dkkx3a Posted July 9, 2010 Posted July 9, 2010 Please help me make it by LISP, thanks. DCT_TP.dwg Quote
The Buzzard Posted July 10, 2010 Posted July 10, 2010 help me!!! Are you being attacked by a mugger? Shall I call the police? You know it would help on your part to do a little explaining. Are you trying to learn lisp or are you demanding it to fall in your lap. Although you say please, It seems you expect it written for you. You do not ask what it is you want to know. Folks volunteer their time here. Some effort on your part is not too much to ask for. Heres a great place to start: http://www.afralisp.net/index.php Here is one of my thread requests along the lines of what you want: http://www.cadtutor.net/forum/showthread.php?t=36793 Its a long thread so keep reading. Quote
The Buzzard Posted July 10, 2010 Posted July 10, 2010 Here is a code that makes a Left Swing Door block with an attribute. The Layers are created with Entmake, The Font Style is also created with Entmake and the Block is made by way of Entmake. This will give you an idea of what you need to do for your code. Can I write your code? Yes Will I write your code? No That you will have to do. If you ask questions about anything you do not understand, I will be happy to answer them. Note: You can refer to AutoCAD's Developer Help Section to look up the functions used here. Also check out the DXF Reference. You will find explainations for everything in this code. Part of the learning process is doing the research. Get working. (defun C:LD (/ INPT AFAP AFAP01 ASAP ASAP01 BNAM INPT EXDR ASTY AWID ASIZ TLNAM WID THK PT01 PT02 PT03 PT04 SANG EANG BRPT) (setq ASTY "Romans") (LD_FS ASTY) (setq AWID 1.0) (setq ASIZ 4.5) (setq TLNAM "A-DOOR-IDEN") (setq DLNAM "A-DOOR-FULL") (setq BNAM "LDR") (setq BRPT (list 0.0 0.0 0.0)) (setq EXDR (list 0.0 0.0 1.0)) (setq WID 36.0) (setq THK 2.0) (LD_ML TLNAM 2 "Continuous" 35) (LD_ML DLNAM 3 "Continuous" 50) (if (null (tblsearch "block" BNAM))(LD_BD)) (setq INPT (getpoint "\nGet insertion point:")) (setq AFAP (polar INPT (DTR 270.0) 11.25)) (setq AFAP01 (polar AFAP (DTR 0.0) 15.0)) (setq ASAP (polar INPT (DTR 270.0) 6.75)) (setq ASAP01 (polar ASAP (DTR 0.0)(/ WID 2.0))) (entmake (list (cons 0 "INSERT") (cons 67 0) (cons 410 "Model") (cons 8 DLNAM) (cons 66 1) (cons 2 BNAM) (cons 10 INPT) (cons 41 1) (cons 42 1) (cons 50 0) (cons 43 1) (cons 70 0) (cons 71 0) (cons 44 0) (cons 45 0) (cons 210 EXDR) (cons 62 256) (cons 39 0) (cons 6 "BYLAYER"))) (entmake (list (cons 0 "attrib") (cons 67 0) (cons 410 "Model") (cons 8 TLNAM) (cons 10 AFAP01) (cons 40 ASIZ) (cons 1 "D01") (cons 2 "ID") (cons 70 (cons 73 0) (cons 50 0.0) (cons 41 AWID) (cons 51 0.0) (cons 7 ASTY) (cons 71 0) (cons 72 1) (cons 11 ASAP01) (cons 210 EXDR) (cons 74 2))) (entmake (list (cons 0 "SEQEND") (cons 8 "0"))) (prompt "\nRotation Angle: ") (command "_.rotate" "last" "" INPT pause)) ;Degrees to Radians (defun DTR (a) (* pi (/ a 180.0))) ;Block Definition (defun LD_BD () (setq PT01 (polar BRPT (DTR 90.0) WID)) (setq PT02 (polar PT01 (DTR 0.0) THK)) (setq PT03 (polar PT02 (DTR 270.0) WID)) (setq PT04 (polar PT03 (DTR 180.0) THK)) (setq SANG 0.0) (setq EANG 1.5708) (setq AFAP (polar BRPT (DTR 270.0) 11.25)) (setq AFAP01 (polar AFAP (DTR 0.0) 15.0)) (setq ASAP (polar BRPT (DTR 270.0) 6.75)) (setq ASAP01 (polar ASAP (DTR 0.0)(/ WID 2.0))) (entmake (list (cons 0 "block") (cons 2 BNAM) (cons 10 BRPT) (cons 70 2))) (entmake (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 67 0) (cons 410 "Model") (cons 8 "0") (cons 100 "AcDbPolyline") (cons 90 4) (cons 70 1) (cons 43 0.0) (cons 38 0.0) (cons 39 0.0) (cons 10 PT01) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 PT02) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 PT03) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 PT04) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 210 EXDR))) (entmake (list (cons 0 "arc") (cons 100 "AcDbEntity") (cons 67 0) (cons 410 "Model") (cons 8 "0") (cons 100 "AcDbCircle") (cons 10 BRPT) (cons 39 0.0) (cons 40 WID) (cons 210 EXDR) (cons 100 "AcDbArc") (cons 50 SANG) (cons 51 EANG))) (entmake (list (cons 0 "attdef") (cons 67 0) (cons 410 "Model") (cons 8 TLNAM) (cons 10 AFAP01) (cons 40 ASIZ) (cons 1 "D01") (cons 3 "Door ID:") (cons 2 "ID") (cons 70 (cons 73 0) (cons 50 0.0) (cons 41 AWID) (cons 51 0.0) (cons 7 ASTY) (cons 71 0) (cons 72 1) (cons 11 ASAP01) (cons 210 EXDR) (cons 74 2))) (entmake (list (cons 0 "endblk") (cons 8 "0")))) ;Make Layer (defun LD_ML (LNAM LCLR LTYP LWGT) (if (null (tblsearch "layer" LNAM)) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 LNAM) (cons 70 0) (cons 62 LCLR) (cons 6 LTYP) (cons 290 1) (cons 370 LWGT)))) (princ)) ;Font Style (defun LD_FS (ASTY) (setq FSTY ASTY TWF 1.0 TOA 0.0 PFN "romans.shx" BFN "") (if (null (tblsearch "style" FSTY)) (entmake (list (cons 0 "STYLE") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbTextStyleTableRecord") (cons 2 FSTY) (cons 70 0) (cons 40 0) (cons 41 TWF) (cons 50 TOA) (cons 3 PFN) (cons 4 BFN)))) (princ)) Quote
fixo Posted July 10, 2010 Posted July 10, 2010 Please help me make it by LISP, thanks. You can start from the simplest way: (defun C:MBL (/ clr col sset) (command "._zoom" "_w" "-1.0,-1.0" "5,3");<-- zoom to desired limits (optional) (setq clr (getvar "CLAYER"));<--store current layer (setq col (getvar "CECOLOR"));<--store current layer color (setvar "CMDECHO" 0); <-- turn command echo off (setvar "CLAYER" "0");<--set current layer "0" (setvar "CECOLOR" "BYLAYER");<-- set color to bylayer (setq sset (ssadd));<-- create empty selection set (command "._line" "_non" "0,0" "_non" "1.8182,0" "") (ssadd (entlast) sset);<--append newly created entity to selection set (command "._pline" "_non" "1.2121,0" "_w" "0" ".2424" "_non" "1.2121,0.7576" "_w" "0" "0" "_non" "1.2121,1.3636" "_non" "4.1818,1.3636" "") (ssadd (entlast) sset);<--append newly created entity to selection set (command "._-attdef" "_p" "" "LEVEL" "Level" "0.00" "_s" "DN_DCT" "_j" "BL" "1.2121,1.3636" "1.0" "0") (ssadd (entlast) sset);<--append newly created entity to selection set (command "._-block" "myBlockName" "_non" "0,0" sset "");<-- change block name here (command "._erase" sset "") (setvar "CMDECHO" 1); <-- turn command echo on (setvar "CLAYER" clr);<--restore current layer (setvar "CECOLOR" col);<--restore current layer color (princ) ) (princ "\n >> Type MBL to cteate block <<") (prin1) ~'J'~ Quote
The Buzzard Posted July 10, 2010 Posted July 10, 2010 Ok, I decided to write it. Try this. I had to fix a flag issue, But it is now fixed. Any changes to these lisps will require you to ask questions. BLK123.lsp This lisp has no prompt for attribute value. (defun C:BLK123 (/ BNAM BLKLNAM BRPT DSF INPT ) (FS_123 "DN_DCT") (setq BLKLNAM "CTnhut") (ML_123 BLKLNAM 7 "Continuous") (setq BNAM "123") (setq BRPT (list 0.0 0.0 0.0)) (or D::SF (setq D::SF 1)) (if (null (tblsearch "block" BNAM))(BD_123)) (setq D::SF (cond ((getint (strcat "\nSpecify block scale factor <"(itoa D::SF)">: ")))(T D::SF))) (setq DSF D::SF) (setq INPT (getpoint "\nInsertion point:")) (command "._-layer" "_S" BLKLNAM "") (command "._-insert" BNAM INPT DSF DSF pause) (princ)) (princ "\nType BLK123 to start.") ;Block Definition (defun BD_123 () (entmake (list (cons 0 "block") (cons 2 BNAM) (cons 10 BRPT) (cons 70 2))) (entmake (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 67 0) (cons 410 "Model") (cons 8 "0") (cons 62 7) (cons 100 "AcDbPolyline") (cons 90 6) (cons 70 0) (cons 38 0.0) (cons 39 0.0) (cons 10 (list 0.0 0.0)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 (list 1.81818 0.0)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 (list 1.21212 0.0)) (cons 40 0.0) (cons 41 0.242424) (cons 42 0.0) (cons 10 (list 1.21212 0.757576)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 (list 1.21212 1.36364)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 (list 4.18182 1.36364)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 210 (list 0.0 0.0 1.0)))) (entmake (list (cons 0 "ATTDEF") (cons 100 "AcDbEntity") (cons 67 0) (cons 410 "Model") (cons 8 BLKLNAM) (cons 100 "AcDbText") (cons 10 (list 1.21212 1.61364 0.0)) (cons 40 1.0) (cons 1 "0.00") (cons 50 0.0) (cons 41 1.0) (cons 51 0.0) (cons 7 "DN_DCT") (cons 71 0) (cons 72 0) (cons 11 (list 0.0 0.0 0.0)) (cons 210 (list 0.0 0.0 1.0)) (cons 100 "AcDbAttributeDefinition") (cons 3 "Value:") (cons 2 "VALUE") (cons 70 (cons 73 0) (cons 74 0))) (entmake (list (cons 0 "endblk") (cons 8 "0")))) ;Make Layer (defun ML_123 (LNAM LCLR LTYP) (if (null (tblsearch "layer" LNAM)) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 LNAM) (cons 70 0) (cons 62 LCLR) (cons 6 LTYP) (cons 290 1)))) (princ)) ;Font Style (defun FS_123 (ASTY) (setq FSTY ASTY TWF 1.0 TOA 0.0 PFN "VNI-Helve-Condense.shx" BFN "") (if (null (tblsearch "style" FSTY)) (entmake (list (cons 0 "STYLE") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbTextStyleTableRecord") (cons 2 FSTY) (cons 70 0) (cons 40 0) (cons 41 TWF) (cons 50 TOA) (cons 3 PFN) (cons 4 BFN)))) (princ)) BLK123-2.lsp This lisp prompts for attribute value. (defun C:BLK123-2 (/ BNAM BLKLNAM BRPT DSF INPT ) (FS_123 "DN_DCT") (setq BLKLNAM "CTnhut") (ML_123 BLKLNAM 7 "Continuous") (setq BNAM "123") (setq BRPT (list 0.0 0.0 0.0)) (or D::SF (setq D::SF 1)) (if (null (tblsearch "block" BNAM))(BD_123)) (setq D::SF (cond ((getint (strcat "\nSpecify block scale factor <"(itoa D::SF)">: ")))(T D::SF))) (setq DSF D::SF) (setq INPT (getpoint "\nInsertion point:")) (command "._-layer" "_S" BLKLNAM "") (command "._-insert" BNAM INPT DSF DSF pause pause) (princ)) (princ "\nType BLK123-2 to start.") ;Block Definition (defun BD_123 () (entmake (list (cons 0 "block") (cons 2 BNAM) (cons 10 BRPT) (cons 70 2))) (entmake (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 67 0) (cons 410 "Model") (cons 8 "0") (cons 62 7) (cons 100 "AcDbPolyline") (cons 90 6) (cons 70 0) (cons 38 0.0) (cons 39 0.0) (cons 10 (list 0.0 0.0)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 (list 1.81818 0.0)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 (list 1.21212 0.0)) (cons 40 0.0) (cons 41 0.242424) (cons 42 0.0) (cons 10 (list 1.21212 0.757576)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 (list 1.21212 1.36364)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 10 (list 4.18182 1.36364)) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 210 (list 0.0 0.0 1.0)))) (entmake (list (cons 0 "ATTDEF") (cons 100 "AcDbEntity") (cons 67 0) (cons 410 "Model") (cons 8 BLKLNAM) (cons 100 "AcDbText") (cons 10 (list 1.21212 1.61364 0.0)) (cons 40 1.0) (cons 1 "0.00") (cons 50 0.0) (cons 41 1.0) (cons 51 0.0) (cons 7 "DN_DCT") (cons 71 0) (cons 72 0) (cons 11 (list 0.0 0.0 0.0)) (cons 210 (list 0.0 0.0 1.0)) (cons 100 "AcDbAttributeDefinition") (cons 3 "Value:") (cons 2 "VALUE") (cons 70 4) (cons 73 0) (cons 74 0))) (entmake (list (cons 0 "endblk") (cons 8 "0")))) ;Make Layer (defun ML_123 (LNAM LCLR LTYP) (if (null (tblsearch "layer" LNAM)) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 LNAM) (cons 70 0) (cons 62 LCLR) (cons 6 LTYP) (cons 290 1)))) (princ)) ;Font Style (defun FS_123 (ASTY) (setq FSTY ASTY TWF 1.0 TOA 0.0 PFN "VNI-Helve-Condense.shx" BFN "") (if (null (tblsearch "style" FSTY)) (entmake (list (cons 0 "STYLE") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbTextStyleTableRecord") (cons 2 FSTY) (cons 70 0) (cons 40 0) (cons 41 TWF) (cons 50 TOA) (cons 3 PFN) (cons 4 BFN)))) (princ)) Quote
The Buzzard Posted July 12, 2010 Posted July 12, 2010 Very very OKKKK, Thanks for help !! Which lisp are you refering to? Quote
