tombu started following Viewport Inset Generator
Lee's code allows the user to automatically generate polylines in modelspace representing the outline of a selected paperspace viewport, all viewports in the active paperspace layout, or all viewports found in all paperspace layouts. As long as the current layer is displayed in the Key Plan Viewport model space all those rectangles should display already. troggarf's code puts a copy of selected objects in paperspace.
tstaudigel joined the community
Okay gotcha. Thank you! I'm sure I'll be back soon with more questions I thought the type of steel girder PF called for changed. From what others have said it was W12x45's, now it's W1240's
Steven P started following Revit -> PDF -> Autocad
Didn't read this post earlier, but a word of caution, if the vendor won't send out vector files (PDFs, DWGs), there might be a reason for it - propriety information. But if you can't get them as vectors then as SLW210 says, got to do the work yourself converting raster graphics to proper lines - also be aware in any converted vectors, text drawn as lines and not text and exploded dashed lines, layer names will often be prefixed with PDF_ which I would also convert (I think Lee Mac has a LISP for that). Dimensions might also be off (intentionally?) to be fixed... Yeah, I love PDFs
neaga joined the community
Papet joined the community
Linli joined the community
Dynamic Block w/Rotation and Stretch
Calteq replied to Bill Tillman's topic in AutoCAD Drawing Management & Output
Here's another enjoy CallOut_Imp.dwg - Last week
@Danielm103 ""with mtext, you have to use a fixed width font" I agree, Monotxt.sHx I think was what I used. monotxt_.ttf EXTRA FONTS A-Z.txt Banner heading3.lsp
Even i have a real job. I just ask you to respect me and if it bothers you, don't respond. I don't want any controversy. Anyway, Happy New Year to everyone.
Most of the members here have real jobs as well and provide help as their own busy schedules allow. I do not believe anyone was being rude, just nudging you along to do a little work for yourself.
I have done something like this a couple of years ago :
I would like to help someone who, like me, will need it and post the list. (defun c:SetByBlockDeep (/ sel i ent obj name nameList) (vl-load-com) ;; --- Funzione Ricorsiva per processare le definizioni --- (defun process-block-def (blockName / bDef) (setq bDef (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blockName)) (vlax-for subEnt bDef ;; 1. Cambia Colore e Trasparenza dell'entità corrente (vla-put-color subEnt 0) ; 0 = ByBlock (vla-put-entitytransparency subEnt "ByBlock") ;; 2. Se l'entità è a sua volta un blocco (nidificato), processa la sua definizione (if (= (vla-get-ObjectName subEnt) "AcDbBlockReference") (progn (if (vlax-property-available-p subEnt 'EffectiveName) (process-block-def (vla-get-EffectiveName subEnt)) (process-block-def (vla-get-Name subEnt)) ) ) ) ) ) ;; ------------------------------------------------------- (princ "\nSeleziona blocchi (verranno processati tutti i livelli nidificati)...") (if (setq sel (ssget '((0 . "INSERT")))) (progn (setq nameList '()) (repeat (setq i (sslength sel)) (setq ent (ssname sel (setq i (1- i)))) (setq obj (vlax-ename->vla-object ent)) ;; Ottieni il nome (gestendo i dinamici) (if (vlax-property-available-p obj 'EffectiveName) (setq name (vla-get-EffectiveName obj)) (setq name (vla-get-Name obj)) ) ;; Se non abbiamo ancora processato questo blocco, avvia la ricorsione (if (not (member name nameList)) (progn (process-block-def name) (setq nameList (cons name nameList)) ) ) ) (vla-regen (vla-get-activedocument (vlax-get-acad-object)) acAllViewports) (princ (strcat "\nCompletato. " (itoa (length nameList)) " definizioni di blocco e relativi sotto-blocchi aggiornati.")) ) (princ "\nNessun blocco selezionato.") ) (princ) )
Thank you @Steven P, Cheers .
thanks for your gide
architectsarath joined the community
so this makes the color byblock and the transparency byblock in the blocks?
I'm working and I don't have time. Not everyone is as good at programming as you. Why did you respond so rudely? I think that without creating unnecessary controversy you could have not responded if the matter bothered you. Did you have a bad Christmas? However thanks
with mtext, you have to use a fixed width font import traceback from pyrx import Ap, Db, Ed import art @Ap.Command() def doit(): try: db = Db.curDb() mt = Db.MText() mt.setDatabaseDefaults() val = art.text2art("Sup Dude!", font="big", sep ="\\P") mt.setContents("{\\Fmonotxt8|c0;" + val + "}") db.addToModelspace(mt) except Exception as err: traceback.print_exception(err)
here's your big text import traceback from pyrx import Ap, Db, Ed ascii = {'A': ['▄████▄ ', '██ ██ ', '██████ ', '██ ██ ', '██ ██ '], 'B': ['█████ ', '██ ██ ', '█████ ', '██ ██ ', '█████ '], 'C': ['▄█████ ', '██ ', '██ ', '██ ', '▀█████ '], 'D': ['█████ ', '██ ██ ', '██ ██ ', '██ ██ ', '█████ '], 'E': ['▄█████ ', '██ ', '█████ ', '██ ', '▀█████ '], 'F': ['██████ ', '██ ', '████ ', '██ ', '██ '], 'G': ['▄█████ ', '██ ', '██ ███ ', '██ ██ ', '▀████▀ '], 'H': ['██ ██ ', '██ ██ ', '██████ ', '██ ██ ', '██ ██ '], 'I': ['██ ', '██ ', '██ ', '██ ', '██ '], 'J': [' ██ ', ' ██ ', ' ██ ', '██ ██ ', '██████ '], 'K': ['██ ██ ', '██ ██ ', '█████ ', '██ ██ ', '██ ██ '], 'L': ['██ ', '██ ', '██ ', '██ ', '█████ '], 'M': ['▄██████▄ ', '██ ██ ██ ', '██ ██ ██ ', '██ ██ ', '██ ██ '], 'N': ['██ ██ ', '███ ██ ', '██████ ', '██ ███ ', '██ ██ '], 'O': ['▄████▄ ', '██ ██ ', '██ ██ ', '██ ██ ', '▀████▀ '], 'P': ['█████ ', '██ ██ ', '█████ ', '██ ', '██ '], 'Q': [' ████ ', '██ ██ ', '██▀▄██ ', '██ ██ ', ' ███ █ '], 'R': ['█████ ', '██ ██ ', '█████ ', '██ ██ ', '██ ██ '], 'S': ['▄████ ', '██ ', '▀███▄ ', ' ██ ', '████▀ '], 'T': ['██████ ', ' ██ ', ' ██ ', ' ██ ', ' ██ '], 'U': ['██ ██ ', '██ ██ ', '██ ██ ', '██ ██ ', ' ████ '], 'V': ['██ ██ ', '██ ██ ', '██ ██ ', ' ██ ██ ', ' ███ '], 'W': ['██ █ ██ ', '██ █ ██ ', '██ █ ██ ', '▀█████▀ ', ' █ █ '], 'X': ['██ ██ ', '██ ██ ', ' ██ ', '██ ██ ', '██ ██ '], 'Y': ['██ ██ ', '██ ██ ', ' ████ ', ' ██ ', ' ██ '], 'Z': ['██████ ', ' ██ ', ' ██ ', '██ ', '██████ '], '0': [' ████ ', '██ ██ ', '██▀▄██ ', '██ ██ ', ' ████ '], '1': [' ██ ', '▄███ ', ' ██ ', ' ██ ', ' ██ '], '2': [' ████ ', '█ ██ ', ' ██ ', '██ ', '██████ '], '3': ['█████ ', ' ██ ', '█████ ', ' ██ ', '█████ '], '4': ['██ ██ ', '██ ██ ', '██████ ', ' ██ ', ' ██ '], '5': ['█████ ', '██ ', '████ ', ' ██ ', '████ '], '6': [' █████ ', '██ ', '█████ ', '██ ██ ', ' ████ '], '7': ['██████ ', ' ██ ', ' ██ ', ' ██ ', '██ '], '8': [' ████ ', '██ ██ ', ' ████ ', '██ ██ ', ' ████ '], '9': [' ████ ', '██ ██ ', ' █████ ', ' ██ ', ' ███ '], ':': [' ', '██ ', ' ', '██ ', ' '], '&': [' ███ ', '██ ██ ', ' █████ ██ ', '██ ███ ', ' █████ ██ '], ' ': [' ',' ',' ',' ',' '] } def _Big_text(text: str): lines = [""] * 5 text = text.upper() for char in text: pattern = ascii.get(char, [" ??? " ] * 5) for i in range(5): lines[i] += pattern[i] for line in lines: print(line) @Ap.Command() def doit1(): try: _Big_text("Sup coders") except Exception as err: traceback.print_exception(err)
There's also art https://pypi.org/project/art/ might take some work to get it in am mtext import traceback from pyrx import Ap, Db, Ed import art @Ap.Command() def doit1(): try: art.tprint("Sup coders") except Exception as err: traceback.print_exception(err)
Made a custom interface for logging measurements of parts so no cad. need to output errors or other prompts to the screen that can be seen from about 5 feet. wouldn't mind taking a look at the lisp also guessing its mtext?
rlx started following block byblock transparency
I have to agree with Bigal about to (new)bee or not to (new)bee but to give you an idea ; (setq val (getentitytransparency (car (entsel)))) (defun getentitytransparency ( ent ) (cond ((= 'vla-object (type ent))(vla-get-entitytransparency ent)) ((= 'ename (type ent))(getentitytransparency (vlax-ename->vla-object ent))))) ; (< lower-limit test-number upper-limit) ; (putentitytransparency (car (entsel)) "ByBlock") (putentitytransparency (car (entsel)) 100) (defun putentitytransparency (e v / i o) (cond ((null v)(setq v "ByLayer"))((and (numberp v)(< 0 v 90))(setq v (itoa (fix v)))) ((and (= (type v) 'STR) (distof v) (>= 0 (setq i (fix (distof v))) 90))(setq v (itoa i))) ((and (= (type v) 'STR) (member (strcase v t)'("bylayer" "byblock"))) v)(t (setq v "0"))) (if (setq o (e->o e))(vla-put-entitytransparency o v)))
"Not familiar with lisp" but you have 662 posts time to start learning and experimenting.
@mhupp do you want a lisp version of that ? It works same way uses "*". I think it was 1990.s used it as header in lisp programs.
Can you modify the code please ? I am not familiar with lisp. Only want tò setbyblock block .color: setbyblock Transparency: byblock
Steven P started following block byblock transparency and Happy New Year 2026
He is only jealous that it hasn't got above freezing here today, new years day BBQ? Pah! Having said that, a great animation and happy new year to all.
Holidays... CAD is off, but if it is like layer transparency then you might need to look at extended entity definitions, I think Lee Mac had something somewhere for layers that might apply - check his website or search on this forum. Could always double check, set a block to a transparency, I tend to use 12.3456 because that number is easy to spot, and do an (entget(car(entsel))) to the block and see if you can spot an part of the definition with 12.3456.. and that is what to change
That does not come into play until you start drawing the required elevation, section and details. I don't see anything that appears to have changed from previous years.
mhupp started following Python with CMS IntelliCAD 14.1
@Danielm103 I have Gotten into Python haven't used it for CAD yet. This will output to the terminal when you really need to see something. ascii = {'A': ['▄████▄ ', '██ ██ ', '██████ ', '██ ██ ', '██ ██ '], 'B': ['█████ ', '██ ██ ', '█████ ', '██ ██ ', '█████ '], 'C': ['▄█████ ', '██ ', '██ ', '██ ', '▀█████ '], 'D': ['█████ ', '██ ██ ', '██ ██ ', '██ ██ ', '█████ '], 'E': ['▄█████ ', '██ ', '█████ ', '██ ', '▀█████ '], 'F': ['██████ ', '██ ', '████ ', '██ ', '██ '], 'G': ['▄█████ ', '██ ', '██ ███ ', '██ ██ ', '▀████▀ '], 'H': ['██ ██ ', '██ ██ ', '██████ ', '██ ██ ', '██ ██ '], 'I': ['██ ', '██ ', '██ ', '██ ', '██ '], 'J': [' ██ ', ' ██ ', ' ██ ', '██ ██ ', '██████ '], 'K': ['██ ██ ', '██ ██ ', '█████ ', '██ ██ ', '██ ██ '], 'L': ['██ ', '██ ', '██ ', '██ ', '█████ '], 'M': ['▄██████▄ ', '██ ██ ██ ', '██ ██ ██ ', '██ ██ ', '██ ██ '], 'N': ['██ ██ ', '███ ██ ', '██████ ', '██ ███ ', '██ ██ '], 'O': ['▄████▄ ', '██ ██ ', '██ ██ ', '██ ██ ', '▀████▀ '], 'P': ['█████ ', '██ ██ ', '█████ ', '██ ', '██ '], 'Q': [' ████ ', '██ ██ ', '██▀▄██ ', '██ ██ ', ' ███ █ '], 'R': ['█████ ', '██ ██ ', '█████ ', '██ ██ ', '██ ██ '], 'S': ['▄████ ', '██ ', '▀███▄ ', ' ██ ', '████▀ '], 'T': ['██████ ', ' ██ ', ' ██ ', ' ██ ', ' ██ '], 'U': ['██ ██ ', '██ ██ ', '██ ██ ', '██ ██ ', ' ████ '], 'V': ['██ ██ ', '██ ██ ', '██ ██ ', ' ██ ██ ', ' ███ '], 'W': ['██ █ ██ ', '██ █ ██ ', '██ █ ██ ', '▀█████▀ ', ' █ █ '], 'X': ['██ ██ ', '██ ██ ', ' ██ ', '██ ██ ', '██ ██ '], 'Y': ['██ ██ ', '██ ██ ', ' ████ ', ' ██ ', ' ██ '], 'Z': ['██████ ', ' ██ ', ' ██ ', '██ ', '██████ '], '0': [' ████ ', '██ ██ ', '██▀▄██ ', '██ ██ ', ' ████ '], '1': [' ██ ', '▄███ ', ' ██ ', ' ██ ', ' ██ '], '2': [' ████ ', '█ ██ ', ' ██ ', '██ ', '██████ '], '3': ['█████ ', ' ██ ', '█████ ', ' ██ ', '█████ '], '4': ['██ ██ ', '██ ██ ', '██████ ', ' ██ ', ' ██ '], '5': ['█████ ', '██ ', '████ ', ' ██ ', '████ '], '6': [' █████ ', '██ ', '█████ ', '██ ██ ', ' ████ '], '7': ['██████ ', ' ██ ', ' ██ ', ' ██ ', '██ '], '8': [' ████ ', '██ ██ ', ' ████ ', '██ ██ ', ' ████ '], '9': [' ████ ', '██ ██ ', ' █████ ', ' ██ ', ' ███ '], ':': [' ', '██ ', ' ', '██ ', ' '], '&': [' ███ ', '██ ██ ', ' █████ ██ ', '██ ███ ', ' █████ ██ '], ' ': [' ',' ',' ',' ',' '] } def _Big_text(text: str): lines = [""] * 5 text = text.upper() for char in text: pattern = ascii.get(char, [" ??? " ] * 5) for i in range(5): lines[i] += pattern[i] for line in lines: print(line) inpt = input("Enter a string: ") _Big_text(inpt)
