  2. Today
  3. BIGAL
    A new get length LISP
    @SLW210 did a little bit of testing and works ok in Metric dwt. The only thing is the Architectural result. Limited Testing in Bricscad V25. made some shapes and inserted some blocks. A rectang 5000x4000 mm or decimal units. For metric don't need Architectural units. Curve length: 18000 Gaps: 0 Total: 18000 Architectural: 1500'-0" ?? For metric could do dwg is in mm but result is in metres to 3 decimals. You could use the Multi radio buttons.lsp to make choices. As its demand loaded you do not have to add it to your code. Re CSV your more than welcome to use the defuns in Alan Excel.lsp to write direct to Excel. Could demand load a lisp with just the defuns needed as don't need all that is in the lisp. Just a Ps a big file to screen copy maybe also post a file copy.
  4. Yesterday
  5. I don't know if there was ever another LISP/Program to do this type of get length at least I never found one, my original just did what I needed, I have since made it more generally useful (I hope). As per the drawing I will attach, I just need to get the length of the center between the inner and outer of the perimeter of guards, etc. to determine the unrolled length. Normally the guards are 3D and I create the profiles with SOLPROF which creates an anonymous block (I used to change these with UNANON) or sometimes in the past I have used SOLVIEW and SOLDRAW, the same issue arises that you just can't select them and get the profile length. So originally that's what this LISP was created to do (I still have some of the older basic versions). I have upgraded it to it's current state and also still working on another version, but only small enhancements. For inside a block that is scaled, you will need to multiply the results by the scale factor, working through a viewport the viewport needs to be active, so I might tackle those issues as well as make a more detailed CSV. I also will try to make sure it works in non-AutoCAD like BricsCAD, CMS IntelliCAD, nanoCAD, etc. when I get time. I lightly tested in most situations, I have no idea how it acts on non-uniformly scaled blocks, though. It handles gaps and slight overlaps, I have some settings at the top, hopefully with enough instructions to modify on your own. Where I work (except for the machine shop which uses decimal inches) they use Architectural units, I did not double check this in Metric, so if someone would report back on that it would help. ;;; Get total length of profile, etc. option to get average and report to CSV. | ;;; | ;;; https://www.cadtutor.net/forum/topic/99276-a-new-get-length-lisp/#findComment-679965 | ;;; | ;;; By SLW210 (a.k.a. Steve Wilson) | ;;; | ;;; ==============================================================================================| ;;; ==============================================================================================| ;;; GetLen.lsp | ;;; PROFILE / CENTERLINE LENGTH | ;;; | ;;; VERSION: 2026-08-31 | ;;; | ;;; Supports a combination of: | ;;; LINE | ;;; ARC | ;;; CIRCLE | ;;; LWPOLYLINE | ;;; POLYLINE | ;;; SPLINE | ;;; ELLIPSE | ;;; | ;;; If PELLIPSE=1: | ;;; Heavy Polyline (a.k.a. Old Style or 2D Polylines) made from bulged VERTEX records. | ;;; These can be converted with CONVERTPOLY command, I chose to work with the Heavy Polylines. | ;;; | ;;; Supports: | ;;; - Model Space | ;;; - Paper Space | ;;; - Blocks (must be Scale 1.0) | ;;; - Nested blocks | ;;; - Anonymous/dynamic blocks (*U...) | ;;; - Uniform block scaling | ;;; - Single profile | ;;; - Two-profile average / centerline | ;;; - Screen output | ;;; - CSV output | ;;; - Architectural formatting | ;;; - Endpoint tolerance for slight overlaps | ;;; - Optional gap measurement | ;;; | ;;; NOTE: | ;;; nentsel returns: | ;;; 1 = entity | ;;; 2 = pick point | ;;; 3 = transformation matrix | ;;; 4 = block-reference path | ;;; | ;;; ==============================================================================================| ;;; ==============================================================================================| (vl-load-com) ;;; ============================================================ ;;; USER SETTINGS ;;; Adjust to your preference. ;;; ============================================================ (setq *GETLEN-TOL* 0.01) ;; T = include gaps ;; NIL = do not include gaps (setq *GETLEN-ADD-GAPS* T) ;; "DECIMAL" ;; "ARCHITECTURAL" (setq *GETLEN-UNITS* "ARCHITECTURAL") ;; Architectural precision: ;; 16 = 1/16" ;; 8 = 1/8" ;; 4 = 1/4" (setq *GETLEN-ARCH-PRECISION* 8) ;; Drawing units expressed as inches: ;; Inches = 1.0 ;; Feet = 12.0 ;; Millimeters = 0.0393700787 (setq *GETLEN-INCHES-PER-UNIT* 1.0) ;;; ============================================================ ;;; CURVE TYPE ;;; ============================================================ (defun GL:CurveType (ent / d typ) (if ent (progn (setq d (entget ent) ) (setq typ (cdr (assoc 0 d) ) ) (if (member typ '("LINE" "ARC" "CIRCLE" "LWPOLYLINE" "POLYLINE" "SPLINE" "ELLIPSE") ) T ) ) ) ) ;;; ============================================================ ;;; GET PARENT HEAVY POLYLINE ;;; ============================================================ (defun GL:GetParentPolyline (vertex / ent data typ parent) (if (and vertex (= "VERTEX" (cdr (assoc 0 (entget vertex) ) ) ) ) (progn (setq parent (cdr (assoc 330 (entget vertex) ) ) ) (if parent (progn (setq data (entget parent) ) (setq typ (cdr (assoc 0 data) ) ) (if (= typ "POLYLINE") parent nil ) ) nil ) ) ) ) ;;; ============================================================ ;;; NESTED SELECTION ;;; ============================================================ (defun GL:GetSelectedEntity (/ sel ent typ parent) (setq sel (nentsel "\nSelect a curve in the profile: " ) ) (if sel (progn (setq ent (car sel) ) (setq typ (cdr (assoc 0 (entget ent) ) ) ) ;; ------------------------------------------------------ ;; Heavy POLYLINE / VERTEX ;; ------------------------------------------------------ (if (= typ "VERTEX") (progn (setq parent (GL:GetParentPolyline ent) ) (if parent (progn (princ "\nHeavy POLYLINE vertex selected." ) (princ "\nUsing parent POLYLINE." ) (list parent (cadr sel) (caddr sel) (cadddr sel) ) ) (progn (princ "\nCould not identify parent POLYLINE." ) sel ) ) ) sel ) ) ) ) ;;; ============================================================ ;;; GET BLOCK PATH ;;; ============================================================ (defun GL:GetBlockPath (sel / path) (if sel (progn (setq path (cadddr sel) ) (cond ((and path (= (type path) 'ENAME) ) (list path) ) ((listp path) path ) (T nil ) ) ) ) ) ;;; ============================================================ ;;; GET BLOCK REFERENCE ;;; ============================================================ (defun GL:GetBlockReference (sel / path) (setq path (GL:GetBlockPath sel) ) (if path (car path) ) ) ;;; ============================================================ ;;; GET BLOCK NAME ;;; ============================================================ (defun GL:GetBlockNameFromPath (sel / ref data name) (setq ref (GL:GetBlockReference sel) ) (if ref (progn (setq data (entget ref) ) (setq name (cdr (assoc 2 data) ) ) name ) ) ) ;;; ============================================================ ;;; GET BLOCK DEFINITION ENTITIES ;;; ============================================================ (defun GL:GetBlockEntities (blkName / btr ent typ result) (setq result nil) (if blkName (progn (setq btr (tblobjname "BLOCK" blkName ) ) (if btr (progn (setq ent (entnext btr) ) (while ent (setq typ (cdr (assoc 0 (entget ent) ) ) ) (if (= typ "ENDBLK") (setq ent nil) (progn (setq result (cons ent result) ) (setq ent (entnext ent) ) ) ) ) ) ) ) ) (reverse result) ) ;;; ============================================================ ;;; GET CURVES FROM BLOCK ;;; ============================================================ (defun GL:GetBlockCurves (blkName / all curves e) (setq all (GL:GetBlockEntities blkName) ) (setq curves nil) (foreach e all (if (GL:CurveType e) (setq curves (cons e curves) ) ) ) (reverse curves) ) ;;; ============================================================ ;;; HEAVY POLYLINE ENDPOINTS ;;; ============================================================ (defun GL:GetHeavyPolylineEndpoints (pline / data flags closed ent vdata typ firstPt lastPt ) (setq data (entget pline) ) ;; POLYLINE group 70 (setq flags (cdr (assoc 70 data) ) ) (setq closed (= 1 (logand (if flags flags 0 ) 1 ) ) ) (setq ent (entnext pline) ) (while ent (setq vdata (entget ent) ) (setq typ (cdr (assoc 0 vdata) ) ) (cond ((= typ "VERTEX") (if (null firstPt) (setq firstPt (cdr (assoc 10 vdata) ) ) ) (setq lastPt (cdr (assoc 10 vdata) ) ) ) ((= typ "SEQEND") (setq ent nil) ) ) (if ent (setq ent (entnext ent) ) ) ) (if (and firstPt lastPt ) (if closed ;; ------------------------------------------------------ ;; CLOSED POLYLINE ;; ------------------------------------------------------ (list firstPt firstPt ) ;; ------------------------------------------------------ ;; OPEN POLYLINE ;; ------------------------------------------------------ (list firstPt lastPt ) ) ) ) ;;; ============================================================ ;;; GENERAL ENDPOINTS ;;; ============================================================ ```lisp (defun GL:GetEndpoints (ent / typ p1 p2 result data) (if (null ent) nil (progn (setq data (entget ent)) (setq typ (cdr (assoc 0 data))) ;; ------------------------------------------------------ ;; Heavy POLYLINE ;; ------------------------------------------------------ (if (= typ "POLYLINE") (progn (setq result (GL:GetHeavyPolylineEndpoints ent) ) result ) ;; ---------------------------------------------------- ;; All other curves ;; ---------------------------------------------------- (progn (setq p1 (vl-catch-all-apply 'vlax-curve-getStartPoint (list ent) ) ) (setq p2 (vl-catch-all-apply 'vlax-curve-getEndPoint (list ent) ) ) (if (and (not (vl-catch-all-error-p p1)) (not (vl-catch-all-error-p p2)) ) (list p1 p2) nil ) ) ) ) ) ) ;;; ============================================================ ;;; BULGE SEGMENT LENGTH ;;; ============================================================ (defun GL:BulgeSegmentLength (p1 p2 bulge / chord included radius) (if (or (null p1) (null p2) (equal bulge 0.0 1e-14) ) (if (and p1 p2) (distance p1 p2) 0.0 ) (progn (setq chord (distance p1 p2) ) (setq included (* 4.0 (atan (abs bulge) ) ) ) (if (or (<= chord 1e-14) (<= included 1e-14) ) chord (progn (setq radius (/ chord (* 2.0 (sin (/ included 2.0) ) ) ) ) (* radius included) ) ) ) ) ) ;;; ============================================================ ;;; HEAVY POLYLINE LENGTH ;;; ============================================================ (defun GL:GetHeavyPolylineLength (pline / data flags closed ent vdata typ firstPt currentPt currentVertexData nextPt bulge total ) (setq data (entget pline) ) (setq flags (cdr (assoc 70 data) ) ) (setq closed (= 1 (logand (if flags flags 0 ) 1 ) ) ) (setq total 0.0) (setq firstPt nil) (setq currentPt nil) (setq currentVertexData nil) (setq ent (entnext pline) ) (while ent (setq vdata (entget ent) ) (setq typ (cdr (assoc 0 vdata) ) ) (cond ((= typ "VERTEX") (setq nextPt (cdr (assoc 10 vdata) ) ) (if (not firstPt) (setq firstPt nextPt) ) ;; Previous vertex controls this segment. (if (and currentPt currentVertexData ) (progn (setq bulge (cdr (assoc 42 currentVertexData ) ) ) (if (null bulge) (setq bulge 0.0) ) (setq total (+ total (GL:BulgeSegmentLength currentPt nextPt bulge ) ) ) ) ) (setq currentPt nextPt) (setq currentVertexData vdata) ) ((= typ "SEQEND") (setq ent nil) ) ) (if ent (setq ent (entnext ent) ) ) ) ;; Closed polyline. (if (and closed firstPt currentPt currentVertexData ) (progn (setq bulge (cdr (assoc 42 currentVertexData ) ) ) (if (null bulge) (setq bulge 0.0) ) (if (not (equal firstPt currentPt 1e-12 ) ) (setq total (+ total (GL:BulgeSegmentLength currentPt firstPt bulge ) ) ) ) ) ) total ) ;;; ============================================================ ;;; GENERAL GETLENGTH ;;; ============================================================ (defun GL:GetLength (ent / typ obj result ep d data p1 p2) (setq typ (cdr (assoc 0 (entget ent) ) ) ) (cond ;; -------------------------------------------------------- ;; HEAVY POLYLINE ;; -------------------------------------------------------- ((= typ "POLYLINE") (GL:GetHeavyPolylineLength ent) ) ;; -------------------------------------------------------- ;; LWPOLYLINE ;; -------------------------------------------------------- ((= typ "LWPOLYLINE") (setq obj (vl-catch-all-apply 'vlax-ename->vla-object (list ent) ) ) (if (not (vl-catch-all-error-p obj) ) (progn (setq result (vl-catch-all-apply 'vlax-get-property (list obj 'Length) ) ) (if (not (vl-catch-all-error-p result) ) result 0.0 ) ) 0.0 ) ) ;; -------------------------------------------------------- ;; LINE / ARC / CIRCLE / SPLINE / ELLIPSE ;; -------------------------------------------------------- (T (setq ep (vl-catch-all-apply 'vlax-curve-getEndParam (list ent) ) ) (if (not (vl-catch-all-error-p ep) ) (progn (setq d (vl-catch-all-apply 'vlax-curve-getDistAtParam (list ent ep) ) ) (if (not (vl-catch-all-error-p d) ) d 0.0 ) ) (progn (setq data (entget ent) ) (setq p1 (cdr (assoc 10 data) ) ) (setq p2 (cdr (assoc 11 data) ) ) (if (and p1 p2) (distance p1 p2) 0.0 ) ) ) ) ) ) ;;; ============================================================ ;;; NENTSEL MATRIX SCALE ;;; ============================================================ (defun GL:MatrixVectorLength (v) (if (and v (numberp (car v)) (numberp (cadr v)) (numberp (caddr v)) ) (sqrt (+ (* (car v) (car v)) (* (cadr v) (cadr v)) (* (caddr v) (caddr v)) ) ) 1.0 ) ) (defun GL:GetBlockScale (matrix / sx sy sz) (if (and matrix (listp matrix) (>= (vl-list-length matrix) 3) ) (progn (setq sx (GL:MatrixVectorLength (nth 0 matrix) ) ) (setq sy (GL:MatrixVectorLength (nth 1 matrix) ) ) (setq sz (GL:MatrixVectorLength (nth 2 matrix) ) ) (if (and (> sx 1e-14) (> sy 1e-14) ) (/ (+ sx sy) 2.0) 1.0 ) ) 1.0 ) ) ;;; ============================================================ ;;; DEBUG SCALE ;;; ============================================================ (defun GL:PrintScale (matrix / scale) (if matrix (progn (setq scale (GL:GetBlockScale matrix) ) (princ (strcat "\nBlock scale: " (rtos scale 2 8) ) ) ) (princ "\nBlock scale: 1.00000000" ) ) ) ;;; ============================================================ ;;; MEASURED LENGTH ;;; ============================================================ (defun GL:GetMeasuredLength (ent matrix / lngth scale) (setq lngth (GL:GetLength ent) ) (if matrix (progn (setq scale (GL:GetBlockScale matrix) ) (* lngth scale) ) lngth ) ) ;;; ============================================================ ;;; NEAR ;;; ============================================================ (defun GL:Near (p1 p2) (and p1 p2 (<= (distance p1 p2) *GETLEN-TOL* ) ) ) ;;; ============================================================ ;;; FIND NEXT CONNECTED ENTITY ;;; ============================================================ (defun GL:FindNext (currentEnd curves used / e ep answer) (foreach e curves (if (and (not (member e used) ) (setq ep (GL:GetEndpoints e) ) ) (cond ((GL:Near currentEnd (car ep) ) (setq answer (list e (cadr ep) ) ) ) ((GL:Near currentEnd (cadr ep) ) (setq answer (list e (car ep) ) ) ) ) ) (if answer (setq e nil) ) ) answer ) ;;; ============================================================ ;;; TRACE PROFILE ;;; ============================================================ (defun GL:TracePath (start curves matrix / used ordered total gapTotal ep current next ent newEnd nextEP gap lengthValue ) (setq used nil) (setq ordered nil) (setq total 0.0) (setq gapTotal 0.0) (setq ep (GL:GetEndpoints start) ) (if ep (progn ;; Start at first endpoint. (setq current (car ep) ) (setq used (list start) ) (setq ordered (list start) ) (setq total (GL:GetMeasuredLength start matrix ) ) ;; ------------------------------------------------------ ;; Follow connected curves. ;; ------------------------------------------------------ (while (setq next (GL:FindNext current curves used ) ) (setq ent (car next) ) (setq newEnd (cadr next) ) (setq nextEP (GL:GetEndpoints ent) ) ;; Calculate actual gap. (if nextEP (setq gap (min (distance current (car nextEP) ) (distance current (cadr nextEP) ) ) ) (setq gap 0.0) ) ;; Add gaps only when enabled. (if *GETLEN-ADD-GAPS* (if matrix (setq gapTotal (+ gapTotal (* gap (GL:GetBlockScale matrix) ) ) ) (setq gapTotal (+ gapTotal gap) ) ) ) (setq used (append used (list ent) ) ) (setq ordered (append ordered (list ent) ) ) (setq lengthValue (GL:GetMeasuredLength ent matrix ) ) (setq total (+ total lengthValue) ) (setq current newEnd) ) ) ) (list ordered total gapTotal ) ) ;;; ============================================================ ;;; GCMD ;;; ============================================================ (defun GL:GCMD (a b / remValue) (setq a (abs a)) (setq b (abs b)) (while (> b 0) (setq remValue (rem a b) ) (setq a b) (setq b remValue) ) a ) ;;; ============================================================ ;;; ARCHITECTURAL FORMAT ;;; ============================================================ (defun GL:Architectural (value / inches feet remainder whole frac num den gcdValue ) (setq den *GETLEN-ARCH-PRECISION* ) (setq inches (* value *GETLEN-INCHES-PER-UNIT* ) ) (setq feet (fix (/ inches 12.0) ) ) (setq remainder (- inches (* feet 12.0) ) ) (setq whole (fix remainder) ) (setq frac (- remainder whole) ) ;; Round fraction. (setq num (fix (+ (* frac den) 0.5 ) ) ) ;; Carry fraction into inch. (if (>= num den) (progn (setq num 0) (setq whole (1+ whole) ) ) ) ;; Carry inch into foot. (if (>= whole 12) (progn (setq whole (- whole 12) ) (setq feet (1+ feet) ) ) ) ;; Reduce fraction. (if (> num 0) (progn (setq gcdValue (GL:GCMD num den ) ) (if (> gcdValue 1) (progn (setq num (/ num gcdValue) ) (setq den (/ den gcdValue) ) ) ) ) ) ;; Format. (cond ;; Feet. ((> feet 0) (cond ((= num 0) (strcat (itoa feet) "'-" (itoa whole) "\"" ) ) ((= whole 0) (strcat (itoa feet) "'-" (itoa num) "/" (itoa den) "\"" ) ) (T (strcat (itoa feet) "'-" (itoa whole) " " (itoa num) "/" (itoa den) "\"" ) ) ) ) ;; Inches only. ((= num 0) (strcat (itoa whole) "\"" ) ) ;; Fraction only. ((= whole 0) (strcat (itoa num) "/" (itoa den) "\"" ) ) ;; Whole + fraction. (T (strcat (itoa whole) " " (itoa num) "/" (itoa den) "\"" ) ) ) ) ;;; ============================================================ ;;; GET PROFILE CURVES ;;; ============================================================ (defun GL:GetProfileCurves (selected sel / blkName curves ss idx e edata selectedSpace ) (setq blkName (GL:GetBlockNameFromPath sel) ) ;; ---------------------------------------------------------- ;; INSIDE BLOCK ;; ---------------------------------------------------------- (if blkName (progn (setq curves (GL:GetBlockCurves blkName) ) (list blkName curves selected ) ) ;; -------------------------------------------------------- ;; MODEL / PAPER SPACE ;; -------------------------------------------------------- (progn (setq selectedSpace (cdr (assoc 410 (entget selected) ) ) ) (setq ss (ssget "_X") ) (setq curves nil) (if ss (progn (setq idx 0) (while (< idx (sslength ss) ) (setq e (ssname ss idx) ) (if (GL:CurveType e) (progn (setq edata (entget e) ) (if (= selectedSpace (cdr (assoc 410 edata ) ) ) (setq curves (cons e curves) ) ) ) ) (setq idx (1+ idx) ) ) ) ) (list nil (reverse curves) selected ) ) ) ) ;;; ============================================================ ;;; CALCULATE PROFILE ;;; ============================================================ (defun GL:CalculateProfile (selected sel / info curves actual matrix blockName ) (setq info (GL:GetProfileCurves selected sel ) ) (if info (progn (setq curves (cadr info) ) (setq actual (caddr info) ) (setq matrix (caddr sel) ) (setq blockName (car info) ) (if (null blockName) (setq matrix nil) ) (if actual (GL:TracePath actual curves matrix ) ) ) ) ) ;;; ============================================================ ;;; PRINT PROFILE ;;; ============================================================ (defun GL:PrintProfile (number result matrix / ordered total gaps e ed typ) (setq ordered (car result) ) (setq total (cadr result) ) (setq gaps (caddr result) ) (princ (strcat "\n\nPROFILE " (itoa number) "\n================================" ) ) ;; Show scale. (GL:PrintScale matrix) (princ (strcat "\nObjects traced: " (itoa (vl-list-length ordered) ) ) ) (foreach e ordered (setq ed (entget e) ) (setq typ (cdr (assoc 0 ed ) ) ) (princ (strcat "\n " typ " Handle=" (cdr (assoc 5 ed ) ) " Length=" (rtos (GL:GetMeasuredLength e matrix ) 2 6 ) ) ) ) (princ (strcat "\n--------------------------------" "\nCurve length: " (rtos total 2 6) "\nGaps: " (rtos gaps 2 6) "\nTotal: " (rtos (+ total gaps) 2 6 ) "\nArchitectural: " (GL:Architectural (+ total gaps) ) "\n================================" ) ) result ) ;;; ============================================================ ;;; CSV ;;; ============================================================ (defun GL:WriteCSV (filename result1 result2 average / f totalValue) (setq f (open filename "w" ) ) (if f (progn (write-line "GETLEN Profile Length Report" f ) (write-line "Profile,Length,Architectural" f ) (if result1 (progn (setq totalValue (+ (cadr result1) (caddr result1) ) ) (write-line (strcat "Profile 1," (rtos totalValue 2 6) "," (GL:Architectural totalValue) ) f ) ) ) (if result2 (progn (setq totalValue (+ (cadr result2) (caddr result2) ) ) (write-line (strcat "Profile 2," (rtos totalValue 2 6) "," (GL:Architectural totalValue) ) f ) ) ) (if average (write-line (strcat "Average," (rtos average 2 6) "," (GL:Architectural average) ) f ) ) (close f) T ) ) ) ;;; ============================================================ ;;; MAIN COMMAND ;;; ============================================================ (defun c:GETLEN (/ mode output sel1 sel2 ent1 ent2 result1 result2 total1 total2 average csvFile info location curvesCount matrix1 matrix2 ) (vl-load-com) (princ "\n\n========================================" ) (princ "\nGETLEN - PROFILE LENGTH" ) (princ "\n========================================" ) ;; ========================================================== ;; MODE ;; ========================================================== (initget "Single Average" ) (setq mode (getkword "\nMode [Single/Average] <Single>: " ) ) (if (null mode) (setq mode "Single") ) ;; ========================================================== ;; OUTPUT ;; ========================================================== (initget "Screen CSV Both" ) (setq output (getkword "\nOutput [Screen/CSV/Both] <Screen>: " ) ) (if (null output) (setq output "Screen") ) ;; ========================================================== ;; FIRST PROFILE ;; ========================================================== (if (= mode "Average") (princ "\n\nFIRST PROFILE" ) ) (setq sel1 (GL:GetSelectedEntity) ) (if sel1 (progn (setq ent1 (car sel1) ) (setq matrix1 (caddr sel1) ) ;; Get information. (setq info (GL:GetProfileCurves ent1 sel1 ) ) (if info (progn (if (car info) (setq location (strcat "Block " (car info) ) ) (setq location "Model/Paper Space" ) ) (setq curvesCount (vl-list-length (cadr info) ) ) (princ (strcat "\nLocation: " location "\nCurves available: " (itoa curvesCount) ) ) ) ) ;; Calculate. (setq result1 (GL:CalculateProfile ent1 sel1 ) ) (if result1 (GL:PrintProfile 1 result1 (if (car info) matrix1 nil ) ) (princ "\nSelected curve could not be resolved." ) ) ) (princ "\nNothing selected." ) ) ;; ========================================================== ;; SECOND PROFILE ;; ========================================================== (if (and (= mode "Average") result1 ) (progn (princ "\n\nSECOND PROFILE" ) (setq sel2 (GL:GetSelectedEntity) ) (if sel2 (progn (setq ent2 (car sel2) ) (setq matrix2 (caddr sel2) ) (setq info (GL:GetProfileCurves ent2 sel2 ) ) (if info (progn (if (car info) (setq location (strcat "Block " (car info) ) ) (setq location "Model/Paper Space" ) ) (princ (strcat "\nLocation: " location "\nCurves available: " (itoa (vl-list-length (cadr info) ) ) ) ) ) ) (setq result2 (GL:CalculateProfile ent2 sel2 ) ) (if result2 (progn (GL:PrintProfile 2 result2 (if (car info) matrix2 nil ) ) (setq total1 (+ (cadr result1) (caddr result1) ) ) (setq total2 (+ (cadr result2) (caddr result2) ) ) (setq average (/ (+ total1 total2) 2.0 ) ) (princ "\n\nTWO PROFILE AVERAGE / CENTERLINE" ) (princ "\n========================================" ) (princ (strcat "\nProfile 1: " (rtos total1 2 6) " " (GL:Architectural total1) ) ) (princ (strcat "\nProfile 2: " (rtos total2 2 6) " " (GL:Architectural total2) ) ) (princ "\n----------------------------------------" ) (princ (strcat "\nAverage / Centerline: " (rtos average 2 6) ) ) (princ (strcat "\nArchitectural: " (GL:Architectural average) ) ) (princ "\n========================================" ) ) (princ "\nSecond profile could not be resolved." ) ) ) (princ "\nSecond profile not selected." ) ) ) ) (if (or (= output "CSV") (= output "Both") ) (progn (setq csvFile (getfiled "Save GETLEN CSV Report" "GETLEN.csv" "csv" 1 ) ) (if csvFile (progn (GL:WriteCSV csvFile result1 result2 average ) (princ (strcat "\nCSV saved: " csvFile ) ) ) ) ) ) ;; ========================================================== ;; FINISH ;; ========================================================== (princ "\n\nGETLEN complete." ) (princ) ) ;;; ============================================================ ;;; LOAD MESSAGE ;;; ============================================================ (princ "\nGETLEN loaded. Type GETLEN to run." ) (princ) GetLenTest.dwg
  6. I wouldn't trust any company that's not an Autodesk official reseller.
  7. If you have an AutoCAD license, you get the toolsets like Map 3D free, you could use MAPCLEAN, which can fill gaps and also has a weed function and more. What if they are overlapping and not a gap, you can get unexpected results from a large selection set and MPedit>Join from overlapping/collinear (P)Lines? I use MPedit as well, you just have to run a polyline weed LISP (like PLDiet.lsp) sometimes to get single polylines. You may also want to look into Overkill and Fillet with radius = 0, it can help with cleanup as well. I know everyone that has this problem is working on a drawing that was not of their own and either generated by another CAD platform or by a past or former coworker. But, the best method for these issues are to properly use and setup your CAD not to have unjoined/unconnected/ends touching (P)Lines, Arcs, Splines, etc. Good post from @irneb here on that issue...
  8. Do you have an example drawing that does this? That sounds more like a Graphics Card or driver issue, though as you say, could be AutoCAD 2010 (I presume that's what you mean since v10 is very old now and was released in 1988). If you still use v10 I would definitely say that's the issue.
  9. I moved your thread to the AutoCAD 3D Modelling & Rendering Forum. Please start threads in the most appropriate forum.
  10. This can happen when working on a 3D model. Two solids may look like one object, but they can still be separate. A simple way to check is to click each part and see if you can select them separately. If they need to become one solid, UNION can combine them. You can also use INTERFERE to check if two solids are overlapping. How many of you have faced this while making a 3D model?
  11. Have you ever used PEDIT → JOIN, but CAD does not join the lines? Sometimes the lines look connected, but there is a small gap between them. They can also have different Z values. First, check the endpoints using OSNAP. If the lines have different Z values, FLATTEN can help bring them to the same level. How many of you have faced this problem? What fixed it for you?
  12. Last week
  13. One other thing I've noticed.. Inserting a 3d block into model space. Occasionally everything in model space disappears and the 3d part appears, nothing else. Purging does not solve it, the 3d part is invisible otherwise. It's very strange and may be a bug in v10.
  14. [Side DIM] VCID: 5EDNWJ @ VedaCAD
  15. [Omni Wheel] VCID: US87Y8 @ VedaCAD
  16. Hi, Does anyone have experience with stack social? (LT @ 199/yr) Thanks!
  17. ReMark
    Judging by what I have seen other students use I would say 8" would be sufficient. BTW... your drawing needs further work. Footings need to be trimmed where beams appear above them. Likewise, channels are not continuous. They too need to be trimmed where they intersect with the beams.
  18. https://drive.google.com/drive/folders/1RW3VS_e2hrR0-L4AcJnErnl0MR6DnZFp?usp=sharing When using this version, check the "Merge PDF" box to print in "Publish" mode.
  19. Hi, Suppose we have three groups positioned within another but all separate. Is there a way to nest the interior groups to the exterior one whilst keeping them intact . If the whole needs to be edited, they can be pulled away as one, then edited as separate entities. Thanks!
  20. I wonder what he thinks about the above...
  21. Can this be modified to include the hyperlinks, like that of publish command in autocad?
  22. @ReMark yes, this drawing is mine I'm on to doing the dimensions I wanted to know the size of the text.
  23. SLW210
    I wouldn't rely on AutoCAD's Autosave feature, see this recently revived old thread... I have some links where you can "Autosave" without Autodesk's version. I know for AutoCAD LT the VBA solution will not work, but maybe the others are worth a shot. As I mention, get into the habit of Ctrl+S often. From the other link I posting in that thread explaining Autosave, etc....
  24. It is widely known that DCL has its native limitations, and to create beautiful and elegant UIs, it's not only about simplifying the underlying logic but also about DCL's presentation. Please share those DCL interface designs that are worth sharing! Here are the DCL interface designs for my two plugins. In the end, it was the image control that took on everything!!!
  25. X11start
    Actually I set the autosave every 5 minutes. At this point the only annoying element of this "bug" is that... it can happen that you don't remember what things have been changed in the last few minutes, so you run the risk of skipping some of them. It happens when I have to retouch a drawing in various areas... but as I say it's a rare case: by now I know about this "bug" and I'm careful!
  26. Danielm103
    Python for AutoLISP Users part 1:
    This thread discusses PyRx. PyRx embeds the Python runtime inside AutoCAD/BricsCAD’s process space. It’s CAD that does the .DWG/DXF file IO. There’s other packages like ezdxf that can read write files. PyRx, is analog to CAD’s .net wrappers in that its bound to ObjectARX
  27. BIGAL
    Pathon a new programming language ? Just open a dxf or a dwg can then run Python scripts. But must install the Python run time.
  28. A google should have pointed you to the great Website by Lee-mac, Bounding Box.
