Avoiding Copy and Paste to secure clipboard data progress!
Nikon replied to ScottMC's topic in AutoLISP, Visual LISP & DCL
The character (_) is missing in these lines. (command "_chprop" "_L" "" "_la" "XLINE" "") ;; make xline grey Maybe that's the problem. - Today
edsel sydy joined the community
ScottMC posted a topic in AutoLISP, Visual LISP & DCL
Need someone to get this tool to crash for a test and get me to find solution. Had this previously using no entmake or trans but seems to work now. (defun c:4x (/ *error* pt1 pt2 ss ) (princ (strcat "\n 45"(chr 186)"/135"(chr 186)" 3D.XLines <!pp>")) (defun *error* ( msg ) (setvar 'cmdecho 0) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (if msg (prompt (strcat "\n" msg))) (setvar 'cursorsize 100) ;; reset to my prefer (setvar 'cmdecho 1) (princ) ) (setvar 'cursorsize 1) (entmakex ;; <LM '( (000 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (002 . "XLINE") ;; Layer Name (070 . 0) ;; Layer Status (bit-coded) (006 . "Continuous") ;; Layer Linetype (must be loaded) (062 . 252) ;; Layer Colour (1-255) (290 . 0) ;; Non-Plot Flag (0=Plot, 1=NoPlot) (370 . -3) ;; Layer Lineweight (-3=Default) ) ) (defun zPoint ( / exv) ;; 3d point mfg (setq pt1 (trans pt1 1 0)) (setq exv (trans (list 0 0 1) 1 0 T)) (entmakex (list (cons 0 "POINT") (cons 10 pt1) (cons 210 exv))) ) (defun cdd () (princ "\n") (princ (setq pp ;; make/prints coords & paste usable (strcat (rtos (car pt1) 2 4) "," ;; 'p' -- vertex from pgm /\ getpoint,... (rtos (cadr pt1) 2 4) "," (rtos (caddr pt1) 2 4) ) ) ) (princ " cucs ");; ; (entmakex (list (cons 0 "POINT") (cons 10 pt))) ;; clean point (setenv "pp" pp) ;; crash saved coords ) ;;// ----------------------------------------------------------------------------------------------------------- ;; Get the initial placement point (while (setq pt1 (getpoint "\nSpecify Point for XLines: ")) (setvar 'cmdecho 0) (progn ;; Create a new empty selection set (setq ss (ssadd)) ;; Create horizontal xline and add to selection set (command "_.xline" "_a" 45 pt1 "") (command "chprop" "_L" "" "la" "XLINE" "") ;; make xline grey (ssadd (entlast) ss) ;; Create vertical xline and add to selection set (command "_.xline" "_a" 135 pt1 "") (command "chprop" "_L" "" "la" "XLINE" "") ;; make xline grey (ssadd (entlast) ss) (cdd) ;; post coords (zPoint) ;; point at 'pick.point ) (setvar 'cmdecho 1) ) ;; end of while (princ) ) -
place align block through lisp going wrong
mhupp replied to pmadhwal7's topic in AutoLISP, Visual LISP & DCL
Was more to show pmadhwal7 an alternative code with less checks but same functionality so you get the wrong layout faster with less compute! - Yesterday
BIGAL replied to pmadhwal7's topic in AutoLISP, Visual LISP & DCL
@mhupp did you look at my comment about the labels being at incorrect distance ? At the start they are correct and further along seem to have been shifted. A lot appear to have same incorrect offset. @pmadhwal7 I just made the blocks 1 unit long, just used BEDIT scale by 0,1 "0,0" then scale will be correct also turned off osnap. General comment given the chainage of the first label, 250414 the start of the pline is 250305, in label terms. Why is this start point not like 250300 which would make a lot more sense. Have used other pick label to set start chainage when testing. @pmadhwal7 need to know how are these labels being generated to a dwg. -
logic was wrong passing 1.0 if not a number and nil if (nth 3 data) & (nth 4 data) was a number should be fixed now. PIPE_InsertBlockFromCSV.lsp -
zidann joined the community
Top 20 AutoCAD Customizations – Part Two: Tuesday Tips With Frank
Let’s get back to it with the second installment of the Top 20 AutoCAD customizations! If you missed it, be sure to check out part one with the first 10. Now, let’s take a look at numbers 11-20. And, again, we’ll list these in no particular order. 11. Command Line Docking When it comes to how you want to view your Command Line, much like the old hamburger ad campaign stated, you can have it your way. Using a left click press and hold on the left edge of default Command Line display, feel free to pull it off the bottom edge of the drawing editor. Make it shorter or larger by dragging an edge. If you want to put it back at the bottom, simply drag it back. When you get close enough, it will snap back into place for you. Maybe you’re like me and prefer the old school “in-line” display. This time, when you drag the Command Line, move it below the bottom edge, and it will be incorporated into the interface, now in its full view state. Either view will dock on any edge, so set it up how it works best for you. Or others! By that I mean that many of us who use a projected image of AutoCAD when teaching a class will place the Command Line at the top, where it can be seen easier by the students. 12. Status Bar Contents The Status Bar doesn’t display everything by default. Click on the customization icon in the lower right. Some people like to call this icon “the hamburger” (uh oh, do I feel a theme building or would that be considered cheesy?) If an entry doesn’t have a check mark, it is not currently displayed. Simply click on it to add it to the Status Bar. Conversely, there may be items that you don’t use. Do you never have the need to draw in Isometric mode? Save some space for something else by unchecking it here. 13. Ribbon Panel Options Similar to the Status Bar, your Ribbon doesn’t show everything by default. To manage your Tabs and Panels, right-click anywhere on the Ribbon to display two tools which display the available Tabs or Panels, and their visibility status. Much like the Status Bar, turn them on or off as needed. Perhaps there’s a tool that you’ll need to access often, but your workflow requires you to change tabs often, adding an extra and unnecessary step of changing tabs constantly. You can do a left-click press and hold on any black spot of a Panel, and drag it off the Ribbon and let it “float” elsewhere. When you’re done, you can click on the small icon in the upper right corner of the floating panel to return it to the position it was in on the Ribbon prior to floating it. 14. Maximize Viewport Do you ever need to work within a Paper Space viewport, but it’s rather small and your space is limited? You can maximize a viewport to fill the entire drawing editor. Simply double click on any edge of the desired viewport, and just like that, it expands to full view. Your visual clue is the large blue border that AutoCAD will display around the editor. Time to return to normal? Just double-click anywhere on the blue border. 15. Model Space Viewports Viewports aren’t just for Paper Space. This customization is extremely useful if you ever work in 3D. From the View tab of the Ribbon, expand the Viewport Configuration tool in the Model Viewports panel. Select from eleven preset layouts. Unlike Paper Space viewports, they are always tiled in Model Space. Just single click inside of any viewport to activate it. In the configuration shown below, it might be used to set one to be a top view, another a front view and another would be a side view. When you need to get back to normal, click on the Single option of the configuration pulldown, and the currently active viewport will display normally. 16. Startup Switches Customizing AutoCAD can be done outside of the interface as well. Did you know there are a number of things that you can have AutoCAD do when you double click on its desktop icon? They’re Command Line Switches, and (properly) adding them to the program’s icon can greatly increase your efficiency. You can tell AutoCAD to use a particular profile when it starts. You can specify a Sheet Set or a Template to start with. Maybe you want to run a particular Script or not display the splash screen — you can do that, too! Explore all of the available switches by clicking on this link to the reference table. 17. WYSIWYG In most modern graphics programs, you work in a What You See Is What You Get, or WYSIWYG environment. AutoCAD, as you know, displays in colors, then translates those colors or objects into the desired printed form. We use the Preview function to see what it will look like. But you can have AutoCAD display as WYSIWIG, and it’s as easy as clicking a single check box. From the pen assignments panel in the Page Setup dialog box, check Display Plot Styles. Having set this, you can see in our sample drawing below, the CTB/STB style of color display, verses the WYSIWYG style. I know of some firms that set an extra layout tab to display this way all the time. 18. Tool Palettes From Design Center Ah, we’ve come to the CAD Manager’s best friend. Tool palettes are an incredible design aid, and using them is fast and easy, as long as they’re already set up and ready to go. This is where the AutoCAD Design Center comes in. Do you need to create a tool palette of hundreds of blocks? Fire it up, navigate to either the folder or file that contains your blocks, right-click and tell it to create a tool palette. Easy peasy. Read all about it in the link below. For all my CAD Manager readers out there, I’m sorry for giving away one of our behind the curtain secrets. 19. View Transitions The AutoCAD drawing editor has improved its graphics in recent years. One of those improvements is the default ability to see the transition from one fiew to the next. You know, you zoom into an area, and you see the graphics zoom to, or transition to the new view. These are called Zoom Transitions and are controlled by a system variable called VTENABLE. To speed things up, you can turn this feature off by setting that varialbe to zero. Below are two animations. The top one shows the default transition settings, and the bottom one performs the same zoom with it turned off. VTENABLE set to its default of 3 VTENABLE set to zero (off) 20. Options Dialog Oh, there’s so much more. But I’m at 20, so it’s time to move on for me. But you can find all kinds of other ways to customize AutoCAD from the Options dialog. Click on the Display tab, and you’ll find that four of the six panels directly affect how you view and interface with AutoCAD. Do you like to have scroll bars displayed, and do you prefer for your crosshairs to be full screen? You can find those options and more here. That’s All Folks Hopefully between this blog and the last, you’ve found a little nugget or two that will make your AutoCAD sessions work a bit more like you do. To paraphrase an early AutoCAD influencer, until next time “keep on customizing.” More Tuesday Tips Check out our whole Tuesday Tips series for ideas on how to make AutoCAD work for you. The post Top 20 AutoCAD Customizations – Part Two: Tuesday Tips With Frank appeared first on AutoCAD Blog. View the full article -
Selçuk joined the community
nhathanhvan joined the community
Ankit Pandit replied to Ankit Pandit's topic in AutoLISP, Visual LISP & DCL
Here’s example from a different drawing where I tested both approaches. In this case, the shrinkwrap command wasn’t able to generate a boundary at all and returned a “failed to create shrinkwrap” message for this selection. Using the same input, I tried an alternative approach i.e. EGBoundary and was able to generate a clean, continuous outer boundary for the full shape. Sharing the comparison and .dwg file itself here. From what I’ve tested so far, the settings command seems to give a bit more control over things like automatic and manual tolerance handling as well as output customization (layer, color, etc.), which probably helps in these more complex cases. I’m still exploring it, but that flexibility seems to make a difference compared to the standard commands. For Clarification:- I am using AutoCAD Architecture 2026 and EGBOUNDARY for AutoCAD listed on their website. Part 6 Assm.dwg -
TOPOGRAFIE joined the community
nattapont.kkp joined the community
MecSoft Corporation joined the community
Ok just ran all 488 values and there may be a problem in your sample dwg the Chainage labels are not at correct chainage compared to the start point. I looked and the block did not align properly so checked the distance from start point for a random label and the blocks inserted are at the chainage but your label is not. The blue line is a circle with the radius set to the correct chainage you can see goes through middle of block but label does not match. So here is some code, note the blocks have been made 1 unit in length. I also changed the Excel to work out the mid point yes can be done with lisp but really why not use Excel. The dwg attached shows the problem. The Excel I used is attached. Yes part two needs to be done but need some answers to what I see as lots of problems in future dwg's. Drawing1-test.dwg test.lsp Book1.xlsx -
pmadhwal7 replied to pmadhwal7's topic in AutoLISP, Visual LISP & DCL
@mhupp Command: Command: AP APPLOAD PIPE_InsertBlockFromCSV1.lsp successfully loaded. Command: Type InsertBlocksFromCSV or IBC to run. Command: Command: INSERTBLOCKSFROMCSV ; error: bad DXF group: (41) -
@BIGAL those chainage only for refernce as the final output is totlay different those are only to place dwc and pcc i was try to scale down the blcok but the size of block are comiing short i am not able understand what is the wrong on this i just need those block will place between those chainages whicha re mentioned in excel sheet otherwise i have to place manualy and i have lots of file like this actually this is the chainage which means if we 250.408-250.420=12meter so my dwc pipe length is 12m at this point what i do i was calculate mid difference of those chainage and i was place mid chiange in autocad (as seen my dwg u can check)now i run the lisp which place those block like the align command it work so in taht portion dwc length should be 12 meters 6meters from each side of that 250414 but the isse is block length comming 8m instead of 12soemwhere the differnce is 2m somewhere 4 as the y scale is only for width so thats the not issue because i will change it by selecting all one time also i am not able to uderstand what u mean for 'scaled like 10 x timee' is anything wrong in my block? sample.dwg - Last week
I am working on something. Its almost there reads data from Excel direct. Yes inserts correct a block 12 long. Just a bit busy with other stuff. maybe later today. Ok a another comment to get the correct position for the block easiest way is using getpointatdist function. So must work out the start chainage of the pline then each point is easy to work out as you have a Midpoint value. I can see a problem and don't know why your distances are in mm. More importantly is the text must have 3 decimal places and this is a problem when a Chainage is xxx01, no third decimal. (setq ch "12301") (/ (atof ch) 1000.) 12.301 SHOULD BE 123.01 Is there a reason the text can not be a true metre text "123.456" then can have any number of decimals. -
mhupp started following place align block through lisp going wrong
All the dxf data can be handled with atof instead of checking numberp (atof "10") ; => 10.0 (atof "-10.5") ; => -10.5 (atof "12abc") ; => 12.0 starts with a number will also return a real. (atof "abc123") ; => 0.0 (atof "hello") ; => 0.0 might not have gotten the right file the csv only has 3 columns so (if (< (length data) 6) is always be true and i don't think (continue) is used in lisp should be giving you an error. (if (< (length data) 6) (setq skip nil) (setq skip T) ) (if skip (progn (setq blkname (nth 0 data)) ... ) ;progn (princ (strcat "\nBlock definition '" blkname "' not found in the drawing. Skipping.")) ) -
@BIGAL i was try to scale down the blcok but the size of block are comiing short i am not able understand what is the wrong on this i just need those block will place between those chainages whicha re mentioned in excel sheet otherwise i have to place manualy and i have lots of file like this actually this is the chainage which means if we 250.408-250.420=12meter so my dwc pipe length is 12m at this point what i do i was calculate mid difference of those chainage and i was place mid chiange in autocad (as seen my dwg u can check)now i run the lisp which place those block like the align command it work so in taht portion dwc length should be 12 meters 6meters from each side of that 250414 but the isse is block length comming 8m instead of 12soemwhere the differnce is 2m somewhere 4 as the y scale is only for width so thats the not issue because i will change it by selecting all one time also i am not able to uderstand what u mean for 'scaled like 10 x timee' is anything wrong in my block? -
ahpstr joined the community
SLW210 replied to Ankit Pandit's topic in AutoLISP, Visual LISP & DCL
Please share some examples where the SHRINKWRAP is failing in Civil or Architecture, maybe a solution can be found. EGBOUNDARY sounds like a great solution for you, hopefully it's a good enough replacement for others looking to replace TotalBoundary and SuperBoundary. -
Edit source of a Array .. switches display mode to 3D conceptual?
mohdomar replied to halam's topic in AutoCAD Bugs, Error Messages & Quirks
your question has helped me solve a problem in my autocad drawing file, so i would like to thank you for that. -
asos2000 started following Layer Table (Lines and Text)
My 5 cent (defun c:LLD () (c:LayerLegend)) (defun c:LayerLegend ( / df i l ln p1 pt sp DSC ENT NM ) ;; Lee Mac 2011 (vl-load-com) (if (and (setq pt (getpoint "\nSpecify Point for Legend: ")) (setq ln (* 100 (getvar 'TEXTSIZE))) ;(getdist "\nSpecify Length of Lines: " pt)) (setq pt (trans pt 1 0)) (setq i -1) (setq sp (* 2.5 (getvar 'TEXTSIZE))) ) (while (setq df (tblnext "LAYER" (null df))) (if (/= 16 (logand 16 (cdr (assoc 70 df)))) (setq l (cons (cdr (assoc 2 df)) l)) ) (setq l (acad_strlsort l)) )) (foreach n l (setq ent (vlax-ename->vla-object (tblobjname "LAYER" n))) (setq dsc (vlax-get-property ent 'Description)) (setq nm (vlax-get-property ent 'name)) (setq lc (itoa (vla-get-color ent ))) (entmakex (list (cons 0 "LINE") (cons 8 n) (cons 6 "ByLayer") (cons 62 256) (cons 10 (setq p1 (polar pt (* 1.5 pi) (* (setq i (1+ i)) sp))) ) (cons 11 (polar p1 0. ln)) (cons 370 -1) ) ) (entmakex (list (cons 0 "TEXT") ;*** (cons 1 (strcat n " : " lc " : " dsc)) ;* (the string itself) (cons 6 "BYLAYER") ; Linetype name (cons 7 (getvar 'TEXTSTYLE)) ;* Text style name, defaults to STANDARD, not current (cons 8 n) ; layer (cons 10 p1) ;* First alignment point (in OCS) (cons 11 p1) ;* Second alignment point (in OCS) (cons 39 0.0) ; Thickness (optional; default = 0) (cons 40 (getvar 'TEXTSIZE)) ;* Text height (cons 41 1.0) ; Relative X scale factor, Width Factor, defaults to 1.0 (cons 62 256) ; color (cons 71 0) ; Text generation flags (cons 72 0) ; Horizontal text justification type (cons 73 1) ; Vertical text justification type (cons 210 (list 0.0 0.0 1.0)) (cons 370 -1) ))) (princ) )
james02 joined the community
Ah got it — thanks for clarifying that, I wasn’t aware the Architecture toolset was included. That makes sense. I also had a chance to try the shrinkwrap command on a different setup (a friend using Civil), and saw similar behavior in the more detailed regions. From the result you shared, it does get quite close, but I’m still seeing some irregularities around the boundary in those complex areas, especially in some of my other projects. That’s been the tricky part in my case — getting a consistently clean outer boundary across the full shape. I’ve been testing EGBoundary across different setups — it’s been working consistently for me in AutoCAD and BricsCAD so far. I haven’t personally tried it yet in GstarCAD or ZWCAD, though I’ve seen them mentioned as compatible with GstarCAD and ZWCAD on their official website. Really appreciate you taking the time to test and share that. Thank you !! -
@mhupp Layer Filters the "Architect" shows "layers 1 & Layer 2" only. Sorry don't have code, but a google revealed in one post of so many suggestions.
Firstly your block is 9.4 long so, at a scale of 12 its 12x9.4 in length. So 1st step is scale down the block by 0.1 and resave then it is basically 1 unit long so a scale of 12 will be a fraction under a true 12 length. The other question is then what sclae factor to use for the Y value but this can be calculated as a factor of the scale and block height Y so they are all the same height. If you want it to be a true 1 unit can rescale to match that and save block. Hint 1.05843568371114 I don't have a problem working out the length or the insertion point. Those values are in your Excel example. You just need to work out the chainage of the start end of the pline. For me I would just start brand new code easier, will see what I can do and will read the Excel direct. -
Still don't know what your talking wanting. you can only select things on the layers. this will make a selection set of whats on those layers and on current tab. (setq ss (ssget "X" (list (cons 410 (getvar "CTAB")) (cons 8 "Layer[12]")))) (sssetfirst nil ss)
@BIGAL actually this is the chainage which means if we 250.408-250.420=12meter so my dwc pipe length is 12m at this point what i do i was calculate mid difference of those chainage and i was place mid chiange in autocad (as seen my dwg u can check)now i run the lisp which place those block like the align command it work so in taht portion dwc length should be 12 meters 6meters from each side of that 250414 but the isse is block length comming 8m instead of 12soemwhere the differnce is 2m somewhere 4 as the y scale is only for width so thats the not issue because i will change it by selecting all one time also i am not able to uderstand what u mean for 'scaled like 10 x timee' is anything wrong in my block? -
The DWC block has a insertion point at mid point, Still not sure about the wrong length and 4m dist. Can you also provide a dwg with before and after so can see how say first 3 blocks should look. add the excel data as MTEXT etc. Yes can read the Excel direct no need for a CSV. Ok understand in Excel from 250.408 to 250.420 so point is (250.408+250.420)/ 2.0 where label is. So need to establish start chainage of pline 250414 compared to start distance away and get that start point X&Y. Your DWC block appears to be scaled like 10 x times. Why is it not 1 unit long say actual is 0.9447 that fits in 1 unit. The scale for 12 would be just that. Also what is Y scale ? Does the block have a fixed height, Y ? Again edit block 1st. Then can do some code to match. -
devitg started following place align block through lisp going wrong
Steven P started following TEXT REQUIRED
Not sure for ZWCAD, but it Tamil font installed on your computer, you should be able to access it if it is
in autocad i need to place block which was align in x scale i have lisp code too but the isseu is the block is placing wrongly i was place mid chainage of the point where i need to place those block but always it placing wrongly l;ike first length of my block is 12m but the code placing 8m 4 m each side i was attached all the input i have can anyone fix this Drawing2.dwg block.dwg PIPE_PlotBlocksFromCSV.lsp PIPE_Block.csv.xls.csv Book1.xlsx
@mhuppIt's like this For example , I have layer 1, layer 2 , layer 3 And I want to select layers 1 and 2, add them to the newgroup filter, and name it something like "architect".
