ACSMan Posted March 15, 2010 Share Posted March 15, 2010 I'm having an issue when i zoom extend my drawing will not center! there is any area out in space that i cannot erase and when i zoom in on it it goes away. Please help Quote Link to comment Share on other sites More sharing options...
Fire_col Posted March 15, 2010 Share Posted March 15, 2010 Select all, Deselect what you want to keep, erase what's left, then try again. Quote Link to comment Share on other sites More sharing options...
nukecad Posted March 16, 2010 Share Posted March 16, 2010 To expand on Fire_col's answer You have 'empty' text, blocks, or similar out in space. to get rid of these 'empty' objects use- ERASE SELECT All Remove (select what you need to keep) ENTER That should get rid of all the 'empty' objects. Quote Link to comment Share on other sites More sharing options...
ChristinaSeay Posted March 22, 2010 Share Posted March 22, 2010 nukecad's suggestion should work. I've had this happen before when there were hidden blocks in my drawing. Not sure how that happens in the first place, but I've used that method to get rid of them several times. Quote Link to comment Share on other sites More sharing options...
MikeScott Posted March 22, 2010 Share Posted March 22, 2010 Your LIMITS might be set too high. (assuming that variable is still used in 2010?) A zoom extents shows the outermost edge of your drawing, and your limits is a part of that. Otherwise purge and audit to see if that fixes it. I had a block once that had an MTEXT box in it that was "empty" and it kept doing that to me until I exploded the block and purged it. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted July 4, 2011 Share Posted July 4, 2011 Select all, Deselect what you want to keep, erase what's left, then try again. Dear Fire_col Thanks. It helped me as well. Quote Link to comment Share on other sites More sharing options...
