  1. Today
  2. Yesterday
  3. lamensterms
    3D Spline to Arcs
    Oh that's cool, thanks for that lrm that will save quite a few steps in my process! Thanks again
  4. BIGAL
    Layer Table (Lines and Text)
    Bit odd yes tested in Bricscad, I will look at the getcellextents, this gives the XY position of the corners of the table cell. If the line is 69 times repeated it sounds like that is the problem. I will make a little test program so can look at what is going on when calculating the Pt1 and Pt2. the code is done that way so if row height is changed for other users the lines are still central in the cell. Add the (princ line and look at the Y value displayed, it should change for every row. Please let me know if it is not changing. (setq pt2 (list (nth 6 pts)(nth 7 pts) 0.0)) (princ (strcat "\n" (rtos (cadr pt1) 2 3) " ")) (setq vdist (/ (- (cadr pt1) (cadr pt2)) 2.0)) Another test could some one try on Acad. 0 is 1st column. (setq objtable (vlax-ename->vla-object (car (entsel "\nPick a table ")))) ; put a number like 3+ in row variable ; then copy this line to command line change the 3 etc to 4 5 6 and so on ; The Y value should change (setq pts (vlax-safearray->list (vlax-variant-value (VLA-GETCELLEXTENTS objtable 3 0 :vlax-false))))
  5. mhupp
    Works with BricsCAD. I know you have to wrap points in AutoCAD sometimes with (vlax-3d-point pt2) not sure about entmake tho.
  6. I don't work with this feature alot so might not be the best to answer this. the double L is two single L's just one is rotated. https://www.youtube.com/watch?v=57wTY5b8qcc&t=635s
  7. f700es
    CMS Intellicad 14 review
    We bought a user at work a copy of CMS IntelliCAD a few years ago that just needed CAD every now and then and so far it was a great buy. For it's price it's hard to beat.
  8. lrm
    3D Spline to Arcs
    @lamensterms I'm glad you found spline curvature VLISP program helpful. Here's another program that you may find useful. It creates an arc through three point that may lie in 3D. Note, the ucs command would not use the 3 world points to correctly define the ucs I wanted so I had to use the more complex Z axis method in VLISP. ; create an arc through 3 points in 3D space ; lrm 3/9/2026 (defun c:arcIn3D( / p1 p2 p3 zpoint p1u p2u p3u) (command "_ucs" "w") (setq p1 (getpoint "\nPick start of arc: ") p2 (getpoint p1 "\nPick next point for arc: ") p3 (getpoint p2 "\nPick end point of arc: ")) (setq zpoint (mapcar '+ p1 (cross (mapcar '- p2 p1) (mapcar '- p3 p1)))) (command "_ucs" "za" "_non" p1 "_non" zpoint) (setq p1u (trans p1 0 1) p2u (trans p2 0 1) p3u (trans p3 0 1)) (command "_arc" "_non" p1u "_non" p2u "_non" p3u) (command "_ucs" "w") (princ) ) (defun cross (a b / crs) ; cross product of vectprs a and b (setq crs (list (- (* (nth 1 a) (nth 2 b)) (* (nth 1 b) (nth 2 a)) ) (- (* (nth 0 b) (nth 2 a)) (* (nth 0 a) (nth 2 b)) ) (- (* (nth 0 a) (nth 1 b)) (* (nth 0 b) (nth 1 a)) ) ) ;end list ) ;end setq c ) ;end cross arc_in_3d_space.lsp
  9. lamensterms
    3D Spline to Arcs
    Wow nice that looks like a very interesting tool, thanks lrm Your understanding of my task is correct. And your suggested workflow is pretty much what I have been doing (except without your LISP of course), and I was using 3DFACE to allocate my 'flat' points. One of the biggest and time consuming challenges has been to determine which points I will use to fit the ARCs to, while also maximising fit accuracy and also smoothness of the transition to the next ARC. I think your routine will come on quite handy to help me decide where to finish 1 ARC and begin the next Thanks again for sharing!
  10. lrm
    3D Spline to Arcs
    As I understand your question your goal is to approximate a 3D spline as a series of arcs (2d of course) that are positioned in series. To get a feel for the 3D nature and curvature of the spline I suggest first running my splinecurvature LISP program on the spline. Respond Y to the prompt: Do you want radius-of-curvature instead of curvature? [y/n] <n>: y and you will get a result like the following: The red lines are created at 100 points along the spline. They show the instantaneous radius of curvature of the spline at the points. The ends of the red lines are at the locations of the center of an arc that would duplicate the spline's curvature for a specific point on the spline. With this information you need to choose, starting at one end of the spline, 3 points along the spline that are in a generally "flat" area. Define a UCS for the 3 points then add an arc via the three point method. Repeat the process for the next "flat" section. Here are the results for two arcs. (defun C:SplineCurvatue (/ path inc n osm par der1 der2 curva p perp normv p2 sf curveType ans) ; = Degree Of Curvature - Lines ; Creates curvature lines or radius-of-curvature lines ; normal to a spline. ; LRM 8/18/2022 edited to place curvature vectors outside (setq path (car (entsel)) inc (/ (vlax-curve-getEndParam path) 100) n 0 osm (getvar 'osmode) ) (setvar 'osmode 0) (setvar "cmdecho" 0) (initget "y n") (setq ans (getkword "Do you want radius-of-curvature instead of curvature? [y/n] <n>: ")) (if (= ans "y") (setq curveType 1) (setq curveType 2 sf (getdist "Enter scale factor.") ) ) (repeat 100 (setq par (* inc n)) (setq der1 (vlax-curve-getfirstDeriv path par) der2 (vlax-curve-getSecondDeriv path par) ) ; calculate curvature at point par (setq d (distance '(0 0 0) (cross der1 der2))) (if (> (abs d) 1.0e-15) (progn (setq curva (/ (expt (distance '(0 0 0) der1) 3) d)) (if (= curveType 2) (setq curva (* -1. (* sf (/ 1. curva)))) ) (princ "\n") (princ n) (princ " curvature = ") (princ curva) (setq p (vlax-curve-getPointAtParam path par) perp (unitv (cross der1 (cross der2 der1))) normv (mapcar '* perp (list curva curva curva)) p2 (mapcar '+ p normv) ) (command "_.line" p p2 "") ) ; end progn ) (setq n (1+ n)) ) (setvar 'osmode osm) (setvar "cmdecho" 1) (princ) ) ;;; Compute the cross product of 2 vectors a and b (defun cross (a b / crs) (setq crs (list (- (* (nth 1 a) (nth 2 b)) (* (nth 1 b) (nth 2 a)) ) (- (* (nth 0 b) (nth 2 a)) (* (nth 0 a) (nth 2 b)) ) (- (* (nth 0 a) (nth 1 b)) (* (nth 0 b) (nth 1 a)) ) ) ;end list ) ;end setq c ) ;end cross (defun unitV ( v / d) (setq d (distance '(0 0 0) v) d (mapcar '/ v (list d d d)))) SplineCurvature.lsp
  11. lamensterms
    3D Spline to Arcs
    Hey thanks for the reply The reason to convert to a small quantity of ARCs is because the SPLINE will become fabricated out of steel pipe. Fab method requires the shape to be fabricated from curved pipe segments. Unfortunately for this project, corkscrew/spiral pipe segments are not an option, so we are stuck with ARCs
  12. CyberAngel
    3D Spline to Arcs
    Obviously, you can't use the original spline or you'd be doing that. It might help us to know why, though. I assume the goal is a 2D spline. Have you thought about starting with an actual spline? That way you can adjust the control points and their tangents, instead of using polyline arcs, which seems more complicated. If the goal is a 2D polyline, you can still draw it with a spline and then convert it to a polyline with SPLINEDIT. The more we know about your project, the better we can help. Right now I'm just guessing.
  13. CyberAngel
    *A##### Blocks
    Another way to handle this issue is to define your title block as an AutoCAD block. That way the seal is already included. You put the seal on its own separate layer and turn that layer on when necessary. Another option is to use visibility states, so you only tap on a button to show the seal. But first, as the other answers suggest, clean up the seal block. That may take care of it.
  14. Steven P
    If you want to do some thinking, this is the row that draws the line: (entmake (list (cons 0 "LINE") (cons 10 pt1) (cons 11 pt2) (cons 8 (cadr lay)))) work it out backwards from there and you might get close to what you want, need to adjust pt1 and pt2. Without looking properly I think BigAl has forgotten to increment something or a variable is set on the wrong side of a loop. Be good learning to see if you can get close?
  15. BIGAL: I agree with you 100%. Unfortunately, Penn-Foster does not offer TIN software nor do they teach its use. And, unless a student has some basic knowledge of LISP to begin with, I doubt they would even think of taking advantage of its functionality. In this project the old way is the best the students can count on. Re: Points. The project is not being done in 3D; strictly 2D all the way.
  16. CAD_Noob
    Thanks @BIGAL tested in AutoCAD 2024. some lines are not showing up. Anyway, the code by @nod684 works and it is according to my needs, Lines and Text not AutoCAD table. EDIT : I tried exploding the table and found that the 2nd line consists of 69 overlapping lines.
  17. Last week
  18. Welcome aboard, a little surprised that the exercise is to interpolate contour points. Given the availability of TIN software. That is a lot of points to tackle. Glad I am not doing that task. If I had to do it yes would use the method shown by @ReMark. But I would use a lisp to do the calculation making a Point at the correct distance then join all the points with a pline. I hope the little crosses are 3D so can pick pairs. Certainly have used the interpolation method in many other civil tasks, so well worth while learning how to do it.
  19. Hey, I've got a project that requires me to reproduce/trace a 3D spline, with ARC segments. The goal being to reproduce the SPLINE as accurately as possible, with as few ARCs as possible Just hoping to get some thoughts on methods to approach this challenge. Right now my method is to divide the SPLINE into sections based on the local normal-ness of part of the SPLINE. Just visually trying to fit each ARC to a portion of the SPLINE I have to perform this task 8 times for this project so hoping to come up with a neat and robust method DWG attached - in this example I am trying to work to a limit of 5 ARCs TEMP.dwg
  20. Thank you so much for you help! I made a spreadsheet in excel, can you take a look? and I have another question: how can I know in which squares to place the interpolations?
  21. In other words, you are having trouble understanding the concept of interpolation, correct? The mathematical interpolation of contours goes like this. Let's say we have two spot elevations A & B. A = 32.7 and B = 54.0. The distance between A & B = 50 feet. We want to know where our 40-foot contour would fall between spot elevations A & B. First obtain the total elevation difference. This is done by subtracting A from B. 54.0 minus 32.7 = 21.3. Next, we want the difference in elevation between our 40-contour interval and the nearest spot elevation which in this case is A or 32.7. That works out to be 7.3. Now we need to calculate the distance (let's call this "d") we need to go from spot elevation A to our 40-foot contour. That takes the form of: d/7.3=50/21.3 or d=7.3*50/21.3 = 7.3*2.347 = 17.13 or the distance, in decimal feet, to our 40-foot contour. Got all that? Good. Now go start interpolating.
  22. BIGAL
    Almost there its a table fixed a couple of bugs and done. Tested on a dwg with 500 layers a little slow takes a few seconds. ; https://www.cadtutor.net/forum/topic/99017-layer-table-lines-and-text/ ; Make a lgend of layers in dwg. ; Bt AlanH March 2026 (defun c:mktablay ( / colwidth doc lay lcol ldesc lname lst numrows objtable oldsnap pt pt1 pt2 rowheight) (defun CreateTableStyle ( / dicts dictobj key class custobj dwglays ) (setq dicts (vla-get-Dictionaries (vla-get-ActiveDocument(vlax-get-acad-object)))) (setq dictObj (vla-Item dicts "acad_tablestyle")) (vlax-for dname dictobj (if (= (vla-get-name dname) "DWGLAYERS" ) ; does it exist (princ "Found DWGLAYERS") (setq dwglays "No") ) ) (if (= dwglays "No") (progn (setq key "DWGLAYERS" class "AcDbTableStyle") (setq custObj (vla-AddObject dictObj key class)) (vla-put-Name custObj "DWGLAYERS") (vla-put-Description custObj "Dwg Index custom table style") (vla-put-BitFlags custObj 1) (vla-put-FlowDirection custObj acTableTopToBottom) (vla-put-HorzCellMargin custObj txtht ) (vla-put-VertCellMargin custObj txtht ) (vla-SetAlignment custObj (+ acDataRow acHeaderRow acTitleRow) acMiddleCenter) (vla-SetTextHeight custObj acDataRow txtht) (vla-SetTextHeight custObj acHeaderRow (* txtht 1.2)) (vla-SetTextHeight custObj acTitleRow (* txtht 1.5)) (vla-SetTextStyle custObj (+ acDataRow acHeaderRow acTitleRow) "Standard") ) ) (princ) ) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq txtht 1.5) (CreateTableStyle) (setvar 'ctablestyle "DWGLAYERS") (setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (setq lst '()) (vlax-for lay lays (setq lname (vlax-get lay 'name)) (setq lcol (vlax-get lay 'color)) (setq ldesc (vlax-get lay 'description)) (setq lst (cons (list lcol lname ldesc) lst)) ) (setq lst (vl-sort lst '(lambda (x y) (< (cadr x)(cadr y))))) (setq pt (vlax-3d-point (getpoint "\npick a point for table "))) (setq doc (vla-get-activedocument (vlax-get-acad-object) )) (if (= (vla-get-activespace doc) 0) (setq curspc (vla-get-paperspace doc)) (setq curspc (vla-get-modelspace doc)) ) (setq numrows 3) (setq numcolumns 3) (setq rowht 5) (setq colwidth 50) (setq objtable (vla-addtable curspc pt numrows numcolumns rowht colwidth)) (vla-settext objtable 0 0 "Layer Details") (vla-settext objtable 1 0 "Color Numb. & Linetype") (vla-settext objtable 1 1 "Layer Name") (vla-settext objtable 1 2 "Layer description") (setq objtable (vlax-ename->vla-object (entlast))) (setq rowht (vla-getrowheight objtable 1)) (vla-put-regeneratetablesuppressed objtable :vlax-true) (setq row 2) (foreach lay lst (princ (cadr lay)) (vla-settext objtable row 0 (strcat (rtos (car lay) 2 0) " ")) (vla-setcellalignment objtable row 0 acMiddleRight) (vla-settext objtable row 1 (cadr lay)) (if (= (caddr lay) "") (setq desc (cadr lay)) (setq desc (caddr lay)) ) (vla-settext objtable row 2 desc) (setq pts (vlax-safearray->list (vlax-variant-value (VLA-GETCELLEXTENTS objtable row 0 :vlax-false)))) (setq pt1 (list (nth 0 pts)(nth 1 pts) 0.0)) (setq pt2 (list (nth 6 pts)(nth 7 pts) 0.0)) (setq vdist (/ (- (cadr pt1) (cadr pt2)) 2.0)) (setq pt1 (mapcar '+ pt1 (list 5.0 (- vdist) 0.0))) (setq pt2 (list (nth 3 pts)(nth 4 pts) 0.0)) (setq pt2 (mapcar '+ pt2 (list (- 7.0) (- vdist) 0.0))) (entmake (list (cons 0 "LINE") (cons 10 pt1) (cons 11 pt2) (cons 8 (cadr lay)))) (vla-insertrows objtable (setq row (1+ row)) rowht 1) ) (vla-put-regeneratetablesuppressed objtable :vlax-false) (setvar 'osmode oldsnap) (princ) ) (c:mktablay)
  23. BIGAL
    PDF TO CAD FILE
    As I said previously "I am sure given that import a pdf and then re email the result back to you could be done by a friend as it takes like one minute." For that dwg maybe a few minutes, as suggested by @SLW210 do small bits at a time. @CHAKRADHAR It may cost you a little bit like cost of a cup of coffee. I can not help, Where are you in the world helps with time differences ? Some one here may be able to help. Did you contact ZWCAD, I know Bricscad are pretty good at listening to requests for missing functions.
  24. Hi, I'm a student from Pen Foster College and I have a trouble with this Project. I would like to get some help. For this part: Drafting the Existing Site Plan (Sheet 1): "Now, you need to figure out where the contour intervals cross the grid lines between each spot elevation. Create contours at 10′ intervals for just the 100′–180′ contour lines. You can estimate where a contour line intersects a grid line using interpolation. You can interpolate the position of the contours by estimating between the known locations of the spot elevations. You may find it quicker to set up a spreadsheet to help you calculate all the locations." Can someone guide me to get started with this part? please 3. Civil Engineering Drafting.pdf
  25. Here's my latest region segment copier.. (defun TLENGTH (/ di ent n pt1 pt2 sel) ;; https://ukcommunity.arkance.world/hc/en-us/articles/21550748461458-AutoCAD-Tip-Using-AutoLisp-to-calculate-total-length-of-multiple-objects (vl-load-com) ;; NotLoaded/Patrick_35/Tot-v1.03 ; (if (ssget '((0 . "LINE,POLYLINE,LWPOLYLINE,ARC,CIRCLE,ELLIPSE"))) (progn (setq di 0) (vlax-for ent (setq sel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (cond ((member (vla-get-objectname ent) '("AcDbLine")) ;; "AcDb3dPolyline" "AcDbPolyline" (setq di (+ di (vla-get-Length ent))) ;; <- not a2k op for /\ poly?? ) ((eq (vla-get-objectname ent) "AcDbArc") (setq di (+ di (vla-get-ArcLength ent))) ) ((eq (vla-get-objectname ent) "AcDbCircle") (setq di (+ di (vla-get-Circumference ent))) ) ((member (vla-get-objectname ent) '("AcDbSpline" "AcDbEllipse")) (setq di (+ di (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)))) ) ) ) ) (princ (strcat (rtos di 2 4) " :Len")) (princ) ) ;;// ----------------------------------------------------------------------------------------------------------- (defun c:crs (/ *error* ss ss1 ssm ssp cec doc lastent html) ;; AI.. https://www.google.com/search?q=copy+region+edge+segment%2C+autolisp&client=firefox-b-1-e&hs=LJSp&sca_esv=28d160b4388e87a1&biw=1143&bih=530&ei=t2enadf8OfXIp84PyJ69kA8&ved=0ahUKEwiXtPqy6oSTAxV15MkDHUhPD_I4ChDh1QMIEQ&uact=5&oq=copy+region+edge+segment%2C+autolisp&gs_lp=Egxnd3Mtd2l6LXNlcnAiImNvcHkgcmVnaW9uIGVkZ2Ugc2VnbWVudCwgYXV0b2xpc3AyCBAAGIAEGKIEMgUQABjvBTIFEAAY7wUyBRAAGO8FMgUQABjvBUjeM1C3D1iRLnABeACQAQCYAYgIoAHMC6oBBzAuNC43LTG4AQPIAQD4AQGYAgagApcNwgIIEAAYsAMY7wXCAgoQIRigARjDBBgKmAMAiAYBkAYFkgcHMS40LjYtMaAH0BCyBwcwLjQuNi0xuAffDMIHBzItMS4zLjLIB2uACAA&sclient=gws-wiz-serp (princ "\n ** wcs Copy Region Segment: <oops> ") ;; https://www.cadtutor.net/forum/topic/99013-segment-copy-of-a-region-cleaning-request/#findComment-678508 (setvar 'cmdecho 0) (vl-load-com) ;; (defun *error* ( msg ) (setvar 'cmdecho 0) ;; (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (if msg (prompt (strcat "\n" msg))) (if (= fin 1) (command "_.pasteclip" "0,0,0")) ;; restores region if incomplete/esc.. (setvar 'cecolor cec) ;; ch copied to prev (setvar 'cursorsize 100) (setvar 'osmode posm) (setvar 'nomutt 0) (setvar 'cmdecho 1) (princ) ) (setq posm (getvar 'osmode)) ;; better without end/with.nea (setvar 'osmode (boole 7 (getvar 'osmode) 512)) ;; adds <nea> (setvar 'osmode (boole 2 (getvar 'osmode) 1)) ;; removes <end> (vla-startundomark (vla-get-activedocument (vlax-get-acad-object))) ;; eases oops's/undo ;; clears clipbrd Roy_043;; https://www.cadtutor.net/forum/topic/62075-copy-to-clipboard/#findComment-512255 (setq html (vlax-create-object "HTMLFile")) (vlax-invoke (vlax-get (vlax-get html 'ParentWindow) 'ClipboardData) 'SetData "Text" "") (vlax-release-object html) (setq fin 1) (setq cec (getvar 'cecolor)) (setvar 'nomutt 1) ;; bypass ssget 'select prompt ;;// ----------------------------------------------------------------------------------------------------------- ;; init selection (while ;; loop/proof/select 1 region (not (setq ss (ssget ":S" '((0 . "REGION"))))) ) (command "_.copybase" "0,0" ss "") ;; copy region to clipbrd (command "chprop" ss "" "c" 142 "") ;; change color (setq LastEnt (entlast)) ;; Set LastEnt to last entity.;;; !! beginning of entity storage \/ (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (command "_.explode" ss) ;; make segs accessible (setq SS1 (ssadd)) ;; create a blank selection set 'SS1 for later use ;; or add to an existing one., (while (setq LastEnt (entnext LastEnt)) ;; Sets LastEnt to first entity name (ssadd LastEnt SS1) ;; adds LastEnt to new 'SS1 selection set, to erase later !! ) (while T ;; loop to multi-copy of exploded region.. <actually anything> (princ "\nSelect Region Segment to Copy ") (setvar 'cursorsize 1) ;; get cursor.lines out.of.site (initget 1) ;; added to filter but, 'rt.clk < pastes but as.from base zero > ;; usable (defun loop ( / ) ;; select.validator (and ;; when ssp+ssm happen.. (setq ssp (getpoint)) ;; get coords for copy/basepoint <----------------------- (if (not (setq ssm (ssget ssp '((0 . "*POLYLINE,ARC,CIRCLE,LINE,ELLIPSE"))))) ;; pick on segment [at 'ssp] (progn (princ "\rSelect Region Segment to Copy ")(loop)) ) ;; /\ NOT CATCHING: ITEMS.NOT.FROM.'EXPLODE' () ;; BUT STILL FUNCTIONS [COPIES] ANY.. ) ;; end of and ) ;; end of if (loop) ;; restart if not 'ssp type or open pic /\ (command "_.copy" ssm) ;; begin move a segment copy (setvar 'nomutt 1) ;; manual prompt (command "" ssp) ;; coords selected in /\ 'loop removed: (princ "\nSpecify Basepoint: ") (command "" "\\") (princ "\nSpecify Destination: ") (command "\\") ;; +move to (setvar 'nomutt 0) ;; turn prompt on (TLENGTH) (command "chprop" "_L" "" "c" cec "") ;; ch copied color to bylayer ) ;; end of while loop (setvar 'cursorsize 100) ;; set 'cross.hair.size' to normal (setvar 'nomutt 0) ;; turn prompt on (command "_.erase" ss "") ;; region copied/erasure (command "_.erase" SS1 "") ;; erases exploded (saved) selection set -|100 ; moved within while /\ (command "chprop" "_L" "" "c" cec "") ;; ch copied color to bylayer (command "_.pasteclip" "0,0") ;; re.places original copied region -|86 (setq fin nil) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) ;; eases oops's/undo (setvar 'cecolor cec) ;; resets color (setvar 'cursorsize 100) (setvar 'osmode posm) (setvar 'nomutt 0) (setvar 'cmdecho 1) (*error* nil) (princ) )
  26. SLW210
    PDF TO CAD FILE
    I have no issues turning the geometry text to MText in AutoCAD. No, you can select a range for the closest matching font, you can have a lot of fonts loaded or just a few, and it can do small or large selections, but better results are from small selections. I have already fixed the OP's file, easy peasy in AutoCAD.
  27. BIGAL
    PDF TO CAD FILE
    @SLW210 just import the sample File.pdf you will see the SHX text its pretty obvious. No pdfshxtext in Bricscad V25 lots of other pdf settings. I am pretty sure I have ran that command it asks for the text font to be searched for like ISOCP.shx and so on.
  28. BIGAL
    Can do the read excel bit but need a csv or Excel. making the table is not a problem. Have somewhere draw a line in a table or make a cell a full solid color, the other is add a block to a table. Bit busy at moment but maybe soon something. It may be easier to just read all current layer details as a step 2.
