  1. Yesterday
  2. BIGAL
    Running DCL directly
    Not sure what your after, you can preview/display the dcl but it has no interaction. A lisp looks at what happens with "Action" of the Keys. Can you explain more what it is your trying to achieve.
  3. marko_ribar
    Segments of polylines
    I've finished with "lw_orth.lsp"... Take it, or leave it... It's up to you OP... lw_orth.lsp orthogonalize_lwpolyline.dwg
  4. SLW210
    Dynamic Panel with array rivet holes problem.
    Are you using AutoCAD LT? You posted in the AutoCAD LT Forum, but your profile shows AutoCAD 2026 (which is full AutoCAD).
  5. SLW210
    Are you sure you copied it correctly? Runs just fine on my AutoCAD 2026.
  6. Last week
  7. PS I forgot one detail: the resulting route won't emulate the curves, if there are any. It will simply draw straight segments.
  8. Steven P
    Converting menues
    A little tip - when you find setting like these that sets CAD to how you like it, put them into a LISP (setvar 'menubar 1) for example - mine is saved something like CADSettings.LSP... so that when it is upgrade time there is half a chance of a quick fix to make thing 'correct' - or spend a day trying to remember what you did 2, 5 or 10 years ago. Add comments so you know what each does,
  9. I took a look at your modifications to make the code more robust I have to say that I didn’t think it would be possible to consider the presence of “splines” in the drawing. But I agree with including this filter in the current code. As for the filters for “legacy” POLYLINEs and LWPOLYLINEs, the code wouldn’t need those filters if we accept the premise that only straight distances between points will be measured. BUT: to also cover this possibility, I’ve introduced a new function and made some modifications that allow any “*LINE” to be included in the analysis (including any “POLYLINE” or “SPLINE”). In this way, the filters for the selection set become, once again, much simpler. This also allows the drawing to compute routes using curved linear objects (arcs are excluded for now). Regarding the use of LM:rtos, I consider this optional for cases where small cells are desired, and this may introduce some drawbacks. Moreover, using such small cells significantly harms execution speed. I ran a comparison between the execution speed of your code and this new one I’m attaching, and yours is 3 x slower. Additionally, creating the matrix with your requirements is also quite slow. ;; Pathfinding with the A* algorithm by ymg 22/07/2024 ; ;; ; ;; Revised a prog by HELMUT SCHRÖDER - heschr@gmx.de - 2014-09-14 ; ;; found at Cadtutor.net ; ;; ; ;; Kept the same format for edges list but added lines as valid choice ; ;; Format: (((x1 y1) (x2 y2)) (((x2 y2) (x3 y3))....(xn yn))) ; ;; ; ;; The user is asked to pick a start and an endpoint. ; ;; The program will find the shortest path in a network of connected ; ;; polylines and/or lines and draw a new polyline representing the result. ; ;; ; ;; Two lists of nodes openlst and closelst are created from the above ; ;; mentionned edges list. The format of a node list is: ; ;; (((Point) (Prev Point) Cumulated_Distance Estimated_Total_Distance)...) ; ;; ; ;; Main change from origina are: ; ;; - cons the list instead of append ; ;; - vl-sort the openlist instead of the quicksort ; ;; - Replaced and renamed some vars and subroutine. ; ;; - Added fuzz 1e-4 to all points comparison ; ;; - Change the get_path function ; ;; - Added line as possible edges ; ;; - Added an error handler ; ;; - Added a timer to the search portion of the program ; ;; ; ;; The above changes amounted to an acceleration of about 4x from the ; ;; original program. ; ;; : ;; If you compile this program to a .fas you'll get more than 10x faster. ; ;; ; ;| Added or revised code by GLAVCVS (january 2026) -All set are grouped into one -An associative sparse matrix cell->handles is created for faster cell querying (using new 'addToDict' and 'getCell' functions) -The "edges" list is replaced with the local search retourned by 'getCell' T E S T S ===== fas: 4-5 x faster than previous fas lsp: 7-8 x faster than previous lsp (february 8, 2026): -Added new function '·dist·' for measuring distances of curved segments -Added a new lightweight function 'glvFix' to prevent possible rounding mismatches -Several modifications to include in filters and matrix the necessary compatibility with curved linear objects |; (defun c:A** (/ *error* addToDict getCell upd_openlst in_openlst get_path memberfuzz mk_lwp f3Dpol LM:rtos set_errhandler sspl i startp endp e openlst closelst found acdoc lstClvs Pathlay Pathcol Pathlwt varl node ti ·dist· glvFix ) (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com)) (defun *error* (msg) (if e (if command-s (command-s "_.draworder" e "" "_f") (vl-cmdf "_.draworder" e "" "_f") ) ) (mapcar (function eval) varl) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))) (princ (strcat "\nError: " msg)) ) (vla-endundomark acdoc) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;ADDED by GLAVCVS ;;;Create dictionary (defun addToDict (en / p val id clv i l c a) (setq i -1 id (cdr (assoc 5 (setq l (entget en)))) c (= (cdr (assoc 0 l)) "LINE") a 10) (while (setq p (if (and (setq i (1+ i)) c) (cdr (assoc (+ a i) l)) (vlax-curve-getPointAtParam en i))) (if (setq val (assoc (setq clv (strcat (itoa (glvFix (car p) 0.0001)) "," (itoa (glvFix (cadr p) 0.0001)) "," (itoa (glvFix (caddr p) 0.0001)))) lstClvs)) ;(setq val (assoc (setq clv (strcat (LM:rtos (car p) 2 4) "," (LM:rtos (cadr p) 2 4) "," (LM:rtos (caddr p) 2 4))) lstClvs)) (setq lstClvs (subst (append val (list (cons id i))) val lstClvs)) (setq lstClvs (cons (list clv (cons id i)) lstClvs)) ) ) ) (defun ·dist· (l? e p1 p2) (if l? (vlax-curve-getEndParam e) (abs (- (vlax-curve-getDistAtParam e p1) (vlax-curve-getDistAtParam e p2))))) ;;;return list cell ;;*** Modified to access the new dictionary format *** (defun getCell (pt / val clv lr pr par l c oc p0 p) (defun oc (c e i) (if c (cdr (assoc (+ i 10) l)) (vlax-curve-getPointAtParam e i))) (if (setq val (assoc (setq clv (strcat (itoa (glvFix (car pt) 0.0001)) "," (itoa (glvFix (cadr pt) 0.0001)) "," (itoa (glvFix (caddr pt) 0.0001)))) lstClvs)) (foreach par (cdr val) (setq e (handent (car par)) c (= (cdr (assoc 0 (setq l (entget e)))) "LINE")) (if (zerop (setq pr (cdr par))) (setq lr (cons (list c e pr (1+ pr)) lr)) (setq lr (cons (list c e (1- pr) pr) lr) lr (if (vlax-curve-getPointAtParam e (1+ pr)) (cons (list c e pr (1+ pr)) lr) lr) ) ) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ; ;; upd_openlst ; ;; ; ;; Each node of the openlst is passed to this sub and we scan the edges list ; ;; to find the corresponding edges. Then both points of the edges are tested ; ;; for equality to the nodes. The fixed cost (distance) is updated and so is ; ;; the estimated total distance. Updates are first put in a temporary node. ; ;; ; ;; We then proceed to test if the temp variable is already in the closelst ; ;; and proceed to the next edge. ; ;; ; ;; If temp is true and temp is not in closelst we go to the recursive sub ; ;; in_openlst which adjust the values and return the updated openlst ; ;; ; ;; Upon return we sort the openlst on smallest estimated distance ; ;; and return the openlst to the main routine ; ;; ; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun upd_openlst (node endp openlst closelst / lEdges pt fcost p1 p2 d l? temp) (setq pt (car node) fcost (caddr node) ) (setq lEdges (getCell pt)) (foreach edge lEdges (setq l? (car edge);new e (cadr edge);new pr1 (caddr edge);new pr2 (cadddr edge);new p1 (vlax-curve-getPointAtParam e pr1);new p2 (if l? (vlax-curve-getEndPoint e) (vlax-curve-getPointAtParam e pr2));new d (·dist· l? e pr1 pr2);new temp nil ) (cond ((equal pt p1 1e-4) (setq temp (list p2 p1 (+ fcost d) (+ fcost d (distance p2 endp)))) ) ((equal pt p2 1e-4) (setq temp (list p1 p2 (+ fcost d) (+ fcost d (distance p1 endp)))) ) ) (if (and temp (not (memberfuzz (car temp) closelst))) (setq openlst (in_openlst temp openlst)) ) ) (vl-sort openlst (function (lambda (a b) (< (cadddr a) (cadddr b))))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun in_openlst (node lst) (cond ((not lst) (list node)) ((equal (car node) (caar lst) 1e-4) (if (< (cadddr node) (cadddr (car lst))) (cons node (cdr lst)) lst ) ) (t (cons (car lst) (in_openlst node (cdr lst)))) ) ) ;; ; ;; get_path ; ;; ; ;; Returns The list of points of shortest path found from closelst. ; ;; ; (defun get_path (lst / path) (setq path (list (caar lst)) prev (cadar lst) lst (cdr lst) ) (while (setq lst (memberfuzz prev lst)) (setq prev (cadar lst) path (cons (caar lst) path) ) ) path ) ;; ; ;; memberfuzz by Gile Chanteau ; ;; ; ;; Modified to work with nodes list ; ;; ; (defun memberfuzz (p lst) (while (and lst (not (equal p (caar lst) 1e-4))) (setq lst (cdr lst)) ) lst ) ;; ; ;; f3Dpol ; ;; ; ;; Draw an 3dpolyline given a point list ; ;; ; ;; Will be drawn on layer, lineweight and color defined by Variables ; ;; at beginning of program. ; ;; ; ;;;ADDED by GLAVCVS (defun f3Dpol (pts c / ep ll la e) (setq ep (if (= 1 (getvar (quote cvport))) (vla-get-PaperSpace acdoc) (vla-get-ModelSpace acdoc)) ll (apply (function append) pts) la (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length ll)))) (mapcar (function float) ll)) e (vla-Add3DPoly ep la) ) (vla-put-Color e c) (vla-put-Layer e Pathlay) (vla-put-Lineweight e Pathlwt) (vlax-vla-object->ename e) ) ;; ; ;; mk_lwp ; ;; ; ;; Draw an lwpolyline given a point list ; ;; ; ;; Will be drawn on layer with color and lineweight defined by Variables ; ;; at beginnung of program. ; ;; ; (defun mk_lwp (pl) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 8 Pathlay) (cons 62 Pathcol) (cons 90 (length pl)) (cons 70 (* 128 (getvar (quote plinegen)))) (cons 370 Pathlwt) ) (mapcar (function (lambda (a) (cons 10 a))) pl) ) ) ) (defun glvFix (r i / f f1) (if (= (setq f (fix r)) (setq f1 (fix (+ r i)))) f f1)) ;; A wrapper for the rtos function to negate the effect of DIMZIN - Lee Mac (defun LM:rtos (real units prec / dimzin result) (setq dimzin (getvar (quote dimzin))) (setvar (quote dimzin) 0) (setq result (vl-catch-all-apply (function rtos) (list real units prec))) (setvar (quote dimzin) dimzin) (if (not (vl-catch-all-error-p result)) result ) ) ;; Error Handler by Elpanov Evgenyi ; (defun set_errhandler (l) (setq varl (mapcar (function (lambda (a) (list (quote setvar) a (getvar a)))) l)) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; MAIN ROUTINE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; Change values of following 3 variables to suit your need. ; (setq Pathlay "0" Pathcol 3 ; 1=Red 2=Yellow 3=Green etc. ; Pathlwt 30 ; lineweight for path 0.3 mm ; ) (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))) (set_errhandler (list "clayer" "osmode" "cmdecho")) (setvar (quote cmdecho) 0) (setvar (quote osmode) 1) (setvar (quote lwdisplay) 1) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (prompt "\nSelect LINE and polygonal POLYLINE network entities...") (if (setq sspl (ssget '((0 . "*LINE")))) (foreach en (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex sspl))) (addToDict en) ) ) (initget 1) (setq startp (getpoint "\nPick or specify Start Point : ")) (initget 1) (setq endp (getpoint "\nPick or specify End Point : ")) (setq openlst (list (list startp (list 0.0 0.0 0.0) 0.0 (distance startp endp)))) (vla-startundomark acdoc) (setq ti (getvar (quote millisecs))) (while (and openlst (not found)) (setq node (car openlst)) (if (equal (car node) endp 1e-4) (setq found t closelst (cons node closelst)) (setq closelst (cons node closelst) openlst (upd_openlst node endp (cdr openlst) closelst)) ) ) (if found (if (vl-some (function (lambda (x) (not (equal (last x) 0.0 1e-4)))) (setq path (get_path closelst))) (setq e (f3Dpol path Pathcol)) (setq e (mk_lwp path)) ) (alert "No path was found...") ) (princ (strcat "\nExecution time : " (itoa (- (getvar (quote millisecs)) ti)) " milliseconds...")) (*error* nil) ) In any case, I haven’t tested the code thoroughly enough on drawings containing “splines” or other complex linear objects. In addition, there may be some situations that may not be covered. But it should work. In any case, the code is open to any improvements anyone may want to make. Best regards.
  10. foer
    no function definition: RLXPREVIEWDCL_CHECKMANUALINPUTSOURCEFOLDER
  11. BIGAL
    Another way around the task is to use a lisp to do all the calculations and the object from 1st principles. ie not a Dynamic block. Something like this. You could have a first dcl with images so choose shape, then 2nd dcl pops up with the enter values. Let me know if you want something, post a sample dwg for layers etc.
  12. Good day all, I have a dynamic block that I use to stretch to the right size for fabrication of panels. I am trying to get the block to automatically add holes as the panel is stretched. The holes need to be spaced equally at maximum 16" o.c. I have set up all my formulas, etc. and in Block editor it looks good. The array is showing properly, etc. The problem is that when I stretch the panel, the holes and formulas do not automatically update. In fact when I stretch the panel, the Constraint dimension that I use for my calculations does not stretch with the panel. It moves the entire constraint dimension. Therefore my formulas are not updating and the array is not working as required. I have tried numerous attempts to get this dclinear dimensions to stretch with the panel to no avail. Maybe there is another way to do this? Ideally when i stretch the panel, the holes should update as per my formulas. Link to AutoCAD Forum with pictures. https://forums.autodesk.com/t5/announcements-and-meet-greet/dynamic-block-with-array-of-rivet-holes-problem/td-p/14007890 Any help is appreciated.
  13. marko_ribar
    I've added (c:lw_orth-2) and (c:lw_orth-grread-2), but IMHO, version 1 is better... Here is link... Regards, M.R.
  14. CyberAngel
    custom part builder
    If I'm looking at the same subsystem, when you edit a part drawing, the Toolspace includes Model Parameters (under Modeling) and Size Parameters (under the part). When you right click on a part in the Size Parameters, you get an "Edit..." option. That opens an "Edit Part Sizes" window, which is a table. Pull down the box on the toolbar (the default is Values) and pick Parameter Configuration instead. That gives you a different table with more rows. One of those rows is Units. Check the units for your part and see if they match your drawing. If that doesn't take care of your issue, please give us more information.
  15. I use the dimensions in the drawing in mm. I need a copy of the dimensional text in m for further calculations. Therefore, the @ronjonp code is quite suitable for me.
  16. You are most welcome.
  17. Converting mm dimension to m? My preference would be to leave the dimension to measure properly and adjust the scale in the properties to 0.001, then you can just copy the text and everything is consistent.
  18. thank you tharwat
  19. BIGAL
    Converting menues
    Yep same for if you do or dont like the Ribbon. Ribbonclose and Ribbon.
  20. john madsen
    Converting menues
    MENUBAR = 1
  21. The path found has to travel on edges not on points. If your graph does not have edges on the diagonal of the nodes it cannot find that path. ymg
  22. I must apologize for forgetting to reply to your comment. Please forgive me for this. Welcome to the forum. Yes, that's right. In the case of that drawing, the code doesn't return the shortest path. Perhaps it's a limitation of A* for drawings like this. I think @ymg3 is the most qualified to answer this.
  23. Douaa
    custom part builder
    when i design a custom manhole in part builder , i have a problem that when i do swap part to place the new manhole that i created instead of an old one in my network (my model), the new manhole seems quite big its even bigger than my model so what do you think i should do ? my manhole is in mm and all the part in my system is in mm but when i measure it in the system its in m .
  24. SLW210
    Converting menues
    Would you mind sharing the solution?
  25. SLW210
    Hybrid parallel
    It will probably be next week before I can check out QGIS solutions. From the user's perspective, even if off in a few spots, several of these LISP solutions here are faster (maybe more accurate), even including time to adjust manually than most of the other solutions for GIS, though I am no speed demon in GIS. Just look at all of the prep work on the Whitebox Tools, though if I had all of those branches and islands as well as a few oxbows, thin connections, etc. like the example, that would be the way to go as far as I can tell, I do believe it also works on vector, IIRC. It looks like part of that is free as a Python toolset, I'll try to read up some more on that. As I mentioned long ago in this thread, my daughter's co-workers are using AutoCAD to create the centerlines and manually adjusting if needed even though they have ArcGIS, though they may not have the extra tools that have the easy centerline tools. From what I looked up, ArcGIS made some tools a higher priced tier. Maybe asking a few questions on some GIS forums might yield more information.
  26. john madsen
    Converting menues
    Thanks for your responce. I found a solution and it´salle working....
  27. PGia
    Hybrid parallel
    That's interesting. Although the starting points seem to be different: pixels vs. vectors. In any case, it would be interesting to test the geometric robustness of that central line. That is, what it can return in some of the more challenging vector examples we've tested here.
