What exactly is your question regarding the channels? BTW... something doesn't look right with your columns and baseplates. Can you email me a copy of the drawing? I will message you with my contact information.
Thank you ReMark. I actually had to go back and do much of the work over. Bit embarrassed to say but I am learning! I think a lot of the instructions have changed. Can you give me some guidance on sheet 4? I got a bit confused with the c9X20 channel beams. The instructions are SO difficult for completely new beginners. This is what I currently have.
Anatoly123 joined the community
LJade: Here is an example of what I mentioned in my previous post. Note that the channel supports the steel decking, and the decking supports the concrete. The rebar is embedded in the concrete. Note the flashing and canted drip edge in the example as well.
Steven P replied to indiancad's topic in AutoCAD 2D Drafting, Object Properties & Interface
No it is more when we go from title block version 7 to version 9.2... with the same block name... for example, title attributes go from 5 down to 4 lines and they rename drawing number attribute DwgNo to Drawing - just updating the block doesn't quite capture it all... so (lazy CAD) - burst usually works well. I think I have a LISP global updates of all the same block in a drawing - think it is one of Lee Macs - but most of our drawings are 1 sheet per file so another of Lees works for multiple sheets over may drawings. -
Paul Li started following VedaCAD - Technical Support, Updates & Community VCIDs
v1.2 Sep 26, 2026 Download link: https://www.vedacad.com - Special thanks to @Paul Li for the rigorous industrial-scale stress testing and invaluable feedback - Upgraded the core execution engine with a new Pre-Execution Guardian for seamless dependency hot-injection and a completely refactored CUIX loader, ensuring rock-solid stability and lightning-fast performance across massive asset libraries - Expanded Bundle capabilities to seamlessly package over 20 companion formats (e.g., .CUIX, .XML, .JSON, .PDF) alongside plugins, while reinforcing Enterprise Ark infrastructure with strict environment-only format whitelisting - Transformed the Asset Manager workflow by introducing Multi-Select Deletion for swift bulk management, combined with smart alphabetical sorting to naturally group main applications with their companion files - Redesigned UI rendering dynamics to better accommodate comprehensive app suites, featuring an expanded 12-character Custom Alias limit, enhanced viewport heights, and a robust truncation algorithm for flawless column alignment - Strengthened Web Workspace portals with advanced ecological dependency protection, ensuring the safety of distributed public assets and improving global backend synchronization --- Important notice: V1.2 is a major underlying revision that packages the plugin companion format into a collection and includes the functionality to download collections containing companion formats, which was not supported in previous versions. Currently, our core engine supports and strictly distinguishes the following three major format arrays: Plugins: .LSP, .FAS, .VLX, (.ARX, .DLL) Companion Formats: Allow packaging with plugins into collections, including: .CUIX, .CUI, .MNU, .MNS, .MNC, .SLB, .MNL, .MNR, .DCL, .CHM, .HLP, .BMP, .PNG, .DAT, .CSV, .PDF, .HTML, .XML, .JSON, .TXT, .INI, .DWG, .DWF, .SLD, (.ZIP) Env Standards: PRO and Enterprise version features, including: (.CTB, .STB, .DWT, .SHX, .PAT, .LIN, .PC3, .PMP, .ATC, .DWS, .PGP, .SCR, .FMP, .UNT) - Yesterday
My only comment and its about appearance not actual details, in C2 I would move the leader "Metal siding" to the right side so it does not cross the detail, just clearer to read. @ReMark has provided great advice supporting the Penn Foster tasks.
@Steven P not sure if this is what you mean, but I have pick attribute in say title block in a layout and it will copy that attribute value into the correct attribute in all blocks of that name, I think also a do multiple atts, handy when say you change a project description, updates all layouts etc. -
multiple file selection dialog box using lisp & powershell
BIGAL replied to Paul Li's topic in AutoLISP, Visual LISP & DCL
Paul li pretty sure using powershell managed to jump to Excel from Cad, may be useful, will try to find again. Jump to explorer window etc make current window. -
The above is somewhat difficult to read/understand but I will do my best. Let's start on the left. The rebar should not extend through the bottom of the footing. The concrete slab (ground floor) appears to be missing. I don't see the steel decking in the floor above and the roof. Your depiction of the vertical steel cladding is incorrect. As regards Detail C1: the flashing should also extend down the exterior face of the structure, and both ends of the flashing should have an angled drip edge. And your steel column is missing the lines denoting the flange. As regards Detail C2: Lines denoting flange on column are missing. Steel decking is missing. Beam that attaches to column is missing. Angle and bolt appear to be sized incorrectly. Steel cladding shown correctly. It looks like you have the concrete roof slab sitting inside the channel when in fact the slab, along with the steel decking and rebar would all sit atop the channel. I'm positive there is more I could comment on but that's the best I can do at the moment. There are several threads in this particular forum that deal with the Penn-Foster structural assignment where these very same details show up. Have you looked at any of them?
Steven P started following 5 CAD Commands That Can Save You More Time Than You Think
The time I most often use burst is when I update drawing borders - often most of the attributes link from one border to the next... but not all of them all the time... (perhaps lazy CAD, move, burst, purge, insert and copy text back to where it should be) -
abucadtutor changed their profile photo -
I would still do the new block or would have one around for it, but like I stated some work places have a different work flow, etc. It would be good to have a "BURST" that kept the block, like with a Field you have "Convert field to text" maybe a convert Attribute value to text. I have a LISP to convert the Attribute Value to text outside the block and leaves the block. -
Ive been looking for references to the Structural Project and found this website. It has helped but I worry alot of the instructions have been updated from the previous post. I'm stuck on the section Drafting Details C, C1, and C2. I feel like I'm missing something and was wondering if anyone could give me some guidance. (I am completely new to Drafting & AutoCAD.) I have uploaded the instructions and my progress via this sheet. Thanks! reading_assignment_core_1.html
LJade joined the community
Do you really need a separate DWG for every revision?
I took over a project (lots actually) when I got to my current work place 16 years ago, from an Architectural firm and made revisions and "what ifs" up until last year. You may have guessed, pretty much back to the first updates I did and they just finished the project several months ago, I am glad I kept most of the working drawings, notes, revisions, etc. It was approved and then not approved a few times in that time. No doubt as soon as I delete a revised drawing, they will want to go back to that one. I often tell them, that's pretty much the exact same as the first one I issued for approval. So I pretty much keep everything until I know a project is completely dead. Sometimes my "Revision" is just the date I last worked on the drawing for updates. -
Did you ever finish plate 3, section A, of the structural project?
I really don't use a lot of XREFs (and you hit on one of those reasons), even then I tend to Bind them at the end of the job, but if you revise a drawing that is Xreffed by other drawings, you can use the Reference Manager or a third party program, I know there are a few LISPs out and about, I believe I posted something for updating referenced Images a while back, I believe I have one for .dwg. By most accounts, if you modify a drawing that is Xreffed into other drawings you also need to update the revision on those as well. I also found a LISP IIRC that will do some revision work on a drawing, I was trying to improve and modify it for my purposes, but haven't revisited it in a good while. I'll get back when I can locate some of those codes. The way you do it is fine, though could be tricky for others, since I do a lot of non-production drawings I also do that on occasion. I spend a lot of my drafting time on "what if we" drawings, not to mention "off the books" drawings, so I have different methods of handling those updates. -
Why does SLICE sometimes create an unexpected result on a 3D solid?
Have you ever used SLICE on a 3D solid and ended up with a cut that wasn't where you expected? I ran into this when the cutting plane was not aligned with the part the way I thought it was. Before slicing, I found it useful to check the current UCS and viewing direction, then define the cutting plane carefully using 3 points or an existing planar object. I also make sure I'm selecting the correct side to keep after the slice. A quick UCS/view check can prevent a lot of unnecessary editing afterward. When SLICE gives an unexpected result, what do you normally check first? -
Paul Li replied to Paul Li's topic in AutoLISP, Visual LISP & DCL
@GLAVCVS I just tried your updated code testing it on two setups: 1) Running AutoCAD 2021 on Windows 10 with multiple screens: Though the File Selection window appears and no longer locks up, sometimes I would get two or more File Selection windows and they would appear behind the AutoCAD window. 2) Running AutoCAD 2027 on Windows 11 with single screen: The File Selection window appears again behind the AutoCAD window. If the AutoCAD window is full screen, I'm not able to toggle to the file selection window. I would have to hit the Esc key to close the File Selection window. When the AutoCAD window is smaller than the screen, then I see the File Selection window behind the AutoCAD window so I can select it to make it appear on top. - Last week
GLAVCVS replied to Paul Li's topic in AutoLISP, Visual LISP & DCL
I've made a few minor changes to the code from my previous post. I've tested it in AutoCAD 2021 and it seems to work. getFilem.mp4 -
Do you check the drawing units before starting work on a DWG?
Paul Li replied to indiancad's topic in AutoCAD Drawing Management & Output
@Dadgad Actually I even went as far as creating a lisp command so I can make the selections to dwgunits within a dcl gui instead of looking at the dull command line interface. https://marketplace.autodesk.com/apps/5190d5ec-0b6a-4b70-b089-2753abcb8e3a?priceId=bfbb3227-aa55-4923-b9e6-7fe3db0a0a5b -
Paul Li started following 5 CAD Commands That Can Save You More Time Than You Think , Do you check the drawing units before starting work on a DWG? , Getting Error message on opening Cadtutor. and 1 other
When it comes to keeping copies of various revisions completed, file naming and renaming could become really tricky especially if they're externally referenced to other dwgs. So to avoid having to repath dwgs that may be referenced elsewhere, what I've done in the past is to have the most current dwg always named the same and stored in the same location. A folder is created with the revision date as the name and the dwg is then copied into that folder. Now I have preserved copies of major milestone revisions saved in the project folder. -
CyberAngel replied to indiancad's topic in AutoCAD 2D Drafting, Object Properties & Interface
This is something I hate to do, but sometimes I'm in a hurry. One title block may be different in some fundamental way. I can't just explode it, because I'll lose all the information in the attributes. There's not enough time to create an entire block for one sheet, and why bother when there's only one? So it's time to Burst a move (sorry). -
That sounds like a fake Norton Pop-Up, ISeeYou, used to be (is?) an older vulnerability for web cams, I guy was activating webcams without the activation light on and blackmailing women with photos, he was caught and arrested a while back. I'll look for the article. Here is the Wiki iSeeYou - Wikipedia This looks to be a good while back.
thomhend joined the community
JilledL joined the community
Something maybe Dave can look at is my Norton antivirus pops up now and then with a warning about "I.see.you" has been detected. Will attach an image next time.
@dexusThis is pretty good too. Thanks for contributing. Though it does not check the AutoCAD window location and so the file selection window may open up on a different monitor, it does open really fast and remembers the monitor location where it last closed. I also like the different looking gui. Interestingly enough, I was able to get it to show multiple file types (*.dwg & *.dxf) by placing that in the filename argument instead of the extension argument: (filePicker (getvar"dwgprefix") "*.dwg;*.dxf" "")
