Help: Section Line for Architecture Drawings
mhy3sx replied to mhy3sx's topic in AutoLISP, Visual LISP & DCL
Hi BIGAL , PARAMETRICSTRETCH not exist in ZWCAD Thanks - Today
Exit the command with the right mouse button in one click
I need to edit the text and change the color. -
Hello, With the help of AI I am trying to make a .lsp script that insert specific block on every vertex of a polyline and orient two "arrows" to the previous and next vertex. I try with different AI models and always I end up with error in Autocad (I use Autocad 2022) Error: "ActiveX Server returned the error: unknown name: "DYNAMICBLOCKPROPERTIES". AI say that the block is not really a dynamic block, which I dont get, how block can be not really dynamic. I am attaching both block and .lsp script. I hope someone will give me some advice what is wrong with the block or with .lsp script. BlockInsert.lsp block.dwg
Do you only need to change the color or also edit the text? -
Nikon posted a topic in AutoLISP, Visual LISP & DCL
Good day everyone! After editing the text, its color changes, but to exit the command, you need to press RMB or enter or Esc twice. Is it possible to complete the execution of the command with the right mouse button in one click? ;; If the current color is not equal to 136, then change it to 136. ;; If the current color is 136, then change it to 230. (defun c:TEcolor136_230 (/ error oldcmdecho sel e type obj res currentColor) (vl-load-com) (defun error (msg) (if oldcmdecho (setvar "CMDECHO" oldcmdecho)) (if (and msg (not (wcmatch (strcase msg) "BREAK,CANCEL,EXIT"))) (princ (strcat " Error: " msg)) ) (princ) ) (setq oldcmdecho (getvar "CMDECHO")) (setvar "CMDECHO" 0) (while (setq sel (entsel " Select TEXT/MTEXT to edit (Enter — exit): ")) (setq e (car sel) type (strcase (cdr (assoc 0 (entget e)))) ) (if (wcmatch type "TEXT,MTEXT") (progn (setq obj (vlax-ename->vla-object e)) ;; get the current color (setq currentColor (vl-catch-all-apply 'vlax-get-property (list obj 'Color)) ) ;; Error handling on receipt (if (vl-catch-all-error-p currentColor) (setq currentColor 0) ) ;; Opening the text editor (setq res (vl-catch-all-apply 'vl-cmdf (list "_.textedit" e)) ) (if (vl-catch-all-error-p res) (princ " Editing canceled.") ;; After editing, we change the color (progn (if (= currentColor 136) ;; If it's 136, change it to 230. (if (vl-catch-all-error-p (vl-catch-all-apply 'vlax-put-property (list obj 'Color 230)) ) (princ " Couldn't change color to 230.") (princ " The color has been changed to 230.") ) ) (if (/= currentColor 136) ;; If it's not 136, change it to 136. (if (vl-catch-all-error-p (vl-catch-all-apply 'vlax-put-property (list obj 'Color 136)) ) (princ " Couldn't change the color to 136.") (princ " The color has been changed to 136.") ) ) (princ " Editing completed.") ) ) ) (princ " It's not an object TEXT/MTEXT.") ) ) (setvar "CMDECHO" oldcmdecho) (princ) ) -
BIGAL replied to mhy3sx's topic in AutoLISP, Visual LISP & DCL
There is parametrics in Bricscad, similar to dynamic block in Acad. Here is a sample think of the two circles as the section arrow details. Can add attributes etc. I just made a block with gap set to 100, then did Bedit and typed PARAMETRICSTRETCH, follow prompts just select one side. Can add a lisp pick 2 points for alignment and reset length. section.dwg - Yesterday
Another ; make table example ; By Alan H 2018 ; updated for post https://www.cadtutor.net/forum/topic/98664-tables/ Aug 2025 (defun c:maketableXY (/ colwidth numcolumns numrows objtable rowheight sp vgad vgao vgms) (vl-load-com) (setvar "osmode" 0) (setq bm (ssget '((0 . "LINE")))) (if bm (progn (setq num (sslength bm)) (setq i 0) (setq point_list '()) (repeat num (setq obj (ssname bm i)) ; Get entity name (setq db (entget obj)) ; Get entity data (setq p1 (cdr (assoc 10 db))) ; Start point (setq p2 (cdr (assoc 11 db))) ; End point (setq midpt (mapcar '/ (mapcar '+ p1 p2) '(2 2 2))) (setq point_list (cons (list p1 p2 midpt) point_list)) (setq i (1+ i)) ) ) ) (setq sp (vlax-3d-point (getpoint "pick a point for table"))) (Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))) (setq numrows (+ (length point_list))) (setq numcolumns 4) (setq rowheight 9) (setq colwidth 70) (setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "Line details") (vla-settext objtable 1 0 "Sr No.") (vla-settext objtable 1 1 "Start point") (vla-settext objtable 1 2 "End point") (vla-settext objtable 1 3 "Mid point") (vla-setcolumnwidth objtable 0 21) (vla-setalignment objTable acTitleRow acMiddleCenter) (vla-setalignment objTable acHeaderRow acMiddleCenter) (vla-setalignment objTable acDataRow acMiddleCenter) (vla-setrowheight objTable acDataRow 9.0) (setq row 2 x 1) (foreach val point_list (vla-settext objtable row 0 (rtos x 2 0)) (setq val1 (strcat (rtos (car (nth 0 val)) 2 3) "," (rtos (cadr (nth 0 val)) 2 3))) (vla-settext objtable row 1 val1) (setq val2 (strcat (rtos (car (nth 1 val)) 2 3) "," (rtos (cadr (nth 1 val)) 2 3))) (vla-settext objtable row 2 val2) (setq val3 (strcat (rtos (car (nth 2 val)) 2 3) "," (rtos (cadr (nth 2 val)) 2 3))) (vla-settext objtable row 3 val3) (setq row (1+ row) x (1+ x)) ) (princ) )
For designing waterfalls or streams, SketchUp is a very user-friendly option for 3D modeling and conceptual designs. Blender is free and allows realistic 3D water simulations, though it has a steeper learning curve. Realtime Landscaping Architect is also beginner-friendly and specifically tailored for landscaping with waterfalls and streams. For precise 2D layouts, AutoCAD or AutoCAD Civil 3D is a good choice.
Danielm103 started following Performance helps for Large-Scale Z-Flattening (Z0) AutoLISP Routine?
see if this drawing is correct. I used project from pyrx import Ap, Ax, Db, Ge # register command @Ap.Command() def doit(): try: db = Db.curDb() ms = db.modelSpace(Db.OpenMode.kForWrite) plane = Ge.Plane(Ge.Point3d.kOrigin,Ge.Vector3d.kZAxis) for id in ms.objectIds(Db.Curve.desc()): dbc = Db.Curve(id) gec = dbc.getAcGeCurve() geproj = gec.project(plane,Ge.Vector3d.kZAxis) if not geproj.isKindOf(Ge.kCurve3d): continue geprojCurve = Ge.Curve3d.cast(geproj) dbproj = Db.Core.convertGelibCurveToAcDbCurve(geprojCurve) ms.appendAcDbEntity(dbproj) dbproj.setColorIndex(1) except Exception as err: print(err) arc2.dwg -
Perhaps this ? (vl-load-com) (defun c:lines2cell ( / js AcDoc Space nw_style oldim oldlay ins_pt_cell h_t w_c lst_id-seg lst_pt n obj dxf_10 dxf_11 mid_pt nb nw_obj ename_cell n_row n_column) (princ "\nSelect points.") (while (null (setq js (ssget '((0 . "LINE"))))) (princ "\nSelection empty, or is not a lines!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (cond ((null (tblsearch "LAYER" "Table-Lines")) (vla-add (vla-get-layers AcDoc) "Table-Lines") ) ) (cond ((null (tblsearch "STYLE" "Text-Cell")) (setq nw_style (vla-add (vla-get-textstyles AcDoc) "Text-Cell")) (mapcar '(lambda (pr val) (vlax-put nw_style pr val) ) (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag) (list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 (/ (* 15.0 pi) 180) 1.0 0.0) ) (command "_.ddunits" (while (not (zerop (getvar "cmdactive"))) (command pause) ) ) ) ) (setq oldim (getvar "dimzin") oldlay (getvar "clayer") ) (setvar "dimzin" 0) (setvar "clayer" "Table-Lines") (initget 9) (setq ins_pt_cell (getpoint "\nLeft-Up insert point of table: ")) (initget 6) (setq h_t (getdist ins_pt_cell (strcat "\nHigth text <" (rtos (getvar "textsize")) ">: "))) (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t)) (initget 7) (setq w_c (getdist ins_pt_cell "\nWidth of cells: ")) (setq lst_id-seg '() lst_pt '() nb 0 ) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) dxf_10 (cdr (assoc 10 (entget obj))) dxf_11 (cdr (assoc 11 (entget obj))) mid_pt (mapcar '* (mapcar '+ dxf_10 dxf_11) '(0.5 0.5 0.5)) lst_pt (cons (list dxf_10 dxf_11 mid_pt) lst_pt) nb (1+ nb) lst_id-seg (cons nb lst_id-seg) ) ) (mapcar '(lambda (p tx) (setq nw_obj (vla-addMtext Space (vlax-3d-point p) 0.0 tx ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation) (list 5 h_t 5 p "Text-Cell" "Table-Lines" 0.0) ) ) (mapcar 'caddr lst_pt) lst_id-seg ) (vla-addTable Space (vlax-3d-point ins_pt_cell) (+ 2 nb) 10 (+ h_t (* h_t 0.25)) w_c) (setq ename_cell (vlax-ename->vla-object (entlast)) n_row (1+ nb) n_column -1) (vla-SetCellValue ename_cell 0 0 (vlax-make-variant (strcat "Summary of " (itoa (sslength js)) " LINES") 8 ) ) (vla-SetCellTextStyle ename_cell 0 0 "Text-Cell") (vla-SetCellTextHeight ename_cell 0 0 (vlax-make-variant h_t 5)) (vla-SetCellAlignment ename_cell 0 0 5) (foreach n (mapcar'list (append lst_id-seg '("N°")) (append (mapcar 'rtos (mapcar 'caar lst_pt)) '("Start X")) (append (mapcar 'rtos (mapcar 'cadar lst_pt)) '("Start Y")) (append (mapcar 'rtos (mapcar 'caddar lst_pt)) '("Start Z")) (append (mapcar 'rtos (mapcar 'caadr lst_pt)) '("End X")) (append (mapcar 'rtos (mapcar 'cadadr lst_pt)) '("End Y")) (append (mapcar 'rtos (mapcar 'caddar (mapcar 'cdr lst_pt))) '("End Z")) (append (mapcar 'rtos (mapcar 'caaddr lst_pt)) '("Middle X")) (append (mapcar 'rtos (mapcar 'cadadr (mapcar 'cdr lst_pt))) '("Middle Y")) (append (mapcar 'rtos (mapcar 'caddar (mapcar 'cddr lst_pt))) '("Middle Z")) ) (mapcar '(lambda (el) (vla-SetCellValue ename_cell n_row (setq n_column (1+ n_column)) (vlax-make-variant el 8)) (vla-SetCellTextStyle ename_cell n_row n_column "Text-Cell") (vla-SetCellTextHeight ename_cell n_row n_column (vlax-make-variant h_t 5)) (if (eq n_row 1) (vla-SetCellAlignment ename_cell n_row n_column 5) (vla-SetCellAlignment ename_cell n_row n_column 6) ) ) n ) (setq n_row (1- n_row) n_column -1) ) (setvar "dimzin" oldim) (setvar "clayer" oldlay) (prin1) )
(defun c:ctf (/ bm num i obj db p1 p2 midpt point_list table pt) (setvar "osmode" 0) ; Select all lines (setq bm (ssget '((0 . "LINE")))) (if bm (progn ; Get number of lines (setq num (sslength bm)) (setq i 0) (setq point_list '()) ; Initialize list to store points ; Loop through each line (repeat num (setq obj (ssname bm i)) ; Get entity name (setq db (entget obj)) ; Get entity data (setq p1 (cdr (assoc 10 db))) ; Start point (setq p2 (cdr (assoc 11 db))) ; End point ; Calculate midpoint (setq midpt (mapcar '/ (mapcar '+ p1 p2) '(2 2 2))) ; Store points in list (setq point_list (cons (list p1 p2 midpt) point_list)) (setq i (1+ i)) ) (setq pt (getpoint "\nSpecify table insertion point: ")) (if pt (progn ; Create table (command "._TABLE" 4 3 pt) ; Set header (command "._TABLEdit" "A1" "TEXT" "sr.no") (command "._TABLEdit" "B1" "TEXT" "Start Point") (command "._TABLEdit" "c1" "TEXT" "endPoint") (command "._TABLEdit" "D1" "TEXT" "mid Point") ; extract data of the lines and filling in cells of table ; point_list data stored ;autocad ver 2025 ) (princ "\nNo insertion point specified.") ) ) (princ "\nNo lines selected.") ) (setvar "osmode" 511) (princ) ) I need to help data automatically fill in the cells of the table table.dwg
mhupp replied to mhy3sx's topic in AutoLISP, Visual LISP & DCL
They are using ZWCAD. and dynamic blocks are a propriety feature of AutoDesk. (or at least were not fully functional when i was using BricsCAD might be a feature now) -
Not sure why you are asking me about units, you could try making the variable names "Aunits". with double quotes, works in Bricscad, else you can use a foreach loop but I would use car & cadr in the loop, (list (list "aunits" 2)("list 'auprec"4)(......)) Just a suggestion for labelling, the character "A" is (chr 65) (chr x) so you can start with a number and each time you run the section lisp it will add 1 to the x, this will do up to 26. You can save the value of X by using ldata so when dwg is opened again you still have next value and can display that in a prompt. So Enter will give next value. Yes there is code for AA AB etc. Why not a dynamic block then can have a single stretch parameter based on the two pick points. - Last week
Isaac26a replied to p7q's topic in AutoLISP, Visual LISP & DCL
As Steven P said, your arcs in order to keep the same display or look should be converted to ellipses or splines, because they are in 3d and to be displayed in 2d should be converted because they're not plain sections of circles as an arc in 2d is meant to be, that's why most of the codes don't apply to what you want -
Hi Bigal I try but I have problem with the angles. In my template the units set (mapcar 'setvar (list 'aunits 'auprec 'angdir 'angbase 'lunits 'luprec 'insunits ) (list 2 4 1 (/ pi 2) 2 3 6)) ; for ZWCAD (defun C:SECTIONLINE ( / pt1 pt2 dirpt baseAngle dirAngle ang arrowBase arrowHeight secLetter txtpt1 txtpt2 angleDeg p1 p2 p3 offset letterOffset) (command "._STYLE" "Section" "Arial" 0.0 1.4 0 "N" "N" "N") (if (= (tblsearch "layer" "Section") nil) (vl-cmdf "_layer" "_m" "Section" "_c" "10" "" "_lw" "0.05" "" "") ) (setvar "clayer" "Section") (setq arrowBase 0.69) (setq arrowHeight 0.27) (setq offset 0.11) (setq letterOffset 0.31) (setq pt1 (getpoint "\nSelect first point of section line: ")) (if (not (and pt1 (listp pt1))) (progn (princ "\nCanceled or invalid first point.") (quit)) ) (setq pt2 (getpoint pt1 "\nSelect second point of section line: ")) (if (not (and pt2 (listp pt2))) (progn (princ "\nCanceled or invalid second point.") (quit)) ) (setq dirpt (getpoint "\nPick a point to define section direction: ")) (if (not (and dirpt (listp dirpt))) (progn (princ "\nCanceled or invalid direction point.") (quit)) ) (setq secLetter (getstring T "\nEnter section letter (e.g., A, B): ")) (if (= secLetter "") (setq secLetter "A")) (setq baseAngle (angle pt1 pt2)) (setq dirAngle (angle pt1 dirpt)) (setq ang (if (< (abs (- baseAngle dirAngle)) (/ pi 2.0)) dirAngle (+ dirAngle pi))) (command "._LINE" "_non" pt1 "_non" pt2 "") (setq p1 (polar pt1 baseAngle offset) (setq p2 (polar p1 (+ baseAngle (/ pi 2.0)) (/ arrowBase 2.0))) (setq p3 (polar p1 (- baseAngle (/ pi 2.0)) (/ arrowBase 2.0))) (command "._PLINE" "_non" p2 "_non" (polar p1 ang arrowHeight) "_non" p3 "_non" p2 "") (command "._HATCH" "SOLID" "_L" "" "") (setq txtpt1 (polar pt1 ang letterOffset)) (setq angleDeg (* 400.0 (/ baseAngle pi))) (command "._TEXT" "J" "MC" "_non" txtpt1 0.27 angleDeg secLetter) (setq p1 (polar pt2 (- baseAngle pi) offset)) (setq p2 (polar p1 (+ baseAngle (/ pi 2.0)) (/ arrowBase 2.0))) (setq p3 (polar p1 (- baseAngle (/ pi 2.0)) (/ arrowBase 2.0))) (command "._PLINE" "_non" p2 "_non" (polar p1 ang arrowHeight) "_non" p3 "_non" p2 "") (command "._HATCH" "SOLID" "_L" "" "") (setq txtpt2 (polar pt2 ang letterOffset)) (command "._TEXT" "J" "MC" "_non" txtpt2 0.27 angleDeg secLetter) (princ "\nSection line created successfully.") (princ) ) Thanks -
p7q started following Steven P
Steven P replied to p7q's topic in AutoLISP, Visual LISP & DCL
arcs in this case will need to be converted to ellipses to display properly.. something to think about -
p7q started following Performance helps for Large-Scale Z-Flattening (Z0) AutoLISP Routine?
ı tried but dindt work for arc. But thanks for interest -
I'm sure I did because I tried exploding an object. But it didn't fill. There must be an error somewhere, but I couldn't find it, so I tried another method. Also, I'm a new programmer and I started writing lips without knowing anything about ACAD, so it was extra difficult. I'm glad this forum exists :))) -
Thanks for interest. you can try this dwg also. I 'm waiting yours code. arc.dwg -
You can try this dwg. But ı wrote code for arc this code. arc.dwg ((member entType '("ARC" "CIRCLE" "ELLIPSE") ) (vla-put-Center data (vlax-3d-point (list (car (vlax-get data 'Center)) (cadr (vlax-get data 'Center)) 0.0 ) ) ) (vl-catch-all-apply (function (lambda () (vlax-put data 'Normal (list 0.0 0.0 1.0)) ) ) ) ) But this code also didnt work. -
marko_ribar started following Help: Section Line for Architecture Drawings
marko_ribar replied to mhy3sx's topic in AutoLISP, Visual LISP & DCL
You haven't defined "arrowAng" variable and you are using it in (polar) function... Sorry, my mistake - you defined it firstly... [EDIT : You should changle variable "angle" to something different like "ang" as (angle) is AutoLISP function and then you should localize "ang" in main (defun) instead of "angle"...] -
(defun C:SECTIONLINE ( / pt1 pt2 dirpt baseAngle dirAngle angle arrowLen arrowAng secLetter txtpt angleDeg p1 p2 ) (setq arrowLen 10.0) (setq arrowAng (/ pi 6.0)) (setq pt1 (getpoint "\nSelect first point of section line: ")) (if (not (and pt1 (listp pt1))) (progn (princ "\nCanceled or invalid first point.") (quit)) ) (setq pt2 (getpoint pt1 "\nSelect second point of section line: ")) (if (not (and pt2 (listp pt2))) (progn (princ "\nCanceled or invalid second point.") (quit)) ) (setq dirpt (getpoint "\nPick a point to define section direction: ")) (if (not (and dirpt (listp dirpt))) (progn (princ "\nCanceled or invalid direction point.") (quit)) ) (setq baseAngle (angle pt1 pt2)) (setq dirAngle (angle pt1 dirpt)) (setq angle (if (< (abs (- baseAngle dirAngle)) (/ pi 2.0)) baseAngle (+ baseAngle pi))) (command "._LINE" "_non" pt1 "_non" pt2 "") (setq p1 (polar pt1 (+ angle arrowAng) arrowLen)) (setq p2 (polar pt1 (- angle arrowAng) arrowLen)) (command "._LINE" "_non" pt1 "_non" p1 "") (command "._LINE" "_non" pt1 "_non" p2 "") (setq p1 (polar pt2 (+ angle arrowAng) arrowLen)) (setq p2 (polar pt2 (- angle arrowAng) arrowLen)) (command "._LINE" "_non" pt2 "_non" p1 "") (command "._LINE" "_non" pt2 "_non" p2 "") (setq secLetter (getstring T "\nEnter section letter (e.g., A, B): ")) (if (= secLetter "") (setq secLetter "A")) (if (and (listp pt1) (listp pt2)) (progn (setq txtpt (mapcar '(lambda (a b) (/ (+ a b) 2.0)) pt1 pt2)) (setq angleDeg (* 180.0 (/ angle pi))) (command "._TEXT" "_non" txtpt 2.5 angleDeg (strcat secLetter "-" secLetter)) ) (princ "\nText not placed due to invalid points.") ) (princ "\nSection line created successfully.") (princ) ) I have this error (I use ZWCAD) Command: SECTIONLINE Select first point of section line: Select second point of section line: Pick a point to define section direction: Error: undefined function - nil Thanks -
mhupp started following Help: Section Line for Architecture Drawings
I am searching for a lisp code to draw a section line like the test.dwg. 1) Select 2 points for the length of the section 2) Pick a point for the direction of the section 3) Draw section line with the arrows and ask for the section letter for exampl A,B Thanks TEST.dwg
Then something wasn't created or modified. aka trying to exploding a invalid or corrupted region, or one that is on a locked layer. maybe run audit and purge before and then check if entity is on a locked layers. -Edit Writing lisp isn't the hard part. figuring out all the different things that could go wrong and how to handle that is the hard part. had a user that would always select things with the crossing selection option(bottom right to top left) and complain about how my lisp was picking up things "outside" what they where selecting.
