AutoCAD 2009 takes a long time to save/open single drawings?
muck
When I open/close a single drawing AutoCAD 2009 takes a long time.
When a multiple drawings loaded in CAD it does not take so long
to close a drawings until CAD is left with a single drawing. At that time
it takes a long time to save it.
Does anyone have this problem. Is there a solution other than keeping
a second open all the time.
Thank You
It happening a work computer which uses 2009 so I don't have any
control on what version I use. They have updated with service packs
but I don't know which ones. Just looking for an answer why it would be doing that.
I don't like running AutoCAD with two drawings when I am only working
on one.
Thank you,
Look in the Useful Links forum for a thread I put in a short while ago. It's called Open Close Save Hotfix for AutoCAD 2009. Perhaps it might be of some use to you.
Used the '07 Hotfix from AutoDesk. Before the fix, took a long time
to close *.dwg files.
