p4)(cadr p2))) c3 (- (* (car p4)(cadr p3))(* (car p3)(cadr p4))) c4 (- (* (car p3)(cadr p1))(* (car p1)(cadr p3))) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Punto de la recta dada por a,b,c dada la cordenada Y ;; (Defun CalculaX (a b c y) (if (= 0.0 a) ; no hay interseccion nil (/ (- c (* b y)) a) ) ) (Defun IntersecX ( / l lista) (setq l () lista (list (CalculaX a1 b1 c1 startY) (CalculaX a2 b2 c2 startY) (CalculaX a3 b3 c3 startY) (CalculaX a4 b4 c4 startY) ) ) (while (/= lista nil) (setq x (car lista)) (if (and (/= x nil) (<= x maxX) (>= x minX)) (setq l (append l (list x))) ) (setq lista (cdr lista)) ) (list (min (car l)(cadr l)) (max (car l)(cadr l))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Interseccion dada la cordenada X ;; (Defun CalculaY (a b c x) (if (= 0.0 b) ; no hay interseccion nil (/ (- c (* a x)) b) ) ) (Defun IntersecY ( / l lista) (setq l () lista (list (CalculaY a1 b1 c1 startX) (CalculaY a2 b2 c2 startX) (CalculaY a3 b3 c3 startX) (CalculaY a4 b4 c4 startX) ) ) (while (/= lista nil) (setq y (car lista)) (if (and (/= y nil) (<= y maxY) (>= y minY)) (setq l (append l (list y))) ) (setq lista (cdr lista)) ) (list (min (car l)(cadr l)) (max (car l)(cadr l))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ;; Programa principal ;; (Defun c:grilla (/ p1 p2 p3 p4 paux incx incy l h n maldato base alfa startX startY minX minY maxX maxY) (setvar "CMDECHO" 0) (command "_.undo" "_begin") (command "osnap" "off") (command "units" "2" "3" "3" "4" "e" "n") (command "LAYER" "M" "TO-GRILLA" "C" "8" "" "") (command "style" "romand" "romand" 0 1 0 "N" "N" "N") (setq incrx 0) (setq p1 (getpoint "\nIngrese un vertice de la region ") p2 (getpoint p1 "\nIngrese el otro vertice ") ) (command "LINE" p1 p2 "") (if (> (cadr p1)(cadr p2)) ; siempre el p1 abajo (setq paux p1 p1 p2 p2 paux) ) (setq p3 (getpoint p1 "\nIngrese punto para Ancho de la region ") l (distance p1 p3) ; calculo de puntos p3 y p4 , paralelos alfa (angle p1 p2) ; a p1 y p2 a distancia l alfa (+ (/ pi 2) alfa) ) (if (> (car p3) (car p1)) (setq alfa (+ pi alfa)) ) (if (= (car p1) (car p3)) (if (< (* (- (car p2)(car p1)) (- (cadr p3)(cadr p1))) 0.0) (setq alfa (+ pi alfa)) ) ) (setq p3 (list (+ (car p1)(* l (cos alfa))) (+ (cadr p1)(* l (sin alfa)))) p4 (list (+ (car p2)(* l (cos alfa))) (+ (cadr p2)(* l (sin alfa)))) ) (command "LINE" p1 p2 p4 p3 "C") ; marco exterior (if (< (cadr p3) (cadr p1)) ; punto1 siempre mas bajo (setq paux p1 p1 p3 p3 paux paux p2 p2 p4 p4 paux) ) (setq minX (min (car p2) (car p3)) maxX (max (car p2) (car p3)) minY (cadr p1) maxY (cadr p4) l (- maxX minX) h (- maxY minY) malDato 1 ) (while (= malDato 1) (setq incx (getreal "\nIncremento malla (m) :")) (if (< (abs (/ l 3)) incrx) (print "\nIncremento muy grande") (setq malDato 0) ) ) (setq incy incx) (setq n (fix (/ minX incx)) ; posiciones donde comenzar startX (* (1+ n) incx) ; el cuadriculado n (fix (/ minY incy)) ; tanto en X como en Y startY (* (1+ n) incy) largoMax (max (distance p1 p3) ; el largo maximo de la region (distance p1 p4) ) ) (if (< minX 0) (setq startX (- startX incx)) ) (if (< minY 0) (setq startY (- startY incy)) ) (setq ff (getreal "\nIngrese Alto (mm) :")) (setq escala (getreal "\nEscala : ")) (setq alto (* (/ ff 1000) escala)) ; alto de los caracteres (setq angP1P3 (angle p1 p3) angP1P2 (angle p1 p2) angBorde (min (abs angP1P3)(abs angP1P2)) dh (min (/ incx 40.0)(/ incy 40.0)) x1 minX ; el caso en que no hay que rotar x2 maxX y1 minY y2 maxY ) (if (or (= (cadr p1)(cadr p2)) (= (car p1)(car p3)) (= (car p1)(car p2))) (setq revisar 0 dl (min (/ incx 30.0)(/ incy 30.0)) ) (setq revisar 1 dl (* (* alto (/ (cos angBorde)(sin angBorde))) 2) ) ) (DatosLineas p1 p2 p3 p4) (while (< startY maxY) (if (= revisar 1) (setq ptos (IntersecX) x1 (car ptos) x2 (cadr ptos) ) ) (setq coordY (rtos startY 2 0) coordY (strcat "N-" (strpto coordY)) ) (command "LINE" (list x1 startY) (list x2 startY) "") (cond ((> (- maxY startY) (* 2 alto)) (command "TEXT" (list (+ x1 dl) (+ startY dh)) alto 0 coordY) (command "TEXT" "R" (list (- x2 dl) (+ startY dh)) alto 0 coordY) ) ) (setq startY (+ startY incy)) ) (while (< startX maxX) (if (= revisar 1) (setq ptos (IntersecY) y1 (car ptos) y2 (cadr ptos) ) ) (setq coordX (rtos startX 2 0) coordX (strcat "E-" (strpto coordX)) ) (command "LINE" (list startX y1) (list startX y2) "") (cond ((> (- startX minX) (* 2 alto)) (command "TEXT" (list (- startX dh) (+ y1 dl)) alto 100 coordX) (command "TEXT" "R" (list (- startX dh) (- y2 dl)) alto 100 coordX) ) ) (setq startX (+ startX incx)) ) (if (> (distance p1 p3) (distance p1 p2)) (setq alfa angP1P3) (setq alfa angP1P2) ) (if (or (/= alfa pi) (/= alfa 0.0)) (setq alfarad (* -1 alfa) alfa (* -1 (/ (* 200 alfa) pi)) p4 (list (- (* (car p4)(cos alfarad)) (* (cadr p4) (sin alfarad))) (+ (* (car p4)(sin alfarad)) (* (cadr p4) (cos alfarad))) ) p1 (list (- (* (car p1)(cos alfarad)) (* (cadr p1)(sin alfarad))) (+ (* (car p1)(sin alfarad)) (* (cadr p1)(cos alfarad))) ) base (list 0.0 0.0) ; el origen ) ) (command "_.undo" "end") (command "_.undo" "auto" "on") ;; (command "units" "2" "3" "3" "4" "n" "y") )
