Maybe have a look at the windows command findstr it will search a directory for a key word, I guess could open one at a time. findstr d2 d:/mylisps/*.lsp may be useful how I find old posts
mhupp started following Find in Notepad
in windows 11 they have two notepads now. think you will have to remove the app one to go back to the classic one. https://www.dedoimedo.com/computers/windows-11-notepad-classic.html
Attribute that updates based on location
Danielm103 replied to EYNLLIB's topic in AutoLISP, Visual LISP & DCL
Nice, I was thinking AcFdFieldReactor because it has all those plus REGEN, but it’s not available to lisp. You might add REGEN to the list, so the user can see the updated values without needing to save or plot. -
JerryFiedler started following Find in Notepad
@Steven P Your function seems to work for me although I am not sure what you expect. I am using Windows 11 and BricsCAD Pro V25. When I run my test program which calls your routine: NotePad++ is opened with the test data file, the specified text is highlighted and the text is in the "find" dialog box. ( I had to click the binocular icon as the find dialog did not open on its own.) Are you expecting the "find" dialog box to open automatically? testdata.txt testNF.lsp
Lee Mac replied to EYNLLIB's topic in AutoLISP, Visual LISP & DCL
Here's a proof-of-concept example for consideration - (defun update-attributes ( / bln idx ins map obj sel tag val ) (setq ;; List of ;; ((lower-left point) (upper-right point) "attribute value") map '( (( 0.0 0.0) (10.0 10.0) "abc") ((20.0 20.0) (30.0 30.0) "def") ) ;; Block name bln "YourBlock" tag "YourTag" ) (setq bln (strcase bln) tag (strcase tag) ) (if (setq sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 (strcat "`*U*," bln))))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) obj (vlax-ename->vla-object (ssname sel idx)) ) (cond ( (/= bln (strcase (vlax-get-property obj (if (vlax-property-available-p obj 'effectivename) 'effectivename 'name))))) ( (setq ins (vlax-get obj 'insertionpoint) val (vl-some '(lambda ( itm ) (if (vl-every '<= (car itm) ins (cadr itm)) (caddr itm))) map) ) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (if (vlax-write-enabled-p att) (vla-put-textstring att val) ) t ) ) ) (vlax-invoke obj 'getattributes) ) ) ) ) ) ) (defun block-position-callback ( rtr arg ) (if (and arg (wcmatch (strcase (car arg) t) "qsave,save,saveas,plot,publish")) (update-attributes) ) (princ) ) ( (lambda ( key ) (vl-load-com) (foreach rtr (cdar (vlr-reactors :vlr-command-reactor)) (if (= key (vlr-data rtr)) (vlr-remove rtr) ) ) (vlr-set-notification (vlr-command-reactor key '( (:vlr-commandwillstart . block-position-callback) ) ) 'active-document-only ) (update-attributes) (princ) ) "block-position-reactor" ) There is no command to run the program: simply amend the block name, tag name, and map at the top of the code to suit your setup, and then load the program - the attributes will be automatically updated when the drawing is saved or plotted. -
Pdietrich joined the community
pewex joined the community
EYNLLIB replied to EYNLLIB's topic in AutoLISP, Visual LISP & DCL
Probably a better idea. I have been looking into the object reactors and it was seeming like it was going to bog down the drawing immensely, since we will have dozens of these blocks in a single file. Thanks! -
I would suggest using a single command reactor to automatically update all blocks on save or plot - this is far simpler than using an object reactor to track modifications to each individual block reference. -
The issue is CAD literacy within the office. One of my engineers would be fine to use it, but the rest are fairly CAD illiterate. I try to keep things as simple as possible (I know running a lisp command is simple to begin with) -
Steven P started following Find in Notepad
Good Morning, I have been using this to search for text in a text file, now I have been upgraded to windows 11 it doesn't work, and I can't work out what change to make. Looking for some guidance again, thanks! fnm: File name (including filepath) str: Text String delay: a delay, say 1000 mS Will open notepad and should perform a 'find' to jump to the text. It gets as far as 'find' to open the dialogue box but won't populate it or hit 'enter' to do the find, using sendkeys - which has always worked before. thanks for any help ;;To find text within a text file. ;;http://www.cadtutor.net/forum/showthread.php?102326-Open-text-file-and-jumping-to-a-line&p=694572#post694572 ; example command to call it (NotepadFind "C:\\Downloads\\test 123.txt" "findtext" 300) (defun NotepadFind (fnm str delay / obj) (vl-catch-all-apply (function (lambda () (setq obj (vlax-get-or-create-object "WScript.Shell")) (vlax-invoke obj 'Run (strcat "Notepad.exe \"" fnm "\"")) ;; or notepad++ if that is used. (setvar 'cmdecho 0) (command "_.delay" delay) ; Milliseconds. For BricsCAD users: (sleep delay) does not work. (setvar 'cmdecho 1) (vlax-invoke obj 'AppActivate "Notepad++") ; Title bar name of application. ++ for notepad++ but still works? (vlax-invoke obj 'SendKeys (strcat "^f" str "{ENTER}{ESC}")) ) ) ) (if obj (vlax-release-object obj)) )
Koz joined the community
mhupp started following Create Camera view that reflects what you see
mhupp replied to pyou's topic in AutoLISP, Visual LISP & DCL
Camera command does 90% what your asking idk if it says layer states tho. - Last week
pyou started following Create Camera view that reflects what you see
Hello Is it possible to create a camera view in a drawing that captures what is currently visible, using a LISP command instantly? For example, when I rotate a 3D object and want to take a "screenshot" of that specific view. The proposed idea is to create permanent camera icons (or similar markers) in the drawing, allowing me to click on them to instantly switch to the saved viewing position as it was captured to review area. Thank you!
lrm started following How to draw the 3d block shown in the image sent?
lrm replied to hemal's topic in AutoCAD 3D Modelling & Rendering
Start with the profiles on the vertical back plane (XZ world) then extrude. Add consruction lines to define regions. Extrude regions, substract cylinders and union it all together. -
S L NARAYANA joined the community
Attributes be added to factor the outcome of Incremental numbers
u4ea2u2 replied to u4ea2u2's topic in AutoLISP, Visual LISP & DCL
Hi Bigal, Curious if had any questions.. if my description was clear. Thanks for looking into this. -
khouloud rezgui joined the community
Tjg23 started following Same Penn Foster Oleson Subdivision Nightmare... different day
Tjg23 replied to Ztrain's topic in Student Project Questions
@cmc1212 did you ever get help I know I’m here like 9 months after your post it I’m stuck and getting desperate -
Steven P started following Attribute that updates based on location
Steven P replied to EYNLLIB's topic in AutoLISP, Visual LISP & DCL
Reading this one, what is the objection to the engineers running a LISP? You could add it as a button, in the ribbon, or as a command to suit their preferences, and if you make it easier for them they'll use it. For example a single command to draw the rectangle and insert the block instead of 3 or 4 commands makes things quicker and easier, the engineers should jump on that (every speed improvement is after all another few seconds to go and make another coffee!) -
pjs3486 joined the community
Tjg23 joined the community
Properties 4,5,6 I can’t seem to get the right sizes or anything I saw your 2012 forum and thanks that helped me get to this point but I’m stuck now -
BIGAL replied to EYNLLIB's topic in AutoLISP, Visual LISP & DCL
If you use a reactor it is a lisp anyway and has to be ran every time you add the block, so as I suggested much easier to do a lisp that looks at the XY point and updates, a lisp will run through multiple blocks very fast and update all. Just make the lisp insert the block 1st. -
That seems very interesting!
@PGia In case you don't mind including all the file locations you need to reference in AutoCAD's "SupportPaths" (other external paths could also be considered, but would require more code), there is another option, unorthodox but disruptive: type the name of the file to open directly into the command line (but with a small convention) I think some of the participants in this thread know what I'm talking about. If not, I'll explain it with a little code when I get home.
Lee Mac started following Find&open files and Attribute that updates based on location
Don't create a new reactor for every object - this is likely to severely impact performance - only one object reactor is required with a set of owning objects. Aside, you're missing the definition for your (let*) function. -
I would also vote for Everything - it's ridiculously fast.
Try Overkill
Cad64 replied to hemal's topic in AutoCAD 3D Modelling & Rendering
My thought exactly. It looks like an Impossible Object. -
I use Everything all the time it indexes hard drives and finds a file instantly. Re Access, Word, Excel and Libre office all of these can be accessed from CAD I use Bricscad. You can for say Access not only open but actually get at the data, most common being Excel get and put. If you have a few known files you want to open all the time can either make a defun for each and load on startup or my preferred would be a sub menu in a POP menu with the file names as the description. As mentioned already using notepad is shown how in ACAD.PGP as an already defined option.
I did write something once to find and launch documents but its a little over the top probably. But Bigal also had a good suggestion , a program called everything.
