Dynamic block - Lookup table for visibility states - not working
Calteq replied to sketch11's topic in AutoCAD Drawing Management & Output
Hi Try the attached block copy and paste it into your drawing cheers WSDynBlkImp.dwg - Today
Eshwar374927 joined the community
mhupp started following Logic Issue: CENTERLINE Command Redefined with Layer Change
mhupp replied to Clint's topic in AutoLISP, Visual LISP & DCL
Don't write lisp command that use the same names or variables as default commands. That said looks like the default centerline command only outputs to layer 0. so you would need to change it to your layer. and pause pause to let you pick the lines. (command "_.centerline" pause pause) (if (setq e (entlast)) (entmod (subst (cons 8 "CENTERLINES") ; new layer name (assoc 8 (entget e)) ; old layer (entget e) ) ) ) - Yesterday
How to Change Dimension in AutoCAD: Tuesday Tips With Frank
In the previous Tuesday Tips, I talked about some of the more important settings to pay attention to when creating your dimension styles. In today’s post, I’ll be talking about various methods of editing existing dimensions and how to change dimension in AutoCAD. OK, let’s set the scene. You defined the location of the dimension incorrectly, or you need to alter its appearance or placement. By far, the easiest thing to do is to use the dimension object’s editing grips. In the animation below, you’ll see how easy it is to select the dimension, make one of the definition points hot and place it into a new position. After that, I hover over a dimension line grip. You’ll see a small popup menu display where you can use the dimension as the start for a continue or baseline dimension, or you can even flip the arrow! In this case, I use the grip to pull the dimension up into the room above. Finally, hovering on the grip of the text string, will again display a popup menu with various options. Here, I choose Move with Leader to re-locate the text and draw a leader. If I had just wanted to move the text string, I would use the grip much like the prior two edits. None of that is very hard, and it’s a very efficient way to make geometric edits to your dimensions. Text Overrides With Special Characters Back to Dim Style settings for a moment. A style definition will let you put the dimension text above the dimension line, or below, but not both. How can you overcome this? The answer lies in the Text Override property of the dimension object. Below, you see a typical example of doing this. I’ve got a number of these 5’-4” dimensions and I want to add TYP below the line. Select the dimension object, and from the Properties palette, scroll down to the Text panel. At the bottom, you’ll first see the measurement in gray, so you can’t edit it (more on that in a minute). Below that is Text override. This is the field that you’ll want to edit There are two parts to the special characters you’re going to use. AutoCAD will interpret <> as the dimensioned measurement, the \X as a line break, and TYP as the text to place under the dimension line. By the way, the X here must be capitalized. Please Don’t Do the Following I just said that the Measurement property is grayed out and can’t be changed via the Properties palette. That’s great. But it can still be done. And, it’s as easy as double clicking on the text string, and typing in whatever you want. Below, I’ve done just that. The 5’-4” measurement has changed, but instead of editing the geometry and/or making sure the definition points are accurately place, the lazy drafter just edits the text and moves on. Here’s the worst part. You won’t know they’ve done it. It looks right, so you just assume that it is. I actually worked with a person who did this. Don’t be that person. Trust But Verify There’s an old Russian proverb that says, “Trust but verify.” To fix overridden dimension strings, type DIMREASSOC in either the Dynamic Input Box or the Command Line. You’ll be prompted to select objects. At this point, select an area, or just type in ALL since the command filters out anything that’s not a dimension. In other words, don’t take extra time to carefully select only dimensions – DIMREASSOC doesn’t care. Note: There is also a command called DIMREASSOCIATE – fully spelled out. It does something entirely different, so please be aware. If there are any dimensions that have overridden text, they will be immediately highlighted for you, as shown below. Here, I find that four of the 3’ dimensions are wrong. Now comes the easy part. Just hit Enter to end object selection, and Boom! All the overridden dimensions now read accurately. There you go, dear readers. Dimension settings and editing in two parts. Next time, I’ll be presenting some of the more important things you need to pay attention to with your CAD standards, and maybe even some ways to manage them. More Tuesday Tips Check out our whole Tuesday Tips series for ideas on how to make AutoCAD work for you. The post How to Change Dimension in AutoCAD: Tuesday Tips With Frank appeared first on AutoCAD Blog. View the full article -
Clint started following Logic Issue: CENTERLINE Command Redefined with Layer Change
Clint posted a topic in AutoLISP, Visual LISP & DCL
Can someone review the code and pick out the error in logic? The BLADE IDE in BricsCAD shows no syntax errors: The code runs well. The defined layer for the centerline is not activating when the command is run (nor returning to the older/previous layer) There is obviously something out of order in the code logic and order. Leaning on AI to learning programming is not a valid shortcut for study and experience! Back to the books for me! Thanks! ;;; CENTERLINE.lsp - Custom CENTERLINE assigning it to the CENTERLINE layer ;;; Author: CEH Assisted by AI ;;; Created on: 2025-12-16 ;;; Last edited: 2025-12-16 ;;; Description: ;;; BricsCAD CENTERLINE command redefined: ;;; Creates centerlines on layer CENTERLINE with CENTER2 linetype, ByLayer color, and ~0.008 inch lineweight ;;; ;;; ------------------------- Program Start ------------------------- ;;; (defun c:CENTERLINE (/ oldlayer oldltype oldlw laydata) ;; Save current settings (setq oldlayer (getvar 'clayer) oldltype (getvar 'celtype) oldlw (getvar 'celweight)) ;; Ensure CENTERLINE layer exists (if (not (tblsearch "LAYER" "CENTERLINE")) (progn ;; Load CENTER2 linetype if not already loaded ;; Tries acad.lin (imperial) first, then acadiso.lin (metric) (cond ((not (tblsearch "LTYPE" "CENTER2")) (command "._-linetype" "_load" "CENTER2" "acad.lin" "") ) ((not (tblsearch "LTYPE" "CENTER2")) (command "._-linetype" "_load" "CENTER2" "acadiso.lin" "") ) ) ;; Create the layer: CENTER2 linetype, ByLayer color, ByLayer lineweight initially (command "._-layer" "_make" "CENTERLINE" "_ltype" "CENTER2" "" "_color" "bylayer" "" "_lweight" "bylayer" "") ) ;; If layer exists but linetype might not be set (progn (command "._-layer" "_set" "CENTERLINE" "_ltype" "CENTER2" "CENTERLINE" "") ) ) ;; Set current layer to CENTERLINE (setvar 'clayer "CENTERLINE") ;; Set current linetype and lineweight to ByLayer (setvar 'celtype "BYLAYER") (setvar 'celweight -1) ; -1 = ByLayer ;; Set layer lineweight to exactly 0.008 inches (converted to internal 0.01 mm units) ;; 0.008 in = 0.2032 mm → 20.32 → integer 2032 (in hundredths of mm? Wait, no: ;; DXF code 370 stores lineweight in hundredths of mm (0.01 mm units), always mm. (setq laydata (entget (tblobjname "LAYER" "CENTERLINE"))) (setq laydata (subst (cons 370 20) (assoc 370 laydata) laydata)) ; 20 = 0.20 mm ≈ 0.00787 in (very close to 0.008 in) (entmod laydata) ;; Run the original CENTERLINE command (command "._centerline") ;; Restore previous settings (optional) (setvar 'clayer oldlayer) (setvar 'celtype oldltype) (setvar 'celweight oldlw) (princ) ) (princ "\nCENTERLINE command redefined: creates centerlines on layer CENTERLINE with CENTER2 linetype, ByLayer color, and ~0.008 inch lineweight.") ((princ "\nType CENTERLINE to run.")) (princ) -
Stretch to a point
CyberAngel replied to Discus84's topic in AutoCAD 2D Drafting, Object Properties & Interface
One simple way is to select the first point (A), use Ctrl-RightClick to open the temporary snap menu, pick From, choose point B, and enter the offset. It's a little tricky the first few times you do it, because you have to get the order of the inputs correct. By the way, this works for any grip selection, not just the stretch command. When you finish this task, go over the other options on that menu, you'll find several that should help you in your daily routine. If this doesn't solve your issue, please provide more information. -
Hi, I'd like to stretch the lower frame from point A to be an exact amount from point B. Is there a way to "acquire" the second point within the stretch command but only as reference? Thanks!
quick xyz coordinates text placed from selected points
CivilTechSource replied to pavanetc's topic in AutoLISP, Visual LISP & DCL
Just use a point and insert Field in Mtext and format it how you want. When copying both point and text it will keep the new copied items linked. Regen to update the coordinates. -
mosa1293 joined the community
Tsuky replied to pavanetc's topic in AutoLISP, Visual LISP & DCL
You can also use fields with selection of points? (defun make_field (ent / pt obj) (setq pt (trans (cdr (assoc 10 (entget ent))) 1 0)) (mapcar '(lambda (lx) (apply '(lambda (ins_point value_field att_point txt_height dwg_dir name_layer txt_rot / nw_obj) (setq nw_obj (vla-addMtext Space (vlax-3d-point (trans ins_point 1 0)) 0.0 (strcat "{\\f@Arial Unicode MS|b0|i0|c0|p34;\\Q15;" "%<\\AcObjProp.16.2 Object(%<\\_ObjId " (itoa (vla-get-ObjectID (vlax-ename->vla-object ent))) value_field "}" ) ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'Layer 'Rotation) (list att_point txt_height dwg_dir ins_point name_layer txt_rot) ) ) lx ) ) (list (list (mapcar '+ (trans pt 1 0) (list (getvar "TEXTSIZE") (+ (* (getvar "TEXTSIZE") 1.25) (getvar "TEXTSIZE")) 0.0)) ">%).Coordinates \\f \"%lu2%pt1%pr3%ps[X:,]\">%" 4 (getvar "TEXTSIZE") 5 "Id-XY" rtx ) (list (mapcar '+ (trans pt 1 0) (list (getvar "TEXTSIZE") 0.0 0.0)) ">%).Coordinates \\f \"%lu2%pt2%pr3%ps[Y:,]\">%" 4 (getvar "TEXTSIZE") 5 "Id-XY" rtx ) (list (mapcar '- (trans pt 1 0) (list (- (getvar "TEXTSIZE")) (+ (* (getvar "TEXTSIZE") 1.25) (getvar "TEXTSIZE")) 0.0)) ">%).Coordinates \\f \"%lu2%pt4%pr3%ps[Z:,]\">%" 4 (getvar "TEXTSIZE") 5 "Id-Z" rtx ) ) ) ) (defun c:point-xyz_field ( / htx rtx AcDoc Space ncol ss n) (initget 6) (setq htx (getdist (getvar "VIEWCTR") (strcat "\nSpecify the height of the field <" (rtos (getvar "TEXTSIZE")) ">: "))) (if htx (setvar "TEXTSIZE" htx)) (if (not (setq rtx (getorient (getvar "VIEWCTR") "\nSpecify the orientation of the field <0.0>: "))) (setq rtx 0.0)) (vl-load-com) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ncol '(96 174) ) (foreach n '("Id-XY" "Id-Z") (cond ((null (tblsearch "LAYER" n)) (vlax-put (vla-add (vla-get-layers AcDoc) n) 'color (car ncol)) ) ) (setq ncol (cdr ncol)) ) (while (null (setq ss (ssget '((0 . "POINT")))))) (repeat (setq n (sslength ss)) (make_field (ssname ss (setq n (1- n)))) ) (prin1) ) -
Small dot appears near MTEXT and cannot be deleted
CHAKRADHAR replied to CHAKRADHAR's topic in AutoCAD 2D Drafting, Object Properties & Interface
Thanks for letting me know. I’ve noted it. -
SLW210 replied to CHAKRADHAR's topic in AutoCAD 2D Drafting, Object Properties & Interface
No, I'm not giving out my email, nor should anybody else. Just simply provide a new draw with a MText with the problem, you can change the wording as well. It may be something a STRIP FORMATING LISP would fix or maybe go into the MText properties and remove the formatting manually. Anything else and I would need the .dwg. -
fuccaro replied to CHAKRADHAR's topic in AutoCAD 2D Drafting, Object Properties & Interface
Just a word of warning: I would not post my e-mail address in a public post... -
Viewport Inset Generator
@BIGAL So in principal I agree with your approach draw rectangles along the selected viewports, send to model space and then select the key plan to bring them back to paperspace. The problem I faced I stumbled across is that you can not define which viewport to CHspace without the user selecting the viewports. So my idea of the optimal workflow/lisp would look something like this: 1. Select Key Plan Viewport 2. Select Insert Viewports 3. Draw Rectangle on all Inset viewports 4. Send Rectangles to ModelSpace of each Inset viewport (So they are at the right scale). 5. Bring all rectangles to PaperSpace through the Key Plan Viewport. -
EnM4st3r started following quick xyz coordinates text placed from selected points
EnM4st3r replied to pavanetc's topic in AutoLISP, Visual LISP & DCL
like this? (defun c:XYText (/ pt str box) (while (setq pt (getpoint "\nPick point for coordinate text: ")) (setq str (strcat "X=" (rtos (car pt) 2 4) "\nY=" (rtos (cadr pt) 2 4) "\nZ=" (rtos (caddr pt) 2 4))) (vla-addmtext (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point pt) 0 str) ) (princ) ) -
pavanetc replied to pavanetc's topic in AutoLISP, Visual LISP & DCL
(defun C:CPP (/ PNT1 P1X P1Y STDY DY COORD PTXT) (setq PNT1 (getpoint "\nPick coordinate point: ")) (setq P1X (car pnt1)) ;x coord (setq P1Y (cadr pnt1)) ;y coord (setq P1Z (caddr pnt1)) ;z coord (setq STDX (rtos P1X 2 3)) (setq STDY (rtos P1Y 2 3)) (setq STDZ (rtos P1Z 2 3)) (setq COORD (strcat "E" STDX) COORD1(strcat "N" STDY) COORD2(strcat "EL" STDZ)) (setq PTXT (getpoint PNT1 "\nPick text location: ")) (command "LEADER" PNT1 PTXT "" COORD COORD1 COORD2 "" "" "") (princ)) ; end -
this is someone did which is existing code, could you please modify as I need in CAD X Y Z SAMPLE.dwg -
CAN U GIVE YOUR EMAIL ADDRESS -
Can you post a .dwg with this MText? -
SLW210 replied to pavanetc's topic in AutoLISP, Visual LISP & DCL
All points in the drawing, select points, etc.? Can you post a sample .dwg with before and after? -
pavanetc posted a topic in AutoLISP, Visual LISP & DCL
looking a lisp quick xyz coordinates text placed from selected points I need x= y= z= not like x, y, z -
pavanetc joined the community
jordan7688 joined the community
I looked for this on various websit es including youtube and solved it using to clear explanation here! Knowing that the Bing map data streams from the Autodesk 360 cloud (and isn't saved in the DWG) is the key piece of info that solves the mystery of why it disappears for others.
CHAKRADHAR started following Small dot appears near MTEXT and cannot be deleted
CHAKRADHAR posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I am using ZWCAD 2026. A small dot appears near an MTEXT, but I did not create it. When I select the dot, the MTEXT is selected. The dot cannot be deleted, and it is not visible inside the MTEXT editor. Text style used: SIMPLEX (SHX font). This drawing was copied/imported from another file. What is this dot and how can I remove it permanently? Thanks in advance. -
CHAKRADHAR joined the community
Lisp exportar todas las presentaciones
ivaj replied to mikarts's topic in AutoLISP, Visual LISP & DCL
Buenos días, el autocad que tengo es el 2026, pertenece a mi empresa. Los planos que realizo son isométricas de tubería y cuando tengo que hacer una línea, pueden que salgan entre 4 hasta 35 planos de isométricas. Todos los planos los tengo en el modelo y me creo una presentación de cada isométrica, "Selecciono todas las presentaciones", ejecuto "publicar las presentaciones seleccionadas" y me crean PDF independientes, ejemplo: - Fichero de autocad "Tomo.dwg" y presentaciones 001, 002, 003, etc. La rutina me lee "TOMO" y las presentaciones, una a una. Y me crea TOMO-(con un guion y seguidamente el nombre de las presentaciones) TOMO-001, TOMO-002, TOMO-003, etc. Pero a la rutina del principio que funciona muy bien, no separa el nombre de fichero dwg y la presentación. Muchas gracia por ayudarme "bidal", pero no se donde colocar lo que has mandado, siento ser tan torpe. -
Yes. I know. I already mentioned that this problem could arise on some long segments during turns. I didn't want to delay posting again to fix this. But I already have an idea of how to solve it. I'll post the solution as soon as I can.
L8in joined the community
Like @dan20047 I make rectangs and then make a layout matching that rectang. Where I worked our title block was fixed, so the viewport in a layout was based on the matching rectang at a scale. The rectangs can be rotated and the viewport will be Twisted to match. You can pick a Viewport and get its info then draw a rectang that matches in paperspace then do a simple CHSPACE, all done. Look at these 3 values. Just take 1/2 the 40 and 41 can work out the corners. (defun c:vp2model ( / vp cp d1 d2 p1 p2 lay) (command "pspace") (setq vp (entget (car (entsel "\nPick the viewport ")))) (setq cp (assoc 10 vp)) (setq cp (list (cadr cp)(caddr cp))) (setq lay (cdr (assoc 8 vp))) (setq d1 (/ (cdr (assoc 40 vp)) 2.0)) (setq d2 (/ (cdr (assoc 41 vp)) 2.0)) (setq p1 (mapcar '+ cp (list (- d1) (- d2) 0.0))) (setq p2 (mapcar '+ cp (list d1 d2 0.0))) (setvar 'clayer lay) (command "Rectang" p1 p2) (command "chspace" (entlast) "" ) (command "pspace") (princ) ) A question will the layouts have more than one viewport as you need to identify which viewport has been selected.
If you don't want to go down the OBDX method you can use a simple script to edit multiple dwgs. There are various ways to get a dwg name list, I use Word to make a script like this. Start with a list of dwgs, you can Replace ^p with a new line, ^p(load "chgvis") same for close the ^p is end of line. Another can get lisp to write the script file. Use (vl-directory-files "D:\\acadtemp" "*.dwg" 1) to get a list of dwg names. Open dwg1 (load "chgvis") Close Y Open dwg2 (load "chgvis") Close Y Open dwg3 (load "chgvis") Close Y Open dwg4 (load "chgvis") Close Y Yes 1st step is get lisp code to work. Use Lee-mac dynamic block lisp to change visibility, Don't forget must use SSGET '((0 . "INSERT")) but must then look for "Effectivename" of the block objects as Dynamic blocks usually have a name like "*U12". Lastly I use an old fashioned DOS command as it can get a list of dwg names including sub directories. Have a go if get stuck post again.
