For years I have been using the following LISP file to Explode blocks into the layer the were inserted on, but now that I am using AutoCAD 2008, I get the following message "nil
LEXPLODE
Select block reference, polyline, dimension, or mesh:
*Invalid selection*
Expects a point or
Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
revious/Undo/AUto/SIngle"
And, if I select the same item again it explodes into the layer it was created on.
I am attaching the LISP file.
Any ideas?
BTW, I am running AutoCAD 2008 with windows XP X64.
LEXPLODE.LSP
It works on my PC, maybe some x64 AutoCAD bug? Try my just written code, it should work also as yours.
(defun c:lxplode(/ cSel cEnt oArr cLay)
 (vl-load-com)
 (if(setq cSel(entsel "\nSelect entity to explode: "))
     (setq cEnt(vlax-ename->vla-object(car cSel)))
     (if(vl-catch-all-error-p
   (setq oArr(vl-catch-all-apply 'vla-Explode(list cEnt))))
(princ "\n<!> Can't explode this entity <!> ")
  (setq cLay(vla-get-Layer cEnt))
  (foreach e(vlax-safearray->list(vlax-variant-value oArr))
    (vla-put-Layer e cLay)
    ); end foreach
  (princ (strcat "\nEntities exploded onto layer " cLay "."))
  ); end progn
); end if
     ); end progn
   ); end if
 ); end of c:lxplode
Thanks, your code works.
I think I must have changed something on my system variables because the same LISP that does not work on my machine, it works on the other X64 machines.
I will keep using your code.
Thanks again.
Excuse me. More three lines of code:
 (vl-load-com)
	       (list cEnt))))
    [color="SeaGreen"](vla-put-Linetype e "ByLayer")[/color]
    [color="#2e8b57"](vla-put-Lineweight e acLnWtByLayer)[/color]
    ); end foreach
  [color="#2e8b57"](vla-Delete cEnt)[/color]
  ); end progn
); end if
     ); end progn
   ); end if
 ); end of c:lxplode
ASMI, after seeing quite a few of your routines - you seem to use only Visual LISP, instead of the older style using DXF tables and whatnot. - When I was looking to approach this problem, I considered using a selection set and then going through each element individually as if it had been selected using entsel.
Could this same routine be accomplished without the use of Visual LISP?
I must admit, I try to avoid Visual LISP at all costs - I know it can accomplish tasks much easier - but I find the functions so complicated to get my head around - I suppose its just what you're used to. :)
In most cases use Visual LISP more convenient seems to me, but I can use and DXF codes. Here an example of this program without Visual LISP:
(defun c:lxplode2(/ cSel eEnt cLay lEnt cDxf nDxf)
     (setq eEnt(car cSel)
    cLay(cdr(assoc 8(entget eEnt)))
    lEnt(entlast)); end setq
     (if(and
   (vl-cmdf "_.explode" eEnt)
   (not(equal lEnt(entlast)))
   ); end and
         (while(setq lEnt(entnext lEnt))
  (setq cDxf(entget lEnt)
	nDxf(subst(cons 8 cLay)(assoc 8 cDxf)cDxf))
    (entmod nDxf)
   ); end while
  ); end progn
); end if
     ); end progn
   ); end if
 ); end of c:lxplode2
I think that studying Visual LISP for you only a matter of time. To tell the truth it is very good that you at first study usual AutoLISP because it base knowledge, without which Visual LISP will not give to you big advantage.
Thanks for your advice ASMI - much appreciated.
I understand the majority of your posted routine, except one thing:
Why must you include this line:
Also, as a side note - would this work?
; Lxplode by ASMI - modified slightly (and hopefully correctly) by Lee McDonnell
(defun c:lxplode2 (/ cSel eEnt cLay lEnt cDxf nDxf)
   (setq ss (ssget))
   (if    (/= (setq ssl (sslength ss)) nil)
       (setq index 0)
       (repeat ssl
       (setq eEnt (ssname ss index)
             cLay (cdr (assoc 8 (entget eEnt)))
             lEnt (entlast)
       ) ; end setq
       (if (and
           (not (equal lEnt (entlast)))
           ) ; end and
           (while (setq lEnt (entnext lEnt))
               (setq cDxf (entget lEnt)
                 nDxf (subst (cons 8 cLay) (assoc 8 cDxf) cDxf)
               ) ;_  end setq
               (entmod nDxf)
           ) ; end while
           ) ; end progn
       ) ; end if
       (setq index (1+ index))
       ) ;_  end repeat
   ) ;_  end progn
   (princ "\nNo Entities Selected!")
   ) ;_  end if
) ; end of c:lxplode2
Because if (equal lEnt(entlast)) last entity after explosion the same as before explosion, i.e. some reason explosion does not happen.
It seems ok. But ss1 and index variables need to make local.
Ahh yes, I forgot oops :oops:
I thought that entlast was the last entity "created" - so the last entity created may not necessarily be the entity that is going to be exploded...?
Ok, with variables localised:
(defun c:lxplode2 (/ ss ssl index eEnt cLay lEnt cDxf nDxf)
   (setq ss (ssget))
       (setq index 0)
       (repeat ssl
             lEnt (entlast)
       ) ; end setq
       (if (and
           ) ; end and
               ) ;_  end setq
               (entmod nDxf)
           ) ; end while
           ) ; end progn
       ) ; end if
       ) ;_  end repeat
   ) ;_  end progn
   ) ;_  end if
