fathihvac Posted December 8, 2011 Share Posted December 8, 2011 HELLO, I have posted this in theswamp.org I am looking for a code that allow me to browse for an existing excel file and create a new worksheet and give it a predetermined name to put some data generated by a calculating autolisp program. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 8, 2011 Share Posted December 8, 2011 Use getfiled with the 'flags' argument set to 1 to allow the user to browse for a new file to be created. Quote Link to comment Share on other sites More sharing options...
fixo Posted December 8, 2011 Share Posted December 8, 2011 Give that a try For the test select some blocks on screen (vl-load-com) (defun C:XLDEMO (/ *error* colm defName ExcelApp exc_data fcol fdata filepath ftype ins_point ins_record Lngcount newName pfset row Sheets Sht ShtNames Wbk x xlCell xlCells XlLastsheet xlNewSheet) (defun *error* (msg) (if (vl-position msg '("console break" "Function cancelled" "quit / exit abort" ) ) (princ msg) (princ "Error!") ) (vl-catch-all-apply 'vlax-invoke-method (list ExcelApp "Quit") ) (mapcar (function (lambda (x)(vl-catch-all-apply(function (lambda() (if (not (vlax-object-released-p x)) (progn (vlax-release-object x) (setq x nil)) ) ) ) ) ) ) (list xlCells Sht Sheets Wbk ExcelApp) ) (gc) (gc) (princ) ) (setq pfset(vla-get-pickfirstselectionset (vla-get-activedocument (vlax-get-acad-object)))) (vla-clear pfset) (setq ftype (list 0 410) fdata (list "insert" (getvar 'ctab))) (setq ftype (vlax-safearray-fill (vlax-make-safearray vlax-vbinteger (cons 0 (1- (length ftype)))) ftype) fdata (vlax-safearray-fill (vlax-make-safearray vlax-vbvariant (cons 0 (1- (length fdata)))) fdata) ) ;;select all: ;;(vla-select pfset acselectionsetall nil nil ftype fdata) ;;or select on screen (prompt "\nSelect blocks that you want to write in Excel") (vla-selectonscreen pfset ftype fdata) (if (> (vla-get-count pfset) 0) (progn (vlax-for block_obj pfset (setq ins_point (vlax-get block_obj 'insertionpoint) ins_record (list (cons "BlockName" (vla-get-effectivename block_obj)) (cons "Position X" (car ins_point)) (cons "Position Y" (cadr ins_point)) (cons "Position Z" (caddr ins_point)) ) ) (setq exc_data (cons ins_record exc_data)) ) ;; Eof acad part ;; (setq newName "PutYourNameHere") ;<-- change a sheet name here (setq filepath (getfiled "Data File" (getvar "dwgprefix") "xls;xlsx" 2)) (setq ExcelApp (vl-catch-all-apply (function (lambda () (vlax-get-or-create-object "Excel.Application"))))) (vlax-put-property ExcelApp 'visible :vlax-true) (vlax-put-property ExcelApp 'ScreenUpdating :vlax-true) (vlax-put-property ExcelApp 'DisplayAlerts :vlax-true) (setq Wbk (vl-catch-all-apply 'vla-open (list (vlax-get-property ExcelApp 'workbooks) filepath))) (setq Sheets (vl-catch-all-apply 'vlax-get-property (list Wbk 'sheets))) (vlax-for itemSheet Sheets (setq shtNames (cons (vlax-get itemSheet 'name) shtNames))) ;; check if sheet already exist (if (vl-position newName shtNames) (progn (alert (strcat "Sheet named " (vl-prin1-to-string newName) " already exist.\nExiting program")) (exit) ) ) (setq lngCount (vl-catch-all-apply 'vlax-get-property (list Sheets 'count))) (setq xlLastSheet (vl-catch-all-apply 'vlax-get-property (list Sheets 'item lngCount))) ;;add new sheet (vl-catch-all-apply 'vlax-invoke-method (list Sheets 'Add nil nil nil)) (setq defName (vlax-get (vlax-get ExcelApp 'activesheet) 'name)) (setq xlNewSheet (vl-catch-all-apply 'vlax-get-property (list Sheets 'Item defName))) (vl-cmdf "delay" 300) ;optional delay 0.3 sec (vlax-invoke xlNewSheet 'move nil xlLastSheet) (vlax-put-property xlNewSheet 'name newName) (vlax-invoke xlNewSheet 'activate) ;; refresh XL screen (setq Wbk (vl-catch-all-apply (function (lambda () (vlax-get-property ExcelApp 'ActiveWorkBook))))) (setq Sht (vl-catch-all-apply (function (lambda () (vlax-get-property ExcelApp 'ActiveSheet))))) (setq xlCells (vl-catch-all-apply (function (lambda () (vlax-get-property Sht 'cells))))) ;;write the headers (setq row 1 colm 1 ) (foreach header (list "Block Name" "X" "Y" "Z") (setq xlCell (variant-value (vlax-get-property xlCells 'item row colm))) (vlax-put-property xlCell 'value2 (vlax-make-variant header ) (setq colm (1+ colm)) ) ;;write the rest data (setq row 1) (foreach line exc_data (setq row (1+ row)) (setq colm 1) (foreach single line (setq xlCell (variant-value (vlax-get-property xlCells 'item row colm))) (vlax-put-property xlCell 'value2 (vlax-make-variant (cdr single))) (setq colm (1+ colm)) ) ) ;; add some format (setq frow (vlax-get-property Sht 'Range "A1:A4")) (vlax-put-property frow 'NumberFormat "@") (setq fcol (vlax-get-property Sht 'Range "A:A")) (vlax-put-property fcol 'NumberFormat "@") (setq fcol (vlax-get-property Sht 'Range "B:D")) (vlax-put-property fcol 'NumberFormat "#0.000") (vlax-invoke (vlax-get-property Sht 'Columns) 'AutoFit) (vlax-put-property ExcelApp 'ScreenUpdating :vlax-true) (vl-catch-all-apply 'vlax-invoke-method (list Wbk 'Save)) (vl-catch-all-apply 'vlax-invoke-method (list Wbk 'Close)) ) ) (*error* nil) (princ) ) (prompt "\n >> Start command with XLDEMO <<") (prin1) Quote Link to comment Share on other sites More sharing options...
stevesfr Posted December 8, 2011 Share Posted December 8, 2011 fixo... using Acad2008, can't get xldemo to work....? HELP... what doing wrong ?? using Office 2000... Quote Link to comment Share on other sites More sharing options...
fixo Posted December 8, 2011 Share Posted December 8, 2011 Hiya, Steve, Perhaps you need to change on thisthis line (setq filepath (getfiled "Data File" (getvar "dwgprefix") "xls" 2)) in Office 2000 just "xls" extension I think You could be also add (C:XLDEMO) at the very end of code and the run lisp from console, after the error will be ooccurs go to menu Debug-->Last error source, the problem line will be highlighted Quote Link to comment Share on other sites More sharing options...
stevesfr Posted December 8, 2011 Share Posted December 8, 2011 Hiya, Steve,Perhaps you need to change on thisthis line (setq filepath (getfiled "Data File" (getvar "dwgprefix") "xls" 2)) in Office 2000 just "xls" extension I think You could be also add (C:XLDEMO) at the very end of code and the run lisp from console, after the error will be ooccurs go to menu Debug-->Last error source, the problem line will be highlighted when I pick a block in the drawing, following message occurs at command line: Command: xldemo Select blocks that you want to write in Excel Select objects: 0 found Select objects: debug is no help, because no definite error message is available yet. Steve TIA Quote Link to comment Share on other sites More sharing options...
fixo Posted December 8, 2011 Share Posted December 8, 2011 My bad, You have to select blocks then press Enter as usual Quote Link to comment Share on other sites More sharing options...
stevesfr Posted December 8, 2011 Share Posted December 8, 2011 My bad, You have to select blocks then press Enter as usual nada program does not recognize block that is picked on screen, says Command: XLDEMO Select blocks that you want to write in Excel Select objects: 0 found Quote Link to comment Share on other sites More sharing options...
