groutiles joined the community
Function to calculate Mtext Justification based on Rotation
I am not gonna lie, its cool!!!! Maybe I can create a separate function have this as my mtext (after some polishing and maybe a menu setting). I will spend sometime and try and remove the FFL function and just keep the text function with prefix suffix, offset, and mouse movement and post it here. - Today
Linking viewport to what it shows
Someone_Pro replied to Someone_Pro's topic in AutoCAD Drawing Management & Output
Thank you for your reply! I was not the one who developed the code so I can only modify the sittings as they are. And it'll only let me freeze or thaw layers. I was hoping I can just freeze the VP layer to stop what's inside from printing when lunching the code. But it seems that won't be possible. -
If you were to use an A2 paper size at 1 to 50, the viewport areas should be much closer.
The difference of scaling between metric paper sizes is the square root of two. So you would have to scale the A3 to 70.7143 for the two sheets to match. However, with the paper margins and any title block requirements, the actual scaling could alter so that the viewport areas would match.
grain started following Trouble displaying drawing in Viewport
I have a drawing made in model space and displayed at 1:100 in an A4 Viewport Landscape layout. No problem, but when I open a second layout using an A3 paper size I assumed the drawing would automatically fit if scaled at 1:50, however, the drawing appears cropped. Please help me understand what I may be expecting or doing wrong.
qwer joined the community
where do you find Penn Foster Cad files for coursework?
ReMark replied to LrdDracul's topic in Student Project Questions
Those course (i.e. - project) files would only be available to actual paying students although if you were to search through the many threads re: Penn-Foster you could conceivably find individual project files students have posted copies of over the years. For example, the Oleson Village Project. What is your interest in the files? -
SLW210 replied to Someone_Pro's topic in AutoCAD Drawing Management & Output
You can turn the viewport off and everything in it will not plot. Frozen layers will still plot, you need to turn them off. -
gaspibarna joined the community
Automatically add text to a table
Emmanuel Delay replied to shokoufeh's topic in AutoLISP, Visual LISP & DCL
I think this is what you want. Command ATTT (vl-load-com) ;; ATTT for Add Text To Table (defun c:ATTT ( / rowstart obj texts i x x_vals x_vals_sorted) (setq rowstart (getint "\nStart Row (row 1 = the row of 000): ")) (setq obj (vlax-ename->vla-object (car (entsel "\nPick table: ")))) (princ "\nSelects the green title objects: ") (setq texts (ssget (list (cons 0 "TEXT") (cons 8 "TEXT-0.3")))) (setq x_vals (list)) (setq i 0) (repeat (sslength texts) (setq x (nth 0 (cdr (assoc 10 (entget (ssname texts i)))))) (setq x_vals (append x_vals (list x))) (setq i (+ i 1)) ) ;; sort the x-values (setq x_vals_sorted (vl-sort-i x_vals '<)) (setq i 0) (setq col 0) (repeat (sslength texts) (setq text (ssname texts (nth i x_vals_sorted))) (setq title (cdr (assoc 1 (entget text)))) (setq row (+ i rowstart)) (vla-settext obj row col title) (setq i (+ i 1)) ) (princ) ) -
If you just want to add to end of a table it is easy as there is a function of Vla-insertrow so just do that for the extra text you want I would look at a selection set. So can do in random order or some sorted list of the selection set. Could then read the entire table and resort it if required.
Emmanuel Delay started following Automatically add text to a table
I think based on something Bigal wrote, link in the code. Command TEST (feel free to rename) - User selects the table - User picks the start row. Fill in 1 for the row of 000, Fill in 2 for the row of 001, ... (you can hardcode this (setq row 1) if you will always start with 1 - User selects the title objects, the green text objects "GENERAL NOTES 0" ... one by one ;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/user-text-to-existing-table-cells/td-p/12238012 ;;You can get tables using ssget. ;; ;;I just posted this, the 0 0 is the title, 1 1 is 1st cell in header (vl-load-com) (defun c:test ( / obj rows cols row col value_ cellvalue) (setq obj (vlax-ename->vla-object (car (entsel "\nPick table: ")))) (setq rows (vlax-get-property obj 'rows)) (setq cols (vlax-get-property obj 'columns)) ;; get value of a cell ;;(setq col (getint "\nColumn: ")) ;;(setq row (getint "\nRow: ")) ;;(setq cellvalue (vlax-variant-value (vla-GETCELLVALUE OBJ row col))) ;;(princ "\n") ;;(princ cellvalue) ;;;;;;;;;;;; (setq col 0) (setq row (getint "\nStart Row (row 1 = the row of 000): ")) (princ "\nNow select texts: ") (while (setq title_obj (entsel "\ntitle object: ")) (setq title (cdr (assoc 1 (entget (car title_obj))))) ;;So if you know where "REVISION" is row & column can check easy then use next to put values. (vla-settext obj row col title) (setq row (+ row 1)) ) ) Happy with this? We can quite easily let you select all the all the frames, and read all the Text objects on layer "TEXT-0.3", sort from left to right, ... then auto fill in the table If you want -
Mukesh Kumar joined the community
vunm joined the community
LrdDracul started following where do you find Penn Foster Cad files for coursework?
LrdDracul posted a topic in Student Project Questions
I have looked everywhere for coursework cad files and haven't found anything. any help would be appreciated It tells you to go to 'X' file, but it doesn't exist. -
LrdDracul joined the community
Someone_Pro started following Linking viewport to what it shows
Hello, Can anyone help me with my dilemma. I'm doing AutoCAD automation and I want a schedule to not shows at time but show at other times. The schedule is shown through a viewport. I have tried making a costume viewport layer for it and freezing it. But freezing the layer of the vp does not seem to stop what inside the vp from printing. So is there an option to link the viewport to what it shows so if I freeze the vp layer it won't print what it shows.
Someone_Pro joined the community
CADTutor started following New user registrations
Hi All, This is just to let you know that we have recently had a problem with the validation of new user registrations. This meant that some people will not have been able to register for the forum. This must have been frustrating and I apologise for any inconvenience this may have caused. The problem with the anti-spam controls has now been fully resolved and all visitors are now able to register. Thanks for your continued support, David
- 1
Alain.j joined the community
Dynamic blocks with alignement parameter and attribute text
Alain.j posted a topic in AutoCAD Drawing Management & Output
How to keep attribute's text horizontal (rotation =0) by dynamic blocks with alignement parameter ? i see a lot of info for keeping text horizontal by block rotation but not for block alignement. -
Springfishblue joined the community
Hi every one I need a lisp that adds the texts I select, to a pre defined table in Autocad. In the attached file, I need to select texts in the "DRAWING TITLE" part, and add them to the first column of the table. It would be great if the lisp, itself, can automatically select all of the mentioned texts and add them to the table. But if not, I can manually select the texts, and the lisp adds them to the table. Add Text to Table.dwg
Multileader justify paragraph doesn't work
3dwannab replied to 3dwannab's topic in AutoCAD Bugs, Error Messages & Quirks
@BIGAL, sorry for the late reply. Here's the property: \pxqj;all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; all work and no play makes jack a dull boy; See screen shot of the properties that shows this too along with how the mleader is left justified and not using justified paragraph. The editor is correct, but as soon as I exit, it displays as above. -
This fake is worth more than two cents. The code works the way I wanted it to. Thanks! But I don't understand why I should drive carefully.
No, I mean the data returned by my (LM:arraydata) function - you just assumed you should use the length of the list, without actually checking what the list contains.
P.S.: This is just my two cents — though to be honest, it’s probably counterfeit
This is the first time I’ve ever done an “autopsy” on an object like this. I’ve carefully extracted what seemed to me to be the information I was looking for. So I must say: DRIVE CAREFULLY AND RESPECT ALL STOP SIGNS.
(defun c:CountElemArrayrect (/ ss n pt ent le dameFFCC) (defun dameFFCC (ent / items rows cont cols filas) (foreach l (entget (cdr (assoc 330 (entget (cdr (assoc 330 (entget ent))))))) (cond (items (if (= (setq cont (+ (if cont cont 0) (if (= (car l) 90) 1 0))) 3) (setq cols (cdr l) items nil cont nil))) (rows (if (= (setq cont (+ (if cont cont 0) (if (= (car l) 90) 1 0))) 3) (setq filas (cdr l) rows nil cont nil))) ((= (car l) 1) (if (= (cdr l) "Items") (setq items T) (if (= (cdr l) "Rows") (setq rows T)) ) ) ) ) (if (and filas cols) (* filas cols)) ) (princ "Select a arrayrect: ") ;;; (setq ss (ssget '((0 . "ARRAY"))) ;;; n 0) (if (and (setq ent (car (entsel))) (= (cdr (assoc 0 (setq le (entget ent)))) "INSERT") (= "ACDBASSOCDEPENDENCY" (cdr (assoc 0 (entget (cdr (assoc 330 le))))))) (progn (setq n (dameFFCC ent)) ;;; (vla-get-Count ;;; (vlax-ename->vla-object (ssname ss 0)))) (princ (strcat "The number of elements in the array: " (itoa n))) (princ "Specify the insertion point of the text: ") (setq pt (getpoint)) (if pt (entmakex (list (cons 0 "TEXT") (cons 10 pt) (cons 1 (itoa n)) (cons 40 25) ; text height (cons 7 (getvar "TEXTSTYLE")) ) ) ) ) ) (princ) )
number of array elements.dwg
If you post an example drawing, maybe someone else will be encouraged to join the conversation.
DXF data ( (-1 . <Object name: 233aa8f9cf0>) (0 . "INSERT") (5 . "17957") (102 . "{ACAD_REACTORS") (330 . <Object name: 233aa8f9d80>) (102 . "}") (330 . <Object name: 23bc15009f0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "Hatching") (100 . "AcDbBlockReference") (2 . "*U268") (10 77260.1 54657.3 0.0) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0) ) I've looked at the data, but I need professional help... How can I count elements in an array in lisp?
Did you even look at the data that my function returns?
