Creating river center-lines with WhiteboxTools
How can I write the code for a batch fillet plugin for images like this?
SLW210 replied to amook147's topic in AutoLISP, Visual LISP & DCL
Here is the one from Kent Cooper, though it seems suspicious you would be blocked from the Autodesk Forums. This is the one that asks for the radius and will accept 0 radius. ;| FilletMultiplePolylines.lsp [command name: FMP] Asks for desired Fillet radius, offering default of prior value if present, otherwise regular Fillet's value, as default. Asks for selection of Polylines, and Fillets all possible corners at specified radius. Restores regular Fillet's radius setting, but stores setting from this command separately, for default on subsequent use. Works on LightWeight and "heavy" 2D Polylines except those that are Fit- or Spline-curved. Accepts selection of those, and of 3D Polylines, but does not process them. |; ;;; ;;; By Kent Cooper ;;; ;;; Found here https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/10151411#M130041 (defun C:FMP ; = Fillet Multiple Polylines (/ *error* doc filr plss n pl) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg)) ); if (setvar 'filletrad filr); reset (vla-endundomark doc) (princ) ); defun - *error* (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (setq filr (getvar 'filletrad)); save current setting (initget 4); no negative (setq *fmpr* ; global variable (cond ( (getdist (strcat "\nRadius for Filleting all Polyline corners <" (rtos (cond (*fmpr*) ((getvar 'filletrad)))) ; prior value as default if present; if not, regular Fillet radius ">: " ); strcat ); getdist ); User-input condition (*fmpr*); prior value if present on Enter ((getvar 'filletrad)); regular Fillet radius if no prior value on Enter ); cond ); setvar (setvar 'filletrad *fmpr*) (if (setq plss (ssget "_:L" '((0 . "*POLYLINE")))) (repeat (setq n (sslength plss)) (setq pl (ssname plss (setq n (1- n)))) (if (= (logand (cdr (assoc 70 (entget pl))) 30) 0); not 3D, fit- or spline-curved (command "_.fillet" "_polyline" pl); then ); if ); repeat ); if (setvar 'filletrad filr) (vla-endundomark doc) (princ) ); defun (vl-load-com) (prompt "\nType FMP to Fillet Multiple Polylines.") -
forcing AutoCAD to look for “AcFields.fdc” in a network location?
halfcracked replied to halfcracked's topic in The CUI, Hatches, Linetypes, Scripts & Macros
it is a pain. that's why I'm trying to find a way to make ACAD use the file in a different location. much like I do for printer configuration files. -
GLAVCVS replied to amook147's topic in AutoLISP, Visual LISP & DCL
Phew! I just copied and pasted from the link you requested. For some reason, the final parenthesis got lost. But I see that the code suggested here is already more complete. Deprecated! - Today
tombu replied to halfcracked's topic in The CUI, Hatches, Linetypes, Scripts & Macros
Sound like the hard way having to update it for every user every time a new version is installed that could be overwritten by an AutoCAD update. I use a Slightly modified version of older version of Lee's code https://www.lee-mac.com/areastofield.html you can find at https://www.cadtutor.net/forum/topic/71208-area-lisp-help/#elControls_571948_menu that labels with selected area or lengths units included. I added the scaled versions of "sqft" for labeling X-Section areas which usually have exaggerated vertical scale for an engineer who wanted it. Tremendous amount of functions in a custom CUI with all code in a network Trusted Support folder. -
Nikon replied to amook147's topic in AutoLISP, Visual LISP & DCL
The code can connect several polylines with a radius of 0. I understood that FILLETRAD must be set beforehand. Or do this: (defun C:FMP0 ; = Fillet Multiple Polylines (/ plss n) (setvar "FILLETRAD" 0) (if (setq plss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ); repeat ); if (princ) ); defun Or a different code for different radii, and you can also use 0. (defun C:FMP01 (/ rad plss n) (setq rad (getreal " Enter the fillet radius (you can use 0): ")) (setvar "FILLETRAD" rad) (if (setq plss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ) ) (princ) ) -
This code should perform the pairing (without specifying the radius?). The code doesn't work: unknown command. The parenthesis after (princ) is lost. +) -
(defun C:FMP (/ plss n) (if (setq plss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ); repeat ); if (princ) I guess this is it -
Can anyone attach a lisp from this link? -
halfcracked started following forcing AutoCAD to look for “AcFields.fdc” in a network location?
I use the fields to calculate acreage not a strait forward option in standard fields that come with out of the box. I was able to add "Acres" to the pulldown list through the AcFields file and quickly force the conversion from SI to acres. -
john madsen started following Converting menues
Hi I´m a little bit rusti in AC. I resently worked in AC12 but have just bougt AC22. I have loaded my old homemade menufiles from AC12 to AC22, but i can´t get my pulldown-bars etc. up on the screen. How do i do that...? John
Dynamic block - align to viewport
CyberAngel replied to D_P's topic in AutoCAD Drawing Management & Output
Let me get this straight. To show some type of pole, you have three types of markers in four sizes. You have a label that applies to all poles, but it needs to appear horizontal in every viewport. One of the markers should also appear with the same alignment (I assume that doesn't matter for the other two since they're circles). You'd rather use a dynamic block because you can easily change the marker size--but then the marker and text don't align. You could use a point style, but you still can't align the marker and text, and you'd have to change the style to change the pole size. My first thought is to add a polar parameter to the block and apply it to the marker and text. Then you can rotate them as desired. Not sure how that interacts with the visibility parameter, that is, you may have to add a new polar parameter for each visibility state. You could use a separate point style and label style for each pole, and you'd have the option to rotate them, but that sounds more clunky. On the other hand, you'd have the option to select the sizes independently (based on point style), which might help with takeoffs. -
EmeraldSynth started following Penn Foster Drafting With AutoCAD Structural Drafting Project Sheets 1-7
Unfortunately, I couldn't check, the link doesn't open for me... -
I'd also like to know what other, more specialized programs can do about this. I'll be following any news on this closely.
Hopefully I will have free time after this week to play with this topic again.
SLW210 replied to D_P's topic in AutoCAD Drawing Management & Output
I moved your thread to the AutoCAD Drawing Management & Output Forum. Can you post a drawing? -
Did you bother to check the link I posted? The first one in my link from Kent Cooper will do fillet>R>0 if that is the value of FILLETRAD. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/6473166#M130031 The FilletMultiplePolylines will work with 0 radius. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/10151411#M130041 -
willliam joined the community
all sorted. my 2022 version was set up with regen when changing layouts but my 2026 wasn't set the same meaning i couldn't see the changes when i switched to modelspace without a manual regen
strange.. im running same routines on 2022 as i do on 2026. i shall do a bit more investigating. cheers for the info
QQQ joined the community
D_P started following Dynamic block - align to viewport
Hi there, I've created a dynamic block (multiple visibility states) but require it to 'align to viewport'. I have this option when turning MTEXT annotative, and when I first created the block before adding the visibility states, however once the visibility states are added the option to 'align to viewport will not work. The block is to display a power pole. Regardless of the orientation of the window, I require the 'X' on the last option to always be an 'X', not a '+' when the UCS is changed to a 45 degree angle. I have read this is not possible due to the block being dynamic, I have also looked at creating cogo point label styles however, I require all 3 of the above scaled for 0.3, 0.35, 0.4, 0.45m power poles which I'd rather have one block/multiple visibility states. Apologies if what I have said does not make sense I am still very early into my civil3d career. Appreciate any assistance. Cheers,
showing zones as a default in the properties of spaces
nod684 replied to ahmedabdallah's topic in Revit MEP
Architects use Rooms while MEP guys use Spaces. You can define your own space. You can also use Space Separator to define the space you need. -
D_P joined the community
mhupp started following viewport outline
This isn't feature rich as Lee's and uses command quite a bit. never got around to updating it. VP2M.lsp
Lee Mac has a similar code. The FMP_R and fpoly codes perform conjugations with a given radius. Only in these codes it is impossible to set the value radius = 0. Is there a code for interfacing with a radius of 0? There's also the marko_ribar code, but I couldn't verify it. When loading, the message appears: Unknown command. -
amndfley365 joined the community
Is there a way to Crop images inserted into a dwg?
SLW210 replied to Rosco's topic in AutoCAD General
Not sure about newer AutoCAD LT, but as per the OP, they had no access to IMAGECLIP. Lot's of methods to do this, but, I would use a Viewport or an image editing software if IMAGECLIP wasn't available, sometimes I use more than one method, depending on the look I need. You could always make the image a vector file if not too complicated and you have the correct tools, I sometimes get sent images that need to be vector files. -
Much like Elvis, the OP seems to have left the building. In case there is a dramatic return, here is a LISP that should work, though unclear what "code" they want or or if this is for an actual plug-in. Solved: Fillet multiple polyline all at once by lisp - Autodesk Community I didn't look at Kent Cooper's version to prompt for a radius, but used the original and added something simple to it. I am sure Kent Cooper's is better. (defun C:FMP_R (/ plss n rad) (setq rad (getdist "\nEnter fillet radius: ")) (if (and rad (> rad 0.0)) (progn (command "_.fillet" "_radius" rad) (if (setq plss (ssget "_:L" '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ) ) ) ) (princ) )
