Another way around the task is to use a lisp to do all the calculations and the object from 1st principles. ie not a Dynamic block. Something like this. You could have a first dcl with images so choose shape, then 2nd dcl pops up with the enter values. Let me know if you want something, post a sample dwg for layers etc.
kimmhanson32 joined the community
Chris Wirsch joined the community
Good day all, I have a dynamic block that I use to stretch to the right size for fabrication of panels. I am trying to get the block to automatically add holes as the panel is stretched. The holes need to be spaced equally at maximum 16" o.c. I have set up all my formulas, etc. and in Block editor it looks good. The array is showing properly, etc. The problem is that when I stretch the panel, the holes and formulas do not automatically update. In fact when I stretch the panel, the Constraint dimension that I use for my calculations does not stretch with the panel. It moves the entire constraint dimension. Therefore my formulas are not updating and the array is not working as required. I have tried numerous attempts to get this dclinear dimensions to stretch with the panel to no avail. Maybe there is another way to do this? Ideally when i stretch the panel, the holes should update as per my formulas. Link to AutoCAD Forum with pictures. https://forums.autodesk.com/t5/announcements-and-meet-greet/dynamic-block-with-array-of-rivet-holes-problem/td-p/14007890 Any help is appreciated.
wiewwie joined the community
Betato joined the community
I've added (c:lw_orth-2) and (c:lw_orth-grread-2), but IMHO, version 1 is better... Here is link... Regards, M.R.
If I'm looking at the same subsystem, when you edit a part drawing, the Toolspace includes Model Parameters (under Modeling) and Size Parameters (under the part). When you right click on a part in the Size Parameters, you get an "Edit..." option. That opens an "Edit Part Sizes" window, which is a table. Pull down the box on the toolbar (the default is Values) and pick Parameter Configuration instead. That gives you a different table with more rows. One of those rows is Units. Check the units for your part and see if they match your drawing. If that doesn't take care of your issue, please give us more information.
help with extracting text from one dimension....
I use the dimensions in the drawing in mm. I need a copy of the dimensional text in m for further calculations. Therefore, the @ronjonp code is quite suitable for me. -
copy & paste to original location multiple times
Tharwat replied to ctrlaltdel's topic in AutoLISP, Visual LISP & DCL
You are most welcome. -
AHMED RAFEEQ joined the community
AmilaSG joined the community
Converting mm dimension to m? My preference would be to leave the dimension to measure properly and adjust the scale in the properties to 0.001, then you can just copy the text and everything is consistent. -
mertcanosaka joined the community
mohdomar replied to ctrlaltdel's topic in AutoLISP, Visual LISP & DCL
thank you tharwat -
Yep same for if you do or dont like the Ribbon. Ribbonclose and Ribbon.
MENUBAR = 1
The path found has to travel on edges not on points. If your graph does not have edges on the diagonal of the nodes it cannot find that path. ymg -
I must apologize for forgetting to reply to your comment. Please forgive me for this. Welcome to the forum. Yes, that's right. In the case of that drawing, the code doesn't return the shortest path. Perhaps it's a limitation of A* for drawings like this. I think @ymg3 is the most qualified to answer this. -
Douaa joined the community
when i design a custom manhole in part builder , i have a problem that when i do swap part to place the new manhole that i created instead of an old one in my network (my model), the new manhole seems quite big its even bigger than my model so what do you think i should do ? my manhole is in mm and all the part in my system is in mm but when i measure it in the system its in m .
Would you mind sharing the solution?
It will probably be next week before I can check out QGIS solutions. From the user's perspective, even if off in a few spots, several of these LISP solutions here are faster (maybe more accurate), even including time to adjust manually than most of the other solutions for GIS, though I am no speed demon in GIS. Just look at all of the prep work on the Whitebox Tools, though if I had all of those branches and islands as well as a few oxbows, thin connections, etc. like the example, that would be the way to go as far as I can tell, I do believe it also works on vector, IIRC. It looks like part of that is free as a Python toolset, I'll try to read up some more on that. As I mentioned long ago in this thread, my daughter's co-workers are using AutoCAD to create the centerlines and manually adjusting if needed even though they have ArcGIS, though they may not have the extra tools that have the easy centerline tools. From what I looked up, ArcGIS made some tools a higher priced tier. Maybe asking a few questions on some GIS forums might yield more information.
Thanks for your responce. I found a solution and it´salle working....
That's interesting. Although the starting points seem to be different: pixels vs. vectors. In any case, it would be interesting to test the geometric robustness of that central line. That is, what it can return in some of the more challenging vector examples we've tested here.
forcing AutoCAD to look for “AcFields.fdc” in a network location?
SLW210 replied to halfcracked's topic in The CUI, Hatches, Linetypes, Scripts & Macros
It could be done, but seems a hassle and inefficient. AutoCAD decides where to look based on a mix of profiles, support paths, and environment variables from what I can determine. It is "intentionally" made to not be used on a network to be shared. You will have to use any number of "tricks" to get it to work that way, even then you may have file locks, slow performance, etc.. Your best bet is to just update on each computer when needed. -
Dynamic block - align to viewport
SLW210 replied to D_P's topic in AutoCAD Drawing Management & Output
That drawing only opened in the block editor and only had one visibility in it. You might try to use an annotative text style and ensure the "Match text orientation to layout" option is checked. Should be a similar character. -
You haven't mentioned what you have tried so far. If you haven't already, MENUBAR to 1, then go to Tools>Hover over Toolbars, should be a dropdown to select the toolbar group you need. If you already have a toolbar docked, just Right-Click an empty area.
I´m using cuix-files and i hav tried to unload and after that to reload the menufile. The file do load as it suppose to, but i can´t get the toolbars, pulldown etc. up on the screen....?
mhupp started following Colors of the top menu bars
mhupp replied to FELIXJMELO's topic in AutoCAD 2D Drafting, Object Properties & Interface
looks like your in dark mode. type COLORTHEME and set it to 0 this will put you in light mode. -
BIGAL replied to halfcracked's topic in The CUI, Hatches, Linetypes, Scripts & Macros
Just a maybe (setq who (getenv "username")) hopefully that matches the XXXX, can use a vl copy file or a shell to copy the modified file. For the correct user. For me I use a Install lisp when I do a new CAD install/update so that file copy could be part of it. -
BIGAL replied to FELIXJMELO's topic in AutoCAD 2D Drafting, Object Properties & Interface
I think you meant "Is it possible" probably a English thing. Some settings to do with the screen colors are buried away in the Registry. But you have to understand what the values mean, its not just a simple "light grey". I think there is a Dark or Light setting, that is about as much help as I can offer, a google should reveal more. -
Where your menu's, MNU or CUI/CUIX files ? Either way you use menuload or menuunload to remove sometimes have to do that before reloading. If your custom menu is inside a "ACAD.mnu" then you may have a problem. Can you please confirm.
