Get length of MLeader/QLeader spline.
BIGAL replied to SLW210's topic in AutoLISP, Visual LISP & DCL
As I suggested can move the vertices and return the new length or say draw something and move say the first point keep repeating till it is the length you want. Will have a play. - Yesterday
TEXT HEIGHT VALUE FOR ARCHITECHTURAL UNIT IN TEXT TAB OF DIMSTYLE MANAGER DILOG
SLW210 replied to LIU's topic in AutoCAD Beginners' Area
If Architectural units are being used, entering 2.6 in the Text Height box would make the text 2.6" in Architectural format that's shown as 2- 15/32". The equivalent to 2.6mm text height for Architectural is 1/8" or .125". -
SLW210 replied to SLW210's topic in AutoLISP, Visual LISP & DCL
But wouldn't undo change it back to original length? Still looking to decipher this one, probably tomorrow when I get back to work. -
Getting and modifying attribute text inside a dynamic block
Thanks ı got the part of ı needed. - Last week
LISP to select lines and text according to "Z" values
Nikon replied to shokoufeh's topic in AutoLISP, Visual LISP & DCL
If all the primitives (TEXT,MTEXT,INSERT,LINE,LWP,Circle,Mleader,Dimension) are perceived as objects, then you can use this code: ;; Set coordinates of objects (TEXT,MTEXT,INSERT,LINE,LWP,Circle,Mleader,Dimension) Z in 0 (defun zeroz-in-list (lst /) (cond ;; The list of coordinates-vertex ((and (listp lst) (= (length lst) 2) (numberp (car lst)) (numberp (cadr lst))) ;; if only XY - expanding to XYZ (list (car lst) (cadr lst) 0.0) ) ((and (listp lst) (= (length lst) 3) (numberp (car lst)) (numberp (cadr lst)) (numberp (caddr lst))) ;; if already XYZ - just do Z=0.0 (list (car lst) (cadr lst) 0.0) ) ;; If it's a large list, it's probably nested ((listp lst) (mapcar 'zeroz-in-list lst) ) (t lst) ) ) (defun c:ObjZ0 (/ ss n e el newel) (prompt " Select objects (all types, including polylines, mleader, dimension): ") (if (setq ss (ssget)) (progn (setq n 0) (while (< n (sslength ss)) (setq e (ssname ss n) el (entget e) newel nil ) (foreach pair el (cond ;; height LWPOLYLINE (code 38) ((and (= (car pair) 38) (numberp (cdr pair))) (setq newel (cons (cons 38 0.0) newel)) ) ;;Point codes (for example, 10, 11, 12...), etc. ((and (numberp (car pair)) (not (= (car pair) 210))) ; Don't touch the normal (if (listp (cdr pair)) (setq newel (cons (cons (car pair) (zeroz-in-list (cdr pair))) newel)) (setq newel (cons pair newel)) ) ) ;; The rest (t (setq newel (cons pair newel))) ) ) ;; Restoring order and modifying the object (entmod (reverse newel)) (setq n (1+ n)) ) ) ) (princ) ) If the Z coordinate is not displayed in the properties (example, for dimensions, for Mleader), then you need to use the _LIST command. Don't think of me as a programmer... The code is written using AI. -
Steven P replied to shokoufeh's topic in AutoLISP, Visual LISP & DCL
Use what you have done previously but for dx code 10: (foreach dxf le (if (= (car dxf) 10) (setq le (subst (cons 10 (zeroz (cdr dxf))) dxf le)) ) ) -
shokoufeh replied to shokoufeh's topic in AutoLISP, Visual LISP & DCL
Oh OK. Thanks for mentioning -
GLAVCVS replied to shokoufeh's topic in AutoLISP, Visual LISP & DCL
Yes I briefly forgot that LWPOLYLINES don't have a Z coordinate and instead use group 38 to define their elevation. Therefore @shokoufeh: the code you added to set the Z for LWPOLYLINES is unnecessary -
so, how should I change the code? -
Missed your message but am intrigued now... (a guess I would say you were saying LWPolyline has X, Y, Z coords - I've done the same many times too) -
I think hatch is the first '10' if an elevation has been set (10 0.0 0.0 'Z') -
I was checking my files and I found out another problem. Except elements I mentioned (lines, poly lines, texts and blocks), the problem with Z values exist in other elements, as I mention below: Hatch: Elevation Leader: Vertex Z Ellipse: Start Z, Center Z, End Z Arc: Start Z, Center Z, End Z Circle: Center Z Solid: Elevation Attribute Definition: Text Alignment Z Array (Rectangular) : Base Z Please check this modified lisp and see if it is correct or not. This lisp doesn't work on HATCH. ZRemove.lsp -
oddssatisfy replied to LIU's topic in AutoCAD Beginners' Area
Enter 2.6 in the Text Height box. -
Sorry: That problem will never exist in a LWPOLYLINE: Forget what I said, if you managed to read the previous message -
Sorry: The problem I referred to will never exist in a LWPOLYLINE: Forget what I said, if you managed to read the previous message -
Steven P started following LISP to select lines and text according to "Z" values
There was a thread a few days ago about speeding up a LISP to do the same, have look at that for ideas. I think the thread got as far as arcs are tricky to do with LISPs. You could use the flatten command for small drawings. This snippet will filter a selection set to lines or LWPolylines to anything not 0 Z (setq MySS (ssget (list (cons 0 "*TEXT,INSERT,LINE,LWPOLYLINE") '(-4 . "<OR") '(-4 . "*,*,<>") (list 10 0.0 0.0 0.0) '(-4 . "*,*,<>") (list 11 0.0 0.0 0.0) '(-4 . "<>") (cons 38 0) '(-4 . "OR>") )) ; end list, end ssget ) Can be added to the other solutions herein the case that your drawing has a lot of lines / polylines / blocks it speeds it up a bit Link to other thread: -
Sounds good If you've tried it and it works: -
GREAT. It works. Thank you very much -
Try again (defun c:todoA0 (/ cj e le n to p1 p2) (IF (setq cj (ssget "x" '((0 . "TEXT,MTEXT,INSERT,LINE,LWP*")))) (while (setq e (ssname cj (setq n (if n (1+ n) 0)))) (setq le (entget e) to (cdr (assoc 0 le)) p1 (assoc 10 le) ) (cond ((= to "LINE") (setq p2 (assoc 11 le)) (entmod (subst (cons 10 (list (cadr p1) (caddr p1) 0.0)) p1 le)) (entmod (subst (cons 11 (list (cadr p2) (caddr p2) 0.0)) p2 (entget e))) ) ((= to "LWPOLYLINE") (entmod (subst (cons 38 0.0) (assoc 38 le) le)) ) ((member to '("TEXT" "MTEXT" "INSERT")) (entmod (subst (cons 10 (list (cadr p1) (caddr p1) 0.0)) p1 le)) ) ) ) ) (princ) ) -
Please check this code. I made a few modification, and I think now it works for both start and end Z values. ZRemove.txt -
Z Value Problem-modified.dwg -
Wow It worked great. thank you very much. just one last question: Only "End Z" of lines are being modified to Zero. how can I make this modification to "Start Z" of lines, too? -
Try (defun c:todoA0 (/ cj e le n to p1 p2) (IF (setq cj (ssget "x" '((0 . "TEXT,MTEXT,INSERT,LINE,LWP*")))) (while (setq e (ssname cj (setq n (if n (1+ n) 0)))) (setq le (entget e) to (cdr (assoc 0 le)) p1 (assoc 10 le) ) (cond ((= to "LINE") (setq p2 (assoc 11 le)) (entmod (subst (cons 10 (list (cadr p1) (caddr p1) 0.0)) p1 le)) (entmod (subst (cons 11 (list (cadr p2) (caddr p2) 0.0)) p2 le)) ) ((= to "LWPOLYLINE") (entmod (subst (cons 38 0.0) (assoc 38 le) le)) ) ((member to '("TEXT" "MTEXT" "INSERT")) (entmod (subst (cons 10 (list (cadr p1) (caddr p1) 0.0)) p1 le)) ) ) ) ) (princ) ) -
thank you. It seems that this lisp finds the lines with Z value problem and adds a label near them. It is great that it can find the lines, but I don't want this label to be added near this lines. I only need to select them. Can this lisp file be modified, so that it changes the Z values of the selected lines, to Zero? I mean, it selects the lines and modifies the "Start Z" and "End Z" to 0. -
Lisp to create Building Envelope with various offsets.
andyb57J replied to andyb57J's topic in AutoLISP, Visual LISP & DCL
thanks. I will see how I go creating the dynamic block. It does sound like what I want
