  2. If you use a reactor it is a lisp anyway and has to be ran every time you add the block, so as I suggested much easier to do a lisp that looks at the XY point and updates, a lisp will run through multiple blocks very fast and update all. Just make the lisp insert the block 1st.
  3. Today
  4. PGia
    Find&open files
    That seems very interesting!
  5. GLAVCVS
    Find&open files
    @PGia In case you don't mind including all the file locations you need to reference in AutoCAD's "SupportPaths" (other external paths could also be considered, but would require more code), there is another option, unorthodox but disruptive: type the name of the file to open directly into the command line (but with a small convention) I think some of the participants in this thread know what I'm talking about. If not, I'll explain it with a little code when I get home.
  6. Don't create a new reactor for every object - this is likely to severely impact performance - only one object reactor is required with a set of owning objects. Aside, you're missing the definition for your (let*) function.
  7. Lee Mac
    Find&open files
    I would also vote for Everything - it's ridiculously fast.
  8. Try Overkill
  9. Yesterday
  10. My thought exactly. It looks like an Impossible Object.
  11. BIGAL
    Find&open files
    I use Everything all the time it indexes hard drives and finds a file instantly. Re Access, Word, Excel and Libre office all of these can be accessed from CAD I use Bricscad. You can for say Access not only open but actually get at the data, most common being Excel get and put. If you have a few known files you want to open all the time can either make a defun for each and load on startup or my preferred would be a sub menu in a POP menu with the file names as the description. As mentioned already using notepad is shown how in ACAD.PGP as an already defined option.
  12. rlx
    Find&open files
    I did write something once to find and launch documents but its a little over the top probably. But Bigal also had a good suggestion , a program called everything.
  13. PGia
    Find&open files
    Thanks to RLX for recommending Lee Mac's code (Lee Mac: thanks for sharing it) I just figured out how it works, and I think it's pretty close to what I need I guess I should create a command to run that code whenever I need it.
  14. PGia
    Find&open files
    Thanks for the answers. They're really very interesting. And I really liked @Steven P's Lisp for searching on Google In response to Ciberangel, I must say that I often need to edit acad.lsp and other AutoCAD support files, and I really feel like I'm wasting a lot of time doing that. Additionally, I almost always need to open Access databases that contain information related to the drawings I manage. I also manage photo banks with standardized names that I need to reference on the fly in my drawings. For these reasons, a tool to search and open these files will save me a lot of time.
  15. mhupp
    Find&open files
    Didn't have the exe in the startapp line so maybe thats why?
  16. Steven P
    Find&open files
    Didn't quite work for me - opened explorer and went to a folder - not sure why yet ... actually, take away the '/watch?v....." and it works, probably just your dodgy youtube viewing habits..
  17. mhupp
    Find&open files
    @Steven P See what this does. again will use default browser. (startapp "explorer.exe" "https://www.youtube.com/watch?v=dQw4w9WgXcQ") So above can be (defun c:GetGoogle ( / Search Page) (setq Search (getstring "Enter Serch Term: [use '+' between terms] ")) ;; get search term, '+' between words (setq Page (strcat "https://www.google.com/search?q=" Search)) ;; google + search term address (startapp "explorer.exe" page) ) -edit didn't have the exe
  18. I've never worked with reactors. I'll have to dig into it. Thanks!
  19. rlx
    Find&open files
    actually quite nice Steven , think I'm gonna add this to one of my toolbars (if there's still room that is...) for opening things I also like : https://lee-mac.com/open.html
  20. Steven P
    Find&open files
    also shell commands - I've only used that once though: (defun c:GetGoogle ( / SearchTerm PageBase) (setq SearchTerm (getstring "Enter Serch Term: [use '+' between terms] ")) ;; get search term, '+' between words (setq PageBase "(command \"shell\" \"start microsoft-edge:http://google.com/search?q=") ;; google address (setq Page (strcat PageBase SearchTerm "\")" )) ;; google + search term address (eval (read Page)) ;; open 'Page' ) Guess what this does....
  21. Steven P
    Find&open files
    This will search a location for a file type, in the example searching for LISP files in c:\MyLocation\Here - remember to use a double backslash in any location, and return a list of files names + extensions (also folders if the file type is *.*). (setq myfiles (vl-directory-files "C:\\MyLocation\\Here" "*.lsp" nil)) You could do a search of this list to check if your required file is in there As MHUPP use startapp to open the file, here opens the file in variable Lispfile with notepad (startapp "notepad" Lispfile) MHUPP example was for explorer - I didn't know that method would work for any file type to open the default programme. For the first line here, your file path could be contained in a list, looping through each list item (location) until you find the file you want - could search a few locations if you knew them and want to hardcode them in the LISP, and if fails to find them there use MHUPPs 'getfiled' line for the user to select a folder or file. Use an if, cond or while loop to open the file where it finds it and stop the rest of the loop from looping
  22. Have you looked into reactors to trigger the lisp? Never really used them didn't like the fact something is running without me knowing/realizing it. (defun block-modified-callback (reactor obj) (let* ( (ent (vlr-object-reactor-object reactor)) (pos (cdr (assoc 10 (entget ent)))) ) ;; Define your target area (example: lower-left (0,0), upper-right (10,10)) (if (and (>= (car pos) 0) (<= (car pos) 10) (>= (cadr pos) 0) (<= (cadr pos) 10) ) (princ "\nBlock moved into target area!") ;call lisp ? (princ "\nBlock moved outside target area.") ; ) ) ) (defun C:BlockReact ( / ss i ent obj) (setq ss (ssget "_X" '((0 . "INSERT")))) ;maybe limit to the blocks you want to update (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq obj (vlr-object-reactor (vlax-ename->vla-object ent) nil '((:vlr-modified . block-modified-callback)))) (setq i (1+ i)) ) (princ "\nReactors attached to block references.") ) (princ "\nNo blocks found.") ) (princ) ) -Edit Would have to run this after ever copy or insert of a block to add a reactor to it. and i don't know how this affect the performance of the drawing.
  23. mhupp
    Find&open files
    Had a command DIR to start in the folder of the active drawing would open the save prompt like window to allow you to select the file you want. pretty sure if you feed the path to explorer it will use the default program to open the file. (defun C:DIR ( / filePath) (setq dwgPath (getvar "DWGPREFIX")) (setq filePath (getfiled "Select a File to Open" dwgPath "*" 0)) ;limit what types you see by changing "*" (if filePath (progn (startapp "explorer.exe" filePath) (princ (strcat "\nOpening: " filePath)) ) (princ "\nNo file selected.") ) (princ) ) -edit You can also hard code where it stats in like if your documents are in a network drive. (setq filePath (getfiled "Select a Spec File" "C:\\Project\\spec\\" "PDF" 0)) ;look in spec folder for all pdf's
  24. CyberAngel
    Find&open files
    If it's not exclusively AutoCAD files, you may be better off using a system tool. What kinds of files would you be looking for? What parameters would you be searching with? What editors would you be opening them with? The more you can tell us, the better we can help you.
  25. There is not enough information to draw a complete object. What is that line on the other side of the rectangular hole? Where does it start and end? Where are the other edges of that surface? What are the dimensions for the ridge next to the ring, and how does it fit into the opposite side? Where does the flange on the left end? What is going on with that rectangular panel on the right? The whole thing looks like it was designed by M.C. Escher. Wait, I'm looking at it inside out as well as upside down. Your best bet may be to start with the rear face (which we can't see). Draw the two uneven sides separately and extrude them. Draw the rectangular side (with two holes) and extrude that along the Z (?) axis. In other words, separate the task into the four faces and pull them in their own directions.
  26. Hello again A quick question (I assume this will be an easy answer for the experts on this forum): I often need to search for and open various types of files, primarily in AutoCAD directories but also in others. Is there a quick way to search for and open any file in an editor using a custom Lisp command? Thanks in advance
  27. Another... https://forums.augi.com/showthread.php?170434-MText-width-set-to-zero&s=8d83700e43971c18c05d195f56cd176a&p=1330953&viewfull=1#post1330953
  28. set the scale to 0.001 then work from there
